FakeSMC3_with_plugins
Driver for emulation SMC device with hardware sensors support
IntelCPUMonitor supporta tutte le nuove CPU Intel: CometLake, IceLake e altre.
RadeonMonitor può monitorare la temperatura della GPU per RX570, Vega e RX5600 / 5700.
SMIMonitor può monitorare temperature e VENTOLE sui laptop Dell.
VoodooBatterySMC può monitorare le batterie sulla maggior parte dei laptop. Supporta la configurazione multibatteria ed è in grado di vedere l'amperaggio a carichi pesanti di laptop.
L'applicazione aggiornata HWMonitorSMC è compatibile con BigSur
 Annuncio --> https://www.insanelymac.com/forum/topic/299861-hwsensors3/?do=findComment&comment=2746073
 Sito ufficiale --> https://github.com/CloverHackyColor/FakeSMC3_with_plugins
 Download --> https://github.com/CloverHackyColor/FakeSMC3_with_plugins/releases/tag/242
HWSensors
This is a Mac OS X Package
Working 10.6 to 10.15 - 11
HWSensors branch based on FakeSMC-3.x
The package includes:
  • FakeSMC.kext version 3.x
  • ACPIMonitor.kext for custom making ACPI methods to access to hardware
  • VoodooBatterySMC for laptop battery monitoring
  • CPU sensors:
    • IntelCPUMonitor
    • AmdCpuMonitor
  • GPUSensors
    • RadeonMonitor for ATI/AMD Radeon card (temperature only)
    • GeforceSensors for Nvidia card Fermi, Kepler, Maxwell, Pascal
    • NVClockX for Nvidia Geforce 7xxx, 8xxx, Tesla
    • X3100 for IntelX3100 (at GM950 chipset)
  • LPC chip sensors, motherboard parameters like FAM, Voltages, temperatures
    • ITEIT87x for chips ITE 87xx, 86xx, usually present on Gigabyte motherboards
    • W836x for chips Winbond/Nuvoton 83xxx, NCT67xx, usually present on ASUS motherboards
    • F718x for chips Fintek
    • PC8739x for chip SMC
  • SMI Monitor
    • monitor and control temperature and fans in Dell computers by using SMM technology
  • Applications
    • HWMonitorSMC for old computers
    • HWMonitorSMC2 for SandyBridge and up
HWSensors Project (c) 2010 netkas, slice, usr-sse2, kozlek, navi, vector sigma and other contributors. All rights reserved.
  • 2 months later...
Release 243
Include support for TigerLake CPU.
Introduced new plugin IntelMCHMonitor for chipsets 7th generation (Kabylake and up). It can monitor chipset and DIMM temperatures.
IntelCPUMonitor
- aggiunte le CPU IceLake e TigerLake
RadeonMonitor
--aggiunto monitoraggio della temperatura delle schede RX5500-5900
Aggiunto nuovo plugin IntelMCHMonitor
fonte: https://www.insanelymac.com/forum/topic/299861-hwsensors3/?do=findComment&comment=2751240
IntelMCHMonitor per FakeSMC_3
È in grado di monitorare la temperatura del chipset, come Northbridge, e le temperature DIMM, DIMM0, DIMM1, DIMM2, DIMM3.
La funzionalità che si trova nei chipset di settima generazione e superiori (CoffeeLake e ...?).
Sarà utile per i notebook in cui non abbiamo SuperIO come ITE o Nuvoton e nessun altro modo per monitorare questi parametri.
Il kext non funziona sul mio Skylake (Slice) quindi ho bisogno dei tuoi test.
Il kext è inteso per FakeSMC 3.5.3 e non funzionerà con FakeSMC 6.xo con VirtualSMC.
Questo FakeSMC con plugin funziona in BigSur. Assicurati solo di non aver installato plugin per hardware non intenzionale.
Se capita di avere questo avviso nell'uso di FakeSMC
1170356048_Schermata2021-03-03alle09_50_25.thumb.png.fa4014f91151a1fb44caaff2165e1b9b.png
è dovuto a una delle chiavi che inietta, MSSD che memorizza lo stato di arresto
Possibile soluzione, editare  info.plist ed eliminare/disabilitare quella chiave.
Soluzione applicata, testata e funzionante, ecco Fake già modificato  FakeSMC-BS.kext.zip
Fonte IM
