GIGABYTE TRX40 DESIGNARE (RÉV. 1.1) / AMD Ryzen Threadripper 3960 X
Arrakis
@Lorys89 @fabiosun
1-I plugged in the cable, turn off, start.
- Result: same
I have never disabled Lan ports in the bios even when they weren't supported since Big Sur 11.4.
2 - I tried the experiment (with the ethernet cable still connected):
- Disable Lan ports in bios, startup, shutdown.
    Result: same (logic)
- Activation of Lan ports in the bios, startup.
    Result: same
@Arrakis would say the problem now is only on i210, can we bother you for the next tests and logs?
For users : If you have the i211 works, if you have 2 i211 you have to connect lan cable only to one, and it works.
Edited by Lorys89
1 hour ago, Lorys89 said:
try to spoof i211, send pciroot lan
In the 2 pciroot of the lan, in config in the DP section, you have to add
device-id
39150000
DATA
And reboots with kext igb active.
Tell me if this is what you want me to inject into the DP section?.
I am a novice... Feel free to correct, thanks in advance.
Note: this is the correct PCI address
I211 Arrrakis.plist.zip
Edited by Arrakis
before try this ssdt witk kext igb active
SSDT-I210.aml.zip
Edited by Lorys89
