GIGABYTE TRX40 DESIGNARE (RÉV. 1.1) / AMD Ryzen Threadripper 3960 X
Arrakis
@mbarbierato
it's identical and the status of the ports in the system preferences is inactive (red dot).
Prevents the hack from shutting down.
AppleIGB5.7.2.txt.zip
10 hours ago, Lorys89 said:
not use kext igb, not use ssdt i210 or patch dp.
add this kext and set min kernel 22.0.0
add bootarg :  e1000=0
reboot and send ioreg log
It's the same.
Intel 210 with Bootarg.zip
  • 3 months later...
On 2/14/2023 at 10:56 PM, Lorys89 said:
try this ssdt without kext igb or bootarg (e1000=0) and send ioreg log
SSDT-I210.aml.zip 853 B · 2 downloads
Hello,
Sorry to answer later in relation to your request but I had a lot of productions so I forbid myself to do tests during this period.
Here is the requested Ioreg.IOREG Arrakis.zip
The injection of the aml file makes the system unstable and kernel panics in series as soon as the activation of the ethernet port I210 seeks the connection….
