Comparativa Apple Silicon M1 vs i5 Hack vs i9 Hack
philarticolo31
  • Supervisor.
Questo non era compilato per ARM. Non so se le librerie MPI sono disponibili su Apple Silicon. In caso, qualcun altro si trovasse un M1 per mano, magari faccia un cenno che si può sempre fare una prova.
Execution time: 92.7589 s
14.7006 ± 4.55493
{0, 38, 30, 23, 25, 18, 26, 8, 16, 45, 41, 44, 24, 31, 3, 13, 35, 6, 49, 5, 12, 9, 29, 42, 7, 43, 39, 17, 48, 33, 19, 40, 36, 21, 37, 2, 20, 27, 46, 14, 15, 28, 10, 47, 22, 1, 4, 32, 11, 34};
Noooooo
Execution time: 92.7705 s
fabio@fabios-iMac-Pro ~ %
14.7566 ± 4.60736
Noooooo
Execution time: 81.7697 s
Felice 😉
Edited by tomnic
Completare il risultato
25 minuti fa, fabiosun ha scritto:
@philarticolo31
stai usando quello multicore postato poco fa da @foskvs?
Ho usato quello postato all'inizio del thread con l'opzione
mpirun --use-hwthread-cpus ~/Downloads/T_S_P
Questo invece il risultato con
1 ora fa, foskvs ha scritto:
Noooooo
Execution time: 107.79 s
@foskvs
Last login: Tue Dec  1 08:19:25 on console
fabio@fabios-iMac-Pro ~ % mpirun -np 32 ~/Downloads/T_S_P
There are not enough slots available in the system to satisfy the 32
slots that were requested by the application:
  /Users/fabio/Downloads/T_S_P
Either request fewer slots for your application, or make more slots
available for use.
A "slot" is the Open MPI term for an allocatable unit where we can
launch a process.  The number of slots available are defined by the
environment in which Open MPI processes are run:
  1. Hostfile, via "slots=N" clauses (N defaults to number of
     processor cores if not provided)
  2. The --host command line parameter, via a ":N" suffix on the
     hostname (N defaults to 1 if not provided)
  3. Resource manager (e.g., SLURM, PBS/Torque, LSF, etc.)
  4. If none of a hostfile, the --host command line parameter, or an
     RM is present, Open MPI defaults to the number of processor cores
In all the above cases, if you want Open MPI to default to the number
of hardware threads instead of the number of processor cores, use the
--use-hwthread-cpus option.
Alternatively, you can use the --oversubscribe option to ignore the
number of available slots when deciding the number of processes to
launch.
fabio@fabios-iMac-Pro ~ % mpirun -np 31 ~/Downloads/T_S_P
There are not enough slots available in the system to satisfy the 31
available for use.
launch.
fabio@fabios-iMac-Pro ~ % mpirun -np 16 ~/Downloads/T_S_P
Thread 0 of 16
Thread 12 of 16
Thread 9 of 16
Thread 15 of 16
Thread 11 of 16
Thread 3 of 16
Thread 4 of 16
Thread 10 of 16
Thread 8 of 16
Thread 13 of 16
Thread 2 of 16
Thread 5 of 16
Thread 1 of 16
Thread 7 of 16
Thread 14 of 16
Thread 6 of 16
0
9
8
12
11
7
3
14
4
1
10
15
6
13
2
5
0 sends to 0
0 receives from 0
10 sends to 10
10 receives from 10
12 sends to 6
12 receives from 3
3 sends to 12
3 receives from 6
0	35.3832
0	34.2127
0	33.8975
0	33.107
0	32.8322
0	31.6298
0	36.1954
0	34.554
0	34.3635
0	34.3039
0	33.5971
0	32.8893
0	32.709
0	32.675
0	32.0406
42.8956 ± 5.81686
43.0229 ± 5.49462
0	36.5877
0	35.8632
0	35.4536
0	35.0276
0	34.8191
0	34.5762
43.7178 ± 4.70171
8 sends to 4
8 receives from 2
4 sends to 11
4 receives from 8
1	31.5512
1	29.7976
1	29.5557
1	31.2245
1	31.0845
1	30.9371
1	30.1108
1	29.9087
38.83 ± 5.30382
39.1154 ± 5.28394
1	34.3944
1	34.1293
1	34.0681
1	32.3801
1	31.8665
41.124 ± 4.33549
0	38.458
0	36.5612
0	35.7884
0	35.4058
0	34.2802
0	32.0212
44.7163 ± 4.74308
2	28.8751
2	28.7516
2	28.6505
2	28.348
2	29.6773
2	29.1667
2	27.4296
2	28.0528
2	26.7424
35.7191 ± 4.71162
36.444 ± 4.88252
2	31.7763
2	31.3081
2	30.9942
2	30.6334
2	29.9501
38.5637 ± 4.35925
1	31.949
1	31.5932
1	30.8514
1	29.9907
40.6139 ± 5.35737
3	24.8929
3	27.9613
3	27.6643
3	27.4672
3	27.2728
3	27.172
3	27.0046
3	26.6099
32.9072 ± 4.61172
34.0044 ± 4.4549
3	29.6515
3	29.1956
3	29.082
3	28.8114
3	28.631
3	26.3175
36.3288 ± 4.49597
2	29.6575
2	29.3509
2	28.541
2	28.3393
2	28.2078
2	28.1663
2	27.7959
36.2853 ± 5.21333
4	26.4587
4	26.2233
4	26.2062
4	26.1813
4	25.8173
4	24.8282
4	24.4434
4	25.3348
4	24.1149
4	23.9358
31.9669 ± 4.17858
4	23.8264
30.664 ± 4.38884
4	26.1084
4	26.0998
4	25.826
4	25.7665
4	25.6482
33.5828 ± 4.73049
3	27.5855
3	27.3307
3	26.8523
3	25.5937
33.7369 ± 4.59052
5	24.9887
5	24.7709
5	23.7054
5	24.6526
5	23.5439
5	23.2678
5	24.1588
5	23.1993
5	22.894
30.3993 ± 4.05407
29.1267 ± 4.10076
5	24.9167
5	24.5688
31.7054 ± 4.55736
4	25.2672
4	24.8572
4	24.7639
4	24.6352
4	24.6115
4	24.5622
32.0075 ± 4.2443
6	24.1286
6	24.1113
6	24.0435
6	23.7308
6	23.5037
6	22.642
6	22.3535
6	22.261
6	23.2061
29.3437 ± 4.06138
6	22.1614
27.9749 ± 4.07204
6	24.391
6	24.3568
6	24.3532
6	23.8251
30.104 ± 4.37627
5	24.1035
5	23.8711
5	23.6101
5	23.3973
30.3635 ± 4.22024
7	22.0251
7	22.3963
7	21.9081
7	21.862
7	21.5284
7	21.5029
27.0201 ± 4.08046
28.3571 ± 3.91689
7	23.6472
7	23.4206
7	23.3031
7	22.952
28.9378 ± 4.28007
6	23.302
6	23.1409
6	23.1385
6	22.9386
6	22.8533
6	22.8343
6	22.7397
6	22.7391
6	22.7347
6	22.6143
6	22.3031
28.7635 ± 4.29562
8	22.1901
8	21.3468
8	21.1582
8	21.9677
8	20.8723
8	21.8481
8	21.6093
27.2463 ± 3.96888
26.1599 ± 4.09794
8	22.6651
8	22.584
8	22.502
8	22.1975
8	22.1522
27.8445 ± 4.32511
7	22.0467
7	21.8549
7	21.7773
7	21.5124
27.3375 ± 4.26879
9	21.5988
9	21.5344
9	21.4061
9	21.2856
9	21.0601
9	20.4861
9	20.4116
9	20.3888
26.6511 ± 4.01551
25.3849 ± 4.06019
11
8
9
3
2
4
12
6
7
5
0
15
1
10
13
14
0 sends to 11
0 receives from 10
10 sends to 0
10 receives from 13
9	21.7842
9	21.7472
9	21.6219
9	20.9547
26.8546 ± 4.25367
12 sends to 1
12 receives from 6
8	21.4198
8	21.3222
8	21.0863
8	20.9386
8	20.7617
8	20.7136
26.2086 ± 4.2439
15 sends to 5
15 receives from 11
9 sends to 1
9 receives from 1
13 sends to 13
13 receives from 13
11 sends to 15
11 receives from 4
7 sends to 14
7 receives from 5
9	20.4918
9	20.4629
9	20.2654
9	20.087
5 sends to 7
5 receives from 15
25.2534 ± 4.1628
4 sends to 2
4 receives from 5
11	20.2551
11	20.2449
25.6654 ± 3.98109
14 sends to 2
14 receives from 7
2 sends to 8
2 receives from 14
6 sends to 3
6 receives from 12
1 sends to 9
1 receives from 9
0	39.4269
0	38.2033
0	34.8676
0	33.7103
0	33.0075
0	38.6501
0	36.635
0	36.4536
0	35.9411
0	35.6092
0	35.6008
0	35.5681
0	36.33
0	35.9165
0	35.5639
0	34.7353
0	35.1827
0	34.6482
0	34.963
0	34.5997
0	32.8165
0	33.4755
43.0893 ± 5.17976
0	33.4428
0	33.4352
0	33.1421
43.3733 ± 4.94315
43.1291 ± 5.09893
12	19.7989
12	19.3232
25.0506 ± 4.05389
0	38.6034
0	35.9262
0	35.8691
0	35.6842
0	35.0985
0	32.7196
0	39.6605
0	37.8222
0	37.282
0	35.7001
0	32.472
0	34.9832
0	34.5004
0	32.2924
0	34.1844
0	34.0106
42.8948 ± 5.24487
44.2368 ± 4.8497
0	39.389
0	37.819
0	37.3865
0	35.7676
0	36.7731
0	36.381
0	36.0923
0	35.0674
0	33.4539
0	32.6027
0	35.5443
0	35.3784
0	35.1086
0	32.3289
0	34.2854
44.8168 ± 4.44664
43.6248 ± 5.16789
0	34.2242
0	33.8841
0	32.6072
0	31.2194
0	31.1818
0	30.4807
0	29.823
0	37.6059
0	33.3575
0	32.6362
0	32.5055
42.2229 ± 5.5437
0	32.2297
0	31.7307
0	37.5144
0	36.0055
0	35.9778
0	35.7256
0	35.5824
0	33.719
0	33.621
0	32.6456
0	32.608
0	32.3037
0	31.705
0	34.36
0	33.9905
0	33.7192
0	33.5427
0	33.5316
0	37.9565
0	36.3633
0	35.9061
0	35.8438
0	33.3765
0	34.2355
0	33.5722
0	33.3657
0	32.0804
0	33.312
0	32.7109
0	32.032
0	32.6312
0	31.8056
43.5388 ± 5.451
0	31.7486
43.5655 ± 5.42637
44.2157 ± 5.06881
44.2924 ± 4.74084
13	19.1838
13	19.1322
13	19.047
13	18.9297
24.1215 ± 4.15116
1	31.3889
1	31.2788
1	30.8259
1	30.5334
1	33.889
1	33.6583
1	33.4455
1	32.2535
1	30.2999
1	32.1437
39.7357 ± 5.24731
1	32.0204
1	31.6863
41.4365 ± 4.85565
1	32.5503
1	32.2874
1	32.2555
1	32.1495
1	32.0533
1	31.759
1	31.6572
1	30.7581
1	30.0587
1	32.8605
1	32.5487
1	32.1515
1	31.9503
1	31.5293
1	31.4212
1	30.9844
1	30.2873
39.4764 ± 4.9091
1	30.2048
1	30.7014
40.2107 ± 4.83234
40.0838 ± 5.1029
1	32.7562
1	31.8369
1	31.1902
1	30.5446
1	29.93
1	32.49
41.7485 ± 4.67146
39.8531 ± 5.02288
1	29.6219
1	29.6012
1	29.3445
1	29.2044
14	18.6829
14	18.5837
1	29.1034
14	18.5353
1	28.7159
14	18.4964
14	18.3127
1	28.5753
1	31.0775
1	30.36
23.3158 ± 4.14518
38.4721 ± 5.41337
1	28.9316
40.009 ± 5.53135
1	31.1217
1	31.4125
1	31.0706
1	30.739
1	31.049
1	30.7346
1	32.4185
1	30.4049
1	30.9188
1	32.3247
1	32.0792
1	30.6638
1	30.1984
1	31.8743
2	30.278
2	29.6246
2	29.3965
2	28.9547
2	28.9084
1	31.7913
2	28.7022
1	29.2737
1	31.7854
1	31.5665
1	30.1005
2	31.2401
2	30.7898
1	31.31
2	30.5033
2	29.7722
2	29.7233
40.2464 ± 5.12342
40.0828 ± 5.23758
2	29.21
36.7966 ± 4.90378
41.0162 ± 4.82358
38.6225 ± 4.92141
2	29.7092
2	29.4351
2	29.1034
2	28.9352
2	28.2719
2	30.0656
2	30.3505
2	30.0347
2	30.2573
2	30.222
2	30.0832
2	29.6553
2	29.913
2	29.8979
2	29.7788
36.5346 ± 4.51444
2	28.8852
2	29.4845
2	28.2419
2	28.3891
2	28.3503
37.2766 ± 5.00615
37.4778 ± 4.59079
15	18.0365
15	18.0265
15	17.5913
22.673 ± 4.19038
3	28.6395
3	28.6133
3	28.2812
3	27.9037
3	27.7948
3	29.0717
3	28.894
3	26.9802
3	27.705
3	27.6776
3	27.3656
34.4231 ± 4.6482
35.149 ± 4.88343
2	29.7597
2	29.532
2	29.0274
2	28.5697
2	32.3797
2	32.2171
2	32.1678
2	31.6516
2	31.0766
2	28.1025
2	30.7087
36.4643 ± 4.91589
38.9384 ± 4.41363
2	28.0969
2	27.3184
2	28.7773
2	28.4608
2	26.9034
35.6189 ± 5.07839
36.5221 ± 5.19031
2	29.5654
2	29.4868
2	28.0974
2	29.1621
2	29.125
2	28.3604
2	31.2939
2	28.3296
2	31.0386
2	27.6997
2	30.7719
2	30.5531
2	30.3209
2	27.5396
2	30.2605
37.2577 ± 5.09747
38.4006 ± 4.71755
36.4432 ± 5.09919
16	17.4492
16	17.3425
16	16.9443
21.9501 ± 4.25182
3	27.7859
3	27.6614
3	27.5062
4	26.9447
3	27.4836
4	26.8042
3	27.4745
4	26.6413
3	27.3384
3	26.9788
4	26.275
4	26.1106
4	26.6643
4	26.1693
4	25.7929
4	25.7338
4	26.0588
4	25.3019
32.5728 ± 4.32188
3	28.2743
3	28.2111
3	28.0659
4	25.144
3	28.1413
3	27.8754
3	27.2592
34.3716 ± 4.41847
3	27.4249
32.6878 ± 4.57656
3	26.8077
3	26.7676
3	26.6868
34.742 ± 4.75241
34.6781 ± 4.61039
3	27.85
3	27.5002
3	27.4465
3	27.1953
3	27.0767
3	26.6688
3	30.6055
3	30.4358
3	30.3139
3	30.0089
3	28.7602
3	26.5144
33.9856 ± 4.45914
36.5079 ± 4.32365
3	26.3403
3	26.7244
3	26.6937
3	26.656
3	26.6237
3	25.889
3	26.1776
3	25.9418
17	16.7674
17	16.7502
3	25.5673
33.7329 ± 4.90872
33.7536 ± 4.55312
21.1988 ± 4.26114
3	26.8018
3	26.5773
3	26.2114
3	29.8402
3	27.5275
3	27.5168
3	27.289
3	27.0457
5	25.7537
5	25.6378
3	27.0009
5	25.5932
5	25.5465
5	25.482
5	25.3572
3	26.8425
3	29.5058
5	25.3543
5	24.8383
3	25.8949
5	25.3371
5	24.8291
3	26.7292
5	25.0645
34.4998 ± 5.00212
5	24.7518
5	24.3573
30.8117 ± 4.19094
30.826 ± 4.32457
36.5969 ± 4.32935
33.7961 ± 4.73586
4	26.9406
4	26.9178
4	26.7827
4	26.586
4	26.5615
4	26.3467
4	25.8406
4	25.808
4	26.2429
4	26.1137
4	25.9231
4	26.6805
4	26.6674
4	26.6345
4	25.7728
4	25.8031
32.5814 ± 4.31054
4	25.5647
4	25.4899
32.7377 ± 4.40601
32.825 ± 4.46539
18	16.7102
18	16.4325
20.8355 ± 4.19882
6	24.7801
6	24.7755
6	24.3778
6	24.2226
6	23.8551
6	24.3258
6	24.2039
6	24.078
6	23.3928
6	23.2163
6	23.1196
29.5506 ± 3.99898
6	22.7251
29.4058 ± 4.00035
4	26.4834
4	26.1568
4	25.6138
4	25.4832
4	25.4513
4	28.7272
4	28.7066
4	28.1164
4	25.2975
4	28.0197
4	27.8095
4	27.4509
31.8805 ± 4.25814
34.3458 ± 4.18006
4	25.3616
4	25.3396
4	24.4886
4	24.8751
4	24.4622
4	24.2705
4	23.923
31.8697 ± 4.57665
31.7807 ± 4.37241
4	25.7702
4	24.4066
4	24.1478
4	29.3692
4	29.0484
4	28.8953
4	26.5356
4	28.448
4	26.3027
4	26.2583
4	26.16
4	26.1498
4	26.0058
4	25.6284
32.1524 ± 4.67184
4	28.4021
4	25.6241
34.9643 ± 4.02675
32.1012 ± 4.24136
19	16.411
19	16.4091
20.7544 ± 4.12048
4
10
9
14
3
1
0
8
15
13
5
7
2
12
6
11
0 sends to 4
0 receives from 6
5	25.3269
5	25.1945
5	25.1043
5	24.8147
5	25.1088
5	25.4367
5	24.6676
5	25.3069
5	24.8991
5	25.0214
5	24.9258
30.8827 ± 4.27434
5	24.4625
5	24.5792
5	23.3836
7	23.4561
7	23.3673
31.1216 ± 4.29881
31.0645 ± 4.2052
7	23.2526
7	23.1334
7	23.0303
7	22.6286
7	22.4875
7	22.3567
7	22.1632
7	22.865
7	22.8528
7	22.1291
28.4159 ± 4.01998
7	22.1267
28.0467 ± 4.05207
5	25.1157
5	24.7638
5	24.3217
5	24.1962
5	24.1123
5	23.5011
5	27.3745
5	27.0108
5	26.8075
5	26.5676
5	26.274
30.1049 ± 4.04215
5	26.043
32.6955 ± 3.99014
5	24.0519
5	24.0428
5	23.8297
5	23.8201
5	23.6573
5	23.632
5	23.1918
5	23.6577
5	23.6444
5	23.2251
30.199 ± 4.49868
5	23.2079
5	22.5837
29.6479 ± 4.33417
5	24.0258
5	23.9176
5	23.642
5	28.3403
5	28.0884
5	27.5811
5	27.0468
8	22.8516
8	22.5928
8	22.5451
8	22.5375
8	22.1703
5	25.3446
5	25.1641
5	23.3341
5	24.9101
5	24.862
5	24.7365
8	21.9568
5	22.6356
5	26.5431
29.9439 ± 4.55759
8	21.3121
8	21.1106
27.6214 ± 4.00726
33.4168 ± 3.89678
8	20.9053
30.5905 ± 4.07238
26.9604 ± 4.05762
6	24.6463
6	24.5021
6	24.2654
6	24.1758
6	24.1383
6	24.1233
6	23.8311
6	24.1356
6	23.2726
6	23.1889
6	23.1491
6	22.8541
6	22.6758
6	22.5901
6	23.6999
6	22.4664
29.6566 ± 4.11882
29.811 ± 4.22408
29.0947 ± 4.36597
9	21.9555
9	21.8016
9	21.4522
9	21.382
9	20.8738
9	20.3099
26.5882 ± 4.1016
9	20.0624
8 sends to 7
8 receives from 1
25.7782 ± 4.21859
3 sends to 3
3 receives from 3
6	23.4193
6	22.7946
6	22.7727
6	22.6656
6	22.5066
6	25.696
6	25.3804
6	22.4928
6	25.2454
6	25.0963
6	22.4484
6	24.731
28.3635 ± 4.10652
31.275 ± 3.98758
6	22.9292
6	22.8744
6	22.6512
6	22.6303
6	22.2516
28.6414 ± 4.35692
6	21.9811
6	21.4803
28.1038 ± 4.20392
6	22.4296
6	22.3749
6	26.3447
6	26.1547
6	25.4575
6	25.2794
6	24.4006
6	23.4126
6	22.1025
6	23.2639
28.0749 ± 4.39071
31.6593 ± 4.01626
29.416 ± 3.94256
7	23.4464
7	23.1713
7	23.9719
7	23.9046
7	23.7669
7	22.9967
7	23.6891
7	23.3226
7	22.4317
7	22.1367
7	22.1054
7	21.9699
7	21.8247
7	22.9087
7	22.8742
7	21.7272
7	21.5084
7	22.7152
7	23.2453
7	21.2476
28.6179 ± 4.08845
28.69 ± 4.06517
27.6019 ± 4.36222
10	19.7075
10	19.6727
10	19.2547
10	19.2284
10	19.1884
24.7162 ± 4.22136
7	22.3767
7	22.1112
7	21.6603
7	21.4991
27.0297 ± 4.13578
7	24.6676
7	24.3443
7	24.0619
7	23.6596
30.1473 ± 3.82386
7	22.1309
7	21.9586
7	21.7265
7	21.69
7	21.6131
7	21.5693
7	21.339
27.3883 ± 4.20632
7	21.4576
7	20.8776
7	20.7652
26.783 ± 4.23019
7	21.0402
7	24.7725
7	24.5638
7	24.3631
7	23.9026
7	23.1757
7	23.0823
7	22.8921
7	22.8835
7	22.7252
26.945 ± 4.2626
30.1745 ± 3.98046
7	22.2429
11	19.0667
11	18.8827
11	18.5405
28.2736 ± 4.08044
11	18.3512
23.7757 ± 4.25674
8	20.9179
8	23.2171
8	23.0623
8	22.4725
8	20.7553
8	22.1629
8	20.5265
8	22.0821
8	22.8848
8	21.7712
8	22.7258
8	22.6602
8	20.4763
8	22.6524
27.8069 ± 4.0308
27.4625 ± 4.05932
26.2985 ± 4.26384
12	18.3197
12	18.1073
12	18.0616
12	17.5708
22.9056 ± 4.29508
8	21.4274
8	21.2512
8	21.1266
8	21.1162
8	21.1154
8	21.1125
8	20.7393
8	20.6439
25.9019 ± 4.0303
8	23.5547
8	23.5426
8	23.0646
8	23.05
8	21.172
8	20.8139
8	20.7909
28.9158 ± 3.90517
8	20.7774
8	20.7005
26.1566 ± 4.12288
8	20.7152
8	20.6563
8	20.6017
8	20.5514
8	20.4224
8	19.8117
25.8525 ± 4.15272
8	21.0367
8	20.3652
8	23.4824
8	20.1216
8	23.3334
25.8175 ± 4.19948
8	22.1642
8	21.8977
8	21.6561
8	21.242
29.0135 ± 3.94761
27.1491 ± 4.13114
9	21.7617
9	20.805
9	22.5668
9	22.1328
9	21.7076
9	20.3614
9	20.2357
9	19.8956
9	19.1163
26.4765 ± 4.11619
26.988 ± 4.0701
25.3259 ± 4.10845
11 sends to 15
11 receives from 0
13 sends to 10
13 receives from 14
15 sends to 14
15 receives from 11
13	17.5635
13	17.5214
13	17.0316
22.1111 ± 4.37029
9	20.2515
9	20.1798
9	19.7671
9	19.6294
24.9154 ± 4.02038
5 sends to 4
5 receives from 9
9	20.591
9	20.4791
9	20.4153
9	20.2028
9	23.04
9	22.9224
9	20.1524
9	22.9149
9	22.5829
9	22.5103
9	22.4941
9	22.4538
25.1906 ± 4.09935
27.8072 ± 3.91651
9 sends to 5
9 receives from 2
7 sends to 6
7 receives from 8
9	19.7826
9	19.598
9	19.4762
9	19.1921
9	19.0622
24.6095 ± 4.17532
14 sends to 13
14 receives from 15
9	19.7821
9	19.7146
9	23.2831
9	23.0862
9	23.0546
9	22.9544
9	22.9068
24.824 ± 4.2189
9	21.0178
9	20.6453
9	20.559
28.5381 ± 3.8136
14	17.0246
2 sends to 9
2 receives from 4
14	16.9989
14	16.7259
14	16.6419
1 sends to 8
1 receives from 12
14	16.6092
26.0452 ± 4.11579
21.6081 ± 4.33702
6 sends to 12
6 receives from 7
10	20.3888
10	20.3647
10	20.2928
10	20.2414
10	20.2018
10	19.0394
10	20.1455
26.5799 ± 4.02625
26.4083 ± 3.96873
10	19.1228
10	18.575
24.9571 ± 4.03549
15	16.2678
10	20.559
10	20.499
10	20.3455
21.0066 ± 4.34774
10	20.2945
10	20.1325
26.9086 ± 4.09648
10	21.5702
10	21.3579
10	21.1989
10	21.016
10	20.8012
27.9399 ± 4.11824
10	21.4585
10	21.2212
10	20.9139
10	19.4505
10	19.0622
10	18.843
10	18.9063
10	18.8375
11	20.5737
11	20.555
10	18.5389
10	19.7146
10	19.5868
10	19.5806
11	20.5218
26.7558 ± 4.13798
26.8424 ± 4.02865
10	18.0672
25.9649 ± 4.0615
24.617 ± 4.149
10	19.7139
10	21.7328
10	21.1103
10	20.9547
10	20.9075
10	20.6304
25.8315 ± 3.93064
10	20.6249
28.1348 ± 4.15128
11	18.4262
11	18.1056
11	17.8278
23.8362 ± 4.16973
11	20.1214
11	19.9803
11	19.6445
11	18.9994
11	18.8917
11	18.8321
11	19.5918
11	18.6039
25.867 ± 4.13212
25.0308 ± 4.27178
16	15.9738
11	21.3079
11	21.1428
11	21.0774
11	20.9114
11	20.0725
11	20.0499
20.6141 ± 4.32896
11	20.0286
11	20.638
11	19.9635
11	19.7839
11	19.628
27.3756 ± 4.16169
11	19.6129
25.8665 ± 4.23402
12	20.3761
12	20.3729
12	20.3236
12	20.2588
12	20.2141
11	19.5427
11	19.2878
12	19.8642
11	18.957
26.1129 ± 4.22847
25.4703 ± 4.17153
12	17.4963
23.1813 ± 4.14367
11	19.5382
11	19.4847
11	19.4711
11	20.4994
11	20.4895
11	20.4478
11	20.7771
11	20.7124
11	20.7047
11	20.6995
11	20.216
11	20.0904
11	20.2329
11	20.0503
11	19.2561
26.9363 ± 4.49614
24.7545 ± 4.06179
27.1792 ± 4.25194
11	18.7997
11	17.8402
11	17.7828
11	18.7424
11	17.7643
11	18.697
25.6343 ± 4.52081
11	17.611
23.7091 ± 4.46359
11	19.5968
11	19.3004
11	19.0389
25.5352 ± 4.01682
17	15.7314
11	20.3021
11	20.1642
11	19.9819
11	19.5421
12	20.6139
12	20.3497
12	20.3033
20.125 ± 4.25631
12	20.2632
12	19.4642
12	19.394
26.2807 ± 4.40798
26.7685 ± 4.06457
25.2019 ± 4.27626
12	19.4618
12	19.3448
12	18.5157
12	18.1945
12	19.1983
24.9442 ± 4.22108
12	17.9815
23.8121 ± 4.34498
12	18.6641
12	18.6249
13	19.623
12	18.4111
24.5317 ± 4.39883
13	19.2508
25.3428 ± 4.12648
13	17.3136
13	17.0783
22.4242 ± 4.20447
12	19.9467
12	19.8499
12	19.0432
25.7609 ± 4.63001
18	15.682
18	15.6609
18	15.6432
18	15.5047
13	20.2391
13	20.2027
13	19.965
13	19.8567
19.7413 ± 4.25744
25.2723 ± 4.43045
13	19.3062
13	19.2974
13	19.2587
13	19.2453
13	19.1482
13	19.0981
24.6567 ± 4.15811
12	19.1505
12	19.0926
12	18.8845
12	18.6018
12	20.2088
12	20.1029
12	19.2201
24.106 ± 4.17245
12	18.6767
12	18.0694
26.0334 ± 4.3666
12	17.5569
12	17.3986
24.528 ± 4.61463
22.6527 ± 4.50633
13	18.1326
13	18.1183
13	17.7903
14	18.6329
14	18.4843
23.5383 ± 4.46099
24.7787 ± 4.16367
12	19.0242
12	19.0196
12	18.6253
12	19.4929
12	19.3401
24.7216 ± 4.14278
12	19.2666
25.3944 ± 4.30582
14	16.6875
14	16.6555
14	16.4005
22.0071 ± 4.29262
13	18.7876
13	18.4161
13	18.9177
13	18.8976
13	18.7856
13	18.3347
13	18.5358
24.0325 ± 4.19518
13	17.8904
13	17.8435
13	18.4937
13	17.5475
24.3374 ± 4.61548
22.8602 ± 4.34163
19	15.4822
19	15.422
19	15.3475
19	15.3217
19.3901 ± 4.2905
14	19.4891
14	19.4082
3 sends to 14
3 receives from 4
14	19.2984
24.4265 ± 4.38172
14	18.8354
14	18.8324
14	18.8205
14	18.7783
14	18.7001
14	18.5895
14	18.432
23.9238 ± 4.19945
14	17.4508
14	17.3296
15	18.4355
15	18.4264
22.5699 ± 4.45348
15	18.3161
15	17.8698
24.0368 ± 4.21613
15	16.2425
15	15.9886
21.5868 ± 4.30664
13	19.196
13	18.5499
13	18.5171
13	18.4383
13	19.1746
13	18.4367
13	19.1494
13	18.7664
13	17.9615
14	18.3682
24.8239 ± 4.58085
13	18.0445
14	18.236
23.2895 ± 4.25719
13	17.9921
13	16.9728
23.3304 ± 4.54755
13	16.4963
13	17.9146
13	17.7942
13	17.6249
23.3966 ± 4.65159
21.9904 ± 4.467
13	18.3882
13	19.2294
13	19.1576
13	19.0646
23.898 ± 4.25219
13	18.9622
15	19.1378
15	19.0092
15	18.9058
15	18.8702
13	18.8515
13	18.8176
15	18.6058
24.3563 ± 4.35621
23.6513 ± 4.27732
15	18.3554
15	18.1235
15	18.0569
23.239 ± 4.31232
14	18.2374
14	18.2355
14	18.1723
14	18.0511
14	17.9241
14	17.7824
23.0686 ± 4.288
14	17.2829
14	17.2454
14	17.2237
14	17.199
22.1248 ± 4.38214
15	16.7581
22.2231 ± 4.1434
16	15.9559
16	15.8306
16	17.6989
16	17.5482
21.0235 ± 4.36047
16	17.5053
23.0997 ± 4.34952
15	18.1105
15	18.0025
15	17.9383
22.5636 ± 4.44273
16	18.6004
16	18.5808
16	18.2964
16	18.2837
16	18.1702
22.9066 ± 4.24898
16	17.5097
22.56 ± 4.23312
14	18.7423
14	18.1302
23.7979 ± 4.576
14	17.9097
14	17.8767
14	17.7979
14	17.7163
14	17.6829
14	17.0286
14	16.0879
14	16.0859
22.6155 ± 4.29447
14	17.6001
14	17.4448
14	17.3497
21.3771 ± 4.35167
14	17.1551
14	17.1427
22.4328 ± 4.59348
16	16.756
16	16.4642
22.0178 ± 4.14027
14	18.3077
14	18.0882
14	18.712
14	18.6468
14	18.6156
14	18.2899
23.1109 ± 4.25314
23.6075 ± 4.22248
15	17.7361
15	17.4157
15	17.3304
22.2747 ± 4.29893
17	15.8018
17	15.7845
17	15.6521
20.4651 ± 4.34391
15	17.0874
15	16.9509
15	16.8639
16	17.8997
16	17.8128
16	17.78
16	17.4925
16	17.4262
22.2969 ± 4.30265
21.4504 ± 4.27598
17	18.141
17	17.852
17	17.8494
17	17.8293
17	17.4818
17	17.0344
22.2605 ± 4.23017
21.9911 ± 4.34265
17	17.3958
17	17.2215
17	17.1661
17	17.136
22.2894 ± 4.36933
17	16.0726
17	15.9426
17	15.824
21.5773 ± 4.12737
15	18.1061
15	17.9972
15	17.7828
18	15.6234
18	15.5906
22.8607 ± 4.5325
18	15.2822
20.0008 ± 4.34775
15	16.9768
15	16.939
15	16.8729
15	16.8291
15	15.9108
15	16.6716
15	15.7856
15	16.6647
15	16.4667
15	15.7754
17	16.9403
15	15.66
17	16.9199
21.6155 ± 4.2388
20.6848 ± 4.35445
21.997 ± 4.12467
15	17.1179
15	17.0412
15	16.4631
21.5542 ± 4.45001
15	18.284
15	18.2816
15	18.1843
15	18.1215
15	18.1191
15	17.5015
15	17.4949
15	18.1122
15	17.2317
15	18.1037
15	17.9137
22.7638 ± 4.22162
22.4194 ± 4.20694
16	17.0844
18	17.4578
18	17.3
18	17.2121
18	17.0829
18	16.87
18	16.725
18	16.6373
18	16.5409
18	16.4207
21.6255 ± 4.27661
21.6378 ± 4.24904
21.2647 ± 4.30807
16	16.8134
16	16.7523
16	16.7416
16	16.7148
21.0033 ± 4.33391
18	15.7943
18	15.703
18	15.6215
18	15.5027
21.0156 ± 4.29637
18	16.7715
18	16.6007
19	15.2699
19	14.8914
21.5913 ± 4.3471
19.6069 ± 4.28695
4 sends to 3
4 receives from 0
18	16.7944
18	16.7404
22.1359 ± 4.12564
16	17.6498
16	17.4807
19	17.0537
19	17.042
19	17.0296
19	16.8751
19	16.8511
16	17.3353
21.3609 ± 4.19081
22.1389 ± 4.43726
8 sends to 15
8 receives from 7
16	15.6137
16	15.6081
19	16.063
19	16.0024
16	15.5422
20.632 ± 4.32851
16	16.4404
16	16.4379
16	16.4149
16	16.2595
16	15.1701
20.0455 ± 4.30008
12 sends to 2
12 receives from 13
20.8435 ± 4.26402
16	16.4383
16	15.6961
20.7453 ± 4.34938
19	15.4728
19	15.4656
19	15.2148
19	14.9795
20.3461 ± 4.35165
9 sends to 13
9 receives from 2
16	17.7429
22.0564 ± 4.17855
16	16.7041
17	16.8189
16	16.5323
17	16.649
21.6267 ± 4.27234
21.1181 ± 4.23614
20	15.0469
20	14.9396
20	14.8914
20	14.864
19.6224 ± 4.22176
19	16.6149
17	16.7137
17	16.6643
17	16.1674
21.9198 ± 4.19847
1 sends to 10
1 receives from 5
20.6809 ± 4.32566
19	16.4499
21.4114 ± 4.31241
10 sends to 5
10 receives from 1
17	17.2272
17	17.1981
17	17.1502
17	17.1292
17	17.0757
17	17.0674
21.6438 ± 4.37491
17	15.1646
17	14.6612
21	14.8376
21	14.8408
19.539 ± 4.42055
20.4097 ± 4.18307
19.3895 ± 4.27022
17	16.2332
17	16.0848
17	15.8005
17	15.549
20.3166 ± 4.2856
17	15.523
17	15.4044
20.1529 ± 4.27257
17	17.7331
17	17.7105
17	17.4776
17	17.4672
21.6269 ± 4.17492
18	16.516
17	16.4769
20.729 ± 4.25833
17	16.3425
21.174 ± 4.33515
18	16.1663
18	16.0764
18	16.0559
18	15.9249
18	15.8949
20.2009 ± 4.34497
22	14.731
22	14.7189
22	14.6944
22	14.2939
22	14.8065
19.7542 ± 4.38189
22	14.7814
19.0502 ± 4.28228
18	16.9593
18	16.8823
18	16.3993
21.2228 ± 4.36294
18	14.6148
18	14.5648
18	14.476
19.5352 ± 4.33075
18	15.3743
18	15.259
18	15.1667
19.7528 ± 4.31996
18	15.3914
18	15.3621
18	15.2487
18	15.0773
19.6177 ± 4.27523
18	17.4195
18	17.3833
18	17.0881
21.2792 ± 4.16462
19	16.4865
19	16.3274
19	16.2638
20.3769 ± 4.27747
11 sends to 7
11 receives from 15
18	15.9663
21.2978 ± 4.11708
23	14.209
23	14.0489
23	13.9418
23	13.9137
23	14.6767
23	14.6343
23	13.8088
23	14.6305
23	14.5761
19.0892 ± 4.52934
23	14.3492
23	14.0496
18.9387 ± 4.27765
19	15.6326
20.7007 ± 4.1197
15 sends to 11
15 receives from 8
21	16.4361
21	16.2518
21.6484 ± 4.21542
19	16.2887
19	16.2761
19	16.095
20.7056 ± 4.42115
7 sends to 8
7 receives from 11
19	14.2563
19	14.1468
19.2382 ± 4.32666
14 sends to 6
14 receives from 3
24	13.4757
18.634 ± 4.48096
19	15.1247
19	15.115
19	15.0917
19	15.08
24	14.0228
18.547 ± 4.40816
19	15.0153
19	14.9424
19.2694 ± 4.34719
5 sends to 1
5 receives from 10
19	15.0642
19	15.0349
19	14.9225
19	14.8278
19.1648 ± 4.31483
19	17.0674
19	16.9641
13 sends to 12
13 receives from 9
19	16.7069
20.9482 ± 4.14084
6 sends to 0
6 receives from 14
19	15.904
19	15.7339
19	15.6409
19	15.451
21.0766 ± 4.2004
2 sends to 9
2 receives from 12
20	15.9398
20	15.6891
20	15.6326
20	15.5036
20	15.2263
20.6557 ± 4.29212
22	16.0812
20	16.3111
20	16.2686
20	16.095
20	16.0709
20	15.934
21.1273 ± 4.21577
21.0826 ± 4.29533
25	13.3433
25	13.8596
18.0872 ± 4.43061
18.3403 ± 4.40212
20	15.4175
20	14.9424
20	14.9379
20	14.9245
20	14.9008
20	14.7421
20	14.72
20	14.2554
21.6218 ± 4.34986
20	15.9779
20	15.5153
20	15.2493
20	14.7818
20	14.6784
20.9301 ± 4.25348
20	16.0648
20	15.3947
21.5535 ± 4.05886
20	15.6742
21.2076 ± 4.20911
20	14.8515
20.8075 ± 4.23214
20	14.5257
20	14.4752
20	14.1468
20.6134 ± 4.37853
21	15.9099
21	15.7567
21	15.732
21	15.6855
20.8846 ± 4.30147
26	13.3207
26	13.3176
17.7072 ± 4.48798
26	13.6324
17.9331 ± 4.34397
21	14.1281
21	14.1193
21	14.1185
21	14.1094
21	13.9041
21	13.8282
21	13.543
20.2568 ± 4.56706
21	15.523
21.4682 ± 4.25501
21	15.2102
21	15.164
21	15.06
21	14.9445
21	14.9115
20.1742 ± 4.36223
21	14.5998
21	15.0743
21	14.5597
21	14.9553
20.4551 ± 4.32723
20.8776 ± 4.2828
23	15.668
20.5775 ± 4.39331
21	14.3887
20.2823 ± 4.25283
21	15.5326
21	15.4732
20.8268 ± 4.25365
22	15.5449
22	15.5158
22	15.3318
21	13.8215
21	13.8055
21	13.7721
20.3587 ± 4.41498
19.3859 ± 4.336
27	13.2638
27	13.4786
17.3556 ± 4.45385
21	14.9114
17.6506 ± 4.36481
21	14.784
22	13.4175
22	13.4157
20.1334 ± 4.39127
19.4035 ± 4.6581
21	14.0102
21	14.7838
21	14.4755
19.932 ± 4.64006
20.0197 ± 4.26017
22	14.2265
22	14.7783
22	14.0929
19.6817 ± 4.44617
20.2293 ± 4.42647
21	15.4142
21	15.2918
21	15.1453
22	14.3337
22	14.3276
22	14.2916
21.5494 ± 4.30669
22	14.2557
22	14.0424
19.5002 ± 4.39794
22	14.8869
22	14.8693
22	14.7337
22	14.6297
22	15.2607
19.5143 ± 4.45172
20.7583 ± 4.38024
24	15.4103
20.147 ± 4.39912
23	15.1994
23	15.0672
23	14.8037
23	14.3669
19.7708 ± 4.39911
28	13.2334
28	13.2077
28	13.1536
28	13.0507
17.1078 ± 4.47539
28	13.3904
28	13.1886
17.4688 ± 4.47896
23	13.2902
18.6847 ± 4.69087
22	15.3991
22	15.3477
22	15.3139
22	15.2919
22	15.221
22	15.2199
20.306 ± 4.31925
23	14.7456
23	14.6717
23	14.0143
23	14.6014
19.8046 ± 4.43286
19.1564 ± 4.46787
22	14.5253
22	14.4009
19.7742 ± 4.30129
22	14.0059
22	13.9014
22	13.858
19.1299 ± 4.73898
22	14.4734
22	14.4665
22	14.2156
22	14.2
19.5678 ± 4.3503
22	14.7045
20.7459 ± 4.45887
24	14.2812
24	14.222
24	14.0676
24	13.9784
24	13.9625
24	13.7614
19.0486 ± 4.54874
29	12.9407
29	12.8115
16.8838 ± 4.49431
29	13.1004
17.1539 ± 4.44618
24	13.1728
23	14.6164
23	14.597
23	14.565
23	14.5546
18.0835 ± 4.69398
18.9886 ± 4.47713
23	15.2268
23	14.9141
20.1355 ± 4.4871
25	15.3936
25	15.365
25	15.3332
25	15.1948
19.6532 ± 4.41915
24	13.7281
18.8937 ± 4.37781
23	14.2452
23	14.2148
23	14.1002
23	14.0694
19.3168 ± 4.38657
23	15.0783
19.7808 ± 4.34431
24	14.4995
24	14.4947
23	14.3925
19.2388 ± 4.42157
19.8648 ± 4.57712
23	13.6574
23	13.6385
23	13.4428
18.6369 ± 4.4738
25	13.7535
25	13.7374
24	13.8169
25	13.7254
25	13.3465
18.241 ± 4.59683
24	13.8028
18.6542 ± 4.43702
25	13.0455
25	13.0262
17.579 ± 4.60612
23	13.8574
23	13.7492
23	13.7244
23	13.3979
18.4101 ± 4.63595
23	14.1979
23	14.191
23	14.0914
18.9251 ± 4.43388
24	14.0445
24	13.994
18.5571 ± 4.44687
24	13.8846
24	13.8832
18.7688 ± 4.44109
24	14.898
24	14.7441
24	14.7111
19.5082 ± 4.50205
26	15.1441
26	15.136
19.1961 ± 4.37628
24	14.3376
19.0286 ± 4.52452
26	13.3224
26	13.3211
26	13.1256
17.6752 ± 4.67003
26	13.022
26	12.7171
17.6616 ± 4.5673
24	15.0041
24	14.8697
19.3609 ± 4.44056
25	14.4041
25	14.2233
18.8601 ± 4.47765
24	13.3281
24	13.2911
18.1187 ± 4.59492
26	13.5701
25	13.7112
18.3549 ± 4.36142
26	13.1771
18.0812 ± 4.47026
25	13.8659
25	13.6985
25	13.4582
18.2304 ± 4.4042
24	13.3577
24	13.2724
24	13.2064
17.9681 ± 4.45049
24	14.0824
24	14.0762
24	13.6314
18.4582 ± 4.47066
25	14.2915
18.4456 ± 4.46654
27	13.1015
27	13.0704
27	12.9926
17.2174 ± 4.65551
25	13.9092
25	13.7262
18.0459 ± 4.44374
25	14.3646
19.0517 ± 4.50265
27	15.123
27	15.0052
27	14.6423
18.9342 ± 4.36169
27	13.0936
17.7387 ± 4.45622
25	14.7281
25	14.7191
26	13.4509
26	13.3366
25	14.6732
25	14.6729
18.979 ± 4.45929
17.8098 ± 4.51269
26	14.1326
18.4138 ± 4.46911
26	14.2855
18.5821 ± 4.30537
25	13.1575
25	13.1253
17.6552 ± 4.58211
26	13.6913
28	12.9685
28	12.8615
26	13.6262
26	13.4911
16.8262 ± 4.57274
17.9266 ± 4.39056
25	13.0728
25	12.8831
17.5841 ± 4.46749
25	13.5394
25	13.4791
17.9386 ± 4.5032
26	13.7104
26	13.4444
26	13.4257
26	13.3981
26	13.3596
17.6996 ± 4.45154
28	12.9073
17.3914 ± 4.47968
27	13.3228
27	13.2135
17.324 ± 4.46012
26	14.3182
26	14.1945
26	14.113
18.5777 ± 4.51205
28	14.5386
28	14.5038
28	14.2946
18.6241 ± 4.3918
27	14.2306
27	14.1205
27	14.0333
18.2773 ± 4.36894
29	12.8375
16.6602 ± 4.57455
26	14.5313
26	14.2056
18.6241 ± 4.44709
29	12.6087
29	12.5987
16.7735 ± 4.49945
27	14.0716
27	14.0584
18.1027 ± 4.40079
26	13.0107
26	12.9917
17.2643 ± 4.59384
27	13.4457
17.5814 ± 4.41311
29	12.8645
29	12.8237
29	12.7808
17.003 ± 4.46474
28	13.1589
28	13.0298
17.1191 ± 4.48858
26	12.7684
26	12.7494
26	12.6517
26	13.3872
26	13.204
17.1212 ± 4.4242
17.5389 ± 4.42203
28	13.6553
17.9775 ± 4.42002
27	13.3269
27	13.286
27	13.2622
27	13.1162
17.4361 ± 4.52798
27	14.1039
27	14.0969
27	14.0282
27	14.0207
18.3954 ± 4.38137
29	14.2619
29	13.9674
18.8111 ± 4.32709
27	14.064
27	14.0527
18.2275 ± 4.4523
29	12.9068
29	12.8522
16.8652 ± 4.5019
28	14.0257
28	13.9678
28	13.9656
18.3544 ± 4.36679
29	13.4847
18.3508 ± 4.26032
27	12.8702
17.4337 ± 4.47918
28	13.4031
28	13.1272
28	13.0895
17.3358 ± 4.45086
27	12.5181
27	12.5001
16.6973 ± 4.42573
28	13.0834
28	13.0425
17.053 ± 4.49917
28	13.9693
28	13.8506
28	13.7186
18.0866 ± 4.46515
28	13.911
28	13.8729
28	13.864
28	13.7109
17.9511 ± 4.50093
29	13.875
18.0528 ± 4.3958
3
7
10
11
9
5
6
2
14
8
12
0
15
1
13
4
8 sends to 14
8 receives from 9
9 sends to 8
9 receives from 4
10 sends to 12
10 receives from 2
0 sends to 3
0 receives from 11
1 sends to 7
1 receives from 13
2 sends to 10
2 receives from 7
3 sends to 11
3 receives from 0
4 sends to 9
4 receives from 15
5 sends to 5
5 receives from 5
28	12.8598
29	12.9869
29	12.8014
28	12.8551
17.2052 ± 4.53048
17.0124 ± 4.50599
12 sends to 15
12 receives from 10
28	12.3854
28	12.3305
16.4202 ± 4.51291
28	13.0067
17.4809 ± 4.3729
29	12.9498
29	12.3196
16.8363 ± 4.49269
11 sends to 0
11 receives from 3
30	12.8448
30	12.7808
30	12.6134
29	13.5288
30	12.8166
30	12.7187
16.6331 ± 4.44956
30	13.0873
17.5816 ± 4.35309
17.0835 ± 4.33694
17.9845 ± 4.26727
17.6902 ± 4.52214
15 sends to 4
15 receives from 12
29	13.5692
29	13.5603
29	13.5223
17.6863 ± 4.50817
7 sends to 2
7 receives from 1
30	13.4847
19.3276 ± 4.25177
29	12.8224
29	12.8213
16.875 ± 4.48479
14 sends to 13
14 receives from 8
31	12.8095
31	12.6711
31	12.6673
31	12.3479
16.5019 ± 4.51207
31	12.5344
17.5345 ± 4.29476
16.8767 ± 4.40334
29	12.2537
29	12.7824
16.5106 ± 4.41194
17.1211 ± 4.37476
6 sends to 6
6 receives from 6
13 sends to 1
13 receives from 14
30	13.1137
30	12.3196
30	12.2666
17.8633 ± 4.50664
30	13.3806
30	13.3339
18.8395 ± 4.18164
30	13.4482
30	12.8014
18.2871 ± 4.31469
30	12.7243
30	12.5987
30	12.5897
17.7307 ± 4.36912
32	12.5516
32	12.4687
32	12.3384
31	13.4805
16.995 ± 4.341
32	12.0978
32	12.2922
31	12.6782
31	12.5056
32	12.2665
31	12.4306
31	12.3795
32	12.2149
32	13.0853
32	12.8559
19.0175 ± 4.42499
31	12.3014
17.3001 ± 4.38911
16.6073 ± 4.48044
17.038 ± 4.47991
17.6949 ± 4.48252
30	12.3968
17.512 ± 4.53892
30	12.2483
30	12.2323
16.4826 ± 4.41323
31	12.259
17.3301 ± 4.58226
31	12.6783
31	12.6498
18.1061 ± 4.41075
33	12.2237
33	12.2048
16.884 ± 4.34906
32	12.2711
32	12.0488
32	12.0308
32	11.8415
33	12.1917
32	11.8086
16.49 ± 4.55817
16.2722 ± 4.52213
31	12.5448
31	12.4032
17.4931 ± 4.37397
32	13.2606
18.3863 ± 4.35808
32	13.3339
18.8152 ± 4.5814
34	11.9942
34	11.9614
16.9302 ± 4.46651
34	12.0692
33	11.7988
34	12.0211
16.4564 ± 4.60666
34	12.179
34	12.1644
31	12.2101
15.9406 ± 4.57497
16.3111 ± 4.4508
32	11.7734
31	12.1996
16.2647 ± 4.43843
32	12.162
16.4872 ± 4.46559
31	12.7636
18.0139 ± 4.34361
16.9201 ± 4.68014
32	12.3325
17.0101 ± 4.44226
33	12.5442
17.1547 ± 4.5812
33	12.9918
34	11.6889
35	11.9398
35	12.0315
16.1154 ± 4.59702
35	12.8054
18.3901 ± 4.60495
15.6421 ± 4.60558
35	12.7101
16.2527 ± 4.51794
16.8123 ± 4.51986
33	12.4904
33	12.4618
16.8713 ± 4.56089
32	12.2953
16.5697 ± 4.56885
33	11.7534
33	11.6217
33	11.6013
33	12.0718
33	12.0625
16.0184 ± 4.5519
32	12.721
16.4099 ± 4.65096
32	12.6548
17.7494 ± 4.48258
34	12.4984
16.774 ± 4.57997
36	12.0083
35	11.5979
15.3883 ± 4.59653
36	12.6219
16.0191 ± 4.53524
16.753 ± 4.42202
34	12.3981
34	12.3282
36	11.8631
16.4766 ± 4.4955
16.5994 ± 4.41899
33	12.3294
33	12.2663
16.711 ± 4.47126
35	12.8452
17.3856 ± 4.53242
34	12.9538
34	12.8452
17.9294 ± 4.50191
35	12.4082
16.4699 ± 4.58935
34	11.5812
34	11.5686
34	11.5657
15.684 ± 4.58087
36	11.5905
15.2351 ± 4.56265
34	12.0425
34	12.037
16.0657 ± 4.59962
33	12.6122
35	12.2645
35	12.221
16.6784 ± 4.49358
17.2872 ± 4.55104
36	12.7201
36	12.6686
17.085 ± 4.428
34	12.1956
34	12.1883
16.3825 ± 4.54034
36	12.3656
16.2617 ± 4.5693
35	12.6686
38	11.9187
15.8486 ± 4.5766
17.4213 ± 4.48867
38	11.7563
38	12.597
38	12.5714
16.3793 ± 4.45275
15.7615 ± 4.56831
36	12.1574
16.4362 ± 4.58342
34	12.2322
35	12.7855
16.0317 ± 4.53275
17.7043 ± 4.42829
37	12.5517
16.7468 ± 4.44769
35	11.5457
15.4705 ± 4.68599
35	11.9108
35	11.6961
15.8403 ± 4.60136
34	12.457
16.8886 ± 4.56503
39	11.9114
15.6428 ± 4.52214
39	11.7207
15.5194 ± 4.5675
35	12.1851
16.1786 ± 4.58556
38	12.4347
16.4188 ± 4.45628
35	12.4144
35	12.4107
16.6275 ± 4.60073
36	12.7733
36	12.7488
36	12.6909
17.4895 ± 4.58481
38	12.2038
38	12.191
16.6574 ± 4.44594
36	11.564
15.5883 ± 4.62531
39	11.4809
39	11.4735
14.9848 ± 4.54037
35	12.1774
15.7104 ± 4.45239
36	12.1706
15.9785 ± 4.5471
39	12.4347
16.1677 ± 4.49733
36	12.3681
16.4208 ± 4.57205
39	12.1591
39	12.1137
39	12.0596
16.6635 ± 4.51978
37	12.6166
16.6991 ± 4.5158
37	12.6786
37	12.5661
17.1246 ± 4.65817
37	11.533
15.1095 ± 4.57491
37	11.5567
37	11.5313
37	11.5311
15.3306 ± 4.57489
37	12.3396
16.2526 ± 4.57542
38	12.1679
15.8378 ± 4.54307
38	12.5943
16.4602 ± 4.47844
38	11.5256
14.9848 ± 4.51408
37	12.2232
15.8579 ± 4.49869
38	12.5198
38	12.4975
16.7172 ± 4.63522
38	11.4984
15.1901 ± 4.55582
39	12.5329
39	12.4219
16.2698 ± 4.47341
39	12.4852
39	12.4619
16.4197 ± 4.57137
39	11.455
15.1249 ± 4.60505
11
6
10
0
2
4
9
3
1
7
14
8
15
15 sends to 13
15 receives from 12
5
12
13
0 sends to 11
0 receives from 3
12 sends to 15
12 receives from 14
13 sends to 5
13 receives from 15
1 sends to 6
1 receives from 8
2 sends to 10
2 receives from 4
3 sends to 0
3 receives from 7
4 sends to 2
4 receives from 5
5 sends to 4
5 receives from 13
7 sends to 3
7 receives from 9
8 sends to 1
8 receives from 11
9 sends to 7
9 receives from 6
10 sends to 14
10 receives from 2
11 sends to 8
11 receives from 0
40	11.5256
40	11.8751
40	11.7207
40	11.8631
40	11.708
40	12.1679
40	12.0596
40	11.455
40	11.4477
40	11.4216
40	12.1149
40	12.0883
40	11.8447
40	11.6083
40	11.4735
40	11.4487
15.9166 ± 4.56644
15.8449 ± 4.46689
16.9536 ± 4.33745
40	12.0458
14.9211 ± 4.50852
16.4859 ± 4.43161
16.0547 ± 4.50559
16.3925 ± 4.30524
14 sends to 12
14 receives from 10
6 sends to 9
6 receives from 1
41	11.338
41	11.6982
41	11.6593
41	11.3306
41	11.5572
41	11.5473
41	11.5012
41	11.474
41	11.465
41	11.383
41	11.3971
41	11.4885
41	12.0201
41	11.9685
41	11.4402
14.9492 ± 4.53574
15.6905 ± 4.49856
15.7535 ± 4.61955
16.2206 ± 4.43699
15.9408 ± 4.46446
40	12.1747
40	12.1703
17.0096 ± 4.2802
40	12.2232
16.3312 ± 4.60019
40	12.1574
41	12.3986
17.2292 ± 4.36665
15.9822 ± 4.50312
42	11.3224
41	11.3814
42	11.4098
15.5311 ± 4.62243
42	11.8831
42	11.4339
15.6378 ± 4.51103
15.4253 ± 4.55761
15.1569 ± 4.48554
15.7521 ± 4.41915
42	11.9823
42	11.9604
16.3125 ± 4.55153
41	11.6411
16.22 ± 4.46008
43	11.8426
15.7058 ± 4.48228
41	12.1612
17.0802 ± 4.36111
41	12.2146
16.1479 ± 4.5678
41	12.15
41	12.0984
42	12.3048
42	12.2138
16.0438 ± 4.52456
17.0385 ± 4.49109
42	11.5564
42	11.374
15.9733 ± 4.5139
15.4067 ± 4.57954
44	11.4032
44	11.3972
14.8729 ± 4.55096
44	11.3911
44	11.3335
15.268 ± 4.59755
15.0669 ± 4.56822
44	11.942
44	11.8831
15.895 ± 4.57832
43	11.5437
43	11.5411
43	11.4877
15.6806 ± 4.59242
42	12.1061
16.0149 ± 4.53691
43	12.2064
16.6805 ± 4.56384
45	11.3951
45	11.3882
45	11.3224
14.7526 ± 4.49721
45	11.8647
15.0361 ± 4.6612
15.4706 ± 4.50941
45	11.8647
15.6344 ± 4.50374
44	11.475
15.4043 ± 4.5586
46	11.385
14.8134 ± 4.54659
46	11.77
15.4054 ± 4.53027
46	11.8404
15.4926 ± 4.57444
43	12.058
16.4461 ± 4.50585
44	12.0808
43	12.0976
16.3388 ± 4.55575
15.9219 ± 4.59348
47	12.1043
15.6501 ± 4.46785
47	11.6556
15.4044 ± 4.59828
47	11.77
47	11.6577
15.3566 ± 4.50896
46	11.4394
15.1615 ± 4.61851
45	12.0734
44	12.0957
44	12.0628
15.6166 ± 4.46585
16.047 ± 4.57626
45	11.3306
14.9196 ± 4.5706
48	11.279
48	12.0608
15.6785 ± 4.54298
14.7369 ± 4.51603
48	11.6013
16.1119 ± 4.26888
47	11.358
47	11.3224
14.9938 ± 4.54867
49	11.9971
15.5578 ± 4.5114
49	11.5992
16.3335 ± 4.40474
49	11.5992
16.1467 ± 4.31758
46	12.058
15.6903 ± 4.49861
48	11.9944
15.6271 ± 4.52973
8
11
6
0
4
14
7
1
12
13
9
3
5
10
2
15
0 sends to 8
0 receives from 3
1 sends to 11
1 receives from 7
2 sends to 6
2 receives from 14
3 sends to 0
3 receives from 11
4 sends to 4
4 receives from 4
5 sends to 14
5 receives from 12
7 sends to 1
7 receives from 6
8 sends to 12
8 receives from 0
9 sends to 13
9 receives from 10
10 sends to 9
10 receives from 13
11 sends to 3
11 receives from 1
13 sends to 10
13 receives from 9
15 sends to 15
15 receives from 15
49	11.941
16.6201 ± 4.46419
14 sends to 2
14 receives from 5
50	11.833
50	11.3433
50	11.3306
50	11.3224
50	11.3224
50	11.5924
6 sends to 7
6 receives from 2
15.9498 ± 4.39557
15.7136 ± 4.53701
15.412 ± 4.48784
16.5767 ± 4.3771
12 sends to 5
12 receives from 8
50	11.7458
50	11.7135
50	11.5992
16.4563 ± 4.30712
51	11.279
15.3534 ± 4.52392
50	11.8426
16.8806 ± 4.44686
50	11.9714
50	11.3456
50	11.3335
16.3796 ± 4.36734
50	11.8927
50	11.8478
50	11.8246
50	11.4046
50	11.279
16.1903 ± 4.3874
52	11.279
15.1255 ± 4.49631
52	11.5892
15.5466 ± 4.61909
52	11.279
15.8787 ± 4.59748
51	11.791
51	11.7355
16.8203 ± 4.53209
53	11.279
15.0927 ± 4.56243
52	11.6839
53	11.791
16.4549 ± 4.56539
15.6309 ± 4.56136
53	11.5924
53	11.5892
15.7786 ± 4.48301
54	11.5657
15.5154 ± 4.51733
55	11.5557
15.298 ± 4.52327
9
15
10
13
2
12
0
3
11
1
5
7
14
8
4
6
0 sends to 9
9 sends to 1
9 receives from 0
10 sends to 5
10 receives from 2
11 sends to 7
11 receives from 8
13 sends to 8
13 receives from 3
15 sends to 6
15 receives from 1
0 receives from 6
1 sends to 15
1 receives from 9
2 sends to 10
2 receives from 4
3 sends to 13
3 receives from 7
4 sends to 2
4 receives from 14
5 sends to 12
5 receives from 10
7 sends to 3
7 receives from 11
8 sends to 11
8 receives from 13
6 sends to 0
6 receives from 15
14 sends to 4
14 receives from 12
60	11.5557
60	11.279
60	11.5362
60	11.4046
60	11.279
60	11.3224
60	11.279
16.0908 ± 4.29463
14.7232 ± 4.5239
14.7545 ± 4.56356
15.9938 ± 4.33229
12 sends to 14
12 receives from 5
60	11.4836
60	11.3335
15.9245 ± 4.32301
61	11.4406
16.1729 ± 4.36445
61	11.3335
15.3703 ± 4.58575
60	11.5609
60	11.279
15.5379 ± 4.48603
62	11.3335
15.9291 ± 4.48866
61	11.279
15.0264 ± 4.57037
65	11.3335
15.0927 ± 4.53592
3
13
2
14
0
11
12
5
9
10
6
1
4
8
15
7
0 sends to 3
0 receives from 4
1 sends to 13
1 receives from 11
2 sends to 2
2 receives from 2
3 sends to 14
3 receives from 0
4 sends to 0
4 receives from 12
5 sends to 11
5 receives from 7
7 sends to 5
7 receives from 15
8 sends to 9
8 receives from 13
9 sends to 10
9 receives from 8
10 sends to 6
10 receives from 9
11 sends to 1
11 receives from 5
13 sends to 8
13 receives from 1
15 sends to 7
15 receives from 14
6 sends to 12
6 receives from 10
14 sends to 15
14 receives from 3
12 sends to 4
12 receives from 6
70	11.279
15.5283 ± 4.51797
70	11.279
15.0857 ± 4.49847
70	11.279
15.0751 ± 4.45226
9
15
14
1
2
7
13
0
11
10
8
6
12
4
3
5
0 sends to 9
0 receives from 7
1 sends to 15
1 receives from 3
2 sends to 14
2 receives from 4
3 sends to 1
3 receives from 14
4 sends to 2
4 receives from 13
5 sends to 7
5 receives from 15
6 sends to 13
6 receives from 11
7 sends to 0
7 receives from 5
8 sends to 11
8 receives from 10
9 sends to 10
9 receives from 0
10 sends to 8
10 receives from 9
11 sends to 6
11 receives from 8
13 sends to 4
13 receives from 6
15 sends to 5
15 receives from 1
14 sends to 3
14 receives from 2
12 sends to 12
12 receives from 12
80	11.279
15.0862 ± 4.51669
80	11.279
15.0463 ± 4.42334
13
14
12
3
9
1
0
8
4
10
5
6
11
7
2
15
0 sends to 13
0 receives from 6
1 sends to 14
1 receives from 5
2 sends to 12
2 receives from 14
3 sends to 3
3 receives from 3
4 sends to 9
4 receives from 8
5 sends to 1
5 receives from 10
6 sends to 0
6 receives from 11
7 sends to 8
7 receives from 13
8 sends to 4
8 receives from 7
9 sends to 10
9 receives from 4
10 sends to 5
10 receives from 9
11 sends to 6
11 receives from 12
13 sends to 7
13 receives from 0
15 sends to 15
15 receives from 15
12 sends to 11
12 receives from 2
14 sends to 2
14 receives from 1
15
14
7
8
13
5
3
2
6
11
4
9
0
10
1
12
0 sends to 15
0 receives from 12
13 sends to 10
13 receives from 4
15 sends to 12
15 receives from 0
1 sends to 14
1 receives from 14
2 sends to 7
2 receives from 7
3 sends to 8
3 receives from 6
4 sends to 13
4 receives from 10
5 sends to 5
5 receives from 5
6 sends to 3
6 receives from 8
7 sends to 2
7 receives from 2
8 sends to 6
8 receives from 3
9 sends to 11
9 receives from 11
10 sends to 4
10 receives from 13
11 sends to 9
11 receives from 9
12 sends to 0
12 receives from 15
14 sends to 1
14 receives from 1
15
9
5
11
2
12
10
1
14
13
3
0
6
7
8
4
0 sends to 15
0 receives from 11
2 sends to 5
2 receives from 4
3 sends to 11
3 receives from 10
4 sends to 2
4 receives from 15
5 sends to 12
5 receives from 2
6 sends to 10
6 receives from 12
7 sends to 1
7 receives from 13
8 sends to 14
8 receives from 14
9 sends to 13
9 receives from 1
10 sends to 3
10 receives from 6
11 sends to 0
11 receives from 3
12 sends to 6
12 receives from 5
13 sends to 7
13 receives from 9
14 sends to 8
14 receives from 8
15 sends to 4
15 receives from 0
1 sends to 9
1 receives from 7
14
7
0
9
3
5
4
13
2
1
12
8
11
6
10
15
0 sends to 14
0 receives from 2
15 sends to 15
15 receives from 15
1 sends to 7
1 receives from 9
2 sends to 0
2 receives from 8
3 sends to 9
3 receives from 4
4 sends to 3
4 receives from 6
5 sends to 5
5 receives from 5
7 sends to 13
7 receives from 1
8 sends to 2
8 receives from 11
9 sends to 1
9 receives from 3
11 sends to 8
11 receives from 12
12 sends to 11
12 receives from 10
13 sends to 6
13 receives from 7
10 sends to 12
10 receives from 14
14 sends to 10
14 receives from 0
6 sends to 4
6 receives from 13
10
12
9
13
14
1
11
8
15
5
2
4
7
0
6
3
4 sends to 14
4 receives from 11
5 sends to 1
5 receives from 9
7 sends to 8
7 receives from 12
8 sends to 15
8 receives from 7
9 sends to 5
9 receives from 2
10 sends to 2
10 receives from 0
11 sends to 4
11 receives from 6
12 sends to 7
12 receives from 1
13 sends to 0
13 receives from 3
15 sends to 3
15 receives from 8
0 sends to 10
0 receives from 13
1 sends to 12
1 receives from 5
2 sends to 9
2 receives from 10
3 sends to 13
3 receives from 15
14 sends to 6
14 receives from 4
6 sends to 11
6 receives from 14
9
14
1
13
7
6
12
5
3
10
2
4
0
15
8
11
0 sends to 9
0 receives from 12
8 sends to 3
8 receives from 14
9 sends to 10
9 receives from 0
10 sends to 2
10 receives from 9
11 sends to 4
11 receives from 15
13 sends to 15
13 receives from 3
15 sends to 11
15 receives from 13
1 sends to 14
1 receives from 2
2 sends to 1
2 receives from 10
3 sends to 13
3 receives from 8
4 sends to 7
4 receives from 11
5 sends to 6
5 receives from 7
7 sends to 5
7 receives from 4
12 sends to 0
12 receives from 6
14 sends to 8
14 receives from 1
6 sends to 12
6 receives from 5
15 sends to 15
15 receives from 15
4
0
3
8
12
6
5
11
2
7
9
13
10
1
14
15
0 sends to 4
0 receives from 1
1 sends to 0
1 receives from 13
2 sends to 3
2 receives from 8
3 sends to 8
3 receives from 2
4 sends to 12
4 receives from 0
5 sends to 6
5 receives from 6
7 sends to 11
7 receives from 9
8 sends to 2
8 receives from 3
9 sends to 7
9 receives from 10
10 sends to 9
10 receives from 12
11 sends to 13
11 receives from 7
13 sends to 1
13 receives from 11
14 sends to 14
14 receives from 14
12 sends to 10
12 receives from 4
6 sends to 5
6 receives from 5
13
14
15
3
1
6
8
4
12
9
10
11
5
0
7
2
13 sends to 0
13 receives from 0
15 sends to 2
15 receives from 2
0 sends to 13
0 receives from 13
1 sends to 14
1 receives from 4
2 sends to 15
2 receives from 15
3 sends to 3
3 receives from 3
4 sends to 1
4 receives from 7
5 sends to 6
5 receives from 12
7 sends to 4
7 receives from 14
8 sends to 12
8 receives from 6
9 sends to 9
9 receives from 9
11 sends to 11
11 receives from 11
10 sends to 10
10 receives from 10
14 sends to 7
14 receives from 1
12 sends to 5
12 receives from 8
6 sends to 8
6 receives from 5
6
0
2
10
4
13
15
8
12
7
1
11
5
3
14
9
0 sends to 6
0 receives from 1
1 sends to 0
1 receives from 10
2 sends to 2
2 receives from 2
3 sends to 10
3 receives from 13
4 sends to 4
4 receives from 4
5 sends to 13
5 receives from 12
7 sends to 8
7 receives from 9
8 sends to 12
8 receives from 7
9 sends to 7
9 receives from 15
10 sends to 1
10 receives from 3
11 sends to 11
11 receives from 11
13 sends to 3
13 receives from 5
15 sends to 9
15 receives from 6
14 sends to 14
14 receives from 14
12 sends to 5
12 receives from 8
6 sends to 15
6 receives from 0
4
7
10
15
12
3
2
0
5
9
6
11
13
14
8
1
1 sends to 7
1 receives from 15
2 sends to 10
2 receives from 6
3 sends to 15
3 receives from 5
4 sends to 12
4 receives from 0
5 sends to 3
5 receives from 8
7 sends to 0
7 receives from 1
8 sends to 5
8 receives from 14
9 sends to 9
9 receives from 9
10 sends to 6
10 receives from 2
11 sends to 11
11 receives from 11
12 sends to 13
12 receives from 4
13 sends to 14
13 receives from 12
15 sends to 1
15 receives from 3
0 sends to 4
0 receives from 7
14 sends to 8
14 receives from 13
6 sends to 2
6 receives from 10
15
14
5
11
1
0
3
2
13
8
12
6
4
9
7
10
0 sends to 15
0 receives from 5
1 sends to 14
1 receives from 4
2 sends to 5
2 receives from 7
3 sends to 11
3 receives from 6
4 sends to 1
4 receives from 12
5 sends to 0
5 receives from 2
7 sends to 2
7 receives from 14
8 sends to 13
8 receives from 9
9 sends to 8
9 receives from 13
10 sends to 12
10 receives from 15
11 sends to 6
11 receives from 3
12 sends to 4
12 receives from 10
13 sends to 9
13 receives from 8
15 sends to 10
15 receives from 0
14 sends to 7
14 receives from 1
6 sends to 3
6 receives from 11
14.7164 ± 4.58943
14.7599 ± 4.59214
Noooooo
Noooooo
14.7185 ± 4.59743
Noooooo
Execution time: 124.746 s
14.6908 ± 4.51379
Noooooo
Execution time: 124.75 s
14.7357 ± 4.59556
14.7488 ± 4.59781
Noooooo
Execution time: 124.754 s
Noooooo
Execution time: 124.758 s
Execution time: 124.76 s
14.7608 ± 4.55481
Noooooo
14.6532 ± 4.50316
14.746 ± 4.58045
Noooooo
Execution time: 124.837 s
Noooooo
Execution time: 124.841 s
Execution time: 124.842 s
14.7358 ± 4.57833
Noooooo
Execution time: 125.907 s
14.771 ± 4.6109
Noooooo
Execution time: 126.212 s
14.7172 ± 4.62192
Noooooo
Execution time: 126.582 s
14.6684 ± 4.51876
Noooooo
14.6647 ± 4.53025
Noooooo
Execution time: 126.595 s
Execution time: 126.597 s
14.7203 ± 4.57363
Noooooo
14.723 ± 4.56372
Noooooo
Execution time: 126.686 s
Execution time: 126.692 s
fabio@fabios-iMac-Pro ~ % mpirun --use-hwthread-cpus ~/Downloads/T_S_P
Thread 27 of 32
Thread 19 of 32
Thread 29 of 32
Thread 17 of 32
Thread 11 of 32
Thread 26 of 32
Thread 7 of 32
Thread 10 of 32
Thread 2 of 32
Thread 30 of 32
Thread 6 of 32
Thread 3 of 32
Thread 14 of 32
Thread 21 of 32
Thread 28 of 32
Thread 1 of 32
Thread 4 of 32
Thread 12 of 32
Thread 23 of 32
Thread 13 of 32
Thread 8 of 32
Thread 18 of 32
Thread 25 of 32
Thread 24 of 32
Thread 0 of 32
Thread 5 of 32
Thread 20 of 32
Thread 9 of 32
Thread 15 of 32
Thread 16 of 32
Thread 31 of 32
Thread 22 of 32
25
29
2
19
4
16
26
24
14
22
28
11
15
13
8
10
5
31
18
3
6
21
9
30
1
23
27
20
17
7
12
0
0 sends to 25
0 receives from 31
7 sends to 24
7 receives from 29
16 sends to 5
16 receives from 5
1 sends to 29
1 receives from 24
10 sends to 28
10 receives from 15
2 sends to 2
2 receives from 2
9 sends to 22
9 receives from 22
11 sends to 11
11 receives from 11
4 sends to 4
4 receives from 4
13 sends to 13
13 receives from 13
5 sends to 16
5 receives from 16
8 sends to 14
8 receives from 14
12 sends to 15
12 receives from 30
22 sends to 9
22 receives from 9
28 sends to 17
28 receives from 10
29 sends to 7
29 receives from 1
23 sends to 30
23 receives from 25
14 sends to 8
14 receives from 8
15 sends to 10
15 receives from 12
27 sends to 20
27 receives from 26
24 sends to 1
24 receives from 7
17 sends to 31
17 receives from 28
19 sends to 3
19 receives from 3
26 sends to 27
26 receives from 6
31 sends to 0
31 receives from 17
30 sends to 12
30 receives from 23
18 sends to 18
18 receives from 18
6 sends to 26
6 receives from 20
25 sends to 23
25 receives from 0
20 sends to 6
20 receives from 27
21 sends to 21
21 receives from 21
3 sends to 19
3 receives from 19
0	39.4335
0	37.4465
0	37.2798
0	37.2113
0	35.9472
0	38.4303
0	34.6286
0	33.3051
0	35.9792
0	35.0983
0	33.633
0	33.5301
0	35.7526
0	32.9331
0	32.2535
0	32.7477
0	35.7469
0	35.1697
0	34.6456
0	31.6672
0	32.5814
0	38.2485
0	37.2737
0	35.5282
0	35.2757
0	35.0448
0	34.7873
0	34.0706
0	32.7843
0	38.6461
0	37.0808
0	34.4033
0	32.3659
0	35.9674
0	35.9411
0	35.4802
0	35.4103
0	35.0743
0	33.2117
0	37.8183
0	33.8016
0	33.2063
0	32.7768
0	32.4473
0	30.0234
0	37.3242
0	35.1007
0	34.5919
0	34.1607
0	33.8841
0	33.6074
0	32.4497
0	32.036
0	35.8695
0	33.8839
0	33.8276
0	32.8119
0	33.1465
0	33.0343
0	37.043
0	34.4426
0	33.3834
0	32.7427
0	35.4457
0	34.106
0	32.3154
0	35.8589
0	32.4972
0	33.9618
0	34.5541
43.856 ± 5.08138
0	32.4958
0	32.2942
44.4611 ± 4.59715
43.6212 ± 5.06164
0	31.8684
0	36.3232
0	35.5119
0	35.2416
0	32.3368
0	39.4269
0	38.2033
0	34.8676
0	33.7103
0	34.7321
0	33.0289
44.4099 ± 4.88333
43.4963 ± 4.92307
42.6394 ± 5.1778
43.6626 ± 5.17558
42.593 ± 5.23327
0	32.9209
43.0467 ± 5.05863
0	33.0075
43.6964 ± 5.49852
0	38.2241
0	36.1042
0	35.5459
0	35.4952
0	35.2529
0	34.8073
0	34.6919
0	34.6709
0	34.612
0	34.3481
0	33.7505
0	33.4588
0	34.2599
0	34.4722
0	34.1609
42.7649 ± 5.2287
44.0203 ± 4.8921
0	36.2628
0	36.1558
0	36.0746
0	35.8431
0	34.1114
44.2541 ± 4.66193
43.0893 ± 5.17976
0	37.5944
0	36.7649
0	36.1881
0	34.96
0	34.1767
0	33.6831
0	33.5721
0	33.314
0	32.8579
0	32.6655
0	32.6031
44.339 ± 4.47087
0	32.1752
0	31.7057
0	39.3377
0	37.2863
0	35.7816
0	35.4852
0	34.8466
0	33.949
0	37.8577
0	36.9998
0	36.9344
0	36.4072
0	35.9728
0	35.6643
0	37.3589
0	36.9067
0	36.807
0	35.8438
0	34.658
0	34.5339
0	33.9236
0	36.8389
0	35.4536
42.7406 ± 5.29245
0	33.7329
44.5891 ± 4.41495
0	34.6521
0	34.1427
0	32.3721
0	35.1895
0	32.6655
0	33.1017
0	32.8334
44.4239 ± 4.9234
0	35.0012
43.935 ± 4.94535
44.3803 ± 4.75632
44.4874 ± 4.4788
0	39.3914
0	38.9496
0	38.8985
0	36.6609
0	34.4862
0	34.2855
0	34.0762
0	33.6812
0	32.0015
0	38.5397
0	35.6967
0	35.1196
0	34.4965
0	34.4698
0	34.4229
0	34.1285
0	33.3407
43.9363 ± 5.40393
0	35.9948
0	35.134
0	32.9879
0	38.2003
0	35.6926
0	34.6482
0	34.4333
0	34.0615
0	32.963
43.2087 ± 4.74448
0	32.3507
0	32.8742
0	31.7675
43.1141 ± 5.37452
42.9274 ± 5.25717
0	34.8464
0	34.3097
0	33.1821
0	33.1709
0	32.6938
0	32.6731
0	32.5135
0	32.0154
0	31.9314
0	31.6261
0	40.1275
0	38.2052
0	34.4989
0	33.0116
0	32.9378
0	31.5806
0	30.9593
0	36.3792
0	33.4828
0	33.3575
0	32.6869
0	31.7791
43.278 ± 5.71306
43.2585 ± 5.31997
0	31.1472
43.6975 ± 5.41173
0	36.8174
0	36.3004
0	35.6496
0	34.3879
0	34.242
0	34.0766
0	33.8182
0	33.7142
0	32.8633
43.9435 ± 4.78053
0	37.7814
0	37.075
0	36.8701
0	36.5877
0	35.7937
0	35.1229
0	34.3034
43.8956 ± 4.45373
0	35.5458
0	35.109
0	34.8847
0	34.5176
0	34.1001
45.1738 ± 4.44137
0	38.6555
0	37.478
0	37.4292
0	35.9079
0	35.3394
0	33.4315
0	32.5879
43.7592 ± 4.69233
1	32.4567
1	32.39
1	32.2148
1	31.8884
1	31.5887
1	31.3862
1	30.8977
1	32.5951
1	31.6042
1	30.8437
1	30.7913
1	30.2185
1	30.7201
40.2445 ± 4.96926
1	29.7819
1	32.7376
1	31.1196
40.3275 ± 5.38782
1	30.9094
1	32.0073
1	31.8094
1	30.8661
1	31.3053
1	31.2997
1	31.2995
1	29.4028
1	30.6664
1	29.7538
1	31.7562
1	31.625
1	31.4042
1	30.2607
1	29.9443
1	31.6075
1	31.4739
1	31.1283
1	31.0537
1	32.2181
1	31.9156
1	31.8021
1	30.7254
1	31.4285
1	31.155
1	30.419
39.7736 ± 4.95579
1	31.0184
1	30.227
39.5896 ± 4.90128
1	32.5503
1	32.2874
1	32.2555
1	32.1495
1	30.116
1	32.0533
1	31.759
39.8239 ± 5.1756
1	30.1254
1	31.6572
1	30.7581
40.3025 ± 5.23254
39.084 ± 4.97283
1	33.6181
1	30.0587
1	33.1495
1	33.0558
1	32.6148
1	31.8412
1	31.3413
1	34.8791
1	34.8195
1	34.4554
1	34.082
1	34.0459
1	33.851
1	33.7471
1	33.6631
1	32.7267
1	33.4111
1	33.3311
1	32.6527
1	31.7743
1	31.8945
1	31.6983
1	31.6854
1	31.4512
1	31.3968
1	31.33
1	30.6393
1	30.44
1	31.7741
1	30.6281
39.4764 ± 4.9091
1	29.5948
1	31.2232
1	31.3853
1	31.0252
1	30.49
1	30.1067
1	29.9199
1	29.5015
1	29.3822
1	29.1172
1	28.7546
41.372 ± 4.60203
1	29.7159
40.0173 ± 5.06879
1	30.6447
40.4436 ± 5.38742
41.6907 ± 4.55789
39.1715 ± 5.88147
39.5114 ± 5.19502
40.5838 ± 4.97798
1	32.3005
1	32.2935
1	31.8526
1	31.718
1	31.7048
1	31.1685
1	31.0876
1	30.8193
1	33.7714
1	31.4928
1	32.8652
1	32.8199
1	32.041
1	30.5645
1	30.1853
1	31.6973
1	31.0255
1	32.0009
1	31.2184
1	31.0253
1	30.8007
1	30.6744
1	29.8921
40.9806 ± 4.49895
39.755 ± 4.93184
1	30.9071
40.4995 ± 5.12605
40.2308 ± 5.03789
1	33.0165
1	32.8925
1	32.8625
1	31.4225
1	30.6252
1	30.2201
1	30.561
1	28.8148
1	28.7999
1	32.2873
1	32.2599
1	32.2497
1	32.1834
1	31.9164
1	31.8804
1	31.7415
1	31.6028
1	31.6021
1	31.5004
1	28.6231
1	30.9725
1	28.4068
40.3701 ± 5.09556
40.0235 ± 4.62308
1	34.4302
1	34.0897
1	33.3716
1	33.611
1	33.2593
1	32.5882
38.8021 ± 5.65522
1	32.5536
1	32.5203
1	32.979
1	31.8272
1	31.0852
1	31.077
1	30.7321
1	30.4676
1	29.6676
41.1847 ± 4.50986
41.738 ± 4.53904
1	31.719
1	31.1877
1	29.9442
39.9468 ± 5.62957
1	29.6141
39.2891 ± 5.40465
1	30.6563
1	29.0543
1	31.7868
1	30.5246
1	30.4897
1	32.7834
1	32.5988
1	32.5421
1	32.3018
1	32.1926
1	31.8062
1	31.5803
1	30.7016
1	28.9144
1	30.0454
1	29.7083
39.5864 ± 5.4173
39.6205 ± 5.19308
40.6288 ± 4.90347
1	33.7396
1	33.5556
1	33.3586
1	33.082
1	32.8487
1	34.2445
1	33.8208
1	33.18
1	33.1579
1	33.0105
1	32.4894
1	32.623
1	32.1523
1	31.8388
42.0195 ± 4.71194
1	31.5555
40.6633 ± 4.52249
1	32.5615
1	32.4233
1	32.2158
1	31.5933
1	31.3508
1	31.1706
1	30.9933
40.0959 ± 5.02271
2	30.5954
2	30.4818
2	29.4605
2	29.3039
2	28.764
37.1036 ± 4.74229
2	29.4043
2	28.252
2	28.1831
2	30.0886
2	30.0367
2	29.9519
2	29.6109
2	29.4419
2	28.2873
2	30.0865
2	29.6123
2	29.3546
2	29.7092
36.719 ± 5.28818
2	29.4351
2	29.1804
2	29.1034
2	28.6511
2	28.9352
2	28.2719
2	29.5332
2	29.3558
2	29.0268
2	28.8526
2	30.2569
36.3571 ± 4.80069
2	28.6455
2	28.2611
2	28.1099
2	30.2548
37.3379 ± 5.11713
36.5346 ± 4.51444
2	32.5484
2	32.4164
2	32.2769
2	31.5362
2	31.2288
36.7097 ± 4.84704
2	29.3487
2	29.035
2	28.3691
2	27.3745
38.2806 ± 4.77714
2	30.5131
39.0432 ± 4.54434
36.1925 ± 4.7309
2	28.1493
2	28.1118
2	28.0972
2	27.7633
2	30.8959
2	29.8851
2	27.6419
2	27.6135
2	27.2286
2	29.7713
2	27.111
2	29.5929
2	29.4821
2	29.353
2	29.1841
35.7856 ± 5.41688
2	28.6544
2	29.3942
2	29.3929
2	29.8892
2	29.6608
2	29.2226
2	29.3104
2	29.3009
37.4808 ± 4.7931
2	29.2674
2	29.2215
2	29.0357
2	29.2197
2	28.9662
2	29.0277
2	28.6163
2	28.9495
2	28.9391
2	28.8512
2	27.9486
2	28.227
37.0023 ± 5.04734
37.4432 ± 4.78424
36.6951 ± 4.6874
2	30.3772
2	29.1162
2	28.7159
2	30.212
2	27.6944
2	29.9633
2	29.709
2	29.307
2	28.5832
2	27.6751
2	28.4906
2	32.3016
2	32.2868
2	30.9757
36.2614 ± 4.90001
37.5565 ± 4.83067
2	28.0531
2	27.9962
2	27.2389
2	30.9612
2	30.2135
2	27.175
2	30.0233
2	29.9834
2	26.6887
2	29.9528
38.6593 ± 4.44773
35.7026 ± 5.18331
2	29.926
2	29.4219
2	29.4209
2	29.0013
2	28.721
2	28.2868
2	28.2008
37.7071 ± 4.76334
36.9291 ± 5.12822
2	29.8844
2	29.8584
2	29.4764
2	29.4061
2	29.3009
2	29.1509
2	28.9837
2	31.8238
2	31.782
2	31.6009
2	31.554
2	31.1556
2	30.3011
2	28.6802
2	27.1593
2	26.6827
2	26.4868
2	25.8814
2	25.8781
2	25.789
37.0429 ± 4.61009
2	25.671
2	30.0951
38.6621 ± 4.537
35.8847 ± 5.35818
2	29.9555
2	29.6462
2	29.4667
2	29.5271
2	29.5223
2	29.2256
2	28.7462
2	28.3865
2	27.6055
2	29.1892
2	28.0364
35.9851 ± 4.8712
2	29.5775
2	29.2819
36.736 ± 4.9185
2	29.0397
2	28.5861
2	28.8108
2	28.6997
2	28.6428
2	28.4972
2	28.5505
2	28.5108
2	28.0807
2	27.3335
2	28.0639
36.7373 ± 4.98105
2	30.4372
2	29.3348
36.31 ± 5.08588
37.7655 ± 4.79978
2	30.6582
2	30.3429
2	30.2056
2	30.121
2	29.787
2	29.001
2	28.1261
37.48 ± 4.8897
2	32.3294
2	32.2142
2	31.7213
2	31.2284
2	30.9703
39.502 ± 4.63671
2	31.486
2	30.8296
2	30.5176
2	30.4629
2	30.3343
2	30.0743
38.0876 ± 4.3628
2	30.7892
2	30.7686
2	30.6014
3	28.5892
3	28.5815
2	30.1431
3	28.2374
3	27.9673
3	27.8948
2	29.5827
3	27.4874
2	29.2961
3	27.1969
2	28.9133
2	28.7682
37.0994 ± 4.77548
34.5288 ± 4.53905
3	29.9284
3	29.189
3	29.0175
3	28.1624
3	27.4474
3	28.8955
3	28.1229
3	27.9057
3	27.155
3	27.3784
3	28.5457
3	27.3498
3	28.5439
3	27.0181
3	28.5427
3	26.8937
3	28.358
3	27.1332
36.0576 ± 4.49937
34.0939 ± 4.60229
3	26.8622
34.5213 ± 4.57549
3	30.2408
3	30.2275
3	30.1295
3	29.7673
3	29.4646
3	29.1581
3	29.1054
3	28.8127
3	28.352
3	27.2466
3	27.1991
3	26.8801
3	26.5908
3	26.5544
3	27.1578
3	28.474
36.8935 ± 4.28689
3	27.1151
3	29.1775
3	29.1316
3	29.0462
3	28.9563
3	28.6992
3	28.2229
3	26.066
3	26.9973
34.4026 ± 4.64838
3	28.1929
35.153 ± 4.46898
33.4749 ± 4.57459
3	28.097
3	27.9599
3	27.6989
3	27.4781
3	26.839
34.2704 ± 4.64925
3	27.4693
3	27.4639
3	26.2936
3	28.5899
3	28.3131
3	28.0894
3	28.053
3	27.9582
3	28.0756
3	27.6972
3	27.6221
3	27.8533
3	27.4872
3	27.6961
3	27.4587
3	26.7401
33.5426 ± 4.5668
3	26.5155
3	26.3668
3	25.9868
34.4152 ± 4.49962
3	25.8444
3	27.6842
3	27.5498
3	27.5265
3	27.4578
3	27.3037
3	26.5719
35.0272 ± 4.66334
34.4528 ± 4.62551
3	25.6161
33.1371 ± 4.77456
34.1592 ± 4.55623
3	28.1812
3	28.1602
3	28.0762
3	28.0083
3	27.9897
3	27.1608
3	27.0424
34.3003 ± 4.58949
3	27.7859
3	27.6614
3	27.5062
3	29.3809
3	29.2676
3	29.1118
3	27.4836
3	27.4745
3	27.3384
3	26.9788
3	29.0776
3	29.072
3	29.0533
3	28.7972
3	28.5944
3	28.4822
3	27.7746
3	28.8793
3	28.7918
3	28.5521
3	28.1208
3	28.0605
34.3716 ± 4.41847
35.8834 ± 4.30121
3	27.9137
3	26.9995
3	26.9908
3	26.664
3	26.2689
3	25.5823
3	25.4975
3	25.4933
3	25.3691
3	25.2789
3	26.1121
34.8496 ± 4.36712
3	25.2056
3	25.1136
3	26.001
3	26.8106
3	26.5843
3	25.7613
3	24.8925
33.4418 ± 4.57127
3	25.2082
3	24.393
3	30.9547
3	30.815
3	30.0685
3	29.5847
32.7093 ± 5.0521
3	24.8247
32.9325 ± 4.97668
3	29.4889
3	29.3425
3	28.6999
36.5808 ± 4.29503
3	29.2921
3	28.9376
3	28.9033
3	28.4341
3	28.0256
3	27.7971
3	27.5995
3	27.4531
3	26.8664
3	27.9662
3	27.6987
3	26.5536
3	27.6455
3	27.6419
3	27.0618
3	29.9156
3	29.8624
3	29.8588
3	28.3327
3	29.2923
3	29.2658
3	29.042
3	26.7264
3	28.7926
3	28.4961
34.1091 ± 4.78403
3	28.0975
35.3213 ± 4.57146
34.2638 ± 4.65308
3	28.2233
35.6001 ± 4.39951
3	27.2216
3	27.1187
3	26.9933
3	26.5983
3	26.4283
33.6623 ± 4.89772
3	30.0662
3	29.9773
3	29.9336
3	29.7838
3	29.6359
3	29.1455
3	28.8106
3	28.4651
35.791 ± 4.26681
3	28.0054
3	27.8245
3	27.3165
3	27.2863
3	26.9206
3	25.6745
35.3391 ± 4.87335
3	30.5969
3	30.5224
3	30.4903
3	30.3107
3	30.0665
3	29.6124
3	29.1607
3	29.1433
37.0338 ± 4.69508
4	28.0316
4	27.9371
4	27.727
4	27.5408
4	27.4434
4	25.907
4	25.8516
4	27.0635
4	26.2868
4	26.0343
4	25.35
4	26.2999
34.0294 ± 4.2598
4	25.8724
4	25.2294
4	25.7168
4	25.1624
32.6959 ± 4.21567
32.6355 ± 4.18697
4	27.0628
4	27.0582
4	27.0444
4	26.4002
4	26.0456
4	25.7185
4	25.4752
4	28.0323
4	27.9303
4	27.8139
4	27.7415
4	27.6959
4	27.6958
4	27.4123
4	26.9138
4	25.8253
4	25.7727
4	25.6741
4	25.4969
4	25.1253
4	24.2758
32.5893 ± 4.23161
31.4152 ± 4.41455
33.3514 ± 4.23531
4	26.4743
4	26.2608
4	26.2539
4	25.9317
4	25.8698
4	25.603
4	25.204
32.3016 ± 4.33008
4	25.1377
4	24.9156
4	26.8374
4	26.7957
4	26.4254
31.5926 ± 4.24164
4	26.4183
32.5481 ± 4.17707
4	26.9739
4	26.6517
4	26.8388
4	26.5711
4	26.0743
4	26.0294
4	26.5284
4	25.5881
4	25.4216
4	25.0709
4	24.9141
4	26.2501
4	24.4912
4	26.0064
32.3158 ± 4.35181
4	24.461
32.975 ± 4.48395
31.212 ± 4.45805
4	26.3595
4	25.9753
4	25.9006
3	28.6299
3	28.2404
4	26.8804
4	26.289
3	28.2183
4	26.1822
4	26.0242
3	28.1357
3	28.0205
3	27.9493
32.2813 ± 4.25735
3	27.7349
4	26.9406
4	26.9178
4	26.7827
4	26.586
4	26.5615
4	25.9514
4	26.3467
4	25.8406
4	26.3638
4	26.2011
4	25.9857
4	25.7472
4	24.5339
32.5438 ± 4.17297
4	25.808
3	27.3543
34.8574 ± 4.42775
32.5814 ± 4.31054
4	25.8612
4	25.7578
4	25.4507
32.2633 ± 4.5115
4	25.1943
4	25.1472
4	24.9726
31.6133 ± 4.272
4	24.7776
4	24.5352
4	24.3254
4	24.2906
4	23.5471
4	26.7134
4	26.6902
4	26.4305
4	23.4601
4	26.3665
4	25.3138
4	24.2322
30.8418 ± 4.3886
30.3723 ± 4.63811
32.328 ± 4.36105
4	26.4181
4	26.413
4	26.1951
4	26.1643
4	26.116
4	25.933
4	25.9197
4	25.7306
4	27.9417
4	27.9194
4	27.407
4	27.3106
4	27.1968
4	27.1926
4	24.3402
4	27.6503
4	27.0415
4	27.2155
4	28.3164
4	28.1616
4	28.1355
4	27.9627
4	27.2558
4	26.908
33.3023 ± 4.275
32.3511 ± 4.36419
4	28.1853
4	28.0158
4	27.5897
4	27.258
34.6209 ± 4.12111
4	26.9718
4	26.6707
4	26.5759
4	26.0048
4	26.9479
4	25.6026
4	26.8582
34.0118 ± 4.11833
33.98 ± 4.29657
4	26.6843
4	26.6785
4	25.3525
33.6665 ± 4.22116
4	25.2856
32.2517 ± 4.3926
4	26.2532
4	25.7203
4	24.9498
31.7326 ± 4.55764
4	28.2193
4	28.1704
4	27.4887
4	27.3337
4	26.8744
34.9512 ± 4.43373
4	28.2235
4	27.8414
4	27.6763
4	27.4657
5	25.9735
5	25.9215
5	25.8139
5	25.7132
5	25.0698
4	27.4044
4	26.9809
33.7755 ± 4.03818
5	24.7479
31.7554 ± 4.23259
5	24.9865
5	24.619
5	24.5717
5	24.4124
5	25.645
5	25.5609
5	25.3404
5	25.062
5	24.9049
5	24.8951
5	23.4751
4	25.6375
5	24.8703
4	25.3673
4	25.2441
4	25.1364
5	25.3463
5	25.1496
5	24.6883
31.1246 ± 4.05056
4	25.1127
30.914 ± 4.19483
4	24.1497
5	26.8597
5	26.8149
5	26.481
5	26.4737
5	26.1024
32.7035 ± 4.92983
5	25.4617
30.8276 ± 4.20543
31.8004 ± 4.05907
5	24.1559
5	24.1168
5	24.0258
5	23.9334
5	23.8755
5	23.5551
5	23.1749
5	23.1147
29.5896 ± 4.26849
5	26.1903
5	25.9817
5	25.9351
5	25.8574
5	25.6481
5	25.5922
5	25.309
31.0794 ± 4.01886
5	26.2274
5	26.1062
5	25.5316
5	25.4611
5	25.3206
5	25.7439
5	25.3037
5	26.2176
5	25.75
5	25.277
5	25.5459
5	25.4961
5	25.3948
31.4582 ± 4.18412
5	25.1281
5	25.1174
5	25.0712
5	25.0771
31.1643 ± 3.93984
30.8142 ± 4.05028
5	24.1173
5	23.8178
5	23.6841
30.5235 ± 4.11253
5	25.198
5	24.3666
5	24.1144
5	23.9272
5	25.3126
5	24.8166
5	24.6712
31.1165 ± 3.95799
5	23.7596
29.9059 ± 4.17268
5	24.0517
5	24.5071
5	23.7025
5	23.6773
5	26.4754
5	26.3927
5	26.0826
30.5392 ± 4.04588
5	25.8584
5	23.5965
5	25.6785
5	25.617
5	25.5533
29.7126 ± 4.01152
5	25.1719
5	23.8153
5	24.1567
5	24.1134
5	23.4208
5	23.3577
5	25.3269
5	25.1945
5	25.1043
5	24.8147
5	27.1811
5	27.1648
5	27.0903
5	26.9928
5	26.8886
5	23.7363
5	23.3728
5	23.317
5	26.4642
5	26.4169
32.0289 ± 4.0993
5	23.9202
5	23.6237
5	22.8904
5	22.6815
5	23.4367
5	26.2151
5	26.0449
5	26.3727
5	26.0184
5	25.9926
5	25.849
5	26.0089
5	25.1436
5	25.048
5	24.9758
5	23.9764
5	22.4205
5	25.7741
5	24.6676
5	25.959
30.1301 ± 4.40815
5	25.6983
30.8827 ± 4.27434
32.6685 ± 4.05252
28.756 ± 4.35535
5	25.9446
5	25.8796
5	25.5694
5	25.153
5	25.1603
30.2256 ± 4.43409
5	25.0241
5	25.0418
31.8812 ± 4.2236
5	25.0081
30.6043 ± 4.29069
5	24.7086
5	24.5384
5	24.8908
5	24.1659
5	24.8378
30.7011 ± 4.08944
30.3067 ± 4.10004
4	27.0184
5	26.7399
5	26.5639
5	26.19
4	27.0086
5	25.7019
4	26.6857
4	26.65
5	26.1803
5	25.9532
33.1125 ± 4.21574
32.0738 ± 4.1422
32.6137 ± 4.01122
5	24.9486
5	24.2972
5	24.2763
5	23.9696
5	23.8247
5	23.6623
29.9833 ± 4.36961
5	26.5693
5	26.542
5	26.4506
5	26.37
5	25.6375
5	25.5961
5	25.2187
5	25.0378
32.3962 ± 4.40838
5	26.3979
5	26.2691
5	26.2102
5	25.9234
5	25.8803
5	25.8071
31.9497 ± 4.04802
6	24.5328
6	24.1165
6	24.0422
6	23.8304
6	23.5691
6	24.6479
6	24.6149
6	24.5734
6	24.5542
6	24.3627
6	23.1885
30.6405 ± 3.98274
6	25.2077
6	25.0855
6	24.9929
29.4609 ± 4.09592
31.0129 ± 3.84978
6	23.4623
6	23.4249
6	22.9318
6	24.7868
6	24.7055
6	24.3623
6	22.8972
6	23.9609
6	22.5074
6	23.9378
29.2668 ± 4.15436
29.9085 ± 4.03909
6	25.0242
6	24.9334
6	24.9078
6	24.8997
5	23.9382
5	23.4368
5	23.373
6	23.9806
5	23.3665
29.9641 ± 3.93882
30.2959 ± 4.71901
6	25.072
6	24.4286
6	23.8187
6	24.4743
6	24.3992
6	24.3304
6	24.0488
6	23.793
6	23.7351
29.5588 ± 3.8923
6	22.3868
6	22.331
30.1575 ± 4.06207
6	24.9335
6	24.8186
6	24.7985
6	24.6193
6	24.4917
6	21.2335
28.3355 ± 4.19624
6	24.3568
6	24.259
30.1664 ± 3.77248
6	23.6677
6	23.574
6	23.5554
6	23.4162
6	23.4142
6	23.3253
6	23.3051
6	23.2007
29.4123 ± 4.11923
6	24.8646
6	24.7646
6	24.7241
6	24.6046
6	24.5437
6	24.28
6	23.9971
6	23.2553
6	22.6991
6	23.6626
6	22.2598
6	24.8166
6	24.6957
6	24.3905
6	24.0162
6	23.9298
30.4752 ± 4.14363
28.1334 ± 4.35945
6	23.8771
30.2353 ± 4.2422
6	24.6463
6	24.5021
6	24.2654
6	24.1758
6	23.6731
6	23.5856
6	24.1383
6	23.386
6	24.1356
6	22.6911
29.6566 ± 4.11882
29.151 ± 4.25682
6	23.1656
6	23.1433
6	23.0603
6	23.0415
6	22.5039
5	26.5161
5	25.9184
5	25.8323
5	25.7283
5	25.6701
5	25.225
6	22.3889
31.7225 ± 4.00304
6	24.9415
6	24.8042
6	23.8795
6	23.7677
28.6218 ± 3.91608
6	23.5971
6	23.2903
6	22.8772
6	22.7695
6	22.7516
6	24.2506
6	22.6333
6	22.4524
6	23.4477
29.6388 ± 3.87633
6	22.023
30.5578 ± 4.06613
6	25.7383
6	25.6131
6	25.4461
28.5292 ± 4.21193
6	25.1703
6	25.1377
6	23.944
6	23.7447
6	23.4472
31.1484 ± 3.99817
6	24.4377
6	23.4264
6	24.3626
6	23.6835
6	23.4517
6	24.1618
6	23.5346
6	23.5003
6	23.1697
6	23.5145
6	22.9888
6	22.9746
6	21.6407
6	21.5431
29.6191 ± 4.07807
6	23.3099
6	22.7829
6	23.4321
29.1112 ± 3.95487
6	22.3012
28.3754 ± 4.13281
29.4879 ± 3.98827
27.3948 ± 4.19188
6	25.918
6	25.7389
6	25.1946
6	25.0632
6	24.734
31.1898 ± 4.09735
6	23.4386
6	23.2872
6	23.2073
6	23.0097
6	22.854
6	22.724
6	22.6308
6	22.3888
28.4587 ± 4.04701
6	24.8791
6	24.6141
6	24.3513
6	24.3038
6	24.1139
6	23.635
30.5043 ± 4.37163
6	24.6664
7	23.1551
7	23.1482
7	22.7077
7	22.577
7	22.555
7	22.5287
7	23.5152
7	23.513
7	23.5032
7	23.3075
7	23.238
7	22.8511
6	24.4902
7	24.5085
7	24.4018
7	23.9328
7	23.5303
7	23.2456
27.997 ± 4.10711
7	23.2452
7	23.0608
30.5544 ± 3.87721
7	22.9296
29.1422 ± 3.98274
29.6381 ± 3.83756
7	23.9233
7	23.9191
7	23.8506
7	23.4359
7	23.4297
7	23.3138
28.78 ± 4.04512
7	23.7125
7	23.6681
7	23.4195
7	23.329
7	23.2619
7	23.0596
7	22.9436
7	22.6968
28.878 ± 4.14752
7	23.3257
7	23.1961
7	23.1694
7	22.8746
7	22.8498
6	23.2694
6	23.2057
6	23.1231
6	22.5898
7	21.0538
7	20.8539
7	20.7946
7	23.6728
7	23.4326
7	20.2321
7	22.979
28.526 ± 3.8898
28.5772 ± 4.39323
26.7913 ± 4.43313
29.0851 ± 3.80392
7	23.1893
7	23.1241
7	22.8469
7	22.4684
7	22.3871
28.7115 ± 4.02075
7	23.554
7	23.5414
7	23.3277
28.7727 ± 4.20834
7	23.9719
7	23.9046
7	23.7669
7	23.6891
7	23.3226
7	23.766
7	23.7172
7	23.6687
7	23.6018
7	23.3696
7	23.3453
7	23.1749
7	22.9855
7	23.4458
7	23.2692
7	22.7608
7	22.2698
7	22.0737
7	22.0122
7	22.1341
7	21.5223
7	21.1257
7	23.2453
28.69 ± 4.06517
7	22.5069
7	22.454
6	24.6863
7	22.3743
7	22.1741
6	24.4125
28.7443 ± 3.92185
7	22.0585
26.7799 ± 4.14542
7	21.9761
7	22.6831
27.9548 ± 4.06582
29.0941 ± 4.13061
6	24.0354
30.2847 ± 4.02933
7	21.5491
27.7455 ± 4.2181
7	22.2682
7	21.8826
7	24.0778
7	23.8979
7	21.8356
7	22.1172
7	22.0526
7	21.3536
7	23.8922
27.5415 ± 4.029
29.9205 ± 3.90631
7	22.7666
28.0749 ± 3.79288
7	23.0946
7	22.5774
7	22.2338
7	22.7301
7	22.4012
7	22.2817
28.1441 ± 3.95867
7	22.2265
7	22.0263
7	23.0541
7	23.0173
28.8862 ± 3.97515
7	22.7988
7	24.8653
7	24.7918
7	24.6418
7	24.5867
7	24.5607
29.2045 ± 3.91228
7	23.6668
7	23.493
7	23.4022
7	23.9319
7	21.4034
30.0423 ± 3.95874
29.8041 ± 4.05819
7	21.3928
7	20.7022
7	21.623
7	21.609
7	20.9287
26.2238 ± 4.16056
7	20.8709
27.3549 ± 4.14279
7	23.1416
7	22.7588
7	22.5932
7	22.2503
7	22.2533
7	22.1033
7	21.809
7	21.5827
7	21.4836
28.2898 ± 4.14762
27.161 ± 4.07712
7	23.2669
7	22.9764
7	22.7498
7	22.6544
7	22.2537
28.9207 ± 4.39504
8	22.4883
8	22.2397
8	22.2208
8	22.0691
8	21.9641
8	22.7463
8	22.3759
8	22.3538
26.9178 ± 4.04926
8	22.2486
8	22.095
28.3163 ± 3.97746
7	24.4557
7	24.3381
7	24.311
7	23.7388
7	23.4769
8	23.1215
8	22.9649
7	23.3191
8	22.8299
8	22.4172
8	22.2701
27.9826 ± 3.98933
29.2631 ± 3.91001
8	22.5056
8	22.4213
8	22.284
8	22.2791
8	22.1287
27.7053 ± 3.89569
8	20.1729
8	20.1456
8	20.0946
8	20.0333
8	19.8265
8	22.6916
8	22.4899
8	22.0231
8	21.7463
25.5052 ± 4.3942
8	22.0333
8	21.9271
8	22.6146
8	22.546
8	22.348
8	22.2296
8	21.4207
8	22.0597
27.9429 ± 4.00858
7	22.2732
27.6315 ± 4.15549
7	22.1354
27.6964 ± 4.15465
7	21.8867
27.2998 ± 4.22943
8	22.8611
8	22.3928
8	22.2976
8	21.9606
27.8485 ± 3.9362
7	23.9836
7	23.5103
7	23.4386
8	22.6789
8	22.359
8	23.2241
8	22.9993
8	22.8957
8	22.29
8	21.9588
8	22.3575
29.0698 ± 3.93069
8	21.5729
8	21.0265
8	22.2115
8	21.651
27.8932 ± 4.1424
27.8817 ± 3.95946
8	21.2625
8	21.0168
26.8783 ± 4.09756
8	23.2171
8	23.0623
8	22.8848
8	22.7258
8	22.6602
8	22.6524
27.8069 ± 4.0308
27.6426 ± 4.09129
8	20.9559
8	20.5621
8	21.3349
8	20.9675
8	20.7987
8	20.4166
25.5643 ± 4.09412
27.3681 ± 3.781
8	20.2697
26.7339 ± 4.11747
8	21.2699
8	23.3334
8	22.8299
8	22.82
8	22.6979
27.4424 ± 4.00891
8	23.7111
8	23.5514
8	23.5211
8	23.4548
8	23.3003
28.4396 ± 4.19048
8	23.2572
8	23.1771
28.7432 ± 3.93453
8	20.621
8	22.6795
8	22.6308
8	22.6101
8	22.6097
8	21.4022
8	21.3474
8	22.044
8	21.7527
8	20.6216
8	20.5058
8	20.0535
8	20.593
8	21.6574
8	21.1344
8	20.8853
8	20.3541
8	20.241
8	20.7888
8	20.1593
26.3661 ± 4.08179
8	21.3485
8	21.0429
8	20.9009
8	20.8011
25.2441 ± 4.14774
8	22.095
27.997 ± 3.98056
8	21.4344
26.1312 ± 4.12795
8	21.7143
8	21.5213
8	21.4319
8	20.6465
27.0615 ± 4.19388
26.4724 ± 4.17572
27.8292 ± 4.1129
8	22.1622
8	22.0192
8	21.8634
8	21.7295
8	21.5238
8	21.3686
27.3792 ± 4.33804
9	21.4793
9	21.4058
9	20.9707
8	23.8854
8	23.8786
8	23.5033
8	23.2702
8	23.2336
8	23.0367
27.1929 ± 4.01326
9	21.8521
9	21.7225
9	21.7076
28.7304 ± 3.926
9	21.6751
9	21.6385
9	21.5472
9	21.3051
26.2461 ± 3.95307
9	22.0153
9	21.7747
9	21.6839
9	21.6575
9	21.2531
27.3923 ± 3.87328
8	23.2723
8	23.1992
8	23.1962
8	23.105
8	23.0925
8	22.5729
8	22.3009
9	19.8051
9	19.6613
9	19.6349
9	19.5812
8	21.778
9	19.0649
24.5949 ± 4.29249
28.1417 ± 3.94675
9	21.6299
9	21.5866
9	21.5536
9	21.5431
9	22.0112
9	21.9822
9	21.8897
9	21.7726
9	21.4224
26.9427 ± 4.07273
8	21.8765
8	21.3459
27.0954 ± 3.95702
8	21.1424
8	21.0736
8	21.0121
9	21.6924
9	21.3903
9	21.6121
9	20.9614
9	21.3157
26.2139 ± 4.06097
9	21.1342
9	21.0727
9	20.8758
9	22.2574
9	22.0494
9	21.9616
9	21.9353
9	21.6869
26.8291 ± 4.11086
26.741 ± 4.06732
9	21.2113
9	20.9344
26.9809 ± 4.02061
9	22.0265
9	21.8803
9	22.5668
9	22.1328
9	21.1172
9	21.7076
9	20.6286
8	23.3222
8	22.6597
9	20.4482
9	20.2994
8	22.4577
27.091 ± 4.11228
9	20.2198
9	20.1753
26.988 ± 4.0701
28.168 ± 3.92933
9	21.1203
9	21.0921
25.7045 ± 4.13862
9	20.745
9	20.5775
9	21.067
9	20.9625
9	20.5511
9	20.8083
9	20.7292
26.4155 ± 4.29995
26.5266 ± 4.23558
9	20.8919
9	20.8402
9	20.2365
9	19.8998
9	19.8187
26.2738 ± 3.97624
9	20.322
9	20.2471
9	20.1963
9	20.1207
9	20.0576
9	19.6094
9	21.1759
9	21.1675
9	20.9964
9	20.9835
9	20.7255
24.6877 ± 4.03108
26.4611 ± 4.04578
10 sends to 10
10 receives from 10
6 sends to 6
6 receives from 6
9 sends to 23
9 receives from 4
4 sends to 9
4 receives from 28
13 sends to 27
13 receives from 30
23 sends to 14
23 receives from 9
14 sends to 5
14 receives from 23
20 sends to 2
20 receives from 0
24 sends to 24
24 receives from 24
17 sends to 17
17 receives from 17
26 sends to 22
26 receives from 5
25 sends to 18
25 receives from 12
30 sends to 13
30 receives from 22
20
12
16
3
9
26
6
7
8
23
10
19
25
27
5
31
15
17
28
0
2
11
30
14
24
18
22
1
4
29
13
21
0 sends to 20
0 receives from 19
16 sends to 15
16 receives from 2
2 sends to 16
2 receives from 20
11 sends to 19
11 receives from 21
9	22.5629
9	22.5494
9	22.2732
9	22.2575
9	22.181
9	21.8965
9	22.9142
9	22.7263
9	22.5683
9	22.5044
9	22.3197
9	21.9662
9	21.6167
9	19.6264
9	21.8647
27.9297 ± 3.89357
27.2729 ± 4.1733
9	20.2506
9	20.1029
9	20.0716
9	20.0322
9	19.7689
9	19.5975
12 sends to 25
12 receives from 1
22 sends to 30
22 receives from 26
25.3235 ± 4.10543
28 sends to 4
28 receives from 18
9	21.3519
9	21.1653
9	20.9307
9	19.3184
9	19.3092
9	20.7391
9	21.2237
25.6095 ± 4.27091
9	21.2189
9	21.1205
9	18.8968
26.0363 ± 4.16887
9	20.2419
24.3185 ± 4.1408
29 sends to 29
29 receives from 29
8 sends to 8
8 receives from 8
7 sends to 7
7 receives from 7
26.8552 ± 4.16961
9	20.092
9	19.9888
1 sends to 12
1 receives from 27
25.4738 ± 4.11566
15 sends to 31
15 receives from 16
9	20.7628
9	20.6526
9	20.2181
9	19.9217
9	21.6352
9	21.5382
9	21.4516
9	21.324
9	21.2571
9	21.0955
9	21.411
9	20.9522
25.2786 ± 4.12774
9	21.2823
27 sends to 1
27 receives from 13
9	21.1785
9	20.6694
26.9997 ± 4.05674
26.2079 ± 4.2959
3 sends to 3
3 receives from 3
18 sends to 28
18 receives from 25
9	22.6533
9	22.6477
9	22.6332
9	22.4991
9	22.3618
27.5603 ± 3.96085
31 sends to 21
31 receives from 15
9	21.7499
9	21.6021
9	21.5161
9	21.4921
9	21.4722
9	20.6533
26.8226 ± 4.12986
19 sends to 0
19 receives from 11
9	20.3476
25.8434 ± 3.98915
5 sends to 26
5 receives from 14
10	20.5229
10	20.3523
10	21.0929
10	20.1829
10	21.016
10	21.0128
10	20.9037
10	21.347
10	20.5709
10	20.1765
10	20.1753
10	20.1603
10	19.9906
10	19.8321
10	19.8054
25.6145 ± 4.10913
10	20.7575
10	20.6006
10	20.4593
10	19.5763
26.2074 ± 3.81217
10	20.7069
26.8785 ± 3.9622
10	19.5471
9	22.2726
9	22.1482
9	22.0313
26.2599 ± 3.9171
27.1667 ± 4.1038
9	21.8573
10	20.08
10	19.8518
10	19.6094
10	19.6072
10	19.5045
9	21.4351
27.2438 ± 4.03724
10	19.4807
10	19.4147
10	19.393
10	19.2898
26.2287 ± 4.09841
21 sends to 11
21 receives from 31
10	20.6998
10	20.5137
10	20.4947
10	19.9155
10	18.498
10	18.3452
10	19.0435
10	18.9491
10	18.8981
25.7434 ± 3.89271
23.6116 ± 4.12149
10	17.6416
23.7093 ± 4.29881
10	21.098
10	19.8187
10	19.6519
10	20.2419
10	19.5771
10	20.2224
10	20.0842
26.9362 ± 4.13022
10	20.0476
10	19.913
10	19.6264
10	19.5671
10	19.1994
28.1356 ± 3.97151
10	21.5338
10	21.4223
10	21.1987
26.285 ± 4.18487
10	19.9217
10	19.8917
27.9435 ± 3.92854
10	18.2596
10	19.4936
10	19.4079
10	19.0426
10	19.4802
10	20.9997
10	20.7434
10	20.7277
10	20.7091
10	20.4539
27.2857 ± 3.97469
10	20.2936
10	18.9019
26.1418 ± 4.06544
24.5326 ± 4.31427
27.5397 ± 4.07946
10	20.9378
10	20.8758
10	20.8689
10	20.7405
10	20.263
10	19.5598
10	20.4421
10	20.2222
10	19.8737
10	19.6399
10	20.9278
10	20.6107
10	20.1272
26.734 ± 4.14057
27.4403 ± 4.11827
10	20.5599
25.4926 ± 4.18323
27.7483 ± 4.02416
10	18.4092
10	18.1461
25.0712 ± 3.82645
10	20.2759
10	20.2681
25.9214 ± 3.85398
10	20.2362
10	20.1639
10	20.1289
10	20.1191
10	20.0694
10	19.6967
10	19.537
10	19.4926
10	19.3764
26.6065 ± 4.22547
11	19.7339
11	19.7032
11	19.5747
11	20.7364
11	19.1752
11	20.6187
11	20.5693
11	20.3509
24.9285 ± 4.126
11	20.6403
27.3613 ± 4.09324
11	20.3383
26.1079 ± 4.07648
10	20.4246
10	20.3892
11	19.7979
11	19.6583
10	20.2776
11	19.3744
11	20.8157
11	19.3242
11	19.2176
11	20.6172
11	19.15
11	19.0884
11	20.519
11	19.0255
11	19.0185
26.4196 ± 4.06854
11	19.1696
11	18.9749
11	18.9535
11	18.8806
10	20.184
26.4669 ± 4.09861
26.1471 ± 4.4757
11	18.8136
25.775 ± 3.9108
24.9915 ± 4.22192
11	18.3136
11	18.1844
11	18.1139
23.1653 ± 4.01612
11	17.6202
11	17.5513
11	17.33
11	19.5695
11	19.5531
11	19.4619
11	17.3086
11	19.6599
11	19.0786
11	19.6582
11	16.9455
22.9438 ± 4.26158
27.1887 ± 4.43997
26.0582 ± 4.41891
11	19.6271
25.9414 ± 3.91691
11	19.1822
11	18.9878
11	18.622
11	18.2274
11	18.1277
11	18.104
11	18.044
11	17.801
25.02 ± 4.22077
25.8504 ± 4.42004
11	19.7472
11	19.7117
11	19.625
11	19.6061
11	19.3475
11	19.6398
11	19.5352
11	19.2172
11	20.1895
11	19.9994
11	19.3018
25.0733 ± 3.94735
25.2234 ± 3.95822
25.6373 ± 4.01845
11	19.6219
11	19.5653
11	19.4412
11	20.2621
11	20.1233
11	19.7293
11	19.3858
11	19.6441
11	19.319
11	19.5234
11	19.3941
11	19.0667
11	19.9435
11	19.864
11	19.7501
11	19.6684
11	19.4794
11	19.1251
24.4884 ± 4.11926
11	19.0453
11	18.9832
11	19.1699
11	21.1867
11	21.1008
11	21.0814
11	20.9202
11	20.8626
11	20.7498
26.4774 ± 4.32301
25.5241 ± 4.17839
25.5441 ± 4.1475
27.1228 ± 4.19022
11	18.5639
11	19.546
11	19.4953
11	19.4512
11	19.2051
25.214 ± 4.41093
11	18.7071
11	18.5679
11	18.5599
26.0956 ± 4.36357
11	18.5425
23.7588 ± 4.24563
11	20.3272
11	20.1904
11	19.9009
11	19.5074
26.7946 ± 4.28161
11	17.9594
11	17.8089
11	17.6188
11	17.3507
23.8723 ± 4.17888
11	19.7464
11	19.6258
25.2484 ± 3.95132
12	20.4689
12	20.4553
26.373 ± 4.27928
12	20.2883
12	20.2501
12	20.2496
12	20.1978
12	19.8989
11	20.6328
11	20.5418
11	19.1891
11	19.1652
11	19.1498
11	19.1417
11	18.7971
11	18.756
25.2866 ± 4.15509
11	20.5128
11	18.3476
11	18.2309
12	19.1352
11	20.3355
12	18.7877
26.1454 ± 4.161
24.9327 ± 4.32476
12	18.609
12	18.5834
12	18.4612
12	18.4227
25.3548 ± 4.29297
12	18.1776
11	20.1414
11	19.9141
11	19.8861
24.2844 ± 4.35455
11	19.8041
25.6936 ± 4.1743
12	18.3707
11	21.3692
11	20.9333
12	18.2393
11	20.6942
24.8914 ± 4.62943
27.4412 ± 4.14284
12	18.9487
12	16.8667
12	16.6339
12	16.4415
12	16.239
22.1415 ± 4.37528
24.4542 ± 4.08222
12	19.4508
12	19.4166
12	19.2807
12	19.1413
12	17.6893
12	18.604
12	18.4344
12	18.324
12	18.2068
12	18.1431
26.2502 ± 4.58521
12	17.8996
12	17.3361
23.8553 ± 4.3227
24.3341 ± 4.60124
12	19.0328
12	18.9647
12	18.8317
12	19.7296
12	19.611
12	19.597
12	18.65
12	18.0822
12	18.0168
12	17.9531
12	19.5012
12	18.2316
12	17.8845
12	19.458
12	19.1142
12	19.2949
24.2045 ± 4.19948
12	19.1957
12	19.0944
12	18.476
12	19.6888
12	19.6852
25.1824 ± 4.16206
12	19.3563
24.9612 ± 4.11744
22.7023 ± 4.06139
23.6866 ± 4.12936
12	18.9763
12	18.7609
12	18.5685
24.5122 ± 4.27933
12	20.1176
12	18.9548
12	18.602
12	18.7841
12	18.6865
12	18.6854
12	20.0537
12	18.283
25.1298 ± 3.98423
12	18.4101
12	18.1897
25.0077 ± 4.57132
24.2977 ± 4.27217
12	18.4674
12	18.042
12	17.9262
24.1659 ± 4.52477
12	18.8956
12	18.7503
12	19.1386
12	19.0294
12	19.0117
12	18.988
12	18.358
12	18.977
12	18.9581
12	18.7338
24.9082 ± 4.48166
12	18.9645
24.8603 ± 4.38232
24.4275 ± 4.15758
12	19.4934
12	19.4005
12	18.4644
12	18.4238
12	18.3733
12	18.1953
12	18.1709
12	19.3933
25.4944 ± 4.47153
23.2883 ± 4.12123
12	17.0877
12	17.0565
12	16.8382
22.7389 ± 4.37385
12	20.6793
12	20.6575
12	20.6432
12	20.2568
12	20.2536
26.3832 ± 4.18094
13	20.3087
12	19.5846
12	18.9423
12	18.914
13	20.2425
25.8644 ± 4.27634
24.5397 ± 4.16228
12	20.1574
12	20.0658
12	19.8178
25.477 ± 4.23519
13	17.6518
13	17.4532
13	19.6241
13	19.5284
23.4953 ± 4.19031
12	18.2208
12	18.1273
12	18.0066
25.168 ± 4.25411
12	17.854
23.7421 ± 4.32913
12	19.715
12	19.4656
12	19.4072
12	20.2409
12	19.2907
13	17.9423
13	17.6148
24.8435 ± 4.24701
13	17.5918
12	20.1319
26.3164 ± 4.25353
13	16.2325
13	16.0722
13	17.4513
23.5654 ± 4.62807
13	15.9192
13	15.9162
21.3176 ± 4.51411
13	17.8891
13	17.853
13	17.6565
13	18.9805
13	17.6016
13	18.4062
13	18.1719
13	17.979
13	17.8461
13	17.4861
22.8944 ± 4.47305
13	17.8292
25.1779 ± 4.37178
13	17.7796
13	17.329
23.1682 ± 4.25379
13	18.397
13	18.3605
13	18.0113
13	17.9141
13	17.7618
13	17.6971
13	18.9148
13	18.797
13	19.1107
13	18.8511
13	18.8455
13	18.585
22.8839 ± 4.17923
13	19.1922
13	19.0865
13	18.5536
13	18.5309
13	18.6854
24.3128 ± 4.30685
23.7834 ± 4.19906
13	19.0456
13	18.4931
13	18.4319
13	18.9543
24.1182 ± 4.15863
13	18.3986
24.117 ± 4.41661
13	17.8529
13	17.349
13	17.1632
13	17.1804
13	17.0938
22.2912 ± 4.16701
13	16.9884
13	18.0392
13	18.5172
13	18.2314
13	18.2243
22.9526 ± 4.65494
13	18.0113
13	17.9035
13	17.8297
23.9696 ± 4.41084
23.9672 ± 4.13614
13	17.6619
13	18.961
13	18.7895
13	18.6127
23.1863 ± 4.51433
13	18.542
13	18.53
13	18.4885
13	20.0241
13	19.9334
13	19.902
23.8758 ± 4.35662
13	19.6981
13	19.6914
13	18.1618
13	19.6862
23.5802 ± 4.27097
13	19.635
13	19.4685
13	18.263
13	18.0287
13	17.9695
24.4063 ± 4.02974
23.8133 ± 4.55561
13	17.827
13	17.8174
13	17.8146
13	17.7886
13	17.4819
23.1884 ± 4.32241
13	16.8157
13	16.7591
13	16.6085
13	16.5407
21.7316 ± 4.3889
13	19.2904
13	19.2897
13	18.6822
24.8778 ± 4.31076
13	18.1522
13	17.7555
14	20.0817
14	19.9647
14	19.9202
22.7117 ± 4.121
25.214 ± 4.21413
13	19.7003
13	19.5484
13	18.8312
13	18.8253
13	18.5782
13	18.265
13	18.2549
23.7422 ± 4.38065
25.0172 ± 4.16553
13	20.2121
13	19.8046
13	19.248
13	19.056
13	19.7784
13	18.5571
25.5566 ± 4.16128
14	19.4353
14	19.2535
13	20.0063
13	19.9575
13	19.1888
23.9951 ± 4.28141
13	17.6573
13	17.5869
24.6376 ± 4.26527
13	17.3935
25.2425 ± 4.31532
22.8174 ± 4.30734
14	17.4371
14	15.8341
14	17.1863
14	15.589
14	15.5531
14	17.3554
14	17.1926
14	17.1583
14	15.1736
14	17.1068
14	17.0173
20.7238 ± 4.49898
14	17.0664
14	16.9494
22.7983 ± 4.21445
22.4666 ± 4.55697
14	17.1954
14	16.6209
14	18.4819
14	18.4817
14	18.1827
14	18.288
14	17.9403
22.2736 ± 4.386
14	17.2671
14	16.9435
14	18.4333
14	18.4333
14	18.4144
14	18.1058
14	18.0526
23.5231 ± 4.31537
14	16.8428
14	18.4142
24.0109 ± 4.35732
14	18.4091
14	18.1339
22.0956 ± 4.32226
14	18.7404
14	18.6845
14	18.6437
23.1621 ± 4.22217
14	17.5223
14	17.4151
14	18.6056
14	17.1352
14	18.5451
14	17.1316
14	17.0024
23.3844 ± 4.21715
14	16.8943
14	16.5909
14	16.8328
14	16.7214
22.1934 ± 4.33209
21.6558 ± 4.17533
21.8578 ± 4.54168
14	17.8428
23.1962 ± 4.41091
14	17.5175
14	17.4859
14	17.3428
14	16.6981
22.5685 ± 4.38178
14	17.8859
14	17.8332
14	17.8027
14	17.6082
14	17.5405
14	17.9601
14	18.1057
14	17.9592
14	19.4684
14	17.9402
14	17.232
22.8517 ± 4.52295
14	19.3544
14	19.3201
14	17.788
14	17.8903
14	17.6624
14	19.2934
14	17.3506
23.1732 ± 4.32011
22.8358 ± 4.21386
24.3474 ± 3.98826
14	17.5643
23.4342 ± 4.17855
14	16.3304
14	16.311
14	16.2364
14	15.769
14	18.3663
14	18.3132
20.9502 ± 4.36418
14	18.2851
14	18.2514
14	18.2096
23.0293 ± 4.27515
14	18.6383
14	17.9077
24.1174 ± 4.31368
14	17.1735
14	16.9602
14	16.6012
23.2454 ± 4.21038
14	18.1721
14	17.9741
15	19.8299
15	19.8246
15	19.5153
15	19.4366
14	17.812
15	19.0941
22.8612 ± 4.36221
24.5239 ± 4.23363
14	18.5212
14	18.3886
14	18.2186
14	19.4949
14	19.4886
14	17.8177
14	19.4598
14	19.4083
14	19.3556
14	19.1097
14	19.0633
14	18.6892
14	18.9017
23.4392 ± 4.27786
14	19.4512
14	19.3654
14	17.6871
14	17.5628
14	18.7667
24.2955 ± 4.20966
24.2215 ± 4.24663
14	17.538
14	17.3601
14	19.1259
14	17.3228
22.1315 ± 4.14008
14	16.987
25.3273 ± 4.08473
15	18.9195
21.9877 ± 4.29937
15	18.8305
24.3522 ± 4.11387
15	16.9454
15	16.9321
15	16.8535
15	16.8379
15	16.7546
21.5722 ± 4.50717
15	17.8458
15	17.7483
15	17.7241
15	17.5414
15	17.3948
15	14.8464
22.7172 ± 4.32184
15	17.9031
15	17.8405
19.9913 ± 4.54089
15	16.5098
15	17.6059
23.0908 ± 4.44479
15	16.4573
15	18.381
15	18.2754
15	16.9159
15	16.3229
15	16.9074
15	18.1416
15	15.9757
21.2831 ± 4.30648
15	16.9035
22.8443 ± 4.20265
15	16.7721
15	16.6792
21.9993 ± 4.21894
15	16.2892
21.3033 ± 4.4802
15	18.0704
15	17.9822
15	17.9633
15	17.9458
15	17.885
15	17.8666
15	16.3599
22.5343 ± 4.26663
15	16.1327
21.0517 ± 4.21418
15	17.4502
15	17.4454
15	17.3737
15	17.1418
15	16.4333
15	17.7788
15	17.6013
15	16.6049
15	17.5459
15	16.5018
22.1598 ± 4.47595
15	17.3983
22.3595 ± 4.39465
15	16.403
21.8587 ± 4.46113
15	17.148
15	17.1529
15	17.0176
15	17.4499
15	17.4488
15	17.129
15	17.2872
15	16.9835
15	16.8517
15	16.9849
15	16.0658
15	19.0496
15	16.9547
22.2975 ± 4.11367
15	17.2384
15	18.9618
15	16.0481
22.4175 ± 4.33284
21.1707 ± 4.50194
22.7773 ± 4.19831
22.2483 ± 4.06657
15	18.9561
24.0368 ± 4.03122
15	15.4715
15	15.4161
15	15.1973
20.1769 ± 4.39176
15	18.0827
15	18.0309
15	17.9242
15	17.8958
22.4243 ± 4.16668
15	17.8482
15	17.8446
15	17.7626
15	17.6732
15	17.6292
15	17.4981
23.0528 ± 4.29888
15	16.5734
15	16.5305
15	16.2171
15	16.1748
22.508 ± 4.39245
15	17.6786
15	17.5311
15	17.5127
15	17.2757
22.1004 ± 4.33446
15	18.6765
15	18.6412
15	18.6008
15	18.4207
15	17.7504
15	17.6477
15	17.5784
23.7439 ± 4.23316
23.4789 ± 4.13605
15	16.3295
15	17.5129
15	17.1287
21.5523 ± 4.2698
21.6456 ± 4.20569
16	16.6403
16	16.6358
16	16.631
16	16.5057
16	16.4176
21.4183 ± 4.29565
15	18.4134
15	18.3795
15	18.352
15	18.2536
23.4606 ± 4.36912
16	17.3787
16	17.089
16	18.6224
16	17.0465
16	18.0977
16	17.9775
16	17.8934
16	17.7682
15	19.0334
16	18.4759
16	16.8602
16	16.6066
15	18.8678
15	18.6441
16	17.3699
16	16.3656
21.9308 ± 4.32083
22.3402 ± 4.19588
16	14.8399
16	16.2319
16	14.7165
16	14.6848
23.7907 ± 4.02589
16	17.4249
24.8277 ± 4.10916
16	16.9388
16	14.3423
21.3168 ± 4.28725
19.2762 ± 4.51854
22.4969 ± 4.28921
16	17.7149
16	17.6724
16	17.6461
16	17.5018
16	17.3707
16	19.0839
16	19.0039
16	18.9091
16	18.8917
22.0208 ± 4.2484
23.7502 ± 4.30318
16	15.793
16	15.6418
20.6755 ± 4.29643
16	17.3343
16	17.3151
16	16.9765
16	16.154
16	15.9017
16	15.895
16	15.669
16	16.0978
16	16.8117
16	15.7606
21.5754 ± 4.26665
21.1779 ± 4.47289
20.7941 ± 4.23729
16	16.8756
16	16.7403
20.6563 ± 4.42104
16	16.5442
16	16.2665
16	16.3008
21.7101 ± 4.3158
16	16.7001
16	16.893
16	16.8099
16	16.7823
22.1883 ± 4.27574
16	18.7601
16	18.4495
16	16.7633
16	15.5816
21.8851 ± 4.09948
21.7532 ± 4.1955
16	15.2254
16	18.4021
16	18.3802
16	17.1228
16	16.9715
23.5623 ± 4.08929
16	16.9577
16	16.9521
20.6501 ± 4.315
16	16.331
22.0504 ± 4.2397
16	17.2636
16	14.6556
20.2848 ± 4.22683
22.1336 ± 4.31538
16	16.1509
16	15.7353
16	15.5825
21.7229 ± 4.45593
16	17.0258
16	16.9669
16	16.9592
16	17.8373
16	16.7949
16	17.3833
21.4738 ± 4.33547
16	18.2952
22.1785 ± 4.07523
16	18.2796
16	18.2349
16	17.8629
23.184 ± 4.221
16	15.9846
16	15.7937
20.8102 ± 4.28465
16	17.4083
16	16.7287
22.8444 ± 4.27263
16	18.2339
16	17.8998
22.7012 ± 4.36909
17	16.1831
17	15.9609
17	15.9182
16	17.1135
16	16.8642
17	15.6755
17	16.7728
17	16.5838
20.6321 ± 4.34141
21.0943 ± 4.17082
21.9467 ± 4.39015
17	17.9423
17	14.2832
17	17.2058
17	17.1002
17	17.0593
17	14.2247
17	17.8452
17	16.1239
23.4572 ± 4.08012
19.2139 ± 4.29216
22.339 ± 4.09871
20.9586 ± 4.25489
17	15.4175
17	15.3087
20.2491 ± 4.29965
16	18.6336
16	18.4111
16	18.4043
17	17.1742
17	15.6542
17	15.5043
17	15.4699
17	15.4626
17	15.3142
17	17.0754
16	18.3882
17	16.3998
17	16.9614
17	16.3435
17	15.2837
16	18.3655
16	18.0526
17	14.9495
19.9964 ± 4.4135
21.4774 ± 4.24064
24.0185 ± 4.21189
21.1618 ± 4.41974
17	18.6897
17	16.6735
17	16.6022
17	16.568
17	16.2447
23.1312 ± 4.22331
17	16.7101
17	16.5702
17	16.1918
17	16.1147
21.4134 ± 4.1981
17	15.4909
20.9664 ± 4.27432
21.6445 ± 4.38973
17	15.8026
17	15.4523
20.2629 ± 4.38792
17	15.7756
17	15.7239
17	15.2292
17	16.0864
17	16.6811
17	16.4764
20.7862 ± 4.37137
17	16.2764
17	16.2155
17	16.0048
17	15.9915
21.7871 ± 4.12012
20.979 ± 4.30381
21.2049 ± 4.40165
17	15.2113
17	15.0625
17	15.0228
17	14.7448
19.9689 ± 4.35874
17	18.2526
17	18.2514
17	18.2487
17	18.0775
17	18.0486
17	17.7329
22.9145 ± 4.17461
17	17.1845
17	17.1283
17	17.1011
21.5055 ± 4.25147
17	15.1984
20.805 ± 4.52078
17	16.6668
17	16.6633
17	16.4117
17	16.3482
20.9414 ± 4.32456
17	17.8607
22.9282 ± 4.11389
17	17.3814
17	17.2814
17	15.6314
17	15.5997
17	15.5851
17	17.096
17	15.3929
17	17.0229
21.7875 ± 4.08531
20.1225 ± 4.29778
17	16.0093
22.0006 ± 4.39451
17	17.8837
17	17.6617
22.0913 ± 4.3108
18	16.0975
18	16.0911
18	16.0805
18	16.0411
18	16.005
18	15.9406
18	15.9051
18	15.4965
20.3826 ± 4.31444
17	16.7959
17	16.7161
17	16.1998
18	15.0844
18	15.0319
18	14.1537
20.7016 ± 4.18142
18	14.103
19.6916 ± 4.31377
18	13.9762
18	13.8559
18.9904 ± 4.24459
18	17.6538
18	17.3117
18	16.3274
18	16.2702
22.6978 ± 4.1882
18	16.9269
18	16.1806
18	16.1367
20.5595 ± 4.41059
17	18.0246
17	17.7568
18	14.7748
18	15.6388
18	14.6515
17	17.6535
18	15.5238
18	16.5468
18	16.4992
18	16.44
18	16.3711
17	17.4763
18	16.1812
21.9236 ± 4.19761
18	16.1305
23.152 ± 4.29267
19.4228 ± 4.46622
20.8204 ± 4.18182
18	16.8284
18	16.7134
21.1618 ± 4.21758
18	16.5665
18	16.5592
18	16.455
18	16.4011
18	16.5704
18	16.4001
18	16.3485
18	16.3276
21.4475 ± 4.24925
18	16.2613
21.269 ± 4.43844
18	16.347
20.8532 ± 4.19518
18	15.4292
18	15.344
18	15.3372
18	15.3358
18	15.3299
18	15.2139
18	15.0871
18	15.1416
19.7646 ± 4.34377
18	14.9142
18	16.0346
18	16.0073
18	16.0025
18	16.0007
18	15.8942
20.1309 ± 4.3643
18	15.7425
18	18.6719
18	18.4962
20.5111 ± 4.30567
18	18.4664
18	16.4574
18	16.2616
18	14.2637
18	16.1105
18	18.3545
22.8222 ± 4.18528
19.4232 ± 4.47676
21.5615 ± 4.23163
18	15.876
18	15.8196
18	15.7825
18	15.6239
18	15.0492
20.6042 ± 4.4298
18	16.0928
18	16.0489
18	15.9758
18	15.5121
21.0062 ± 4.47218
18	14.3703
19.4215 ± 4.39621
18	16.9804
18	16.088
21.3596 ± 4.16004
18	15.0101
18	17.6053
18	17.4303
18	16.2718
18	16.2509
18	16.1828
18	17.414
18	17.4014
19.9948 ± 4.54598
18	17.0987
18	16.0673
18	16.0316
20.4904 ± 4.38727
18	17.812
22.2278 ± 4.2471
18	17.7984
18	17.7235
22.7022 ± 4.13034
18	16.9901
18	16.759
21.3357 ± 4.10368
18	15.2306
18	15.2055
18	14.9925
19.5592 ± 4.35357
18	17.6455
18	17.5238
18	17.4712
18	17.4147
21.6925 ± 4.31862
18	15.9053
18	15.8392
21.0416 ± 4.53948
19	15.4488
19	15.3791
19	15.3497
19	15.3265
19	15.2655
19.8978 ± 4.35095
19	15.0189
19	15.0048
19	15.0043
19	13.7758
19	13.4308
19	14.9149
19.2129 ± 4.36994
18.5354 ± 4.32651
19	15.9859
19	15.9543
18	17.4435
18	17.3832
18	17.2365
18	17.1305
19	14.4768
19	15.9632
19	15.9336
19	15.4789
19	15.7437
20.1357 ± 4.34198
18	17.0772
22.8775 ± 4.25307
18.8767 ± 4.48974
18	16.0743
18	15.8562
20.6731 ± 4.25807
18	15.8412
19	16.7105
19	16.603
20.3066 ± 4.26124
19	16.7132
19	16.6594
21.4692 ± 4.28713
19	16.5615
19	16.4816
19	16.2648
21.2087 ± 4.23999
19	15.8458
19	15.5147
19	15.373
20.5227 ± 4.21812
19	16.79
19	16.5981
21.2933 ± 4.16029
22.1456 ± 4.20641
19	15.0265
19	14.7849
19	14.7838
19	15.6907
19.242 ± 4.3391
19	15.6736
20.0129 ± 4.34799
19	14.8856
19	14.7231
19	14.7023
19	14.6341
19	14.5867
19	15.9632
19	14.4509
19	14.2107
19.773 ± 4.461
19	14.2098
20.9866 ± 4.29801
18.7868 ± 4.47263
19	14.8659
19	14.7721
19	14.7476
19	16.0492
19	18.0085
19	15.9881
19	15.7728
19	14.3061
19	17.2885
19	15.5017
19	15.7364
19	15.4903
19.7663 ± 4.25761
19	15.7179
19	15.4858
19	15.0925
19.2663 ± 4.20829
20.6207 ± 4.32398
20.3053 ± 4.47865
22.7119 ± 4.18065
29 sends to 16
29 receives from 11
23 sends to 14
23 receives from 31
20 sends to 20
20 receives from 20
15 sends to 25
15 receives from 24
27 sends to 11
27 receives from 19
24 sends to 15
24 receives from 10
17 sends to 31
17 receives from 12
18 sends to 18
18 receives from 18
30 sends to 30
30 receives from 30
9
8
21
3
4
19
1
28
13
2
24
29
17
0
5
25
6
31
18
27
20
10
22
14
15
12
26
11
7
16
30
23
0 sends to 9
0 receives from 13
7 sends to 28
7 receives from 28
16 sends to 6
16 receives from 29
1 sends to 8
1 receives from 6
2 sends to 21
2 receives from 9
6 sends to 1
6 receives from 16
3 sends to 3
3 receives from 3
4 sends to 4
4 receives from 4
13 sends to 0
13 receives from 8
28 sends to 7
28 receives from 7
19	16.0051
19	15.6543
14 sends to 5
14 receives from 23
9 sends to 2
9 receives from 0
20.9354 ± 4.35737
19	15.9343
19	15.6194
12 sends to 17
12 receives from 25
19	14.7283
20.0741 ± 4.39773
19	14.5444
5 sends to 19
5 receives from 14
19.5884 ± 4.40135
19	17.0467
19	16.7798
31 sends to 23
31 receives from 17
19	17.598
19	17.5544
21.5315 ± 4.30428
10 sends to 24
10 receives from 21
19	17.5425
19	17.3656
22.1868 ± 4.19341
21 sends to 10
21 receives from 2
19	16.7262
19	16.724
19	16.6228
19	16.597
21.0635 ± 4.1478
22 sends to 22
22 receives from 22
19	15.8291
19	15.7598
19	15.7175
20.6746 ± 4.33095
19 sends to 27
19 receives from 5
19	17.3986
19	17.2147
19	17.0658
21.6508 ± 4.18542
11 sends to 29
11 receives from 27
19	16.8953
19	16.6875
19	14.4958
19	15.7521
22.4548 ± 4.37262
19.0085 ± 4.35299
25 sends to 12
25 receives from 15
20.5489 ± 4.18322
26 sends to 26
26 receives from 26
8 sends to 13
8 receives from 1
20	15.4066
20	15.396
20	15.3929
20	15.3652
20	14.4823
20	14.4768
20	14.9784
19.9079 ± 4.38952
20	16.5981
20	14.7021
19.8719 ± 4.22125
20	16.3275
20	14.3963
20	14.2873
20	14.1039
20	13.8117
19.299 ± 4.34532
22.4528 ± 4.15885
20	15.9756
20	15.6543
20	15.5188
19.0331 ± 4.50518
20	15.3243
20	15.3991
20	15.0925
20	15.0893
20	15.3214
20	15.2912
20	16.7188
20	14.93
20	14.8765
20	14.3061
20	14.302
21.434 ± 4.21668
20	14.2463
20.431 ± 4.34416
20.1143 ± 4.29303
20	14.219
20.8391 ± 4.3969
21.4049 ± 4.6013
20	16.3179
20	16.1198
20	15.9666
20	15.6736
20	15.5166
22.3811 ± 4.24183
20	13.4308
20	13.3825
20	13.3165
19.6777 ± 4.49296
20	15.7262
20	15.6749
20	15.4731
20.5113 ± 4.41673
20	16.3331
20	16.2982
20	16.197
20	16.5296
20	16.4042
20	16.1941
20	15.7908
20	15.6876
20	15.5359
20	15.2538
20	15.1032
20.7302 ± 4.16306
22.0825 ± 4.32287
21.2834 ± 4.43077
20	15.7113
20	15.4789
20	15.3281
20	15.3281
22.1071 ± 4.42895
20	15.6206
20	14.7456
20	14.5028
20	14.2654
20	14.2098
20.4392 ± 4.28533
20	14.0513
18.558 ± 4.40614
20	16.9285
20	14.9149
20	14.8647
21.5669 ± 4.23074
21	15.5399
21	15.4072
21	14.9396
21	14.9089
21	16.2734
21	14.8993
21	16.1301
21.5732 ± 4.45708
21	15.8937
21	14.342
21	14.2532
19.3442 ± 4.50287
22.1921 ± 4.21411
21	14.5441
21	13.6962
19.6917 ± 4.38193
21	13.435
21	15.1033
21	14.2262
19.4833 ± 4.26268
18.8401 ± 4.35371
18.3124 ± 4.61173
20.8728 ± 4.38499
21	14.4279
21	14.3766
21	14.2187
21	14.0935
21	14.0306
19.4361 ± 4.27112
19.9298 ± 4.58886
21	15.4033
21.5825 ± 4.47455
21	15.0361
21	14.78
21	14.701
21	14.516
21	14.509
21	15.0666
21	15.0099
19.6922 ± 4.35649
21	13.2937
21	14.7374
20.1448 ± 4.35784
21	13.2503
18.8094 ± 4.61235
21	14.2445
21	14.1344
21	14.1473
21	14.8869
21	14.0909
21	15.1985
19.777 ± 4.52899
20.2081 ± 4.70095
20.5734 ± 4.3704
19.9545 ± 4.42122
21	13.3945
21	15.5286
21	15.3577
21	15.0952
21.328 ± 4.49951
19.2468 ± 4.51885
21	14.9026
21	16.7625
21	14.8746
19.7682 ± 4.2148
21	16.6795
21.837 ± 4.34206
21	15.0553
21	14.9716
21	14.724
21	14.695
20.4722 ± 4.42089
21	16.1944
21	16.0808
21	15.954
21	15.9271
20.2661 ± 4.16841
21	15.6258
21	15.5411
21.527 ± 4.16743
21	15.2492
21	14.1915
21	14.0117
21.1937 ± 4.49449
19.7449 ± 4.56408
21	15.2336
21	15.1427
21	15.0635
20.562 ± 4.34383
21	13.6821
18.0707 ± 4.41587
21	14.831
21	14.5824
20.8061 ± 4.43885
22	15.3553
22	15.2046
22	14.9695
22	15.8395
22	15.6963
22	15.6591
20.8067 ± 4.52826
22	15.6252
22	13.4127
22	13.3195
22	14.1184
22	15.4617
21.595 ± 4.39634
22	15.0723
22	14.9679
22	14.8732
22	14.6603
22	14.6228
17.701 ± 4.58225
19.2026 ± 4.5716
22	14.4872
20.1269 ± 4.44102
19.2669 ± 4.25108
22	14.4544
19.8519 ± 4.43123
22	15.377
22	15.2887
20.8288 ± 4.55262
22	13.9083
22	14.0797
22	14.0563
19.4346 ± 4.60958
19.0253 ± 4.35238
22	14.8605
22	14.8298
22	14.8259
22	14.6711
22	14.6177
18.896 ± 4.44466
22	14.8765
22	14.7498
22	14.5835
19.8654 ± 4.4221
22	14.1464
22	14.1054
22	13.0357
18.985 ± 4.60748
18.0584 ± 4.59816
22	15.059
22	14.9457
22	14.9169
22	14.2056
20.4104 ± 4.5624
22	14.1964
22	14.5767
19.0031 ± 4.45225
22	14.4233
22	14.409
22	16.5539
22	16.4998
22	16.4942
22	16.4401
22	14.3275
22	14.0138
22	13.7785
22	13.6427
22	13.5422
22	13.3725
22	13.3455
19.5398 ± 4.53328
21.45 ± 4.32412
18.968 ± 4.40618
22	15.1871
22	15.003
22	14.5634
22	14.5397
22	14.5297
22	14.4933
22	14.4142
22	14.235
22	14.0293
22	13.9192
22	14.8221
19.6283 ± 4.53188
19.4929 ± 4.43337
22	14.7723
19.214 ± 4.67957
22	15.6841
22	15.5555
22	14.5976
22	13.3519
22	13.2798
22	13.1796
22	13.1136
19.7997 ± 4.19564
18.388 ± 4.59399
22	15.3183
19.38 ± 4.30106
21.0303 ± 4.33241
22	14.9602
22	15.6131
22	15.5898
20.082 ± 4.44441
21.1554 ± 4.5511
22	15.2335
22	15.1271
22	14.9389
22	14.8386
22	13.8082
19.169 ± 4.509
20.2402 ± 4.44089
22	14.4951
19.9613 ± 4.59534
23	14.9472
23	14.9176
23	14.8953
23	14.8484
23	13.2972
23	13.01
23	14.7343
20.047 ± 4.53642
23	12.8945
17.2702 ± 4.52887
23	14.4353
23	14.5766
23	14.3657
23	14.4732
23	14.4651
19.3007 ± 4.42272
23	14.1972
19.1004 ± 4.28686
23	13.9208
19.1824 ± 4.50074
23	15.4076
23	15.3373
21.0491 ± 4.43753
23	13.8796
23	13.7618
23	13.6319
18.999 ± 4.61684
23	15.2311
23	15.1017
23	14.0888
23	13.7552
20.0709 ± 4.48987
18.6481 ± 4.51047
23	14.5818
23	14.4465
23	14.1927
23	14.1453
19.1949 ± 4.51269
23	14.051
23	14.5386
23	14.44
23	14.0349
18.5523 ± 4.42762
18.4618 ± 4.38502
23	14.0548
23	14.0739
23	14.0105
18.3845 ± 4.45297
23	13.9778
23	13.9526
19.0242 ± 4.48766
23	14.2912
23	14.1335
23	14.0848
18.9485 ± 4.57942
23	12.8328
23	14.2198
23	14.1034
23	13.9541
23	13.8597
23	13.9341
23	13.8009
23	13.9214
23	13.6146
17.4313 ± 4.61764
18.515 ± 4.60292
18.7948 ± 4.53661
23	13.3192
23	13.2758
23	15.0475
23	15.3012
23	15.0225
23	14.9096
23	14.8807
23	16.3089
23	16.0599
23	14.9378
23	14.8598
19.9347 ± 4.12244
20.4266 ± 4.42366
18.1868 ± 4.51534
23	14.7704
23	14.6991
20.9702 ± 4.29021
19.0649 ± 4.43679
19.6745 ± 4.56436
23	14.5699
23	14.4953
23	14.2674
23	14.2056
18.9839 ± 4.42774
23	12.98
23	14.6973
23	15.51
17.6253 ± 4.57092
19.606 ± 4.46657
20.5347 ± 4.56677
23	13.3828
17.4863 ± 4.43721
23	13.7525
23	13.7298
18.4637 ± 4.54716
23	14.7966
23	14.3914
19.5763 ± 4.49942
24	14.189
24	13.8032
18.8434 ± 4.40226
24	13.7958
18.5124 ± 4.57435
24	14.538
24	15.2313
24	15.1542
19.3619 ± 4.54002
20.4717 ± 4.48178
24	12.8722
23	14.3879
23	14.1904
24	12.7004
19.1874 ± 4.54818
16.8959 ± 4.52449
24	13.4854
18.4414 ± 4.60623
24	14.9471
24	14.9055
24	14.78
24	14.6963
24	14.0912
24	13.6099
19.53 ± 4.45155
24	13.4634
19.0712 ± 4.41257
24	14.3609
24	14.331
24	14.2972
24	14.1895
18.2253 ± 4.44531
24	14.0381
24	14.0311
24	14.0264
24	13.831
24	13.907
24	13.8113
18.6649 ± 4.43734
17.972 ± 4.42446
24	13.7252
24	13.5669
18.1726 ± 4.52881
24	13.4058
24	13.934
24	13.8458
24	13.5913
24	13.7611
18.2143 ± 4.59026
17.9059 ± 4.5187
24	13.7358
18.1652 ± 4.39794
18.3053 ± 4.51719
24	12.7181
24	12.6992
24	14.7377
24	15.7795
24	14.2489
24	14.8587
16.8591 ± 4.49287
24	14.1385
24	14.0057
19.7571 ± 4.39452
24	15.2985
24	15.1903
24	15.1849
19.0329 ± 4.49192
20.4489 ± 4.3091
19.7178 ± 4.17531
18.4448 ± 4.40836
24	14.6733
24	14.646
24	14.6096
24	14.6003
24	14.5993
24	14.5262
18.7128 ± 4.50219
24	14.6832
24	14.4502
24	14.4384
19.1816 ± 4.5238
24	15.3496
19.9238 ± 4.48116
24	13.5263
24	13.424
24	13.4042
18.0419 ± 4.49895
24	14.3495
24	14.1481
18.8492 ± 4.44801
25	14.0675
25	13.766
25	13.7076
18.4158 ± 4.42123
25	14.4583
25	14.3872
18.7779 ± 4.46467
25	14.4569
25	14.1505
18.4958 ± 4.47566
24	12.9374
25	13.6782
25	15.0905
25	15.0052
25	14.977
25	14.7144
25	13.5415
25	13.53
25	14.6603
19.7888 ± 4.4226
24	12.9138
17.5058 ± 4.49042
18.043 ± 4.53358
24	14.1841
24	14.1233
24	13.9906
18.599 ± 4.50684
24	13.3802
24	13.3495
17.1908 ± 4.44311
25	12.6781
16.5905 ± 4.53802
25	14.3707
25	14.3542
19.0056 ± 4.45468
25	14.1104
25	14.0467
25	13.8373
17.9259 ± 4.42065
25	13.773
25	13.7152
25	13.6908
25	13.813
25	13.8122
25	13.5064
18.2322 ± 4.47651
25	13.1341
25	13.4527
17.7499 ± 4.47181
25	13.1213
25	13.4474
25	13.2892
25	13.693
17.6536 ± 4.45649
18.3594 ± 4.28212
17.5195 ± 4.49417
25	13.4076
18.5556 ± 4.43873
25	13.6793
17.9293 ± 4.53411
25	13.5311
17.7714 ± 4.50369
25	14.563
25	15.2098
25	14.3306
25	14.2301
25	14.2026
25	14.1488
19.3924 ± 4.35753
19.9362 ± 4.3402
25	13.9035
18.6321 ± 4.44131
18.0416 ± 4.39632
25	14.436
25	15.0586
25	14.4358
25	14.4114
19.5241 ± 4.18214
18.4007 ± 4.47492
25	13.8833
25	13.8529
17.6559 ± 4.38396
25	15.2809
19.4481 ± 4.43948
25	14.1755
18.7334 ± 4.50801
25	13.1651
25	13.2006
25	13.1643
17.2176 ± 4.52349
17.5221 ± 4.51073
25	13.9804
25	13.8405
18.3347 ± 4.49205
26	13.586
26	13.3896
26	13.9928
26	13.7015
18.0384 ± 4.4703
18.0914 ± 4.5202
26	13.4125
26	13.1415
17.6597 ± 4.5192
26	14.6335
26	14.5966
26	14.5548
25	13.2717
25	13.0503
26	13.7582
26	13.5868
26	14.5137
26	13.548
19.2502 ± 4.37611
25	12.8712
17.2824 ± 4.50764
26	13.29
17.0028 ± 4.46496
17.6073 ± 4.39398
25	13.8947
26	14.2034
26	14.2034
26	13.9922
18.4512 ± 4.44238
18.121 ± 4.49782
26	13.6053
26	13.542
26	13.0979
26	12.8765
17.8497 ± 4.51535
26	12.8028
17.1364 ± 4.53412
26	13.4343
26	13.42
26	13.1134
26	13.1107
26	13.1089
26	13.2866
26	12.939
17.4188 ± 4.50755
26	13.1401
17.1706 ± 4.5327
17.9994 ± 4.50361
26	13.3762
26	13.1417
26	13.6749
18.07 ± 4.46505
26	13.5423
18.1532 ± 4.32951
26	15.2034
26	15.1189
26	14.3233
26	14.3053
19.3199 ± 4.32008
26	14.1161
19.1001 ± 4.38717
26	14.0974
18.4671 ± 4.4585
26	12.6566
16.8695 ± 4.38107
26	14.3148
26	14.2511
26	14.1392
26	14.9481
26	14.0727
18.1529 ± 4.44402
19.1888 ± 4.18774
26	13.8292
26	13.5784
26	13.6965
17.8051 ± 4.43855
17.5285 ± 4.44029
26	15.2176
26	15.1671
26	15.1488
19.1548 ± 4.3969
26	13.8001
26	13.5223
26	14.0856
17.9057 ± 4.52896
26	13.9642
26	13.501
18.2617 ± 4.48241
26	13.3069
17.4467 ± 4.42753
26	13.1505
27	13.3238
26	13.101
16.8826 ± 4.41127
27	13.2601
17.5768 ± 4.50816
27	13.1181
17.256 ± 4.52491
27	12.6707
27	12.6444
16.313 ± 4.52276
26	13.0343
26	12.9715
26	12.9472
27	13.0395
27	13.0269
26	12.8294
16.7293 ± 4.43457
27	14.4329
27	14.3541
17.1803 ± 4.45168
27	14.3352
27	14.1992
26	13.8399
26	13.766
26	13.712
26	12.7399
18.7803 ± 4.41761
26	13.6437
17.7919 ± 4.43715
17.0043 ± 4.45963
27	13.5081
27	13.4991
27	13.4226
27	13.2595
27	12.7317
27	12.5665
16.687 ± 4.50801
17.4871 ± 4.48093
27	12.7962
27	12.6012
16.7841 ± 4.47512
27	12.9701
17.4515 ± 4.52431
27	15.1057
27	13.0627
27	15.0231
27	12.8946
17.0251 ± 4.46431
27	15.0097
27	14.9374
27	14.5318
27	14.2726
27	14.0352
18.9606 ± 4.32174
18.7177 ± 4.4034
27	14.0432
27	13.8806
18.2199 ± 4.47327
27	14.9322
27	13.8156
27	14.8909
18.9314 ± 4.21977
17.9881 ± 4.41202
27	12.5764
27	14.0724
27	13.963
18.31 ± 4.29828
27	13.4157
17.6942 ± 4.52914
17.257 ± 4.35789
27	14.9141
27	14.6739
19.141 ± 4.25561
27	13.5101
27	13.9268
27	13.5006
27	13.9151
27	13.3722
17.5276 ± 4.52202
27	13.4762
27	13.8456
17.9443 ± 4.47609
27	13.3333
17.4579 ± 4.39611
27	12.9904
16.6806 ± 4.39007
28	12.8957
28	14.2684
27	13.2961
27	13.2024
27	13.1741
18.6488 ± 4.33017
16.9733 ± 4.50941
27	13.0137
17.1927 ± 4.43715
27	13.1094
17.9374 ± 4.34831
27	12.8101
16.5191 ± 4.47855
28	14.1326
28	14.0016
27	12.6062
18.4601 ± 4.48743
28	13.5675
28	12.4862
16.9072 ± 4.34603
28	12.3983
28	12.4722
16.3083 ± 4.47714
16.2217 ± 4.56004
28	13.4333
17.3913 ± 4.44678
28	14.0278
28	14.5227
28	13.2256
28	13.6127
28	12.8402
18.61 ± 4.41871
28	13.2056
17.0008 ± 4.49204
28	13.096
18.5882 ± 4.42377
17.4592 ± 4.42918
28	12.5205
28	12.2867
16.4263 ± 4.50606
28	13.2952
18.0116 ± 4.37836
28	12.7764
28	13.8479
28	13.8292
28	13.8016
28	14.8798
28	14.7884
28	14.6526
16.8444 ± 4.46769
28	13.775
18.7108 ± 4.22576
17.8725 ± 4.4724
28	13.4735
28	13.7922
28	12.8302
28	12.8208
17.6565 ± 4.39812
28	13.7062
28	12.7157
28	13.4097
16.8227 ± 4.56795
18.2167 ± 4.38089
28	13.3314
28	13.2594
17.6202 ± 4.21579
28	14.6106
28	14.5601
28	12.5129
28	12.4881
28	12.2944
17.4418 ± 4.58423
18.8889 ± 4.30696
28	12.6235
16.5235 ± 4.4006
28	13.7809
28	13.2389
28	13.7556
28	13.2351
28	12.9782
17.7373 ± 4.49924
17.2574 ± 4.5164
28	12.9227
16.5487 ± 4.41696
29	14.236
29	14.1968
18.3719 ± 4.32505
29	12.8371
28	13.2311
17.1386 ± 4.53292
28	13.2277
17.238 ± 4.46591
28	12.7313
28	12.5892
28	12.5636
16.3341 ± 4.44935
29	12.8723
16.7837 ± 4.39715
29	12.6893
16.6708 ± 4.4716
28	13.0521
17.542 ± 4.38927
29	12.1884
16.056 ± 4.45806
29	13.3929
29	13.3835
29	13.587
29	13.2831
29	13.935
17.1971 ± 4.45238
29	13.922
29	13.6799
29	13.4994
29	13.9449
29	13.4221
17.9963 ± 4.55893
18.0335 ± 4.41458
29	13.7205
18.2866 ± 4.4043
28	13.5591
29	13.0621
29	13.0153
29	12.9287
29	12.8949
28	13.515
29	12.8205
17.9047 ± 4.35894
29	12.0778
16.0934 ± 4.50497
17.1221 ± 4.45045
0
9
22
3
26
21
6
14
19
30
4
1
12
13
5
15
28
17
18
16
11
20
23
8
31
10
2
27
7
29
25
24
0 sends to 0
0 receives from 0
29 sends to 29
29 receives from 29
17 sends to 17
17 receives from 17
31 sends to 24
31 receives from 24
30 sends to 25
30 receives from 9
10 sends to 4
10 receives from 25
2 sends to 22
2 receives from 26
6 sends to 6
6 receives from 6
9 sends to 30
9 receives from 1
4 sends to 26
4 receives from 10
1 sends to 9
1 receives from 11
29	13.2738
29	13.2523
29	12.8301
29	12.8074
29	13.1016
29	12.7146
29	12.9226
29	12.7998
16.6325 ± 4.4487
17.7585 ± 4.48005
14 sends to 5
14 receives from 7
20 sends to 11
20 receives from 21
29	14.4436
29	12.6973
29	12.6552
18.4393 ± 4.26605
16.5136 ± 4.50797
22 sends to 23
22 receives from 2
29	13.3228
18 sends to 18
18 receives from 18
29	13.5354
29	12.5392
29	12.4909
17.3387 ± 4.4257
17.9033 ± 4.37773
21 sends to 20
21 receives from 5
16.4959 ± 4.50272
3 sends to 3
3 receives from 3
19 sends to 16
19 receives from 8
29	13.7235
29	13.257
29	13.6751
29	13.2534
29	13.2357
29	13.1869
29	13.1751
29	13.071
17.5916 ± 4.41217
17.4975 ± 4.30922
5 sends to 21
5 receives from 14
16 sends to 28
16 receives from 19
29	12.6227
29	12.8872
29	14.5596
16.3839 ± 4.47853
29	14.3963
15 sends to 15
15 receives from 15
16.9598 ± 4.51423
25 sends to 10
25 receives from 30
18.6293 ± 4.38644
29	13.6009
12 sends to 12
12 receives from 12
29	13.558
17.4572 ± 4.46894
29	12.812
13 sends to 13
13 receives from 13
16.4801 ± 4.43797
28 sends to 7
28 receives from 16
29	12.2093
29	12.2061
16.833 ± 4.68285
23 sends to 8
23 receives from 22
29	13.1254
29	13.0714
29	12.9993
16.7358 ± 4.49691
29	12.8341
16.9615 ± 4.38775
7 sends to 14
7 receives from 28
27 sends to 27
27 receives from 27
29	12.5636
16.6236 ± 4.40227
24 sends to 31
24 receives from 31
29	12.4737
29	12.4032
16.1795 ± 4.4556
26 sends to 2
26 receives from 4
29	12.9972
29	12.9051
29	12.7937
17.3328 ± 4.48743
8 sends to 19
8 receives from 23
29	13.4304
29	13.4286
29	13.3788
30	12.0587
17.6453 ± 4.39902
30	12.0094
11 sends to 1
11 receives from 20
15.8839 ± 4.53443
30	13.5789
30	13.662
30	12.1884
30	13.661
30	13.6375
30	13.3448
18.7193 ± 4.35037
17.3488 ± 4.26506
17.7576 ± 4.46299
30	13.2713
30	13.2172
30	13.2025
30	13.0851
17.1067 ± 4.38511
30	13.4581
30	13.2061
17.6185 ± 4.43812
30	14.3476
30	13.6008
30	13.5604
19.4353 ± 4.37219
30	13.071
30	12.9985
30	12.394
17.9953 ± 4.2834
17.4433 ± 4.36085
30	12.3921
30	12.8159
30	12.7421
30	12.7055
30	12.4722
30	12.313
16.2983 ± 4.48113
17.2524 ± 4.32826
30	13.4681
30	13.4032
17.2413 ± 4.42273
30	12.8612
30	12.7938
30	12.7146
17.731 ± 4.32251
30	12.8872
17.8684 ± 4.50457
30	14.3959
30	14.3758
30	14.2912
18.3457 ± 4.35798
30	12.6781
30	12.5891
30	12.4834
17.0104 ± 4.27917
30	12.5636
30	12.5138
30	13.9227
30	13.6861
30	13.275
30	13.0349
30	12.5497
30	12.4032
17.1993 ± 4.28549
18.1079 ± 4.47381
30	12.812
30	12.7659
30	12.6985
30	12.6854
30	12.4772
30	12.2552
30	12.0857
30	12.0795
30	12.0374
17.1352 ± 4.25492
30	11.8547
16.3929 ± 4.43326
31	11.9903
30	13.1128
30	13.0768
30	12.7998
30	12.6533
31	11.9667
30	12.2061
30	12.1738
30	12.0668
30	11.9726
30	11.9497
15.6463 ± 4.51863
30	12.6337
17.5518 ± 4.35371
17.1454 ± 4.6239
31	13.0191
31	13.1424
16.88 ± 4.35759
31	13.1288
17.2593 ± 4.55994
31	13.4882
31	12.7752
31	13.3441
18.7452 ± 4.48904
31	12.3277
31	12.6533
17.5776 ± 4.49648
31	12.208
17.0794 ± 4.55566
31	13.2894
31	13.0793
31	12.2493
17.5164 ± 4.48046
16.0934 ± 4.51745
31	12.3296
31	13.3799
31	13.3133
31	12.8993
31	12.8942
31	12.7234
31	13.2899
17.0442 ± 4.38785
17.0536 ± 4.44834
31	12.5384
17.5464 ± 4.37582
31	12.6431
17.1679 ± 4.3522
31	12.1591
17.6764 ± 4.5639
31	11.9389
17.1779 ± 4.39941
31	12.6021
31	14.2219
31	12.4555
31	14.0931
31	12.5599
18.279 ± 4.3771
17.6096 ± 4.42003
17.394 ± 4.56855
31	12.0838
31	12.3254
31	12.2155
17.4073 ± 4.5932
16.776 ± 4.38632
31	11.6507
31	11.5765
31	11.4941
31	11.4202
15.9763 ± 4.54438
31	12.4871
32	11.7265
15.5198 ± 4.52288
17.2674 ± 4.36631
31	11.8669
31	11.8341
31	11.8143
16.5257 ± 4.63236
32	13.0931
32	13.0753
32	13.0651
32	13.0611
32	12.6671
17.005 ± 4.56085
31	12.5853
32	13.5462
32	13.4368
31	12.5121
18.1186 ± 4.52935
17.1678 ± 4.34493
31	12.4924
17.3837 ± 4.42407
32	12.9787
32	12.2052
32	12.1417
32	12.1399
32	11.9654
32	13.3037
32	13.2315
16.7336 ± 4.41979
16.5887 ± 4.62319
18.0849 ± 4.57754
32	12.6123
32	12.5387
17.0827 ± 4.52028
32	12.1759
32	12.3112
15.9319 ± 4.52829
32	13.1647
16.9674 ± 4.45483
32	12.2816
16.7423 ± 4.48407
32	12.0708
17.0057 ± 4.66795
32	11.8961
16.7375 ± 4.58127
32	12.5299
16.067 ± 4.42482
32	12.3918
32	12.3782
17.1744 ± 4.4906
32	13.0604
32	12.9464
17.7222 ± 4.34722
17.1122 ± 4.47783
32	12.5239
16.9216 ± 4.4096
32	14.0239
32	13.9015
32	12.4384
18.0286 ± 4.39829
32	12.3906
32	12.3738
16.8937 ± 4.63904
32	12.0445
32	11.9683
16.6462 ± 4.63066
32	12.6778
32	12.4667
32	12.2115
17.6709 ± 4.2754
33	12.0847
32	12.0575
32	11.7315
32	11.6988
16.6114 ± 4.41626
16.2994 ± 4.52662
32	12.4184
16.9326 ± 4.43348
15.9756 ± 4.58983
33	12.5994
16.5783 ± 4.53809
33	13.4116
33	13.4041
17.7016 ± 4.56339
32	12.3295
16.8388 ± 4.50901
33	12.8871
16.6683 ± 4.48389
33	11.8864
16.1551 ± 4.69297
33	13.1414
33	12.2743
33	12.1439
16.8437 ± 4.48901
33	12.3879
16.356 ± 4.49246
17.1031 ± 4.46333
33	12.1432
15.832 ± 4.52875
32	12.458
32	12.4565
16.9455 ± 4.42813
33	13.1047
33	11.8705
17.6496 ± 4.47428
16.1879 ± 4.55869
33	12.5345
16.5163 ± 4.50222
33	11.8164
16.4934 ± 4.67722
33	12.6985
33	12.3547
33	12.2889
33	12.8909
17.6704 ± 4.33639
33	12.8743
33	12.2974
16.7669 ± 4.5067
16.8242 ± 4.47241
33	12.2748
17.4027 ± 4.45763
33	12.3186
33	12.2522
33	12.2268
33	12.3734
33	13.608
17.8847 ± 4.45516
33	12.2045
16.4734 ± 4.61145
15.9786 ± 4.37926
33	12.3638
33	12.0838
16.6198 ± 4.53349
33	11.9623
33	11.9356
33	11.9234
33	11.8079
16.1126 ± 4.63471
33	12.1043
17.2436 ± 4.43768
34	12.573
34	12.4167
16.411 ± 4.57151
33	12.4808
16.6468 ± 4.48672
33	12.345
33	12.293
33	12.1938
16.6478 ± 4.47749
34	12.9271
33	12.0248
17.3809 ± 4.55214
16.3099 ± 4.46202
34	12.8761
34	12.8544
16.5979 ± 4.38169
34	13.1155
34	12.3243
34	13.0151
16.6763 ± 4.44923
34	12.0094
16.9887 ± 4.5097
16.0868 ± 4.54551
34	12.1365
34	11.8607
33	12.3007
34	11.8182
16.4355 ± 4.52607
15.7769 ± 4.58622
16.0319 ± 4.48351
34	13.0808
34	11.8278
34	12.954
34	12.1387
34	11.7822
15.8613 ± 4.57458
17.3013 ± 4.54801
15.7127 ± 4.5429
33	12.4496
33	12.4024
33	12.3886
17.0087 ± 4.45759
34	11.7935
16.0269 ± 4.70483
34	12.7938
34	12.1756
16.5895 ± 4.52108
34	12.6559
34	12.6046
34	12.3335
34	12.2909
16.8976 ± 4.54815
17.2612 ± 4.49304
34	12.1493
34	12.1264
34	12.1229
16.122 ± 4.64382
34	12.4835
16.3624 ± 4.41008
34	13.5421
34	13.3169
17.643 ± 4.45678
34	12.2082
34	12.1844
34	11.7879
15.7394 ± 4.5977
16.4179 ± 4.586
35	12.4067
16.1869 ± 4.60014
34	11.6754
15.4071 ± 4.58951
34	11.3024
34	12.48
15.1037 ± 4.6608
35	12.8434
34	12.4337
16.3553 ± 4.47212
16.4639 ± 4.40607
35	12.9356
35	12.9079
35	12.2808
17.0431 ± 4.52496
35	12.2458
35	12.8318
16.6155 ± 4.47416
16.695 ± 4.5362
35	11.7925
35	11.7795
34	12.1204
15.573 ± 4.59354
16.3072 ± 4.5349
35	11.773
35	11.7565
15.5595 ± 4.54206
35	12.0548
16.4814 ± 4.38358
34	12.2542
34	12.2407
16.1092 ± 4.49246
35	12.5155
35	12.471
17.1252 ± 4.41926
35	12.7749
35	12.6279
16.7102 ± 4.46211
34	12.3344
16.8305 ± 4.46
35	12.3483
35	12.3271
35	11.8964
15.7498 ± 4.36063
15.877 ± 4.51623
35	13.0919
35	13.026
35	12.7659
17.3438 ± 4.49831
35	11.7752
15.4998 ± 4.57038
36	12.343
15.9888 ± 4.51851
35	12.1661
35	12.0043
16.1393 ± 4.6111
36	12.7584
36	12.5955
36	12.1822
36	12.1387
16.5229 ± 4.52
36	12.7587
16.4473 ± 4.59643
36	11.7198
36	11.7005
16.481 ± 4.42872
15.1262 ± 4.47741
36	11.6748
15.3682 ± 4.54593
35	12.0716
35	12.0947
16.2213 ± 4.58301
35	12.0025
15.8844 ± 4.59531
16.0337 ± 4.55312
36	12.9215
36	11.7239
17.3926 ± 4.38569
36	12.022
15.4176 ± 4.54828
36	12.0094
36	11.8659
15.7254 ± 4.60485
16.5357 ± 4.42881
36	12.0463
36	12.5483
36	12.4338
15.6434 ± 4.49714
36	12.138
35	12.1192
16.6015 ± 4.44811
16.1833 ± 4.63661
16.4884 ± 4.36818
36	12.4619
16.9229 ± 4.49948
36	11.8637
36	11.7809
15.6965 ± 4.5768
36	11.9049
15.7285 ± 4.55878
36	12.1492
16.3065 ± 4.54123
36	12.7581
36	12.6926
17.0827 ± 4.46751
36	11.9785
36	11.7644
15.8458 ± 4.56359
37	12.028
16.1301 ± 4.53704
37	12.7057
37	12.5185
16.3758 ± 4.40806
37	12.5928
16.4099 ± 4.52255
36	11.9739
15.775 ± 4.4886
37	11.6605
15.1314 ± 4.52233
36	12.2699
37	11.6721
37	12.8607
37	12.7799
15.9935 ± 4.4404
37	11.6682
37	11.5909
15.2014 ± 4.51254
15.2619 ± 4.49592
36	11.996
17.3405 ± 4.32096
15.9063 ± 4.51826
37	11.9748
16.3451 ± 4.46901
37	11.7298
37	11.6164
15.5314 ± 4.50607
15.3329 ± 4.53561
37	12.1359
37	12.1151
37	12.1053
15.951 ± 4.61295
36	12.0865
16.4613 ± 4.47059
37	12.3541
37	12.3529
16.3624 ± 4.47291
37	11.7236
15.5834 ± 4.554
37	12.4429
37	12.3381
16.6427 ± 4.54694
37	12.7332
16.7407 ± 4.49722
38	12.3403
38	12.2633
38	12.1602
15.8547 ± 4.51551
37	11.7735
37	11.7482
15.4993 ± 4.5517
37	12.6921
37	12.6613
36	12.2242
37	12.5655
16.7812 ± 4.46201
36	12.17
16.4299 ± 4.56717
37	11.7009
15.5654 ± 4.54915
38	12.5194
16.2648 ± 4.52355
38	12.0153
15.8753 ± 4.53966
38	11.6382
15.0608 ± 4.46243
38	11.3662
15.1552 ± 4.5086
38	11.4766
15.072 ± 4.46421
37	11.9005
38	12.083
38	11.9762
15.5921 ± 4.47989
15.8831 ± 4.59586
37	12.0727
37	11.811
16.2674 ± 4.50035
38	11.9782
38	11.9421
38	11.81
15.466 ± 4.4507
16.1101 ± 4.50267
38	12.3037
16.1759 ± 4.52303
38	12.3191
38	12.2953
16.3832 ± 4.57762
38	12.3186
15.6495 ± 4.38593
38	12.1471
37	12.0708
15.8043 ± 4.48156
16.2203 ± 4.60673
38	12.5328
16.4502 ± 4.48008
38	11.6321
15.3903 ± 4.57523
39	11.6382
15.0263 ± 4.50441
0
11
29
20
16
18
10
4
9
1
8
23
15
21
14
3
17
2
31
12
27
13
26
6
24
25
7
22
28
19
30
5
0 sends to 0
0 receives from 0
3 sends to 20
3 receives from 15
13 sends to 21
13 receives from 21
20 sends to 27
20 receives from 3
17 sends to 2
17 receives from 16
39	12.7799
30 sends to 30
30 receives from 30
16.786 ± 4.41929
39	11.9074
22 sends to 26
22 receives from 27
39	11.7897
39	11.3636
15.7504 ± 4.53496
15.0329 ± 4.55478
21 sends to 13
21 receives from 13
16 sends to 17
16 receives from 4
9 sends to 1
9 receives from 8
23 sends to 6
23 receives from 11
39	11.7284
15.862 ± 4.59162
18 sends to 31
18 receives from 5
25 sends to 25
25 receives from 25
39	12.2764
16.105 ± 4.52285
28 sends to 28
28 receives from 28
39	12.2228
39	12.2228
39	12.1432
16.0447 ± 4.55455
6 sends to 10
6 receives from 23
39	12.3613
15.873 ± 4.39869
24 sends to 24
24 receives from 24
10 sends to 8
10 receives from 6
39	11.7752
39	11.6537
15.1521 ± 4.48174
2 sends to 29
2 receives from 17
15 sends to 3
15 receives from 12
38	12.064
15.9989 ± 4.59748
12 sends to 15
12 receives from 19
39	12.5816
39	12.5573
16.4119 ± 4.45913
29 sends to 19
29 receives from 2
4 sends to 16
4 receives from 7
27 sends to 22
27 receives from 20
5 sends to 18
5 receives from 31
8 sends to 9
8 receives from 10
26 sends to 7
26 receives from 22
31 sends to 5
31 receives from 18
39	11.7934
15.2824 ± 4.39795
40	12.3329
40	11.7897
40	11.7844
40	11.777
11 sends to 23
11 receives from 1
40	12.017
40	11.8337
40	11.6454
40	11.4891
40	11.3636
19 sends to 12
19 receives from 29
16.9444 ± 4.35716
16.6188 ± 4.4227
40	11.4766
14.933 ± 4.53837
1 sends to 11
1 receives from 9
39	11.9703
15.4609 ± 4.44794
14 sends to 14
14 receives from 14
40	11.9485
15.3166 ± 4.45035
40	12.2899
40	12.1832
15.8687 ± 4.42165
40	11.7298
16.0435 ± 4.50138
40	11.6537
17.0254 ± 4.36309
40	11.6164
40	11.6146
40	11.4976
40	12.0025
16.1889 ± 4.34066
15.1899 ± 4.53972
7 sends to 4
7 receives from 26
17.1573 ± 4.32369
40	11.7284
40	11.7195
16.6872 ± 4.31546
40	11.5872
16.4942 ± 4.27343
40	11.6321
40	11.567
40	11.5643
16.1361 ± 4.3863
40	11.7378
40	11.4279
40	11.3024
16.6169 ± 4.38658
40	11.763
40	11.6164
16.3311 ± 4.29727
41	11.9381
16.0493 ± 4.4809
41	11.625
41	11.9752
41	11.6142
41	11.5911
40	11.8724
15.9678 ± 4.42369
41	11.5613
15.4327 ± 4.49454
15.7343 ± 4.40925
15.7135 ± 4.5455
40	11.7765
16.1723 ± 4.2481
41	11.5461
16.7488 ± 4.46594
41	11.3146
40	11.7482
41	11.5956
15.1226 ± 4.56088
16.3122 ± 4.39452
16.5258 ± 4.32661
41	11.5851
41	11.5783
41	11.5641
16.4445 ± 4.32745
40	12.064
16.4004 ± 4.33556
41	11.521
16.0559 ± 4.5227
42	11.3605
16.0868 ± 4.36551
42	11.7541
42	11.7397
16.3 ± 4.53803
41	11.5251
16.37 ± 4.4156
42	11.9254
42	11.8034
42	11.5366
15.8425 ± 4.4721
42	11.4037
15.7232 ± 4.45613
41	11.7537
41	11.7448
15.9372 ± 4.33175
41	11.7436
41	11.6239
16.6145 ± 4.30696
42	11.6603
42	11.4696
15.5816 ± 4.56523
16.4398 ± 4.5695
42	11.5829
42	11.5671
41	12.0124
16.4963 ± 4.41422
16.1209 ± 4.47019
16.0588 ± 4.55892
42	11.5567
16.327 ± 4.46193
43	11.2917
15.8831 ± 4.47375
43	11.7777
43	11.7261
43	11.6701
15.6106 ± 4.4808
43	11.3963
15.4686 ± 4.5514
43	11.5388
43	11.621
15.7523 ± 4.50697
15.757 ± 4.56514
43	11.6373
42	11.7259
43	12.0868
42	11.5655
16.3409 ± 4.55374
16.0896 ± 4.52453
15.3848 ± 4.50627
43	11.498
15.4944 ± 4.60219
44	11.7168
15.7068 ± 4.59015
43	11.4037
43	11.3146
16.0253 ± 4.53461
15.4887 ± 4.59154
44	12.2601
16.359 ± 4.55651
44	11.6574
44	11.6444
43	11.7005
15.448 ± 4.53488
15.9144 ± 4.50622
44	11.3763
15.2279 ± 4.55612
44	12.316
16.0688 ± 4.50095
44	11.9941
44	11.312
44	11.279
14.852 ± 4.59455
44	11.4738
44	11.9258
15.8443 ± 4.52031
15.9209 ± 4.52817
15.4638 ± 4.55776
44	11.4037
15.7197 ± 4.57813
44	11.4653
15.2916 ± 4.59273
44	11.3963
15.6318 ± 4.59198
44	11.7055
15.7618 ± 4.59825
44	11.5251
44	11.312
45	11.279
15.3069 ± 4.55582
15.5223 ± 4.60134
15.2883 ± 4.60041
44	11.6973
15.6949 ± 4.52649
45	11.6317
15.2297 ± 4.4999
45	11.3529
15.0274 ± 4.52061
44	11.5774
15.6866 ± 4.58876
45	12.2622
15.859 ± 4.44858
45	11.3814
45	11.3603
15.4121 ± 4.50448
46	11.622
45	11.3529
15.2963 ± 4.57263
15.3333 ± 4.59583
46	11.629
15.1335 ± 4.47862
46	11.3224
14.9001 ± 4.50634
46	11.4411
15.091 ± 4.56043
46	12.2596
15.7272 ± 4.47394
46	11.338
15.2478 ± 4.56867
46	12.0512
15.7728 ± 4.56472
46	11.7055
15.3681 ± 4.54681
46	11.6335
15.137 ± 4.56981
46	11.279
14.9934 ± 4.60583
47	11.279
14.8141 ± 4.50484
46	11.9752
15.2956 ± 4.40417
47	11.9941
15.5691 ± 4.47389
48	11.5939
15.2366 ± 4.57744
47	11.338
47	11.2864
14.9761 ± 4.56033
47	11.6869
47	11.5874
15.2838 ± 4.56923
47	11.5201
15.1538 ± 4.56717
48	11.5201
15.0713 ± 4.51415
48	11.5979
48	11.338
14.9994 ± 4.57963
48	11.5214
16.1376 ± 4.36617
48	12.0482
15.6584 ± 4.57894
48	11.279
21
16
9
5
13
2
15
7
22
25
28
3
1
4
0
10
6
11
18
27
20
19
14
17
12
23
24
30
8
29
26
31
0 sends to 21
0 receives from 14
13 sends to 4
13 receives from 4
28 sends to 8
28 receives from 10
17 sends to 11
17 receives from 23
14.8934 ± 4.62632
25 sends to 23
25 receives from 9
30 sends to 26
30 receives from 27
21 sends to 19
21 receives from 0
2 sends to 9
2 receives from 5
23 sends to 17
23 receives from 25
5 sends to 2
5 receives from 3
9 sends to 25
9 receives from 2
18 sends to 18
18 receives from 18
49	11.4976
15 sends to 10
15 receives from 6
15.0289 ± 4.57787
10 sends to 28
10 receives from 15
19 sends to 27
19 receives from 21
27 sends to 30
27 receives from 19
29 sends to 29
29 receives from 29
22 sends to 14
22 receives from 8
31 sends to 31
31 receives from 31
20 sends to 20
20 receives from 20
3 sends to 5
3 receives from 11
16 sends to 6
16 receives from 1
26 sends to 24
26 receives from 30
8 sends to 22
8 receives from 28
50	11.622
50	11.6093
50	11.5577
15.3512 ± 4.53031
12 sends to 1
12 receives from 24
1 sends to 16
1 receives from 12
14 sends to 0
14 receives from 22
11 sends to 3
11 receives from 17
6 sends to 15
6 receives from 16
50	11.8737
50	11.5829
50	11.4256
50	11.279
15.9832 ± 4.3344
15.8781 ± 4.35232
50	11.7794
50	11.6441
50	11.6231
50	11.4976
16.4925 ± 4.44437
7 sends to 7
7 receives from 7
49	11.9254
50	11.9566
50	11.9501
50	11.3024
15.3378 ± 4.42218
24 sends to 12
24 receives from 26
4 sends to 13
4 receives from 13
16.7877 ± 4.37931
50	11.5161
50	11.279
15.6522 ± 4.49834
50	11.279
15.3225 ± 4.63597
50	11.5774
16.7803 ± 4.34451
50	11.312
50	11.3636
15.2818 ± 4.53038
14.9762 ± 4.53562
51	11.312
15.0931 ± 4.56056
50	11.7492
50	11.6702
50	11.5322
50	11.5201
50	11.5874
16.0933 ± 4.21914
15.4167 ± 4.45929
50	11.279
15.9455 ± 4.34194
50	11.8757
50	11.6066
50	11.5939
16.331 ± 4.38276
51	11.312
14.9544 ± 4.58711
52	11.5197
15.827 ± 4.56429
52	11.279
14.8649 ± 4.53998
52	11.3146
15.467 ± 4.55372
52	11.279
14.9793 ± 4.61333
53	11.5087
15.2239 ± 4.64831
52	11.5581
14.8645 ± 4.46902
53	11.279
15.2153 ± 4.54435
53	11.3306
15.3872 ± 4.62028
53	11.3146
15.5061 ± 4.57593
53	11.5197
15.6189 ± 4.56394
53	11.5187
15.385 ± 4.5376
54	11.2864
15.1389 ± 4.5838
55	11.279
15.0079 ± 4.58122
56	11.279
14.6139 ± 4.49247
56	11.312
14.9485 ± 4.61817
57	11.279
14.8865 ± 4.60465
56	11.5012
14.8604 ± 4.44251
57	11.3972
57	11.374
15.1932 ± 4.39911
58	11.279
14.8219 ± 4.56283
58	11.5187
14.9623 ± 4.49412
59	11.629
59	11.4653
14.9627 ± 4.46568
14.8396 ± 4.47975
5
18
16
27
21
15
6
0
8
17
31
25
12
13
22
1
29
19
9
7
2
11
20
28
4
3
30
23
14
10
26
24
0 sends to 5
0 receives from 7
16 sends to 29
16 receives from 2
1 sends to 18
1 receives from 15
10 sends to 31
10 receives from 29
2 sends to 16
2 receives from 20
6 sends to 6
6 receives from 6
3 sends to 27
3 receives from 25
5 sends to 15
5 receives from 0
22 sends to 20
22 receives from 14
29 sends to 10
29 receives from 16
23 sends to 28
23 receives from 27
20 sends to 2
20 receives from 22
27 sends to 23
27 receives from 3
21 sends to 11
21 receives from 4
17 sends to 19
17 receives from 9
18 sends to 9
18 receives from 1
19 sends to 7
19 receives from 17
26 sends to 30
26 receives from 30
25 sends to 3
25 receives from 11
30 sends to 26
30 receives from 26
31 sends to 24
31 receives from 10
12 sends to 12
12 receives from 12
28 sends to 14
28 receives from 23
13 sends to 13
13 receives from 13
8 sends to 8
8 receives from 8
4 sends to 21
4 receives from 24
7 sends to 0
7 receives from 19
14 sends to 22
14 receives from 28
9 sends to 17
9 receives from 18
15 sends to 1
15 receives from 5
11 sends to 25
11 receives from 21
60	11.279
60	11.5124
60	11.4916
24 sends to 4
24 receives from 31
60	11.279
60	11.3946
60	11.279
60	11.4046
60	11.279
14.6554 ± 4.50504
15.056 ± 4.52682
14.8887 ± 4.55796
15.8794 ± 4.3563
15.8958 ± 4.284
60	11.4976
60	11.4861
60	11.4653
60	11.3146
15.0531 ± 4.57031
60	11.3946
60	11.279
15.2549 ± 4.53415
60	11.279
60	11.3946
60	11.279
15.9831 ± 4.33756
15.1511 ± 4.46471
60	11.374
15.6839 ± 4.31785
60	11.279
15.6866 ± 4.3349
60	11.279
15.817 ± 4.328
60	11.279
15.7099 ± 4.33908
60	11.312
60	11.279
15.0319 ± 4.62684
14.9297 ± 4.52052
61	11.374
15.7674 ± 4.39917
62	11.312
14.9932 ± 4.61944
63	11.279
14.8104 ± 4.50163
66	11.3306
15.3001 ± 4.57541
67	11.279
14.7826 ± 4.54608
10
2
31
0
16
13
3
7
8
21
15
26
14
5
27
9
17
1
19
11
20
29
22
4
24
25
30
12
18
6
23
28
0 sends to 10
0 receives from 3
18 sends to 19
18 receives from 28
19 sends to 11
19 receives from 18
26 sends to 30
26 receives from 11
31 sends to 28
31 receives from 2
25 sends to 25
25 receives from 25
30 sends to 23
30 receives from 26
7 sends to 7
7 receives from 7
16 sends to 17
16 receives from 4
1 sends to 2
1 receives from 17
10 sends to 15
10 receives from 0
6 sends to 3
6 receives from 29
3 sends to 0
3 receives from 6
11 sends to 26
11 receives from 19
13 sends to 5
13 receives from 5
5 sends to 13
5 receives from 13
8 sends to 8
8 receives from 8
12 sends to 14
12 receives from 27
28 sends to 18
28 receives from 31
29 sends to 6
29 receives from 21
23 sends to 4
23 receives from 30
14 sends to 27
14 receives from 12
20 sends to 20
20 receives from 20
15 sends to 9
15 receives from 10
27 sends to 12
27 receives from 14
24 sends to 24
24 receives from 24
17 sends to 1
17 receives from 16
2 sends to 31
2 receives from 1
9 sends to 21
9 receives from 15
21 sends to 29
21 receives from 9
22 sends to 22
22 receives from 22
4 sends to 16
4 receives from 23
70	11.4256
70	11.279
70	11.279
15.926 ± 4.35024
14.8885 ± 4.52701
70	11.279
15.8962 ± 4.32174
70	11.279
15.6996 ± 4.31579
70	11.279
15.7274 ± 4.34063
70	11.279
14.9675 ± 4.60062
73	11.279
14.7272 ± 4.53279
23
27
17
6
20
8
30
9
18
24
29
11
12
19
7
15
2
13
4
16
22
21
14
0
10
3
25
26
28
5
1
31
0 sends to 23
0 receives from 23
9 sends to 24
9 receives from 7
5 sends to 8
5 receives from 29
26 sends to 25
26 receives from 27
28 sends to 28
28 receives from 28
20 sends to 22
20 receives from 4
10 sends to 29
10 receives from 24
27 sends to 26
27 receives from 1
24 sends to 10
24 receives from 9
13 sends to 19
13 receives from 17
8 sends to 18
8 receives from 5
30 sends to 1
30 receives from 6
21 sends to 21
21 receives from 21
25 sends to 3
25 receives from 26
1 sends to 27
1 receives from 30
15 sends to 15
15 receives from 15
2 sends to 17
2 receives from 16
3 sends to 6
3 receives from 25
14 sends to 7
14 receives from 22
19 sends to 16
19 receives from 13
31 sends to 31
31 receives from 31
29 sends to 5
29 receives from 10
17 sends to 13
17 receives from 2
6 sends to 30
6 receives from 3
7 sends to 9
7 receives from 14
11 sends to 11
11 receives from 11
12 sends to 12
12 receives from 12
22 sends to 14
22 receives from 20
18 sends to 4
18 receives from 8
23 sends to 0
23 receives from 0
16 sends to 2
16 receives from 19
80	11.279
15.7638 ± 4.32667
80	11.279
14.7271 ± 4.56061
4 sends to 20
4 receives from 18
11
15
12
20
17
26
7
25
23
29
14
8
3
13
2
6
18
21
19
5
30
1
22
24
10
16
0
27
4
9
28
31
0 sends to 11
0 receives from 26
16 sends to 18
16 receives from 25
1 sends to 15
1 receives from 21
10 sends to 14
10 receives from 24
6 sends to 7
6 receives from 15
9 sends to 29
9 receives from 29
3 sends to 20
3 receives from 12
11 sends to 8
11 receives from 0
13 sends to 13
13 receives from 13
5 sends to 26
5 receives from 19
8 sends to 23
8 receives from 11
12 sends to 3
12 receives from 2
22 sends to 22
22 receives from 22
28 sends to 4
28 receives from 30
29 sends to 9
29 receives from 9
23 sends to 24
23 receives from 8
14 sends to 2
14 receives from 10
15 sends to 6
15 receives from 1
27 sends to 27
27 receives from 27
24 sends to 10
24 receives from 23
21 sends to 1
21 receives from 17
17 sends to 21
17 receives from 4
18 sends to 19
18 receives from 16
19 sends to 5
19 receives from 18
26 sends to 0
26 receives from 5
31 sends to 31
31 receives from 31
25 sends to 16
25 receives from 7
30 sends to 28
30 receives from 20
7 sends to 25
7 receives from 6
2 sends to 12
2 receives from 14
4 sends to 17
4 receives from 28
20 sends to 30
20 receives from 3
0
27
16
21
28
15
6
12
1
3
11
18
7
2
14
9
23
13
26
4
20
29
19
24
17
30
10
31
22
5
8
25
0 sends to 0
0 receives from 0
16 sends to 23
16 receives from 2
10 sends to 11
10 receives from 26
3 sends to 21
3 receives from 9
13 sends to 2
13 receives from 17
5 sends to 15
5 receives from 29
8 sends to 1
8 receives from 30
22 sends to 19
22 receives from 28
28 sends to 22
28 receives from 4
23 sends to 24
23 receives from 16
27 sends to 31
27 receives from 1
24 sends to 17
24 receives from 23
19 sends to 4
19 receives from 22
31 sends to 25
31 receives from 27
1 sends to 27
1 receives from 8
26 sends to 10
26 receives from 18
18 sends to 26
18 receives from 11
29 sends to 5
29 receives from 21
6 sends to 6
6 receives from 6
25 sends to 30
25 receives from 31
14 sends to 14
14 receives from 14
15 sends to 9
15 receives from 5
7 sends to 12
7 receives from 12
12 sends to 7
12 receives from 7
9 sends to 3
9 receives from 15
4 sends to 28
4 receives from 19
11 sends to 18
11 receives from 10
21 sends to 29
21 receives from 3
17 sends to 13
17 receives from 24
20 sends to 20
20 receives from 20
30 sends to 8
30 receives from 25
2 sends to 16
2 receives from 13
4
13
2
18
10
5
25
22
15
1
19
6
20
24
31
3
26
17
12
30
28
21
0
23
7
11
8
27
16
29
9
14
0 sends to 4
0 receives from 22
23 sends to 23
23 receives from 23
22 sends to 0
22 receives from 7
14 sends to 31
14 receives from 31
21 sends to 21
21 receives from 21
10 sends to 19
10 receives from 4
25 sends to 11
25 receives from 6
26 sends to 8
26 receives from 16
9 sends to 1
9 receives from 30
4 sends to 10
4 receives from 0
24 sends to 7
24 receives from 13
7 sends to 22
7 receives from 24
31 sends to 14
31 receives from 14
27 sends to 27
27 receives from 27
5 sends to 5
5 receives from 5
15 sends to 3
15 receives from 8
19 sends to 30
19 receives from 10
6 sends to 25
6 receives from 11
12 sends to 20
12 receives from 18
28 sends to 16
28 receives from 20
1 sends to 13
1 receives from 9
3 sends to 18
3 receives from 15
29 sends to 29
29 receives from 29
20 sends to 28
20 receives from 12
11 sends to 6
11 receives from 25
16 sends to 26
16 receives from 28
8 sends to 15
8 receives from 26
17 sends to 17
17 receives from 17
13 sends to 24
13 receives from 1
2 sends to 2
2 receives from 2
18 sends to 12
18 receives from 3
30 sends to 9
30 receives from 19
23
1
10
21
13
12
27
5
0
19
2
11
7
9
31
29
8
17
14
4
3
24
20
16
30
25
26
18
28
22
6
15
27 sends to 18
27 receives from 6
21 sends to 24
21 receives from 3
0 sends to 23
0 receives from 8
7 sends to 5
7 receives from 12
10 sends to 2
10 receives from 2
5 sends to 12
5 receives from 7
23 sends to 16
23 receives from 0
4 sends to 13
4 receives from 19
3 sends to 21
3 receives from 20
20 sends to 3
20 receives from 22
11 sends to 11
11 receives from 11
31 sends to 15
31 receives from 14
19 sends to 4
19 receives from 9
29 sends to 22
29 receives from 15
25 sends to 25
25 receives from 25
26 sends to 26
26 receives from 26
22 sends to 20
22 receives from 29
1 sends to 1
1 receives from 1
28 sends to 28
28 receives from 28
16 sends to 8
16 receives from 23
6 sends to 27
6 receives from 30
13 sends to 9
13 receives from 4
17 sends to 17
17 receives from 17
8 sends to 0
8 receives from 16
14 sends to 31
14 receives from 18
2 sends to 10
2 receives from 10
24 sends to 30
24 receives from 21
18 sends to 14
18 receives from 27
12 sends to 7
12 receives from 5
9 sends to 19
9 receives from 13
15 sends to 29
15 receives from 31
30 sends to 6
30 receives from 24
1 sends to 27
1 receives from 22
10 sends to 4
10 receives from 19
2 sends to 13
2 receives from 18
3 sends to 26
3 receives from 20
11 sends to 16
11 receives from 28
4 sends to 9
4 receives from 10
5 sends to 0
5 receives from 7
8 sends to 8
8 receives from 8
22 sends to 1
22 receives from 13
28 sends to 11
28 receives from 16
23 sends to 19
23 receives from 12
20 sends to 3
20 receives from 27
27 sends to 20
27 receives from 1
26 sends to 17
26 receives from 3
25 sends to 12
25 receives from 29
24
27
13
26
9
0
6
5
8
29
4
16
23
22
14
18
28
7
2
10
3
21
1
19
15
12
17
20
11
25
30
31
0 sends to 24
0 receives from 5
16 sends to 28
16 receives from 11
13 sends to 22
13 receives from 2
7 sends to 5
7 receives from 17
21 sends to 21
21 receives from 21
31 sends to 31
31 receives from 31
24 sends to 15
24 receives from 0
17 sends to 7
17 receives from 26
6 sends to 6
6 receives from 6
15 sends to 18
15 receives from 24
18 sends to 2
18 receives from 15
19 sends to 10
19 receives from 23
9 sends to 29
9 receives from 4
14 sends to 14
14 receives from 14
12 sends to 23
12 receives from 25
29 sends to 25
29 receives from 9
30 sends to 30
30 receives from 30
15 sends to 15
15 receives from 15
27 sends to 12
27 receives from 10
24 sends to 7
24 receives from 0
21 sends to 21
21 receives from 21
19 sends to 28
19 receives from 17
26 sends to 25
26 receives from 5
24
1
17
5
2
26
6
4
8
14
27
3
20
29
18
15
10
19
30
28
11
21
22
9
7
0
25
12
16
31
13
23
0 sends to 24
0 receives from 25
7 sends to 4
7 receives from 24
16 sends to 10
16 receives from 28
2 sends to 17
2 receives from 4
6 sends to 6
6 receives from 6
3 sends to 5
3 receives from 11
11 sends to 3
11 receives from 20
13 sends to 29
13 receives from 30
5 sends to 26
5 receives from 3
8 sends to 8
8 receives from 8
20 sends to 11
20 receives from 12
31 sends to 23
31 receives from 29
1 sends to 1
1 receives from 1
17 sends to 19
17 receives from 2
9 sends to 14
9 receives from 23
18 sends to 30
18 receives from 14
4 sends to 2
4 receives from 7
28 sends to 16
28 receives from 19
10 sends to 27
10 receives from 16
23 sends to 9
23 receives from 31
22 sends to 22
22 receives from 22
29 sends to 31
29 receives from 13
14 sends to 18
14 receives from 9
12 sends to 20
12 receives from 27
25 sends to 0
25 receives from 26
30 sends to 13
30 receives from 18
0
9
2
8
17
23
22
26
15
1
13
12
24
10
14
7
29
11
19
3
20
4
6
5
27
25
18
30
28
31
16
21
0 sends to 0
0 receives from 0
7 sends to 26
7 receives from 15
16 sends to 29
16 receives from 30
1 sends to 9
1 receives from 9
10 sends to 13
10 receives from 13
2 sends to 2
2 receives from 2
6 sends to 22
6 receives from 22
9 sends to 1
9 receives from 1
3 sends to 8
3 receives from 19
11 sends to 12
11 receives from 17
4 sends to 17
4 receives from 21
13 sends to 10
13 receives from 10
5 sends to 23
5 receives from 23
8 sends to 15
8 receives from 3
12 sends to 24
12 receives from 11
22 sends to 6
22 receives from 6
28 sends to 28
28 receives from 28
29 sends to 31
29 receives from 16
14 sends to 14
14 receives from 14
20 sends to 20
20 receives from 20
15 sends to 7
15 receives from 8
27 sends to 30
27 receives from 24
24 sends to 27
24 receives from 12
21 sends to 4
21 receives from 31
17 sends to 11
17 receives from 4
18 sends to 19
18 receives from 26
19 sends to 3
19 receives from 18
26 sends to 18
26 receives from 7
31 sends to 21
31 receives from 29
25 sends to 25
25 receives from 25
23 sends to 5
23 receives from 5
30 sends to 16
30 receives from 27
21
1
12
2
22
13
6
20
30
9
27
17
0
31
26
7
3
11
18
19
23
5
4
29
15
25
28
24
16
8
10
14
0 sends to 21
0 receives from 12
10 sends to 27
10 receives from 30
6 sends to 6
6 receives from 6
3 sends to 2
3 receives from 16
11 sends to 17
11 receives from 17
4 sends to 22
4 receives from 22
13 sends to 31
13 receives from 5
5 sends to 13
5 receives from 21
28 sends to 16
28 receives from 26
29 sends to 8
29 receives from 23
14 sends to 26
14 receives from 31
15 sends to 7
15 receives from 24
27 sends to 24
27 receives from 10
18 sends to 18
18 receives from 18
19 sends to 19
19 receives from 19
26 sends to 28
26 receives from 14
25 sends to 25
25 receives from 25
30 sends to 10
30 receives from 8
12 sends to 0
12 receives from 2
23 sends to 29
23 receives from 20
9 sends to 9
9 receives from 9
2 sends to 12
2 receives from 3
31 sends to 14
31 receives from 13
22 sends to 4
22 receives from 4
17 sends to 11
17 receives from 11
1 sends to 1
1 receives from 1
20 sends to 23
20 receives from 7
21 sends to 5
21 receives from 0
8 sends to 30
8 receives from 29
16 sends to 3
16 receives from 28
7 sends to 20
7 receives from 15
24 sends to 15
24 receives from 27
6
22
1
4
24
5
20
27
7
8
26
14
12
15
0
10
28
19
18
9
13
21
3
23
17
11
31
2
25
29
30
16
0 sends to 6
0 receives from 14
4 sends to 24
4 receives from 3
13 sends to 15
13 receives from 20
5 sends to 5
5 receives from 5
22 sends to 3
22 receives from 1
28 sends to 25
28 receives from 16
29 sends to 29
29 receives from 29
23 sends to 23
23 receives from 23
27 sends to 2
27 receives from 7
17 sends to 19
17 receives from 24
18 sends to 18
18 receives from 18
26 sends to 31
26 receives from 10
25 sends to 11
25 receives from 28
10 sends to 26
10 receives from 15
2 sends to 1
2 receives from 27
6 sends to 20
6 receives from 0
9 sends to 8
9 receives from 19
3 sends to 4
3 receives from 22
1 sends to 22
1 receives from 2
12 sends to 12
12 receives from 12
31 sends to 16
31 receives from 26
21 sends to 21
21 receives from 21
14 sends to 0
14 receives from 11
30 sends to 30
30 receives from 30
11 sends to 14
11 receives from 25
16 sends to 28
16 receives from 31
7 sends to 27
7 receives from 8
8 sends to 7
8 receives from 9
20 sends to 13
20 receives from 6
15 sends to 10
15 receives from 13
19 sends to 9
19 receives from 17
24 sends to 17
24 receives from 4
2 sends to 10
2 receives from 24
6 sends to 13
6 receives from 21
3 sends to 9
3 receives from 15
11 sends to 25
11 receives from 10
4 sends to 23
4 receives from 23
5 sends to 20
5 receives from 14
8 sends to 26
8 receives from 16
12 sends to 7
12 receives from 7
22 sends to 27
22 receives from 19
28 sends to 21
28 receives from 18
29 sends to 1
29 receives from 26
23 sends to 4
23 receives from 4
21 sends to 6
21 receives from 28
26 sends to 29
26 receives from 8
25 sends to 16
25 receives from 11
30 sends to 30
30 receives from 30
0
24
10
9
23
20
13
12
26
17
11
25
7
15
5
3
8
18
28
22
31
6
27
4
2
16
29
19
21
1
30
14
0 sends to 0
0 receives from 0
16 sends to 8
16 receives from 25
31 sends to 14
31 receives from 20
13 sends to 15
13 receives from 6
14 sends to 5
14 receives from 31
7 sends to 12
7 receives from 12
18 sends to 28
18 receives from 17
1 sends to 24
1 receives from 29
10 sends to 11
10 receives from 2
27 sends to 19
27 receives from 22
20 sends to 31
20 receives from 5
9 sends to 17
9 receives from 3
15 sends to 3
15 receives from 13
19 sends to 22
19 receives from 27
24 sends to 2
24 receives from 1
17 sends to 18
17 receives from 9
16
28
17
23
4
12
20
26
6
9
2
10
13
14
29
27
7
15
3
19
22
0
8
11
1
31
5
18
24
21
25
30
0 sends to 16
0 receives from 21
6 sends to 20
6 receives from 8
29 sends to 21
29 receives from 14
23 sends to 11
23 receives from 3
26 sends to 5
26 receives from 7
25 sends to 31
25 receives from 30
13 sends to 14
13 receives from 12
28 sends to 24
28 receives from 1
14 sends to 29
14 receives from 13
12 sends to 13
12 receives from 5
10 sends to 2
10 receives from 11
5 sends to 12
5 receives from 26
8 sends to 6
8 receives from 22
16 sends to 7
16 receives from 0
7 sends to 26
7 receives from 16
21 sends to 0
21 receives from 29
4 sends to 4
4 receives from 4
30 sends to 25
30 receives from 31
31 sends to 30
31 receives from 25
20 sends to 22
20 receives from 6
3 sends to 23
3 receives from 18
11 sends to 10
11 receives from 23
1 sends to 28
1 receives from 24
27 sends to 18
27 receives from 15
15 sends to 27
15 receives from 17
24 sends to 1
24 receives from 28
9 sends to 9
9 receives from 9
18 sends to 3
18 receives from 27
22 sends to 8
22 receives from 20
19 sends to 19
19 receives from 19
2 sends to 17
2 receives from 10
17 sends to 15
17 receives from 2
14.7165 ± 4.52889
{0, 38, 30, 23, 25, 18, 26, 8, 16, 45, 41, 44, 24, 31, 3, 13, 35, 6, 49, 5, 12, 9, 29, 42, 7, 43, 39, 17, 48, 33, 19, 40, 36, 21, 37, 2, 20, 27, 46, 14, 15, 28, 10, 47, 22, 1, 4, 32, 11, 34};
Noooooo
Execution time: 95.1692 s
14.7006 ± 4.55493
Noooooo
Execution time: 94.9976 s
14.6933 ± 4.53999
Noooooo
Execution time: 95.1467 s
14.692 ± 4.58118
Noooooo
Execution time: 95.0757 s
14.6329 ± 4.48554
Noooooo
14.7015 ± 4.50398
Noooooo
Execution time: 95.1384 s
Execution time: 95.0781 s
14.7501 ± 4.5732
14.7345 ± 4.59954
Noooooo
Noooooo
Execution time: 94.9201 s
Execution time: 95.3493 s
14.7486 ± 4.60565
Noooooo
Execution time: 95.284 s
14.6899 ± 4.57923
Noooooo
Execution time: 95.2201 s
14.7161 ± 4.5355
Noooooo
14.8082 ± 4.60281
14.6608 ± 4.54575
Noooooo
Noooooo
Execution time: 95.4672 s
Execution time: 95.0572 s
Execution time: 95.2261 s
14.6668 ± 4.53978
Noooooo
Execution time: 95.2727 s
14.6515 ± 4.52607
Noooooo
14.6277 ± 4.51443
Noooooo
Execution time: 95.1981 s
Execution time: 95.2164 s
14.6809 ± 4.53338
Noooooo
Execution time: 95.3009 s
14.6461 ± 4.53682
Noooooo
Execution time: 95.1025 s
14.7474 ± 4.59562
Noooooo
Execution time: 95.2622 s
14.7358 ± 4.57998
Noooooo
Execution time: 95.376 s
14.6689 ± 4.51515
Noooooo
Execution time: 95.3602 s
14.7473 ± 4.57906
Noooooo
Execution time: 95.1328 s
14.7495 ± 4.55617
Noooooo
Execution time: 95.6272 s
14.7303 ± 4.59865
Noooooo
Execution time: 95.6277 s
14.7225 ± 4.58174
Noooooo
Execution time: 95.4878 s
14.7013 ± 4.56164
Noooooo
Execution time: 95.4704 s
14.7011 ± 4.55
Noooooo
Execution time: 95.7863 s
14.7274 ± 4.58004
Noooooo
Execution time: 95.718 s
14.6772 ± 4.56301
Noooooo
14.638 ± 4.52221
Noooooo
Execution time: 95.6076 s
14.7136 ± 4.51328
Noooooo
Execution time: 95.553 s
14.6583 ± 4.53833
Noooooo
Execution time: 95.8648 s
A system call failed during shared memory initialization that should
not have.  It is likely that your MPI job will now either abort or
experience performance degradation.
  Local host:  fabios-iMac-Pro.lan
  System call: unlink(2) /var/folders/y4/h1hd2tzn06dblldr8c26sdsc0000gn/T//ompi.fabios-iMac-Pro.501/pid.1125/1/vader_segment.fabios-iMac-Pro.7a300001.30
  Error:       No such file or directory (errno 2)
[fabios-iMac-Pro.lan:01125] 2 more processes have sent help message help-opal-shmem-mmap.txt / sys call fail
[fabios-iMac-Pro.lan:01125] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
fabio@fabios-iMac-Pro ~ % mpirun --use-hwthread-cpus ~/Downloads/T_S_P
Thread 39 of 64
Thread 13 of 64
Thread 7 of 64
Thread 30 of 64
Thread 48 of 64
Thread 52 of 64
Thread 0 of 64
Thread 18 of 64
Thread 3 of 64
Thread 14 of 64
Thread 23 of 64
Thread 6 of 64
Thread 31 of 64
Thread 34 of 64
Thread 37 of 64
Thread 36 of 64
Thread 44 of 64
Thread 50 of 64
Thread 61 of 64
Thread 57 of 64
Thread 60 of 64
Thread 24 of 64
Thread 25 of 64
Thread 19 of 64
Thread 32 of 64
Thread 16 of 64
Thread 33 of 64
Thread 20 of 64
Thread 43 of 64
Thread 41 of 64
Thread 59 of 64
Thread 1 of 64
Thread 4 of 64
Thread 29 of 64
Thread 22 of 64
Thread 35 of 64
Thread 51 of 64
Thread 56 of 64
Thread 12 of 64
Thread 21 of 64
Thread 5 of 64
Thread 8 of 64
Thread 9 of 64
Thread 10 of 64
Thread 40 of 64
Thread 42 of 64
Thread 46 of 64
Thread 47 of 64
Thread 49 of 64
Thread 53 of 64
Thread 62 of 64
Thread 63 of 64
Thread 2 of 64
Thread 17 of 64
Thread 26 of 64
Thread 28 of 64
Thread 27 of 64
Thread 15 of 64
Thread 45 of 64
Thread 54 of 64
Thread 55 of 64
Thread 11 of 64
Thread 38 of 64
Thread 58 of 64
25
51
49
3
4
5
39
7
8
9
33
11
46
53
54
48
16
28
44
19
15
21
61
22
0
34
26
27
29
17
20
56
32
10
13
50
36
37
38
6
14
41
42
43
18
45
23
47
63
2
35
59
12
30
40
55
31
52
62
1
60
24
58
57
0 sends to 25
0 receives from 24
10 sends to 33
10 receives from 33
40 sends to 14
40 receives from 54
26 sends to 26
26 receives from 26
39 sends to 6
39 receives from 6
54 sends to 40
54 receives from 14
41 sends to 41
41 receives from 41
47 sends to 47
47 receives from 47
24 sends to 0
24 receives from 61
14 sends to 54
14 receives from 40
49 sends to 2
49 receives from 2
38 sends to 38
38 receives from 38
16 sends to 16
16 receives from 16
61 sends to 24
61 receives from 22
30 sends to 20
30 receives from 53
25 sends to 34
25 receives from 0
17 sends to 28
17 receives from 29
20 sends to 15
20 receives from 30
34 sends to 13
34 receives from 25
63 sends to 57
63 receives from 48
19 sends to 19
19 receives from 19
45 sends to 45
45 receives from 45
52 sends to 12
52 receives from 57
21 sends to 21
21 receives from 21
7 sends to 7
7 receives from 7
28 sends to 29
28 receives from 17
22 sends to 61
22 receives from 23
42 sends to 42
42 receives from 42
53 sends to 30
53 receives from 13
50 sends to 35
50 receives from 35
56 sends to 31
56 receives from 31
31 sends to 56
31 receives from 56
37 sends to 37
37 receives from 37
8 sends to 8
8 receives from 8
43 sends to 43
43 receives from 43
13 sends to 53
13 receives from 34
9 sends to 9
9 receives from 9
36 sends to 36
36 receives from 36
46 sends to 23
46 receives from 12
48 sends to 63
48 receives from 15
51 sends to 59
51 receives from 1
27 sends to 27
27 receives from 27
18 sends to 44
18 receives from 44
12 sends to 46
12 receives from 52
44 sends to 18
44 receives from 18
55 sends to 55
55 receives from 55
57 sends to 52
57 receives from 63
11 sends to 11
11 receives from 11
32 sends to 32
32 receives from 32
1 sends to 51
1 receives from 59
62 sends to 58
62 receives from 58
33 sends to 10
33 receives from 10
58 sends to 62
58 receives from 62
4 sends to 4
4 receives from 4
60 sends to 60
60 receives from 60
29 sends to 17
29 receives from 28
3 sends to 3
3 receives from 3
6 sends to 39
6 receives from 39
2 sends to 49
2 receives from 49
5 sends to 5
5 receives from 5
15 sends to 48
15 receives from 20
35 sends to 50
35 receives from 50
59 sends to 1
59 receives from 51
23 sends to 22
23 receives from 46
0	39.3377
0	36.3877
0	36.1005
0	35.5675
0	35.0981
0	34.7854
0	34.0425
0	37.2308
0	36.8787
0	35.2806
0	35.1963
0	34.9382
0	34.7803
0	33.8355
0	34.298
0	33.8344
0	33.2347
0	33.619
0	32.2239
0	32.9735
0	33.7373
0	33.1166
0	31.9554
0	37.4019
0	37.0083
0	36.689
0	36.3183
0	36.2303
0	35.8934
0	35.1151
0	32.2148
0	38.6148
0	36.0421
0	33.8354
0	37.5046
0	36.4137
0	36.0367
0	35.358
0	35.099
0	33.7375
0	33.719
0	35.0431
0	32.8724
0	34.6007
0	34.9823
0	34.7441
0	32.772
0	35.3594
0	35.3167
0	34.4155
0	35.1264
0	34.1289
0	33.6535
0	32.7068
0	33.3746
0	34.0876
0	37.3987
0	35.4439
0	34.6592
0	33.535
0	33.4461
0	32.6978
0	32.6292
0	31.4575
0	31.8038
0	33.2889
0	37.03
0	35.0969
0	34.563
0	32.5316
0	33.1685
0	34.5591
0	34.1284
43.3545 ± 5.1466
0	31.2756
0	37.2157
0	36.0818
0	35.0204
0	34.8615
0	35.5154
0	35.4474
0	33.5674
0	35.1466
0	34.4306
0	33.2353
0	39.3914
0	38.9496
0	38.8985
0	36.6609
0	34.4862
0	32.7189
0	34.2855
0	34.0762
0	33.3167
0	33.6812
0	34.2603
42.8721 ± 5.14612
0	32.0015
0	37.2289
0	35.5318
0	33.9513
0	33.146
0	35.6298
0	35.1955
0	35.0991
0	33.9043
0	32.8148
0	33.3039
0	38.6222
0	36.2469
0	34.6329
0	34.0816
0	33.0699
0	38.6555
0	37.478
0	37.4292
0	35.9079
0	32.5206
0	35.3394
43.4531 ± 5.27871
0	33.4315
0	32.4664
0	32.9669
0	36.6973
0	34.9473
0	32.3527
0	34.9338
0	33.5097
43.4827 ± 4.77666
0	34.781
0	37.0516
0	37.0328
0	36.1782
0	33.9177
0	32.5637
0	36.173
0	35.2308
0	35.1483
0	38.6008
0	36.5339
0	36.009
0	35.9959
0	35.9944
0	35.1286
0	34.2538
0	32.4491
43.7641 ± 5.34798
0	32.8106
0	37.3581
0	36.8964
0	36.7821
0	36.6532
0	36.1526
0	35.4003
0	34.5802
0	37.0899
0	36.9858
0	36.1666
42.9821 ± 5.04835
0	36.1229
0	35.931
0	38.1023
0	38.049
0	38.0394
0	35.9743
0	34.9255
0	34.6507
0	35.5422
0	34.9754
44.1841 ± 4.65678
0	34.7092
0	34.9507
0	37.4406
0	34.7364
0	38.4866
0	38.2803
0	35.8726
0	35.8587
0	34.9866
0	34.2944
0	32.5879
0	34.0411
0	33.8539
0	33.8422
0	34.1791
0	38.0266
0	37.5078
0	35.8835
0	35.1511
0	34.0196
0	34.7051
0	33.1017
0	33.4665
0	34.0895
0	33.3201
0	33.0636
0	32.3191
0	32.8197
0	34.3956
0	32.0757
43.1187 ± 5.23379
0	40.4095
0	36.8708
0	36.5784
0	35.5754
0	33.9319
0	33.8841
0	33.2096
0	34.2764
0	39.8408
0	36.1739
0	35.2069
0	34.1802
0	34.9037
0	34.8891
0	32.7534
0	32.9769
0	34.2751
0	33.8201
0	37.6614
0	37.5095
0	37.3116
0	36.8388
0	33.5736
0	33.3818
0	37.1162
0	36.6596
0	35.8605
0	35.5302
0	33.8081
0	33.2733
0	35.3184
0	34.9789
0	34.479
0	34.3383
0	36.3039
0	34.1354
0	34.0201
0	33.8624
0	34.2875
0	32.8931
0	32.9464
0	32.0454
0	33.2431
0	33.1325
0	33.8399
0	36.0193
43.555 ± 5.03993
43.9363 ± 5.40393
0	34.0852
0	33.8092
0	37.4376
0	35.1246
43.5008 ± 5.29752
42.8321 ± 5.60578
0	35.0631
0	34.9317
0	35.2531
0	34.5011
0	33.7201
43.3107 ± 5.02906
0	32.6073
43.3545 ± 4.76467
0	32.8195
0	33.0163
0	38.2086
0	37.9145
0	34.3101
0	34.2578
0	33.6546
0	33.4075
0	33.1892
0	32.5515
0	32.8432
0	33.4937
0	33.739
0	32.1446
0	34.4342
0	39.4399
0	37.5261
0	37.1358
0	36.9651
0	36.0935
0	35.1428
0	35.0652
0	33.3994
0	36.4867
43.2074 ± 5.09116
0	32.5235
0	35.9844
0	35.6864
0	32.4076
0	32.283
0	36.813
0	35.4837
0	35.0997
0	34.7716
0	34.7541
0	34.3651
0	35.635
0	35.542
0	33.8154
0	37.5819
0	37.4834
0	35.6372
0	35.628
0	34.4537
0	34.3315
0	34.3304
0	33.452
0	32.2209
0	34.9225
43.9872 ± 4.46857
0	33.4685
0	34.4291
0	32.8166
0	33.4245
0	32.8104
0	35.5142
0	32.3524
0	37.8231
0	35.5057
0	35.2975
0	34.8704
44.6201 ± 4.53802
0	33.9187
0	34.73
0	32.6468
0	32.7405
0	32.44
43.7592 ± 4.69233
0	35.0029
0	34.7038
0	34.9493
0	35.1086
0	33.8057
0	38.3423
0	38.0334
0	36.087
0	36.0833
0	35.8586
0	34.067
0	35.6347
0	35.4472
0	34.5946
44.1126 ± 4.55341
0	32.1247
0	31.7731
0	31.654
0	34.5177
0	32.6008
0	33.8133
0	32.579
42.6136 ± 5.23421
0	35.4177
0	34.5572
0	34.2453
0	34.0165
0	33.4606
43.6108 ± 5.00831
43.7793 ± 4.60762
0	34.554
0	33.4439
0	33.7665
0	33.4798
0	32.8537
43.758 ± 5.05914
0	32.6634
43.9681 ± 5.08817
0	32.742
43.9665 ± 4.96271
0	33.0352
0	31.9773
0	32.5093
0	33.9843
0	31.3796
0	37.0831
0	35.1283
0	34.8955
0	33.7786
0	36.8033
0	33.3404
0	32.5103
0	36.1294
0	34.4044
0	34.2244
0	33.8438
0	32.2151
0	32.67
0	37.7673
0	36.167
0	36.0661
0	35.7001
0	34.8031
0	34.7215
0	33.8891
44.0163 ± 4.90458
42.5598 ± 5.41342
44.9966 ± 4.72387
0	33.7305
0	33.6872
0	34.2372
0	31.3735
0	35.8575
0	35.2234
0	34.897
0	34.7111
0	34.4246
0	33.7379
0	36.1832
0	35.5585
0	35.2549
0	35.1311
0	35.1176
0	34.8669
0	33.7751
0	38.2003
0	35.6926
0	34.6482
0	34.4333
0	34.7847
0	33.1073
0	33.5102
0	33.4576
43.3141 ± 5.00196
43.5531 ± 5.0911
0	34.0615
0	33.5832
0	32.6877
0	32.6766
0	32.963
0	38.3114
0	37.7746
0	35.5336
0	35.4869
0	34.7955
0	33.6631
0	35.4648
0	31.9206
0	33.0093
0	33.1854
0	35.1755
44.1642 ± 4.75688
42.4094 ± 5.38689
0	38.9242
0	38.0982
0	36.0265
0	36.0205
0	35.0571
0	33.5477
0	35.4168
0	34.2047
0	33.7045
0	34.6831
0	34.5465
0	33.3555
0	33.4594
0	33.3352
0	34.6451
0	34.637
0	33.2559
44.065 ± 4.75108
44.1855 ± 4.75528
0	32.4696
0	33.4553
0	37.0304
0	37.014
0	36.79
0	36.6786
0	34.377
0	33.2623
0	33.0021
0	36.9578
0	36.2836
0	35.9286
0	35.7007
0	34.1455
0	34.015
0	33.4039
0	33.1318
0	32.1389
0	33.4079
0	32.1833
0	33.6432
0	32.4184
0	33.5715
44.2841 ± 4.80352
43.9899 ± 4.77788
0	32.1927
0	32.1231
0	31.9886
0	32.3568
0	38.2098
0	36.0867
0	34.8194
0	33.7175
0	33.4338
0	32.7101
43.6923 ± 5.08634
0	32.6718
0	32.6411
0	33.4085
0	31.9855
0	32.4868
0	38.8799
0	36.5489
0	31.1898
0	36.1606
0	32.6041
0	34.4842
0	37.8731
0	36.5877
43.3282 ± 4.95121
0	36.0387
0	36.361
0	35.7272
0	35.4536
0	36.6909
0	36.2813
0	36.2151
0	36.0058
0	34.2216
0	35.0379
0	32.0654
0	33.2098
0	35.1229
0	32.3507
0	32.9977
0	33.3805
0	32.5372
0	35.9674
0	35.9411
0	35.4802
0	35.4103
0	35.0743
0	33.2117
0	32.4627
0	33.06
0	32.1024
0	31.4216
43.6511 ± 5.23387
42.6063 ± 5.23695
0	33.9391
0	30.756
0	31.7675
0	39.4668
0	38.4304
0	38.1829
0	37.3707
0	36.2821
0	35.7772
0	35.5135
0	38.0726
0	36.2457
0	35.6978
0	35.4627
0	35.4522
0	35.5018
0	34.8177
0	33.6535
0	35.4344
0	34.8875
43.2345 ± 5.44097
0	32.7572
0	32.1601
0	31.1046
0	34.0901
0	33.1465
43.0962 ± 5.54139
0	34.7607
44.1954 ± 5.16054
0	35.8524
0	34.137
0	33.0444
0	32.638
0	32.2337
0	31.0175
0	30.3983
43.2966 ± 4.91934
0	33.0343
44.2786 ± 5.00943
43.1141 ± 5.37452
43.3685 ± 5.29778
43.017 ± 4.79472
0	29.2989
0	32.8556
0	38.1244
0	35.6193
0	35.2757
0	34.1152
43.5143 ± 5.15627
0	34.0434
43.467 ± 5.17901
0	32.2631
0	34.1934
0	34.0087
0	33.8751
42.9166 ± 4.93903
0	33.5669
0	33.5148
43.6363 ± 4.83382
43.6788 ± 5.21053
0	33.0271
0	36.566
0	36.5095
0	35.8411
0	35.3541
0	34.5157
0	33.2748
0	33.9952
44.0115 ± 4.97755
0	32.5601
42.7196 ± 5.38801
44.2893 ± 4.55963
42.8762 ± 4.98112
43.9043 ± 4.76067
0	33.5881
0	32.9209
43.0467 ± 5.05863
0	32.5024
0	31.8259
44.1226 ± 4.78529
44.027 ± 5.03676
42.3878 ± 5.51923
43.3098 ± 5.1026
44.2176 ± 4.72025
1	32.4235
1	32.369
1	31.2855
1	31.2739
1	33.7484
1	33.2127
1	32.3807
1	32.3236
1	31.6867
1	33.2901
1	33.1565
1	32.9483
1	32.7087
1	31.2071
1	31.48
1	32.357
1	31.3199
1	31.29
1	30.9344
1	30.4613
1	30.8823
1	30.9413
1	30.6523
1	30.2866
1	32.0944
1	32.0252
1	31.8274
1	30.1975
1	31.7786
1	29.9726
1	31.1824
1	32.6607
1	32.4343
1	31.9599
1	31.7561
1	31.7789
1	31.7239
1	30.0579
39.4669 ± 4.9621
1	31.704
1	30.7938
1	30.4682
1	31.1433
1	31.5055
1	31.2188
1	31.1738
1	31.0299
1	32.4009
1	32.3033
1	32.3225
1	31.7982
1	30.9056
1	31.9106
1	31.7767
40.4711 ± 4.86364
1	31.8466
1	30.9511
1	30.428
1	32.5615
1	32.4233
1	32.2158
1	31.6749
1	31.5933
1	32.4299
1	32.3581
1	31.5159
1	30.7705
1	30.5303
1	31.6068
1	31.3508
1	29.6928
1	31.623
1	32.9764
1	32.8038
1	32.7843
1	32.7373
1	32.0235
1	32.7681
1	32.0953
1	31.8715
1	30.5761
1	30.8494
1	32.7202
1	31.8034
40.0055 ± 4.80043
1	29.9951
1	31.4734
1	31.2963
1	32.7513
1	31.2455
1	32.5675
1	32.0809
1	30.7193
1	31.5021
1	31.1268
39.6734 ± 5.24428
1	30.5186
1	30.6481
1	32.0108
1	30.6854
1	32.5336
1	31.4033
1	30.8972
1	30.2421
1	30.4901
1	31.6973
1	29.4049
1	32.5175
1	31.0255
1	31.5676
1	32.0239
1	33.5848
1	32.7583
1	32.7529
1	32.1862
1	31.4225
1	31.9647
1	31.3931
39.3528 ± 4.79037
1	33.3592
1	31.9206
1	31.8483
1	31.3096
1	32.4967
1	29.9458
1	34.3459
1	30.5283
1	34.1658
1	33.1654
1	32.8602
1	32.248
1	31.1706
1	31.0789
40.0042 ± 5.22921
1	30.7194
39.7443 ± 4.92472
1	34.2677
1	32.5159
1	30.8148
1	32.5146
1	32.3471
1	31.047
1	29.2083
1	32.1575
1	32.1439
1	32.1024
1	31.8407
1	31.3051
39.386 ± 4.9619
40.1435 ± 5.07723
1	34.2365
1	33.3261
1	32.534
1	30.3073
1	30.5131
1	30.4643
1	30.7513
1	30.5763
1	30.5269
1	30.4702
1	30.1006
1	32.4702
1	31.7085
1	32.5997
1	32.2441
1	30.9942
1	31.0253
1	30.8007
39.6832 ± 4.98012
1	30.9933
40.0959 ± 5.02271
1	30.4557
39.5175 ± 4.93612
1	31.7411
1	32.4824
1	32.1071
1	31.1495
1	30.5002
1	32.5785
1	31.9513
1	31.1892
1	33.3202
1	33.2236
1	33.3382
1	32.9279
1	31.6651
1	31.8258
39.376 ± 4.78867
1	33.0122
1	31.3858
1	29.8283
1	30.8654
1	30.7206
1	32.8605
1	32.1952
40.2448 ± 4.56586
1	30.0861
41.3508 ± 4.66152
1	32.238
1	32.0418
1	31.5109
1	31.9728
1	31.1896
1	30.8097
1	29.6313
39.7889 ± 5.26231
1	31.4358
1	31.5472
1	29.3399
1	31.3834
39.3604 ± 5.13495
39.22 ± 5.37439
41.2219 ± 4.65223
1	31.8903
1	31.8118
1	31.7771
1	31.573
1	31.3039
1	30.4173
40.7034 ± 4.73351
1	30.3917
40.4995 ± 5.12605
1	31.3364
1	32.0569
1	32.5113
1	29.7642
1	31.8823
1	31.895
1	31.7595
1	31.4118
1	30.3477
1	29.5227
1	32.1955
1	31.5974
1	31.4907
1	31.6503
1	30.9388
1	29.2761
38.863 ± 5.03668
41.6951 ± 4.57672
40.6543 ± 5.03322
1	32.9291
1	31.8993
40.4331 ± 4.91225
1	29.84
40.2344 ± 4.72207
1	30.5683
1	30.7549
1	30.3998
1	30.9549
39.9528 ± 5.0197
1	31.8265
1	31.0956
1	31.7017
1	31.836
1	31.2923
1	30.9921
39.7917 ± 5.04972
39.0809 ± 5.31524
1	31.1231
1	30.7091
1	32.0232
41.201 ± 4.44203
1	30.7429
1	29.923
1	30.2629
1	31.4145
1	30.2362
1	29.7796
1	29.7393
1	31.1474
1	29.3948
40.2173 ± 5.24215
1	31.6413
1	31.0408
40.5499 ± 4.94843
1	28.6099
1	32.4295
38.6151 ± 5.05807
39.0049 ± 4.99901
1	31.8573
1	30.4029
1	31.7473
1	31.1783
40.8224 ± 5.0173
1	30.9533
1	31.7648
1	32.7376
1	31.1196
1	29.7744
1	30.1709
1	30.3515
1	30.91
1	28.4977
1	30.1972
40.9076 ± 4.62831
1	31.4655
1	31.1255
1	32.5192
1	32.1203
40.0185 ± 4.99511
1	30.9094
39.2284 ± 5.42014
1	27.9425
40.1637 ± 4.92887
1	33.7532
1	30.673
1	33.2867
1	32.6021
1	31.9457
1	32.0776
1	31.7228
1	31.6122
1	31.618
1	30.6072
1	31.1894
1	31.3541
1	33.1465
1	32.4731
1	32.4528
1	32.2537
1	30.8661
1	31.719
1	31.1877
1	29.9442
1	30.7548
1	31.2641
1	30.2336
40.1104 ± 5.38604
1	29.6117
1	27.7844
1	30.6664
1	33.832
40.1903 ± 5.39037
1	29.8968
1	30.9787
1	33.3595
1	32.0145
1	33.2598
1	29.7538
1	30.8433
1	29.1806
1	31.5429
1	28.8631
1	30.4333
1	30.3836
1	33.1583
1	28.8177
40.5768 ± 5.16717
1	29.6728
1	29.0936
40.1611 ± 5.04644
1	29.6141
1	28.7674
1	30.3601
1	28.6302
1	31.0469
1	32.5559
1	30.5755
1	33.7592
1	33.3665
1	32.7803
1	32.4636
1	32.3173
1	30.7498
1	31.4143
39.1746 ± 5.37464
41.0475 ± 5.43734
1	33.2784
1	33.1622
1	33.0426
1	31.6977
39.7846 ± 4.70867
1	31.6032
1	31.7916
1	31.7173
1	31.4402
1	30.7884
38.7626 ± 5.64693
1	30.18
1	30.4576
1	28.5101
40.3221 ± 5.01167
1	31.7953
39.7736 ± 4.95579
40.2807 ± 4.91862
38.9341 ± 4.96916
40.3248 ± 4.8078
1	28.4927
1	29.7207
1	28.3235
40.4379 ± 5.06955
1	30.2314
39.2891 ± 5.40465
40.0665 ± 5.0246
39.5538 ± 4.94189
40.7801 ± 4.95448
40.9084 ± 4.60539
1	29.0933
41.2724 ± 4.68216
1	30.1312
38.5608 ± 5.35072
38.1363 ± 5.47363
1	31.5944
41.081 ± 4.62991
40.6227 ± 4.76076
40.0165 ± 4.91909
2	30.8725
2	30.7012
2	29.768
2	29.6798
2	30.1761
2	29.9219
2	28.5012
2	29.3313
2	29.2065
2	30.1994
2	30.0131
2	29.6478
2	29.0285
2	29.54
2	28.3919
2	29.7756
2	29.6031
2	29.2242
2	29.2558
2	28.9515
2	27.9645
36.8101 ± 4.37478
2	30.3816
2	28.6443
2	30.2513
2	30.4674
2	30.434
2	30.3388
2	30.0987
2	30.0906
2	29.8026
2	29.7856
2	29.9853
2	31.6991
2	31.6984
2	31.2201
2	29.508
2	29.1088
2	28.4566
2	28.6228
2	30.0801
2	29.6515
2	32.3559
2	31.9664
2	31.5767
2	31.2086
2	30.3554
2	29.9061
36.9836 ± 4.72917
2	29.5802
2	29.6521
2	28.5989
2	30.7182
2	28.469
2	29.3699
2	29.4349
2	28.8935
2	28.2875
2	30.378
2	29.5712
36.8215 ± 4.96374
2	28.7112
2	30.5395
2	29.704
2	29.6631
2	29.4638
2	29.3724
2	28.1165
2	30.333
2	30.2325
37.3567 ± 4.73841
2	30.0045
2	29.1943
2	27.8585
2	29.9015
2	30.2233
2	29.357
2	28.706
36.6706 ± 4.54381
2	31.9058
2	31.898
2	31.829
2	30.7037
2	30.0191
2	29.58
2	29.192
2	29.1525
2	29.2197
2	28.8877
2	28.8783
2	28.8722
2	30.9698
2	28.1448
2	28.0568
2	30.9431
2	31.3633
2	30.5459
2	30.8934
2	30.3772
2	30.212
2	30.1942
2	27.619
2	30.0397
2	30.8579
2	31.1302
2	30.6925
2	29.7272
2	29.9633
2	29.5761
2	30.1011
2	30.1557
2	28.728
2	27.2096
2	29.709
2	29.6753
2	28.9833
2	29.307
36.9019 ± 4.5413
2	30.7226
2	30.5051
2	30.3711
2	29.5781
2	28.5832
2	29.9643
2	28.355
2	30.7892
2	30.7686
2	30.6014
36.7873 ± 4.58359
38.9244 ± 4.52964
37.1732 ± 4.8552
2	29.944
2	30.1431
2	29.7788
2	28.8554
2	29.3675
2	30.8015
2	30.3327
2	30.1094
2	29.9464
2	29.3292
2	28.8512
2	28.7078
2	30.3305
2	30.0455
2	29.2442
2	28.2257
2	31.7406
2	31.6527
2	31.5977
2	30.7257
2	29.3327
2	29.2206
2	29.0906
2	28.936
2	30.3363
2	28.7592
2	28.1232
2	30.6734
2	30.3052
2	30.034
2	29.709
2	29.0472
2	28.9777
2	28.8115
2	28.4146
2	29.0702
2	28.824
2	28.4686
36.4523 ± 4.97878
38.478 ± 4.59523
2	29.4487
2	28.9483
2	31.397
2	31.2852
2	30.9856
2	29.8221
2	30.2334
2	30.0422
2	30.0409
2	28.7371
36.8512 ± 4.65824
2	29.5827
2	30.689
2	30.4042
2	28.4833
36.4262 ± 4.68491
2	30.7222
2	28.579
2	30.6246
2	28.3551
36.596 ± 4.72536
2	28.5486
2	27.8844
2	31.3098
2	31.2813
2	30.3843
2	28.1343
2	28.6271
2	28.3265
2	28.914
2	27.9643
2	28.3934
2	29.8199
2	29.8804
2	29.2961
2	30.6565
2	30.0876
2	29.593
2	30.5132
36.7415 ± 4.81092
2	28.0656
2	28.4879
2	29.7122
2	28.9133
37.9162 ± 4.39114
2	27.7677
2	29.0761
2	28.4906
2	28.7682
2	29.2967
37.101 ± 4.39541
2	28.5747
2	29.2786
2	31.0293
2	30.6304
37.5347 ± 4.72365
36.4261 ± 4.91655
2	28.5132
37.7794 ± 4.55985
2	28.3326
2	30.5438
2	30.3706
2	28.2003
38.3346 ± 4.63101
2	30.2846
2	29.5864
2	29.0776
37.465 ± 4.57221
2	28.7071
2	29.9197
2	29.7361
2	29.5294
37.5565 ± 4.83067
2	29.0824
2	29.0158
2	29.063
2	28.8105
2	28.1004
2	27.9916
2	28.4089
2	29.79
36.3439 ± 4.49803
2	27.9018
36.2169 ± 4.58078
2	27.4983
2	27.1897
36.8038 ± 4.80245
2	29.1107
2	29.0165
2	28.8829
2	28.5572
37.4777 ± 5.37698
2	31.5494
2	31.2653
2	30.0535
37.8236 ± 4.73984
37.0994 ± 4.77548
2	30.0098
2	29.6997
2	29.4944
2	29.3697
2	29.3681
2	29.1412
2	29.4276
2	27.9903
36.9235 ± 5.19069
2	29.9874
2	29.343
2	29.0919
2	27.9802
2	27.0857
2	31.0217
2	30.9969
2	30.7366
2	30.6331
2	30.4401
2	28.6364
2	30.5459
2	30.5119
2	30.349
2	29.4228
2	29.3549
2	29.0849
36.8911 ± 4.70222
2	31.2441
2	30.4804
2	30.4737
2	30.3794
2	30.2335
2	29.2273
2	30.2864
2	30.275
2	30.1916
2	30.0993
2	29.8499
2	28.6932
2	27.1539
38.0327 ± 4.93827
2	27.5132
2	29.9015
37.9031 ± 4.33976
2	29.5271
2	29.5223
2	29.2256
2	28.7462
2	28.3865
2	27.6055
37.0725 ± 5.02067
2	31.4501
2	30.1982
2	30.0258
2	29.8068
2	31.2524
2	31.1433
38.5355 ± 4.49427
2	28.6888
2	30.2916
2	29.8528
2	31.2383
2	30.9988
2	30.5639
2	28.1639
2	29.6422
38.2 ± 4.63094
2	28.7231
36.3728 ± 5.06716
35.7788 ± 4.60255
2	28.5729
2	30.9173
2	30.6282
2	30.5831
2	26.7951
37.474 ± 4.58359
2	28.8615
2	28.676
2	31.0619
2	29.3929
2	30.9486
2	30.7384
2	30.576
2	26.2018
2	29.3104
2	29.6472
2	29.004
2	31.5331
2	31.4173
2	31.1287
2	29.3009
2	29.7059
2	28.5967
2	28.7471
2	30.9757
2	29.1738
2	28.1584
2	28.3429
37.0314 ± 5.03602
2	29.2674
2	29.2215
2	30.779
2	29.0357
2	28.2052
2	27.418
2	28.9662
36.9194 ± 4.9375
2	30.643
2	28.9495
36.0735 ± 5.0621
2	30.6362
2	29.2119
2	28.9391
2	28.8744
2	28.8512
2	30.5386
37.3635 ± 5.62236
2	30.4763
36.3436 ± 4.84188
2	30.052
2	29.5765
2	29.3871
37.9363 ± 4.74518
37.2966 ± 4.46566
37.3557 ± 4.68048
35.9117 ± 4.67474
37.4562 ± 4.60083
2	28.3967
37.3855 ± 4.8361
35.1134 ± 5.34657
38.2637 ± 4.70929
2	30.4591
2	27.9486
37.8453 ± 4.57197
2	27.3073
2	27.812
37.949 ± 4.61125
2	28.9512
37.8703 ± 4.59157
36.447 ± 4.8643
35.9851 ± 4.8712
36.6951 ± 4.6874
38.2075 ± 4.63392
37.2229 ± 4.88657
35.2283 ± 5.08011
2	32.2102
2	31.9533
2	31.4126
2	31.4082
2	27.7887
2	31.3181
35.5712 ± 4.90396
37.3068 ± 4.71639
2	31.1819
2	31.1237
2	29.7261
38.7762 ± 4.31618
3	28.4928
3	28.4797
3	27.9044
3	28.4708
3	27.8241
3	27.4311
3	27.2876
3	27.7194
3	27.0972
3	27.6464
3	27.8493
3	27.5747
3	27.5369
3	27.529
3	26.8148
3	27.9462
3	27.6862
3	27.2974
3	27.9685
3	27.7171
34.5837 ± 4.1454
3	27.0955
34.4235 ± 4.53356
3	27.8079
3	27.6045
3	29.294
3	29.2568
3	29.0877
3	27.4422
3	26.694
3	27.9495
3	28.5997
3	27.3579
3	28.5023
3	28.247
3	27.3482
3	28.2211
3	28.5723
3	29.1648
3	29.0603
3	28.4976
3	28.0237
3	27.3863
3	26.9734
34.5455 ± 4.46614
3	29.6712
3	29.2378
3	27.9993
3	27.8087
3	28.8359
3	28.2232
3	27.3377
3	28.0772
3	27.927
3	27.8342
3	27.3553
3	28.5647
3	28.3074
3	28.023
3	27.9549
3	27.263
3	27.2383
3	27.5558
3	27.852
3	27.3493
3	29.0238
3	28.918
3	28.756
3	26.8825
3	28.3502
3	29.0051
3	28.6955
3	27.1246
3	27.0031
3	28.1931
3	27.5037
3	27.0502
3	28.1284
34.5766 ± 4.56464
3	27.15
3	27.9559
3	26.7872
3	27.9502
3	28.481
3	28.286
34.4886 ± 4.46976
3	27.8901
3	28.1037
3	28.014
3	26.5234
3	28.0503
3	28.0118
3	28.6909
3	27.8959
3	27.8692
3	26.7415
3	27.8173
3	28.0756
3	27.9233
3	26.9505
34.5893 ± 4.27169
3	28.1466
3	27.6596
3	27.6777
3	27.4927
3	28.6472
3	28.3006
3	27.4309
3	27.8533
3	27.5803
3	28.036
3	27.4872
3	26.8165
3	27.8199
3	27.7602
3	27.3334
3	27.7696
3	27.0226
3	28.673
3	26.6183
3	27.1581
3	27.4648
3	27.2911
3	26.9567
3	27.8443
3	28.3503
3	28.076
3	27.8043
3	26.7776
3	26.3171
3	26.5436
3	29.8971
3	28.9922
3	27.9497
34.1483 ± 4.62794
3	27.3471
3	27.6125
3	28.989
3	25.8791
3	25.8751
3	28.4321
3	28.0887
3	27.621
3	26.6628
3	28.778
3	29.2839
34.9694 ± 4.61249
3	28.1575
3	27.5392
3	26.6231
3	27.6554
3	27.2941
3	27.4325
3	30.1928
3	29.7125
3	29.4979
3	27.1631
34.5426 ± 4.28132
3	27.8912
3	27.2615
3	27.2248
3	28.0685
35.3622 ± 4.42217
35.9299 ± 4.5331
34.8102 ± 4.57975
3	29.1993
3	26.8645
36.1859 ± 4.55057
3	28.8671
3	26.7876
3	27.705
3	26.4167
3	27.2579
3	28.9162
3	28.0425
3	27.5736
3	29.343
3	29.1756
3	26.3134
3	29.1151
3	27.568
34.2455 ± 4.72735
3	26.5969
3	28.5604
3	27.5047
3	29.0346
3	28.5995
33.9497 ± 4.37846
3	28.1476
3	28.5508
3	29.0871
3	27.6504
3	27.4623
3	27.4052
3	26.8221
3	27.5038
34.7806 ± 4.36905
3	26.636
3	26.8039
3	28.6299
3	27.2148
3	29.6631
3	28.3833
34.2907 ± 4.26982
3	28.1733
3	28.2404
3	25.6756
34.1296 ± 4.61043
3	26.132
3	26.0866
3	25.8239
3	25.4505
3	27.3885
3	30.4179
3	30.2678
3	29.9376
34.3682 ± 4.54064
3	25.5555
3	28.4712
3	27.1834
3	26.1305
35.3056 ± 4.36658
3	29.2734
34.5222 ± 4.30451
3	28.2183
3	25.3636
3	27.8454
3	27.3595
33.895 ± 4.70887
3	25.1301
3	25.5465
3	26.9411
3	24.7003
3	28.1357
34.5553 ± 4.73964
3	28.0205
3	28.5785
34.4385 ± 4.4623
3	27.9493
3	26.9339
3	26.4294
3	28.5777
3	28.4554
3	28.917
3	27.9968
3	28.153
3	27.3878
35.0272 ± 4.66334
3	28.8727
34.1412 ± 4.31513
3	27.6958
3	27.6639
3	28.3986
3	29.0874
3	27.7349
3	28.9111
3	28.4599
3	28.7128
3	27.1765
3	28.6935
3	28.4096
34.0749 ± 4.18429
36.0466 ± 4.20547
3	28.3253
35.4252 ± 4.44297
34.2388 ± 4.8526
3	29.5426
3	29.218
3	28.2721
3	27.8753
3	25.7272
3	28.7528
34.3572 ± 4.56408
3	27.0668
3	26.956
3	28.6749
3	28.4871
3	27.1719
3	26.9332
3	26.3776
3	26.1192
3	28.7207
3	27.4772
3	27.388
3	28.3874
3	26.7034
3	29.9943
3	28.6763
3	28.1286
3	29.9734
3	26.6337
36.3608 ± 4.3803
33.8906 ± 4.25473
3	26.5264
3	29.9282
3	29.9044
3	28.3535
3	26.7328
3	28.0104
3	27.1036
3	25.9429
3	28.5191
3	26.0641
3	28.4615
3	28.2024
35.5753 ± 4.20633
3	29.4183
3	28.0334
3	27.592
3	28.1415
3	29.0453
3	27.6842
3	27.9883
3	27.5498
3	28.0998
3	28.9974
3	28.9799
3	29.3444
3	27.5265
3	27.9934
3	27.4578
3	27.3037
3	27.9296
34.7329 ± 4.76483
3	27.189
3	27.7642
3	28.329
3	26.9596
3	25.3553
3	27.0076
3	27.384
3	27.2819
35.7041 ± 4.45604
3	27.2672
3	26.9753
3	26.8624
3	26.5719
3	27.3543
3	26.9908
3	27.509
35.3741 ± 4.63232
3	26.9844
3	27.334
3	26.5074
3	27.677
32.2153 ± 4.92442
3	26.664
3	29.1621
35.9679 ± 4.42265
34.8574 ± 4.42775
3	26.2689
3	26.7977
3	28.3905
3	27.8093
34.457 ± 5.1641
35.4381 ± 4.82342
36.0661 ± 4.56151
3	27.7473
3	26.782
34.4028 ± 4.48513
3	27.8426
34.1389 ± 4.37937
3	28.2178
3	26.7401
3	27.084
3	28.4329
35.4923 ± 4.38679
3	26.2398
3	27.6332
33.6371 ± 4.60982
35.3494 ± 4.473
3	27.6259
3	26.501
3	25.9063
35.4341 ± 4.69249
3	26.1121
3	26.7535
35.1617 ± 4.39049
34.0294 ± 5.32246
33.3858 ± 4.49962
36.1285 ± 4.36085
35.6068 ± 4.41082
3	27.5853
35.0352 ± 4.47534
3	28.0827
3	27.9552
3	27.939
3	26.2587
3	26.001
35.863 ± 4.12608
3	27.9023
34.1592 ± 4.55623
33.0701 ± 4.72036
3	26.4725
33.0289 ± 4.5263
3	27.873
33.4418 ± 4.57127
3	27.312
3	26.9455
3	29.4233
3	29.3389
3	28.9944
3	28.951
34.82 ± 4.61011
3	28.8882
3	28.7876
3	28.5356
3	28.8248
3	28.7567
3	28.3672
3	28.1584
3	28.5202
34.5789 ± 4.46018
36.2579 ± 4.45407
3	27.8512
35.0722 ± 4.51209
4	26.9397
4	26.8061
4	26.7258
4	26.1757
4	26.1543
4	27.2549
4	27.1695
4	27.0309
4	26.7398
4	26.1949
4	26.0513
4	26.0381
4	25.7914
4	27.3931
4	27.3146
4	27.0951
4	26.8511
32.4913 ± 4.26178
4	25.5082
4	26.6286
4	26.5852
4	26.3222
4	27.2443
4	27.1585
4	26.8077
4	26.2727
4	26.7551
32.7479 ± 4.06014
4	26.0553
4	26.9468
4	26.7797
4	26.4994
4	26.2386
4	26.0618
4	26.6703
4	26.3042
32.9491 ± 4.33548
4	26.2742
4	26.148
4	25.79
4	27.1865
4	26.5191
4	26.7045
4	26.0877
4	26.4379
4	25.17
4	23.9218
4	26.5735
4	26.3335
4	26.5755
4	25.9661
4	26.1585
4	25.9056
4	26.218
4	28.0464
4	27.729
4	26.6721
4	26.6382
4	25.8219
4	25.9481
4	25.9891
4	26.1579
4	25.9072
4	25.9168
4	26.6669
4	26.5484
4	26.3599
4	26.2335
4	26.6073
4	26.5098
4	27.4017
4	25.8793
4	26.3301
4	25.8242
4	26.5278
4	26.5218
4	26.3036
4	25.8978
4	26.2752
32.5347 ± 4.36556
4	27.3943
4	25.6654
4	25.9604
4	25.1693
33.1456 ± 3.91372
4	26.0288
4	25.7347
33.1015 ± 4.40412
4	25.8907
4	25.7698
4	27.6895
4	25.6555
4	25.2521
4	25.9248
4	27.6001
4	27.4606
4	27.0836
4	25.8521
4	26.8976
4	26.7699
4	26.7207
4	25.4996
4	25.5554
4	27.3683
4	26.9541
4	26.672
4	26.6894
4	26.331
4	26.1874
4	26.5626
4	28.4218
4	28.3437
4	26.058
4	25.9592
4	25.8918
4	26.5062
4	25.776
4	27.5606
4	26.9739
4	28.4043
4	28.2766
4	27.8493
4	25.6172
4	26.7928
4	26.6517
4	27.1266
4	26.1881
4	27.7
4	26.5523
4	25.7674
4	25.5692
4	25.6524
4	25.498
32.5486 ± 4.29575
4	26.5284
4	27.2494
4	25.8169
4	27.2464
4	28.6747
4	28.3814
4	25.3115
4	25.248
4	27.1648
4	26.4312
4	25.4753
4	24.996
32.5837 ± 4.26751
4	27.7099
4	24.6995
4	26.1434
4	27.7013
32.9169 ± 4.32277
32.6712 ± 4.18638
4	27.3561
4	27.5716
4	26.1098
4	27.5036
4	25.3999
4	26.2501
4	26.5183
4	24.7872
4	26.4897
4	26.3093
4	25.5028
4	27.3247
4	27.1866
4	26.0757
4	26.0651
32.1132 ± 4.1941
4	25.8658
4	24.9019
4	25.4277
32.808 ± 4.05829
4	26.4059
4	25.2245
31.6846 ± 4.62441
4	25.0864
4	26.9032
4	25.6589
4	25.1996
4	25.2442
33.8306 ± 4.38892
32.4052 ± 4.29328
4	27.057
4	26.9287
4	26.8273
4	27.0184
32.5857 ± 4.2602
4	28.4509
4	28.1178
4	26.5047
32.6834 ± 4.52361
4	27.1689
32.1638 ± 4.50008
4	26.0346
4	27.962
4	28.3539
32.5189 ± 4.28864
31.8979 ± 4.36173
32.2162 ± 4.36659
4	27.0926
4	23.7599
4	27.9263
4	27.0086
4	25.5271
4	27.2304
33.5922 ± 4.16913
4	27.1663
4	26.6128
4	26.9118
4	26.6857
4	27.778
4	25.7834
4	25.4046
4	25.2151
4	26.5356
4	25.8612
4	25.7578
33.6101 ± 4.27166
4	25.9462
4	26.3997
4	25.4507
4	27.5847
4	28.2381
4	28.2996
4	25.9285
4	28.8955
4	28.5964
4	26.5256
4	27.0558
32.4802 ± 4.07459
4	23.6526
4	26.2461
4	27.478
4	27.3499
4	25.1182
4	27.9738
4	26.3941
4	27.3316
4	24.7491
4	26.1515
4	26.1404
4	27.4729
4	27.9075
4	27.7841
4	26.123
4	25.959
4	27.2447
4	26.65
4	25.7775
32.089 ± 4.38765
4	26.9272
4	26.8983
4	24.9445
4	24.8474
34.1734 ± 4.31547
4	27.4934
4	26.0916
4	27.5598
4	24.8187
4	25.5695
4	28.1176
4	24.6856
4	27.8169
4	25.5098
4	27.4302
4	24.5423
4	24.6574
4	24.5153
4	27.2795
4	25.7523
32.975 ± 4.48395
4	26.848
4	24.4074
4	27.3002
4	28.0669
33.5056 ± 4.0728
4	25.7474
4	25.3397
4	25.11
4	24.83
4	24.3894
4	24.54
4	24.6836
4	25.6915
4	25.5625
4	24.6683
4	25.1943
4	24.5351
4	26.9285
32.5518 ± 4.70943
4	25.1472
4	27.2947
4	27.242
4	26.3595
33.3145 ± 4.2712
4	26.6184
4	26.5945
4	28.2623
4	28.0128
4	27.9668
4	27.9424
4	27.8641
4	26.5048
4	26.2417
4	24.4286
4	24.1511
31.4228 ± 4.6394
4	27.0488
34.0142 ± 4.48001
4	27.6596
4	26.7481
4	27.514
4	27.1989
4	27.0899
4	25.5096
4	26.7371
4	26.6744
4	25.9753
4	26.6031
4	26.5203
4	24.136
33.9667 ± 4.28225
34.1374 ± 3.99092
32.0575 ± 4.171
4	26.3807
4	26.6241
4	26.2455
4	26.0797
4	23.9326
4	27.0347
31.7513 ± 4.72815
4	25.3761
32.2819 ± 4.15274
33.1125 ± 4.21574
4	26.796
4	26.7601
4	26.1623
4	25.9006
33.8265 ± 4.18805
4	22.8123
4	26.3276
4	26.1217
4	27.1581
4	25.8894
4	24.9726
33.1935 ± 4.49825
32.6494 ± 3.93526
4	25.4835
4	27.2641
4	27.1013
4	26.8727
31.6133 ± 4.272
4	25.7847
32.0162 ± 4.2354
31.3728 ± 4.42709
33.7582 ± 4.10016
4	26.4581
4	25.5312
4	26.7555
34.4151 ± 4.18943
33.1549 ± 4.25486
33.5939 ± 4.21884
4	26.4063
4	25.4706
31.9684 ± 4.289
31.3234 ± 4.93992
33.7871 ± 4.50015
4	26.167
4	26.4358
30.2408 ± 4.66813
4	25.2817
32.2813 ± 4.25735
4	26.7959
4	26.6434
4	26.4161
4	26.3424
4	25.1779
31.5733 ± 4.32687
33.1833 ± 4.229
4	25.6107
32.5257 ± 4.79853
4	25.0558
33.7491 ± 4.19625
4	25.4687
4	25.2025
4	26.1116
33.2891 ± 4.3845
33.1431 ± 4.50069
4	28.3167
4	28.2052
4	27.5869
4	25.1328
31.2031 ± 4.2498
32.9467 ± 4.31576
4	26.6247
32.7066 ± 4.2337
34.1909 ± 4.38064
4	27.6812
4	27.5759
4	27.5583
4	27.474
4	27.3699
4	27.3351
4	27.0583
4	27.0046
4	26.8715
4	25.9294
33.2573 ± 4.15349
5	25.77
5	25.541
5	25.5003
5	25.3743
5	25.076
5	24.9074
5	24.602
5	25.5046
5	25.3642
5	24.9959
5	24.9579
5	24.9067
5	24.6366
5	25.3742
30.8881 ± 4.14065
5	25.36
5	25.694
5	25.1933
5	24.9936
5	25.9772
5	25.8754
5	24.9411
31.3288 ± 4.04044
5	25.4713
5	25.4152
5	24.5832
5	25.3807
5	25.1595
5	25.0068
5	24.9117
5	23.9952
5	25.7843
30.8822 ± 4.26457
5	24.6552
5	25.8334
5	23.5639
5	25.0929
5	24.1229
5	25.6524
5	25.339
5	24.2543
5	24.6803
5	25.4109
5	25.59
5	24.3909
5	25.1013
5	25.4543
5	24.3712
5	26.2728
5	26.2345
5	23.0932
5	25.2281
5	24.7292
5	26.1638
5	25.0885
5	26.0124
5	25.8967
5	25.6288
5	26.7258
5	25.6495
5	25.2572
5	25.5804
5	26.0313
5	25.9302
5	24.3824
5	25.0449
5	25.8588
5	25.4411
5	25.1294
5	25.0973
5	24.3339
5	25.0211
5	24.9257
5	24.7954
5	24.3917
5	25.1219
5	24.0922
5	25.8657
5	25.1453
5	25.4246
5	25.0637
5	24.6766
5	23.8158
5	25.2083
31.0724 ± 4.17915
5	24.662
5	25.5441
5	25.4894
5	24.9875
5	26.2274
5	26.1062
5	25.5316
5	25.4611
5	25.3206
5	25.1751
5	23.5191
5	24.5722
31.8108 ± 3.92689
5	25.8492
5	25.3993
5	25.2896
5	25.0985
5	24.5462
5	25.2004
5	25.0581
5	23.9309
5	25.672
5	24.7998
5	25.0352
30.9566 ± 4.19706
5	24.9742
5	24.2403
5	24.9242
5	24.8621
5	23.4524
30.6328 ± 4.32648
5	26.5161
5	25.9184
5	25.8323
5	23.5102
5	24.17
30.8733 ± 4.19913
5	25.3936
5	25.7283
5	24.0878
5	24.4784
5	25.6457
5	24.9019
5	26.5281
5	26.3239
5	27.8786
5	27.5372
5	26.2348
5	24.4737
5	23.8274
5	26.0535
5	25.7939
5	25.5751
5	24.4412
31.394 ± 4.16553
5	25.4883
5	25.2665
5	27.3375
5	25.35
5	25.0785
5	23.8035
5	26.9684
5	25.2039
5	26.1589
30.341 ± 4.28183
30.4467 ± 4.33517
5	25.3376
5	25.1437
30.5969 ± 4.02107
31.5909 ± 4.31177
5	24.7808
5	24.6889
5	25.6701
5	25.1793
31.9233 ± 4.14045
5	24.7263
5	24.7566
5	26.2358
5	26.1607
5	26.1196
5	25.9709
5	24.6304
5	25.6348
5	25.225
5	25.8059
5	25.056
31.0177 ± 4.08162
5	23.9883
5	24.7086
5	24.5384
5	25.2288
5	24.6804
5	27.3329
5	26.9478
5	24.5965
5	24.2874
5	24.1321
5	23.6838
30.0801 ± 4.17406
5	24.5406
5	26.3254
5	23.9197
32.2165 ± 4.17481
5	24.0895
31.5575 ± 4.30084
5	23.6391
5	24.5373
5	25.2976
5	24.3479
5	24.4867
31.2445 ± 3.97483
5	23.5868
5	23.1334
5	23.8438
5	22.8027
31.1844 ± 4.06062
5	24.3201
5	23.5097
5	25.4489
5	24.5136
5	24.3338
5	24.2991
5	22.8761
5	24.1089
31.4582 ± 4.18412
5	25.9897
5	26.7953
5	24.1659
5	27.0647
5	25.1234
5	26.4977
5	26.3821
29.6309 ± 4.56588
5	25.7464
5	26.9168
5	27.3965
5	27.1168
5	23.7296
5	26.4236
5	23.6783
30.3544 ± 4.19913
5	23.5455
30.8567 ± 4.26242
5	26.3776
31.0533 ± 4.1719
5	25.3999
5	25.1838
31.5501 ± 4.1753
5	24.1771
5	24.3505
5	24.3095
5	26.3163
5	25.7439
5	25.3037
5	23.3649
5	27.0211
5	23.8959
5	25.9379
31.433 ± 4.12318
5	26.4565
5	24.2802
5	26.205
5	26.021
5	24.6505
5	24.3637
5	26.2123
5	25.89
5	25.277
5	24.2434
5	23.5642
5	25.6202
31.7225 ± 4.00304
5	24.7802
5	26.2081
5	26.9007
5	25.8938
30.8359 ± 3.9214
5	26.0413
5	25.9918
5	26.911
5	26.7712
5	24.1371
5	26.0774
5	25.8295
5	25.7729
5	25.1807
5	25.5342
5	26.341
5	24.8805
30.984 ± 4.53877
32.0031 ± 4.37813
32.6463 ± 3.74869
5	26.2063
5	26.1077
5	25.923
5	26.0803
5	25.443
5	24.3149
5	25.1012
5	24.9205
5	24.6122
31.6943 ± 4.23995
5	26.5657
5	24.329
5	26.1415
30.9791 ± 4.19973
31.5114 ± 4.12529
31.8204 ± 4.15147
5	25.931
5	25.5397
5	23.6738
5	25.4438
5	25.5405
5	25.1281
5	23.6473
5	24.0408
5	23.1297
5	22.7296
5	22.54
29.5473 ± 4.29739
32.4883 ± 4.10062
5	24.3525
5	22.3816
5	23.6204
30.3067 ± 4.10004
30.4073 ± 4.23235
5	25.0935
5	25.1174
5	25.0712
29.5561 ± 4.55572
5	22.6283
31.596 ± 3.68788
5	23.6608
5	22.2236
5	25.5508
5	25.4775
5	25.3628
5	23.4548
5	24.4027
32.082 ± 4.22075
5	24.9121
32.0848 ± 4.00986
32.471 ± 3.80198
5	24.6498
30.0964 ± 4.13874
30.2683 ± 4.16861
32.1647 ± 4.23309
30.8142 ± 4.05028
32.1656 ± 3.89718
31.8128 ± 4.00741
31.5222 ± 4.18958
30.7504 ± 4.57881
5	22.5547
5	24.4951
5	24.8413
5	24.6506
5	26.3962
5	23.8342
5	24.6318
30.676 ± 4.12209
31.3582 ± 4.2835
30.2019 ± 4.14983
5	26.291
5	24.571
5	24.8248
5	26.246
5	25.9676
5	23.7305
31.5721 ± 4.23764
29.4284 ± 4.65928
5	24.4836
5	24.2432
28.1934 ± 4.57794
5	24.461
5	25.6983
5	25.4192
5	25.2769
31.1727 ± 4.37932
29.8096 ± 4.03836
32.227 ± 4.39865
31.1503 ± 4.28196
5	25.9242
5	25.5341
5	25.5105
5	25.3822
5	25.3382
31.3477 ± 4.14936
6	24.5805
6	24.1549
6	24.5869
6	24.2873
6	23.9644
6	23.1101
6	24.3329
6	23.8866
6	24.1421
6	22.9958
6	23.4128
6	23.9582
6	25.4118
6	25.1255
6	25.0111
6	22.9786
6	23.9104
6	23.2876
6	24.7474
6	25.0071
29.3835 ± 4.03851
6	24.8437
29.9291 ± 3.988
6	24.6614
6	24.555
6	24.3831
29.3205 ± 4.08647
6	24.5057
6	23.878
6	23.5206
6	23.3424
6	22.9177
6	24.7241
6	24.1174
6	24.5546
6	25.0924
6	25.0605
6	23.7203
6	24.8355
6	24.8138
6	24.2213
6	24.3212
6	23.6439
6	23.4835
6	23.3231
6	22.8944
6	23.0148
6	24.4929
30.6099 ± 3.90491
6	23.0305
6	24.2648
6	24.3145
6	24.2214
6	24.1344
6	24.0121
6	23.8536
6	22.9399
6	24.1447
6	24.8771
6	25.2274
6	24.9084
6	24.8454
6	22.9975
6	24.5131
6	24.7314
6	25.1097
6	24.9781
6	24.3764
6	24.3619
6	23.4301
6	23.3366
6	23.2505
6	24.4333
6	24.1717
29.9556 ± 3.89706
6	22.925
6	23.6051
6	23.4351
6	23.1979
6	23.1449
6	24.0009
6	23.8079
6	23.8088
6	22.7003
6	23.0047
6	24.2155
6	24.7106
6	22.7774
6	24.0613
6	24.5079
6	24.4137
6	23.9459
6	24.3965
29.5942 ± 4.10568
6	23.937
6	23.391
6	23.1362
6	22.4496
6	24.3879
6	24.3608
6	26.6993
6	26.371
6	23.919
6	23.4902
6	23.2145
6	23.8574
6	24.8297
6	24.6848
6	25.2556
6	25.227
6	25.1816
6	23.7065
6	25.072
6	24.0893
6	23.636
6	24.4286
6	23.8527
6	24.9216
6	23.8187
6	23.2866
29.3047 ± 4.23054
6	24.0731
6	22.6511
6	24.6738
6	24.6542
6	22.4734
6	22.4607
30.0752 ± 4.17016
6	24.2272
6	24.6444
29.9389 ± 3.95054
6	24.6625
6	23.1935
6	23.9685
6	22.5989
28.7411 ± 4.21142
6	24.1729
6	26.2631
6	22.4125
6	22.8309
28.7005 ± 4.08847
6	24.6375
6	23.6504
6	26.4248
6	23.9995
6	24.171
6	23.7162
6	26.0349
6	23.6325
6	25.4287
6	23.5393
6	24.1618
6	23.5346
6	23.5003
6	23.8571
6	23.2521
6	25.3406
6	25.1195
6	24.7406
29.1786 ± 4.13652
6	22.3178
6	24.9112
6	24.6863
6	23.3166
6	23.2943
30.7646 ± 3.77023
6	24.0997
6	22.6376
6	23.5793
6	23.2891
6	24.6474
6	25.337
6	24.8226
6	22.4985
6	23.2042
6	23.5286
6	23.6018
6	23.007
6	22.9842
6	22.9554
6	23.9081
30.8304 ± 4.01124
6	23.5724
6	23.829
6	23.7571
6	23.8896
30.3078 ± 4.14463
6	24.2471
6	24.2133
6	23.7851
6	23.9408
6	23.7308
29.7644 ± 4.12956
29.4517 ± 3.74583
6	25.6128
6	25.3918
6	25.2454
6	21.9437
6	22.4491
6	23.8099
6	23.6115
6	23.5489
6	23.0144
6	25.1783
6	24.791
29.1286 ± 4.12585
6	22.3742
6	23.9305
28.6416 ± 4.16833
6	24.4125
6	23.9469
6	24.9747
6	24.7513
6	22.8772
6	22.772
6	25.4189
6	24.8935
6	26.0526
6	25.6897
6	25.447
6	25.2999
6	23.3053
6	22.8194
6	23.7351
6	24.6339
6	24.0138
6	23.7849
6	24.7314
6	23.1455
6	24.2857
6	23.1388
29.4159 ± 4.29156
6	23.7648
29.6439 ± 4.08458
6	26.2159
6	23.417
6	23.8209
6	24.277
6	23.4616
6	26.1278
29.1652 ± 4.12016
29.8635 ± 4.19429
6	22.6644
29.9944 ± 4.13586
29.7305 ± 4.19751
6	23.5175
6	24.6916
6	23.3676
6	24.0384
6	22.0388
6	25.2705
28.1565 ± 4.4645
6	22.5679
6	24.5807
30.1575 ± 4.06207
30.2978 ± 4.2719
6	24.0947
6	23.6046
6	23.6428
6	26.064
6	23.4601
6	24.7266
6	23.3757
6	23.3254
6	23.2739
6	24.3777
6	25.1582
6	23.9071
6	23.2319
6	22.8167
6	25.5368
31.3975 ± 3.70703
6	23.7978
6	24.6694
6	23.555
6	24.4573
6	23.2193
6	23.4282
6	24.8848
6	25.0051
6	22.3324
6	22.2937
6	23.7575
6	24.9994
6	23.4321
6	24.9281
6	23.9469
6	22.0649
6	24.6089
31.3993 ± 3.73329
6	23.1838
6	23.8929
6	22.0367
6	23.7567
6	22.14
6	21.3113
6	23.1757
6	24.072
6	23.2132
29.5534 ± 4.4029
6	23.6727
6	22.0349
28.1092 ± 4.10394
6	24.0354
30.0254 ± 4.04687
29.1112 ± 3.95487
6	21.9477
6	21.7514
31.1873 ± 4.01888
6	22.2873
6	22.954
6	23.977
6	22.5708
30.2847 ± 4.02933
29.7789 ± 4.22461
6	23.6153
6	23.7223
6	23.3339
29.1149 ± 4.13411
30.4745 ± 3.76131
29.7884 ± 4.14437
6	23.325
30.6021 ± 3.90715
6	24.0097
29.4528 ± 3.94298
30.7806 ± 3.94959
6	23.0995
28.0075 ± 4.32631
6	24.4743
6	24.3992
30.4115 ± 4.10184
30.746 ± 3.97024
30.1152 ± 4.25665
30.4105 ± 4.25517
28.8695 ± 4.10885
29.5146 ± 4.08122
6	22.8741
6	24.3304
6	25.1135
6	21.168
6	25.0603
6	24.3888
6	24.0488
30.8758 ± 3.81471
29.6619 ± 4.47902
29.8654 ± 3.97515
30.3014 ± 4.16772
6	23.793
27.6921 ± 4.44053
30.6093 ± 4.10159
6	22.4423
26.8311 ± 4.38032
6	23.0645
28.9258 ± 4.19942
6	24.0634
6	23.8306
6	23.7226
6	23.6007
29.5844 ± 4.30883
6	23.3676
29.2423 ± 4.1982
29.5588 ± 3.8923
30.3905 ± 4.19499
6	25.3282
6	25.2311
6	25.121
6	25.0971
6	24.9753
6	24.9685
28.6345 ± 3.973
6	24.794
30.4055 ± 3.7568
7	23.6906
7	23.47
7	22.8747
7	22.1984
7	22.885
7	22.8371
7	22.675
7	21.9596
7	23.3638
7	23.4224
7	23.3894
7	23.0446
28.836 ± 3.9372
7	24.2027
7	23.9024
7	21.8542
7	23.8655
7	22.9755
7	24.0307
7	22.5264
7	24.0174
7	21.8616
7	22.6409
28.2897 ± 3.87612
28.0624 ± 4.06571
7	22.63
7	22.525
7	22.1984
7	22.9319
7	22.9575
7	22.9117
7	23.9791
7	23.427
7	23.3626
7	22.8026
7	22.9669
7	22.5924
7	23.8394
7	22.5403
7	22.4047
7	22.2551
7	21.4628
7	23.674
7	23.5808
7	23.5813
7	24.5436
7	24.3927
29.0677 ± 4.11169
7	22.4814
7	22.9628
7	23.3188
7	23.8895
7	23.476
7	22.4125
7	23.7822
7	23.793
7	23.6514
7	23.6505
7	23.605
7	22.31
7	23.4016
7	22.1158
7	22.587
7	24.3392
7	22.9308
7	23.1319
7	23.3327
7	23.2188
7	21.9638
7	22.8266
7	23.412
7	23.3227
28.8435 ± 3.82611
7	22.9158
7	23.2857
7	23.2827
7	22.9699
28.8877 ± 3.80004
7	23.2654
7	23.171
7	22.2937
7	24.2106
7	21.9494
7	23.1035
7	22.317
7	23.9612
7	23.5555
7	22.2382
7	23.0955
27.6891 ± 4.06748
7	22.8276
7	20.9429
7	24.6042
7	24.508
7	24.1593
7	21.5908
7	24.0691
7	23.7125
7	21.6074
7	23.005
7	22.9258
27.914 ± 4.06227
7	23.6681
7	23.2408
7	22.4776
7	22.4973
7	22.7753
7	22.9133
7	23.4195
7	23.1104
7	22.524
7	22.2782
27.5999 ± 3.97596
7	22.6955
7	23.9025
7	22.5169
7	22.4355
7	21.541
7	22.9197
7	22.7693
7	23.329
7	21.1788
7	23.8697
7	23.2619
7	22.7428
28.9646 ± 3.85389
7	23.7441
7	22.5333
7	22.7977
7	22.2159
7	22.1638
7	22.8634
7	22.0647
7	21.7453
7	21.9218
7	22.6878
7	22.9139
7	22.7028
7	23.4578
7	22.9966
7	22.7666
7	22.6866
29.9554 ± 3.73851
7	23.8804
27.8354 ± 4.1083
7	22.158
7	21.5861
7	22.3485
7	22.2241
7	20.8562
7	23.0596
29.129 ± 3.93277
28.6827 ± 4.10194
7	23.7722
7	23.7699
7	23.387
29.0544 ± 4.12216
7	22.0339
7	23.562
7	23.7304
7	23.5489
7	23.2111
7	23.179
7	23.1146
7	22.9961
7	22.6117
7	22.9355
7	22.6457
7	25.124
7	24.9878
7	22.6358
7	22.3741
7	22.8147
7	23.9836
7	22.0235
7	23.5103
7	23.4386
7	22.4274
7	23.2154
7	24.0035
7	22.6307
28.5776 ± 4.10351
7	22.9436
7	21.1396
7	22.5262
28.0729 ± 4.03297
28.5143 ± 3.68694
7	23.4273
7	23.2843
7	22.2971
7	24.6649
7	22.0122
7	23.7892
7	23.2969
7	24.3376
7	24.2804
7	24.2597
7	24.843
7	22.7301
7	23.1849
7	21.8501
7	21.7392
27.6905 ± 4.19915
28.8072 ± 4.04432
7	21.5459
7	24.5905
7	23.9596
28.2084 ± 4.09328
7	24.5499
7	24.4487
7	22.8985
7	24.2383
7	22.3026
7	23.6509
7	23.9213
7	21.0757
7	23.9156
7	23.8335
7	22.4012
7	23.7559
7	21.6379
7	22.6968
7	21.022
7	22.8786
7	21.01
7	20.8241
27.2221 ± 3.96971
27.8986 ± 4.06589
29.5483 ± 3.99178
7	23.7832
7	23.2074
7	24.6063
7	23.6149
26.9365 ± 4.42036
28.5115 ± 4.13079
28.878 ± 4.14752
7	23.5399
7	20.7928
27.181 ± 4.16089
7	22.2866
28.3461 ± 4.17769
7	23.5082
7	23.2567
7	26.0443
7	25.7024
7	21.0013
7	21.9834
7	25.6889
7	25.6573
7	25.5205
7	24.4047
7	23.6016
7	23.0732
7	25.3287
7	20.6636
7	22.1779
7	23.763
7	24.3284
7	22.0755
7	22.9159
7	25.0982
29.7136 ± 3.88908
27.8706 ± 4.33356
7	22.5066
28.2382 ± 4.26189
7	21.8419
7	22.2817
7	21.8935
7	23.72
7	23.5873
7	20.6115
7	23.5357
7	21.9787
28.1441 ± 3.95867
7	19.9887
7	21.9003
7	23.1351
7	22.0113
28.8711 ± 4.00888
7	23.5684
7	22.5406
7	23.51
7	23.0764
7	23.042
7	23.4431
7	22.8411
29.172 ± 4.20727
7	25.5033
7	23.0139
7	22.9394
7	23.1771
7	23.068
7	21.4144
7	25.422
28.5783 ± 4.31922
28.2513 ± 4.0495
7	24.8277
7	22.96
7	22.7032
7	22.6081
7	22.4385
7	23.3226
7	22.6883
7	23.3257
29.0698 ± 3.93069
7	22.6532
7	24.6107
27.7615 ± 4.07243
7	25.322
7	25.0945
29.6045 ± 3.79349
7	20.6615
7	20.5856
28.0554 ± 4.07805
7	22.451
7	22.5605
7	21.7366
30.6042 ± 3.82242
29.5523 ± 3.94369
7	23.1093
7	20.5427
7	20.3359
26.9114 ± 4.12423
29.5265 ± 4.01192
7	22.6826
7	22.6239
7	22.5807
29.496 ± 3.84005
28.489 ± 4.04079
7	21.9698
29.1369 ± 4.09496
7	23.1961
26.4685 ± 4.26112
7	23.1694
29.0744 ± 4.26215
7	22.8746
7	22.5338
28.2389 ± 4.42272
30.4844 ± 3.67155
7	24.3577
7	24.3278
7	22.3829
7	24.1773
7	22.8498
7	23.6458
29.8924 ± 3.7894
7	21.6898
26.6448 ± 3.97314
7	23.5145
28.7151 ± 4.34092
29.6025 ± 4.15397
7	22.033
7	22.1298
29.0396 ± 4.0976
27.9245 ± 4.08097
7	24.4158
7	23.7265
7	23.36
28.1461 ± 4.27424
28.526 ± 3.8898
27.5833 ± 3.89693
27.6041 ± 4.15706
29.0307 ± 4.14068
29.5638 ± 3.70803
8	22.4372
8	23.0285
8	22.6513
8	22.3053
8	22.2614
8	22.1042
8	22.52
8	21.7884
8	22.8812
8	22.4049
8	22.0905
8	22.1342
27.8866 ± 3.95032
8	21.8155
8	21.427
27.1269 ± 4.00459
8	21.2871
8	22.048
8	22.0689
8	22.0184
8	21.8592
8	22.0377
8	22.6982
8	22.6782
8	23.4848
8	23.3816
8	22.5934
8	21.4518
8	22.5303
8	22.2747
8	22.6041
8	21.2218
8	22.5042
8	21.8366
8	22.0253
8	23.3048
8	22.0889
8	23.0126
8	21.7294
8	21.6309
8	22.199
27.9933 ± 4.14087
27.2149 ± 3.91727
8	21.1621
8	22.974
8	22.1607
8	22.6029
8	22.0197
8	22.5523
8	22.5415
8	20.6581
8	21.6912
8	22.2155
8	20.8164
8	21.7828
8	22.8783
8	22.6888
8	22.5799
8	22.6514
8	20.663
8	20.5211
8	22.4259
8	21.3092
8	20.7092
8	22.6239
8	21.3255
8	22.6812
8	23.6694
8	21.9718
8	21.8546
8	21.6564
8	20.8024
8	22.5874
8	23.4815
8	21.7629
8	22.2056
8	22.4196
8	21.8932
27.9055 ± 3.89534
8	22.1315
8	21.8891
8	21.81
8	23.3862
8	20.5635
8	20.513
8	21.8317
8	21.7381
8	22.1502
8	21.6824
8	21.1273
8	20.2699
8	20.805
8	21.6556
26.735 ± 4.03637
8	21.5861
8	22.9982
8	20.7762
8	22.1442
26.5273 ± 4.19344
8	21.5126
8	22.1673
8	20.6258
8	21.8022
8	21.6645
8	20.5563
8	21.461
28.151 ± 3.78218
8	21.5775
8	22.6539
8	23.0683
8	22.8372
8	21.405
8	23.1413
8	21.4339
8	23.229
8	22.8465
8	22.7422
28.0194 ± 3.8834
8	19.8488
8	20.6349
8	20.979
8	22.4192
8	22.9803
27.3023 ± 4.0566
8	22.668
8	23.1413
26.8884 ± 3.99936
8	22.6146
8	23.1321
8	23.0839
8	20.5303
8	22.794
8	20.8602
8	22.546
8	22.348
8	22.4501
8	22.4467
8	22.9989
8	21.0548
8	21.7192
27.5617 ± 4.14649
8	21.5673
8	20.9915
8	20.6502
8	21.6271
8	22.3553
8	22.8235
8	22.6919
26.4521 ± 4.15971
8	21.4011
8	22.2296
8	21.5215
8	20.7463
8	22.602
8	22.3864
8	21.8728
8	22.6636
28.1556 ± 4.00412
27.8375 ± 4.13229
8	22.3552
8	22.365
8	22.2043
8	21.9619
8	22.4384
8	21.8425
8	24.2276
8	24.0456
8	23.3222
8	23.5451
26.3657 ± 4.21438
8	21.7852
29.0608 ± 3.85059
8	22.6597
8	22.7799
27.9232 ± 3.88107
27.5083 ± 4.12524
28.4196 ± 3.98944
8	23.3753
8	20.2892
8	23.9534
8	21.4097
8	22.0597
8	21.8257
8	21.5843
8	22.2676
8	22.504
8	21.9268
8	23.3717
26.837 ± 3.98303
8	23.9338
8	23.6756
8	23.609
8	21.5218
8	23.1822
8	22.8971
25.9117 ± 4.27581
27.1598 ± 4.12947
8	21.1514
8	23.2767
8	22.2636
8	22.4577
8	22.5657
8	23.2687
8	22.7758
8	22.1456
8	21.1435
8	21.2699
8	22.8051
27.8513 ± 3.67951
8	22.7027
8	21.0481
8	20.779
8	21.9216
8	20.6804
8	24.5717
8	22.2413
8	23.9437
8	23.7949
8	21.4692
27.2083 ± 4.26071
8	20.3521
8	21.8409
8	21.1926
8	23.1297
28.1598 ± 4.18417
27.6964 ± 4.15465
8	20.732
8	22.592
8	20.9448
8	20.7156
8	20.5939
26.9409 ± 4.19657
28.4957 ± 4.06421
8	22.8401
8	22.7171
8	20.4864
8	22.433
8	19.9608
8	19.9146
26.125 ± 4.0611
8	21.7217
8	21.6879
28.7719 ± 4.05698
8	21.6847
8	21.5645
8	25.0049
8	24.7626
8	19.7279
8	24.6469
8	24.5754
8	20.3781
8	22.124
8	21.865
8	24.5649
8	21.1182
8	21.7334
8	20.5406
27.2216 ± 3.93257
8	24.5005
27.116 ± 4.11758
8	21.4674
8	21.3765
28.168 ± 3.92933
28.6932 ± 3.90789
8	19.6483
27.3897 ± 3.93099
8	20.5168
8	22.8725
8	22.9854
8	22.9795
8	22.3323
8	23.7449
8	24.3853
8	22.1537
8	20.2172
8	20.1504
8	20.1139
8	20.2957
8	22.6746
8	20.096
8	23.6196
8	21.4368
8	19.7811
29.6175 ± 3.9932
8	22.3721
8	22.9672
8	22.1074
8	24.2945
8	23.6013
8	23.5706
8	22.324
8	21.9998
26.7546 ± 4.08777
8	23.3092
8	21.9385
27.9782 ± 4.20914
28.585 ± 3.94673
8	19.6893
8	21.4091
8	22.7389
28.5377 ± 3.89145
8	21.904
8	23.0497
28.2192 ± 4.16888
27.6781 ± 4.05881
8	21.3819
8	21.8717
8	21.8305
8	21.8061
27.4424 ± 4.00891
8	22.5056
8	19.3971
8	23.0336
8	24.2887
8	23.9244
8	21.0957
8	22.1067
8	23.9196
8	22.4213
8	21.7068
8	22.092
27.3059 ± 4.023
29.0854 ± 3.81586
26.4323 ± 4.10755
26.8611 ± 4.28045
8	21.5113
8	21.6953
8	21.5516
8	22.8601
8	20.3424
8	22.284
8	21.5417
26.2769 ± 4.36238
8	21.2032
25.6505 ± 4.14949
8	23.0151
8	21.7618
8	22.8775
27.8729 ± 4.12199
29.5177 ± 3.76754
27.2018 ± 4.35677
26.8405 ± 4.18292
28.0494 ± 4.15441
8	21.7991
8	22.2791
8	22.8671
25.5308 ± 4.10599
28.244 ± 4.19477
8	21.3764
8	22.7893
25.9852 ± 4.00927
26.695 ± 3.87425
8	22.1287
28.596 ± 3.75605
26.5912 ± 4.11297
27.7053 ± 3.89569
8	22.6765
28.6274 ± 3.94102
27.0391 ± 4.02786
9	21.7774
9	21.1555
9	21.6169
9	21.5235
9	20.9407
9	21.1402
9	20.9995
9	20.8636
26.1715 ± 3.93695
9	20.7028
9	20.5272
26.8312 ± 3.9461
9	19.9071
9	21.708
9	21.2025
9	20.6316
9	21.6814
9	22.4384
9	20.848
9	22.431
26.2432 ± 4.0199
9	20.8156
9	20.5187
9	21.5866
9	21.3681
9	19.3124
9	19.2623
9	21.5728
9	21.3921
9	20.6768
9	20.5523
9	21.0764
9	19.7337
9	20.5467
9	21.9505
9	20.3232
9	20.1587
9	21.3669
9	21.1322
9	20.926
9	23.061
9	22.0651
9	22.0077
9	21.8598
9	20.8637
9	21.6456
9	21.4747
9	21.5767
9	20.791
9	20.6919
9	20.8214
9	20.8562
9	20.514
9	20.5776
9	20.532
9	22.6502
9	20.3259
9	21.2122
9	22.6298
9	19.213
9	22.1339
9	22.0707
9	21.7501
9	20.2625
9	22.0001
9	21.8989
9	20.3562
9	21.8619
25.4158 ± 4.32021
9	22.6106
9	22.2714
9	22.1129
9	20.0452
9	21.8333
9	21.5563
9	20.5845
9	20.3545
9	20.1238
26.7637 ± 4.19297
9	19.095
9	19.9452
9	22.5375
9	20.4104
9	21.0749
9	19.6702
9	21.7618
25.9055 ± 4.0388
9	22.7109
27.2239 ± 3.93133
9	21.6299
9	21.6793
27.2045 ± 3.89847
9	22.1297
9	22.3326
9	21.8861
9	20.1276
9	21.8062
9	19.6296
9	21.7561
9	20.4749
9	22.1321
9	20.4816
9	20.4293
9	21.6807
9	22.0801
9	22.0631
25.232 ± 4.2479
9	21.5928
9	21.4791
9	21.8364
9	22.2836
9	21.5866
9	21.2425
9	23.5043
9	23.3609
9	20.2814
9	20.3243
9	23.1192
9	20.4128
9	22.6196
9	22.4621
9	21.5988
9	20.2185
9	21.0026
26.7139 ± 4.00011
9	22.3431
9	20.1798
9	21.6004
9	20.1167
26.5956 ± 4.2694
9	20.0888
26.1341 ± 3.96624
9	22.2726
9	22.2833
9	22.1482
27.0964 ± 4.00599
9	21.5277
9	22.2672
9	21.909
9	21.5161
9	20.1508
9	20.1923
9	22.7829
9	20.1604
9	19.9929
9	22.7488
9	21.3898
9	20.5134
28.4268 ± 3.78338
9	19.9742
9	22.0313
9	22.4195
9	20.6512
25.296 ± 4.1841
9	21.5536
26.3602 ± 3.97299
9	21.5431
9	21.2923
26.9072 ± 4.08148
9	20.0626
25.9962 ± 3.96378
9	22.2005
9	22.0592
25.9011 ± 4.13236
27.8555 ± 3.98303
9	19.3521
9	20.4312
9	19.0923
9	21.0471
9	19.8404
9	20.6516
9	21.649
26.9538 ± 3.80979
9	20.6617
9	20.0311
9	21.4967
9	20.9222
9	21.4554
26.0251 ± 4.36672
9	21.8573
9	21.5927
9	22.0858
9	18.805
9	22.7497
25.028 ± 4.25357
9	22.5804
9	21.7207
9	21.6724
9	22.4898
9	21.1964
9	22.7202
26.7475 ± 4.06983
9	20.1476
9	20.0584
9	21.8354
9	22.1371
9	20.7066
9	21.9622
9	20.9906
9	19.7394
9	21.1759
26.9427 ± 4.07273
9	21.1675
9	20.9964
9	23.8794
9	21.6673
0
10
57
3
62
19
6
7
63
9
11
44
12
13
14
15
16
17
18
54
20
26
47
23
24
25
39
31
1
29
61
21
32
4
34
35
42
2
27
56
30
55
36
43
22
28
46
5
48
49
50
53
52
51
45
41
40
37
58
59
33
38
8
60
9	23.7148
9	23.3855
9	20.9671
46 sends to 46
46 receives from 46
47 sends to 5
47 receives from 22
56 sends to 40
56 receives from 39
55 sends to 41
55 receives from 41
61 sends to 38
61 receives from 30
14 sends to 14
14 receives from 14
26 sends to 39
26 receives from 21
16 sends to 16
16 receives from 16
37 sends to 2
37 receives from 57
36 sends to 42
36 receives from 42
38 sends to 27
38 receives from 61
42 sends to 36
42 receives from 36
41 sends to 55
41 receives from 55
52 sends to 52
52 receives from 52
0 sends to 0
0 receives from 0
9	21.6318
27.2735 ± 4.03621
9	21.4351
19 sends to 54
19 receives from 5
25.8234 ± 4.28426
9	20.9301
9	21.3014
40 sends to 30
40 receives from 56
9	20.5311
51 sends to 53
51 receives from 53
9	20.2263
9	19.6587
27.5348 ± 4.17579
28.5886 ± 4.06415
9	20.4326
9	20.1168
9	21.3166
9	21.1068
9	23.0152
9	23.6746
9	23.4941
9	23.3899
9	18.9372
9	20.9168
63 sends to 60
63 receives from 8
9	20.9835
26.4187 ± 4.00341
32 sends to 32
32 receives from 32
9	20.8171
27.2438 ± 4.03724
25.1489 ± 4.18093
9	20.7738
9	22.4807
48 sends to 48
48 receives from 48
9	21.3662
27.3096 ± 4.0596
9	21.2051
9	22.2252
25.9936 ± 4.15266
54 sends to 45
54 receives from 19
9	22.3696
9	18.7086
9	20.567
9	21.9101
9	21.0451
9	20.7255
9	19.6599
9	21.1242
9	20.9634
53 sends to 51
53 receives from 51
45 sends to 28
45 receives from 54
9	20.2356
9	19.6833
9	19.5754
9	21.1029
9	22.6334
9	22.4746
9	22.372
26.9629 ± 4.22967
9	22.8066
27.9818 ± 3.98099
26.6541 ± 4.1267
26.3262 ± 3.91456
9	21.7165
9	21.7106
27.3812 ± 3.97429
9	19.641
9	21.653
9	21.2931
43 sends to 43
43 receives from 43
9	22.178
9	20.6599
25 sends to 25
25 receives from 25
20 sends to 20
20 receives from 20
15 sends to 15
15 receives from 15
9	21.0703
9	20.6551
24.5305 ± 4.24845
9 sends to 9
9 receives from 9
9	19.5995
9	20.8415
9	18.785
21 sends to 26
21 receives from 31
25.7026 ± 4.33019
30 sends to 61
30 receives from 40
9	22.0112
9	21.9822
9	21.8537
9	21.8897
9	21.7726
9	21.4224
28 sends to 1
28 receives from 45
31 sends to 21
31 receives from 27
27.7761 ± 3.95687
9	20.5514
25.0548 ± 4.23872
26.4611 ± 4.04578
9	20.5531
9	20.5133
9	20.4611
27.3958 ± 4.09104
33 sends to 4
33 receives from 60
26.68 ± 3.97097
26.7275 ± 4.25039
5 sends to 19
5 receives from 47
9	18.7328
26.9287 ± 4.13352
27 sends to 31
27 receives from 38
25.9932 ± 4.14781
44 sends to 22
44 receives from 11
50 sends to 50
50 receives from 50
18 sends to 18
18 receives from 18
25.7628 ± 3.90705
28.6651 ± 3.72942
9	20.82
9	20.8113
9	18.4928
25.9024 ± 4.29556
9	19.5134
24.5551 ± 4.16386
58 sends to 58
58 receives from 58
9	21.3204
9	19.2997
9	21.2689
39 sends to 56
39 receives from 26
26.4319 ± 4.19776
25.8594 ± 4.14942
28.4469 ± 3.89586
9	21.1953
9	21.003
9	21.2834
27.9716 ± 3.90394
9	20.8312
22 sends to 47
22 receives from 44
11 sends to 44
11 receives from 10
24 sends to 24
24 receives from 24
25.4586 ± 4.13459
9	20.0608
29 sends to 29
29 receives from 29
34 sends to 34
34 receives from 34
25.2681 ± 3.96865
9	20.0276
27.6722 ± 3.96321
27.017 ± 4.3796
13 sends to 13
13 receives from 13
7 sends to 7
7 receives from 7
2 sends to 57
2 receives from 37
6 sends to 6
6 receives from 6
57 sends to 37
57 receives from 2
23 sends to 23
23 receives from 23
10 sends to 11
10 receives from 1
27.0954 ± 3.95702
1 sends to 10
1 receives from 28
8 sends to 63
8 receives from 62
60 sends to 33
60 receives from 63
12 sends to 12
12 receives from 12
17 sends to 17
17 receives from 17
62 sends to 8
62 receives from 4
35 sends to 35
35 receives from 35
3 sends to 3
3 receives from 3
25.7187 ± 4.14244
26.3871 ± 4.01184
4 sends to 62
4 receives from 33
59 sends to 59
59 receives from 59
49 sends to 49
49 receives from 49
10	21.4988
10	21.4045
10	20.8116
10	21.3656
10	20.4816
10	20.3782
10	20.2397
10	19.9429
10	19.7337
10	19.9008
10	19.4608
10	19.4374
10	21.3609
10	21.3608
10	21.3361
10	20.3289
10	22.5737
10	22.4574
10	22.4271
10	21.6214
10	19.691
10	22.596
10	21.3114
10	21.5301
10	19.3671
10	21.3081
10	21.1133
10	20.563
10	21.0484
10	19.6296
10	20.1587
10	20.1145
10	19.4117
10	19.1977
10	20.001
10	19.8978
10	21.2461
10	20.9571
10	22.4487
10	20.9099
10	22.2639
10	20.4594
10	19.1181
10	21.2871
10	22.073
10	20.4201
10	19.6416
10	18.7528
10	21.3681
10	20.967
10	20.7877
10	20.516
10	19.7147
10	20.6512
10	20.3032
10	20.9397
10	19.8404
10	22.3089
10	18.7933
10	20.2963
10	22.0402
10	21.0943
10	19.8343
10	19.7698
10	19.7526
10	20.2472
10	21.0398
10	19.3285
10	19.6911
10	19.6933
10	19.8142
10	20.8878
10	21.3921
10	21.4175
10	21.4146
26.0169 ± 3.96455
10	19.8436
10	20.7694
10	20.4089
10	21.3446
10	21.3197
10	21.3785
10	21.2814
10	20.0416
26.9689 ± 3.97582
10	21.0052
10	21.4351
10	20.3554
10	19.6211
10	21.8286
10	21.3008
26.3859 ± 4.01822
10	20.8645
10	20.2417
10	20.401
10	20.1923
25.3102 ± 4.07555
10	20.3381
10	19.5477
10	20.9098
10	19.3155
24.3154 ± 4.09085
10	19.7619
10	19.9801
10	21.1707
10	21.0046
10	20.5537
10	20.5118
10	21.3061
10	20.43
10	18.983
10	18.5289
10	18.4105
10	17.8277
27.5634 ± 4.17405
10	19.0147
10	18.0761
26.4835 ± 4.07841
10	20.3892
10	17.7177
10	19.4326
10	21.2746
25.7861 ± 4.0866
10	17.6957
10	20.7835
10	21.7642
10	21.4776
10	20.1813
10	21.2693
10	20.6769
10	17.6271
10	20.4827
25.7382 ± 3.85844
10	17.6099
10	18.6668
10	18.3765
10	21.1661
10	17.7609
27.9837 ± 3.76054
10	17.5744
10	20.9407
10	20.6969
10	20.0311
10	19.7973
10	19.5323
10	20.1996
25.904 ± 3.91843
10	17.4557
10	17.4337
26.4146 ± 4.03304
27.4323 ± 3.79693
10	20.9062
10	20.7352
10	20.7128
10	21.2205
10	19.8764
25.5635 ± 4.20258
26.9156 ± 4.187
10	20.4655
10	20.0205
10	19.8364
26.3371 ± 4.09515
10	20.5893
27.2325 ± 3.82534
26.2916 ± 3.93572
10	19.9836
26.6032 ± 3.99698
10	21.6361
10	21.5468
10	17.3145
26.4929 ± 4.23051
27.3762 ± 3.99379
26.191 ± 4.04363
10	20.7071
10	20.5659
10	19.2819
10	19.1861
10	20.3988
10	19.1692
10	20.2975
10	22.3966
10	20.6507
10	20.4627
10	19.5776
10	19.3584
10	19.045
10	18.6867
10	21.1454
25.7832 ± 4.26167
10	21.3931
10	20.6363
26.4752 ± 4.20496
10	18.9773
27.3649 ± 3.98605
10	20.1702
10	20.0726
10	20.0626
10	19.9004
24.8283 ± 4.28459
10	19.1117
10	19.7539
10	22.9492
10	22.8628
25.3518 ± 4.04799
10	21.418
10	21.319
10	21.1706
26.4253 ± 3.98344
10	20.4459
10	20.1508
10	20.1444
10	20.975
10	20.9507
10	20.2811
10	19.5025
10	20.9283
10	17.1826
10	22.7332
27.1601 ± 3.9845
10	20.2911
10	19.7995
10	20.729
10	19.2591
27.1551 ± 3.98303
10	21.3386
25.6595 ± 4.28367
27.1939 ± 3.85151
10	18.9134
27.1637 ± 4.14984
24.5076 ± 4.29927
10	18.8689
10	19.9656
10	20.3608
10	19.4767
27.0839 ± 4.08076
10	20.6552
10	21.9414
10	18.7854
27.0961 ± 4.04701
23.5735 ± 4.37243
10	21.1177
25.2061 ± 4.06239
25.7908 ± 4.14047
26.4974 ± 4.12942
10	21.0335
25.8146 ± 4.30333
10	20.0296
10	20.569
10	21.2884
10	18.6495
27.1678 ± 4.00122
24.3936 ± 4.30769
10	20.1165
26.3628 ± 3.97039
10	20.6338
27.6142 ± 4.3456
24.154 ± 4.18734
27.8913 ± 3.82946
10	20.9873
26.7169 ± 4.06554
26.5965 ± 4.14322
26.7673 ± 4.12127
25.9976 ± 4.33406
10	19.9808
10	19.6968
10	19.5143
25.8293 ± 4.12407
25.5444 ± 4.04883
10	20.742
26.9023 ± 3.92563
10	19.5062
10	18.917
24.7467 ± 4.19415
11	20.7832
11	20.6945
11	20.5697
11	20.2472
11	19.6887
11	20.9207
11	20.6093
11	18.2565
11	18.1976
11	20.2335
11	20.2188
11	20.4124
11	20.0953
11	22.1573
11	19.5871
11	19.0322
11	19.7176
11	21.6699
11	19.6734
11	19.0597
11	20.0723
11	20.1773
25.1931 ± 3.91531
11	19.6575
11	20.1694
11	19.3881
11	21.5886
11	20.0358
11	19.4707
11	21.4749
11	21.0897
11	20.163
11	19.2837
11	18.9214
11	18.7074
11	18.2144
11	20.1066
11	20.1935
11	18.1751
11	19.2525
11	18.5753
11	19.9506
11	20.9714
11	19.1533
11	18.1118
11	20.3809
11	19.5049
26.4356 ± 4.11694
11	20.3125
11	19.9696
11	19.7777
11	21.3204
11	22.1026
11	20.1986
11	18.1296
11	19.6137
11	20.8926
11	20.5382
11	19.9184
11	19.5843
11	19.4859
25.7855 ± 4.04064
11	20.1839
11	19.335
11	18.9246
11	21.6912
11	19.0364
11	19.6257
11	19.6166
11	19.4096
11	19.2648
23.6366 ± 4.0669
11	18.8696
11	19.4469
11	19.0796
11	18.0693
11	20.4681
11	17.8187
11	21.268
25.1681 ± 3.93527
11	18.0465
11	20.1744
11	21.1223
11	20.9499
11	20.4562
11	19.9456
11	20.117
11	19.6011
11	20.8433
11	19.7144
11	19.4151
11	20.947
11	19.6566
27.3898 ± 3.93143
11	19.329
11	19.7582
11	19.57
11	19.8779
11	20.9555
11	17.5373
11	19.7687
11	20.8639
11	20.6975
11	20.644
11	19.9215
11	19.5677
24.6272 ± 4.06345
11	19.9964
11	18.1904
11	19.032
11	20.6415
11	19.9102
11	20.8756
11	19.3657
11	20.7925
11	20.454
11	18.4068
26.8331 ± 3.88175
25.6025 ± 4.14557
11	20.495
11	20.1497
24.9744 ± 4.18142
11	19.9212
25.7673 ± 4.24945
11	20.4217
11	18.1426
25.0593 ± 4.02098
11	19.6526
11	20.9686
11	20.1728
26.7521 ± 4.04137
11	19.3928
11	20.6185
11	20.8679
11	20.5512
25.3394 ± 4.29384
11	21.885
11	20.7474
11	19.2938
11	21.7949
11	17.5152
11	17.0974
25.8277 ± 4.00203
25.4216 ± 4.45458
25.6519 ± 4.61786
11	20.0211
11	21.1466
26.5859 ± 3.95706
25.8324 ± 4.19122
11	20.5115
11	19.1845
11	20.4645
11	19.762
11	20.7089
11	20.2202
25.922 ± 4.25204
11	19.9873
11	20.3229
11	20.2091
24.4412 ± 4.2568
11	20.4464
11	19.9791
11	20.0873
26.0151 ± 3.99731
26.7473 ± 4.31252
11	19.9841
11	20.8271
11	20.811
11	20.0342
24.8722 ± 4.33374
24.6139 ± 4.10866
11	19.542
23.9517 ± 4.26747
11	20.1026
11	19.2881
11	19.0715
11	19.744
11	18.7311
24.3305 ± 4.15295
26.4059 ± 4.12373
11	18.432
11	19.7654
11	20.6612
11	19.6048
11	19.4904
11	19.983
11	19.984
11	19.0833
26.3617 ± 3.97573
24.4121 ± 4.60355
11	18.3725
11	18.168
11	20.3777
11	20.0623
26.177 ± 4.16596
11	19.564
22.5935 ± 4.43288
11	18.3595
11	19.1413
11	17.1384
11	16.9516
24.9006 ± 4.15682
11	19.6718
11	19.0258
11	19.4732
25.6229 ± 4.08231
11	20.6803
11	20.5584
11	19.969
26.9922 ± 4.13889
11	19.9101
11	18.2655
11	18.9728
11	19.9142
26.263 ± 4.04573
11	19.2749
11	19.3194
24.0983 ± 4.19882
11	20.5432
11	19.2097
11	19.806
11	19.9633
11	19.8304
11	18.8026
11	19.0272
11	19.8018
11	19.6065
26.423 ± 4.07224
26.6808 ± 4.19986
26.8867 ± 4.04441
11	19.5635
25.3997 ± 4.16998
11	20.5397
25.6463 ± 4.11145
11	19.7304
11	19.6226
11	19.2303
11	18.8358
25.3255 ± 4.1593
11	19.7773
25.5513 ± 4.09606
11	18.7528
25.6823 ± 3.98612
25.0278 ± 4.32212
11	19.5784
11	19.4662
11	16.9472
11	19.2286
11	19.7192
11	19.4727
11	18.7265
11	18.7228
11	20.3482
24.7455 ± 4.18464
11	18.6728
11	19.8368
23.4929 ± 4.28125
11	19.5857
25.907 ± 4.29926
11	18.5961
11	19.3857
11	18.3302
11	19.3217
25.6474 ± 4.34745
26.0206 ± 4.63647
23.2811 ± 4.22674
25.7731 ± 3.95113
26.5015 ± 4.16701
11	20.1562
25.7824 ± 4.21367
23.0703 ± 4.5226
26.0733 ± 4.19138
26.3939 ± 4.03568
25.616 ± 4.20169
26.1548 ± 4.30354
11	18.3167
11	19.3846
24.5273 ± 4.14895
25.5397 ± 4.17249
11	18.2448
11	18.0249
23.7985 ± 4.22822
12	20.2622
12	20.0955
12	20.0914
12	18.8205
12	18.7722
12	18.9158
12	19.9514
12	20.0622
12	18.6243
12	18.7005
12	18.5456
12	18.2818
12	19.4808
12	18.8998
12	19.3224
12	17.5928
12	19.8931
12	19.8537
12	19.7583
12	19.8381
12	19.7525
12	20.6968
12	19.3139
12	18.1191
12	19.5235
12	19.4931
12	19.3172
12	21.2893
12	19.5577
12	20.3685
12	18.7222
12	19.6974
12	19.4921
12	19.0724
12	18.9243
12	17.534
12	20.9406
12	18.7599
12	19.1523
12	18.8831
12	18.8591
12	19.1968
12	18.7635
25.1898 ± 4.0639
24.5168 ± 3.93215
12	19.3849
12	19.6665
12	19.7329
12	19.6892
12	20.7725
12	20.5515
12	19.6174
12	18.8301
12	19.7619
12	19.7546
12	20.9468
24.3398 ± 4.58133
12	19.6922
23.6427 ± 4.1362
12	17.7362
12	17.4463
12	19.6355
12	18.8157
12	20.2562
12	17.6367
12	19.249
12	19.4039
12	18.8184
12	20.658
12	18.0389
12	17.6964
12	18.1178
12	18.6113
12	17.3822
12	19.2891
12	18.5036
12	19.5442
24.2837 ± 4.31033
12	18.4924
25.4693 ± 4.2831
12	19.418
12	17.5003
12	20.6705
12	20.6609
12	17.0953
12	19.403
12	20.4857
22.8697 ± 4.17475
12	18.0886
12	19.7488
12	19.3129
12	18.5931
12	19.0916
12	17.0884
24.436 ± 3.96383
12	19.1935
12	19.0635
12	20.306
12	17.419
12	19.1035
12	19.2723
12	20.1783
12	18.93
12	17.053
12	17.5229
12	17.3979
25.0146 ± 4.10889
12	19.5867
12	20.3612
12	19.7535
23.6879 ± 4.32993
12	16.9977
25.9415 ± 4.04996
12	18.7175
12	19.5945
12	19.1402
12	16.4325
12	19.7802
12	19.1763
26.5497 ± 4.02243
12	20.4222
12	19.7479
12	20.4433
12	18.8174
12	20.3387
12	20.6463
12	20.497
12	20.4578
25.8355 ± 4.10845
12	19.4617
12	19.4167
24.8496 ± 4.47058
12	19.3955
12	20.3342
12	19.0989
12	18.2988
12	18.5793
12	20.6622
12	18.5194
12	18.3652
12	20.544
12	20.3119
23.6099 ± 4.24238
12	20.2333
24.3993 ± 4.08672
12	18.4744
26.0926 ± 4.00792
12	20.1989
25.2024 ± 4.3296
12	19.5411
12	18.994
24.9533 ± 4.25882
12	20.4729
12	19.6734
25.1841 ± 4.33491
12	18.7292
12	19.4575
12	19.6496
12	19.3318
12	19.9589
24.8909 ± 4.22158
12	17.2416
12	19.7706
12	19.1863
12	20.2425
12	19.0957
12	19.7945
12	19.7693
23.5415 ± 4.14437
12	19.5322
12	20.2577
24.2528 ± 4.76183
12	18.9752
12	19.2468
12	18.9852
12	18.4651
24.2781 ± 4.14005
12	18.0946
12	20.2136
12	20.0205
12	18.8212
12	17.8815
25.5409 ± 4.58227
12	19.6532
23.3458 ± 4.35936
12	17.5335
12	19.9636
12	18.1122
12	17.8779
12	19.8956
12	19.4689
12	17.55
12	17.2324
23.0071 ± 4.77031
12	19.8733
12	18.8724
12	18.1826
12	17.8253
12	18.7728
12	18.4422
12	19.3822
12	18.3325
12	17.6103
25.7524 ± 4.04543
12	18.8341
12	19.1955
12	19.0221
12	16.829
12	16.6279
12	19.7103
12	18.7032
12	16.5183
12	19.5275
25.2251 ± 4.15918
12	19.7624
21.9642 ± 4.41901
12	19.6628
12	19.1641
12	19.3715
12	19.231
12	19.6863
12	18.7804
12	18.4448
25.151 ± 4.19713
12	19.16
12	19.1381
12	19.6849
12	19.6095
12	19.8442
12	19.6298
12	19.7662
12	18.35
12	20.2942
25.4155 ± 4.17741
12	19.1371
12	19.1062
12	18.9597
12	18.4236
12	18.4919
12	20.1239
12	18.9797
12	18.9244
12	19.6994
12	19.5131
12	18.7796
12	17.9782
12	18.4388
25.6603 ± 4.24176
24.8989 ± 4.06618
25.7903 ± 4.31231
12	18.7453
12	16.4595
24.9607 ± 4.17192
12	19.6512
12	17.6623
12	19.5303
12	17.658
12	19.3785
12	19.5841
12	18.9589
23.6053 ± 4.22002
12	18.7519
12	18.7439
12	19.5386
26.0484 ± 4.24687
12	19.5747
12	17.5871
24.0355 ± 4.19025
12	18.2993
24.7417 ± 4.31348
24.3188 ± 4.27107
24.6935 ± 4.19395
24.7435 ± 4.17997
24.7706 ± 4.19206
22.4884 ± 4.23067
12	19.9914
25.0213 ± 4.05123
12	18.741
12	18.7212
12	18.6884
12	19.5405
23.2033 ± 4.36762
25.2404 ± 4.14113
12	18.7087
12	18.397
12	19.249
25.208 ± 4.25654
22.3538 ± 4.41689
23.1899 ± 4.09947
12	18.1751
23.7945 ± 4.29661
25.1607 ± 4.15375
24.6985 ± 4.14258
12	18.4456
24.4925 ± 4.21483
12	17.395
24.8524 ± 4.41802
25.2291 ± 4.27603
25.3775 ± 4.37073
24.7905 ± 4.21164
24.6248 ± 4.45926
23.6481 ± 4.15201
24.8635 ± 4.58931
22.8764 ± 4.24556
24.5336 ± 4.42019
13	19.5666
13	19.6917
13	19.5686
13	19.4044
13	18.5726
13	19.2256
13	18.1403
13	18.3196
13	17.8887
13	17.7703
13	19.5677
13	18.2438
13	17.5171
13	17.317
13	19.3835
13	19.2154
13	17.2217
13	18.378
13	18.3547
13	18.2428
13	18.4794
13	19.6178
13	18.1288
13	19.4789
13	18.2554
13	19.4218
13	20.4547
13	18.3577
13	17.9278
13	17.7686
13	20.3815
13	17.1464
13	17.7502
13	20.1156
13	19.9357
13	18.9422
13	18.6534
13	17.1084
13	19.7697
13	18.5985
13	18.3804
13	17.6645
23.9394 ± 3.96171
13	18.6443
13	18.9474
13	17.9895
13	19.5055
13	18.7015
24.3294 ± 4.12061
13	18.3008
13	19.3029
13	20.418
13	20.7786
13	20.5404
13	20.1871
13	20.0482
13	19.1493
13	18.7999
13	18.235
23.1163 ± 4.5136
13	16.4236
13	15.9
13	18.6222
13	17.3538
13	17.0093
13	18.2004
13	20.0251
13	18.7943
13	18.7548
13	17.6089
13	18.8527
13	17.8373
13	18.1069
22.0233 ± 4.24828
13	19.8568
13	18.8883
13	18.8469
13	18.8397
13	19.2949
13	19.2283
13	19.1758
13	19.166
25.0946 ± 4.08537
13	19.1402
13	20.287
13	18.5143
13	18.7394
13	20.1259
13	20.081
13	18.9733
13	18.7706
23.4072 ± 4.34563
13	18.0888
13	16.909
13	17.5684
22.941 ± 4.19019
24.2903 ± 4.4655
13	18.7433
13	19.0509
23.8896 ± 3.99554
23.8954 ± 4.14224
13	19.3857
13	18.3721
13	18.6454
13	17.9758
13	20.4671
13	18.6876
13	19.6389
13	19.2255
13	18.5175
13	17.8592
13	17.1088
13	19.3318
13	20.104
22.7858 ± 4.26056
13	18.392
13	19.1201
22.9868 ± 4.29231
13	15.4229
24.9576 ± 4.10108
13	19.2236
13	17.5866
23.9292 ± 4.43671
13	18.6538
13	18.5567
13	19.0351
13	17.8901
13	18.9756
13	18.9216
13	18.5284
13	18.4361
24.159 ± 4.18351
13	18.539
13	17.2857
13	18.5352
25.2825 ± 4.10554
13	19.6927
13	18.8766
24.6634 ± 4.11828
13	15.2819
13	18.4816
13	17.247
13	18.5013
13	19.6766
25.74 ± 4.08035
13	19.5145
13	19.4643
13	19.4441
21.6959 ± 4.76988
13	19.4397
23.8671 ± 4.30918
13	18.182
24.0058 ± 4.23135
13	17.0507
13	19.4055
13	18.2602
13	18.4978
22.3715 ± 4.43054
13	18.472
13	19.235
22.7633 ± 4.18333
13	19.3946
13	19.3984
13	19.9626
13	17.8956
22.052 ± 4.08327
13	19.4399
13	17.5196
13	17.472
13	17.3474
24.4659 ± 4.56573
13	17.5043
13	17.487
13	19.0961
13	16.8887
23.5441 ± 4.17753
24.9929 ± 4.30627
24.1159 ± 4.22342
13	19.2131
24.0909 ± 4.28828
13	17.2852
13	17.9526
13	19.1668
13	18.8737
13	19.7444
13	18.4114
13	19.5021
13	19.501
13	19.4031
13	18.2054
13	17.9503
13	19.3817
25.2224 ± 4.10171
13	18.6498
13	19.3887
13	19.0019
13	17.9672
13	18.9985
13	17.0194
24.5234 ± 4.33972
13	19.2569
13	19.7383
13	19.6597
13	19.2636
13	18.395
13	18.378
13	17.3042
13	18.3067
13	19.3377
13	16.3078
13	16.2231
24.4452 ± 4.2434
13	19.2291
13	19.0135
13	19.5063
22.9064 ± 4.76761
13	19.471
24.005 ± 4.20344
23.6793 ± 4.32013
13	18.9403
13	18.4302
13	18.2903
13	18.2618
13	18.6628
13	16.1086
13	17.5872
13	18.6466
13	17.228
13	18.1376
23.2426 ± 4.26027
23.75 ± 4.16748
13	18.1048
13	18.0465
13	17.8101
13	18.2646
13	18.2261
13	19.2284
13	18.7462
13	19.4545
13	18.2596
13	17.4763
21.7345 ± 4.24816
13	19.4221
13	18.9911
13	17.4656
13	18.2373
24.1313 ± 4.21391
13	17.6878
13	18.9278
13	17.1122
13	19.0941
13	17.5899
13	18.026
13	19.0743
24.3365 ± 4.25445
13	17.0705
13	17.9575
13	18.7606
13	18.5779
22.8551 ± 4.18925
13	18.4924
13	16.8646
13	17.1945
23.961 ± 4.12046
23.9108 ± 4.19779
13	16.9603
13	18.1854
13	19.3007
13	18.4676
22.2229 ± 4.33731
13	18.0018
24.1724 ± 4.25644
13	17.518
22.5707 ± 4.21651
13	17.9822
24.4328 ± 4.32982
13	19.0886
24.8309 ± 4.00278
13	19.0466
13	17.3892
13	18.1264
23.8243 ± 4.19337
25.2252 ± 4.24546
13	18.0837
13	17.6534
21.7699 ± 4.35245
23.802 ± 4.14531
23.7046 ± 4.60541
13	17.5743
23.6348 ± 4.28515
24.6217 ± 4.23282
24.1208 ± 4.3129
23.7691 ± 4.64725
23.4611 ± 4.50347
23.6352 ± 4.55288
25.0388 ± 4.18815
22.5674 ± 4.39932
13	18.2891
23.7579 ± 4.26747
23.4307 ± 3.96217
22.1625 ± 4.28149
14	19.2322
14	19.0696
14	19.1763
14	19.136
14	18.7436
14	17.0802
14	16.9813
14	16.8366
14	17.085
14	16.979
14	16.6464
14	18.6056
14	18.1382
14	17.8918
14	19.9435
14	19.8554
14	17.792
14	17.243
14	19.8262
14	17.643
14	16.6848
14	17.6966
23.454 ± 3.99687
14	18.6175
14	20.445
14	17.5981
14	20.4354
14	18.3739
14	20.2893
14	18.3056
14	20.2826
14	15.273
14	17.8933
14	18.5825
14	17.454
14	17.2265
14	19.698
14	19.6768
14	15.2381
14	17.9692
14	17.1373
14	19.7804
14	18.1619
14	18.1608
14	19.6719
14	18.1088
14	15.0248
14	17.5225
14	17.9548
14	18.5241
14	17.4677
14	16.9966
14	17.2767
14	17.2446
23.689 ± 4.17416
14	17.6722
22.0274 ± 4.47292
14	19.3872
14	18.3845
14	19.3604
14	17.5657
14	18.5272
14	17.4638
14	17.627
14	18.3817
14	16.8982
14	16.7871
21.3716 ± 4.28635
14	18.3814
14	19.3725
14	16.9955
14	19.0372
14	16.9551
14	16.7445
14	17.6056
14	18.2792
14	18.2635
14	19.3364
14	18.9581
24.4094 ± 4.09987
14	18.3985
14	18.2068
14	17.7637
14	18.079
14	19.0705
14	18.2431
14	18.0573
14	16.5916
22.0741 ± 4.2655
14	14.8622
22.8586 ± 4.33297
14	17.6045
14	20.168
14	20.1412
14	18.1459
14	18.4833
14	17.8058
14	18.2892
23.0547 ± 4.54825
14	18.057
14	17.6015
14	18.264
14	18.0886
23.1024 ± 4.10916
14	17.5051
14	18.0016
14	17.9364
14	17.9532
14	17.836
14	17.764
14	19.7651
14	18.5913
14	17.5618
14	18.3882
20.439 ± 4.75337
14	18.8718
14	18.4662
14	18.4173
14	18.0471
14	17.8128
14	18.3548
14	17.4353
14	19.5253
14	17.938
14	17.7406
14	17.9809
14	17.2323
14	17.3097
14	17.3491
14	16.7742
14	16.2555
14	19.5116
22.3956 ± 4.20623
14	17.3024
14	16.8886
14	16.7678
23.6289 ± 4.03062
14	16.5632
14	18.016
14	16.4187
14	17.4395
25.0677 ± 3.91779
21.6144 ± 4.09584
14	17.4896
23.1673 ± 4.33137
14	17.9781
22.775 ± 4.41912
25.1139 ± 4.15624
14	17.8724
14	18.8826
24.5868 ± 4.07494
14	17.6959
14	19.3891
14	16.9275
14	16.9752
14	18.2634
14	18.0971
14	17.9213
14	17.0148
14	16.8671
14	17.6249
23.283 ± 4.19382
14	16.8373
23.384 ± 4.46592
14	17.2983
14	16.9513
14	16.8227
23.1496 ± 4.17153
14	16.829
14	16.7502
23.1726 ± 4.24983
14	16.7547
14	17.2736
21.616 ± 4.42753
14	16.3691
14	17.657
14	17.7968
24.0772 ± 4.17236
14	17.4866
14	17.9262
14	17.1805
14	18.9099
14	17.7791
14	18.0151
14	18.8843
22.2057 ± 4.19152
14	17.5591
14	18.8654
22.2253 ± 4.25088
14	17.5725
14	16.6348
14	18.033
14	18.9778
14	18.903
23.2402 ± 4.33132
22.8622 ± 4.12597
14	17.9027
22.6969 ± 4.35242
14	17.7591
14	17.3922
14	17.3653
14	16.4317
14	15.9569
14	15.9357
14	18.4683
14	18.6468
22.4035 ± 4.36183
14	17.252
14	18.4287
23.5443 ± 4.19287
14	18.7789
14	18.0666
14	17.531
14	16.3865
14	18.623
14	19.1999
22.2552 ± 4.23965
14	17.6594
14	17.5089
22.927 ± 4.2481
23.2449 ± 4.20577
14	18.588
23.2741 ± 4.26844
14	19.1676
14	18.8652
14	19.0397
14	18.7034
24.7083 ± 4.14492
14	18.422
14	17.0698
14	16.7433
14	17.4902
14	18.4615
14	16.7275
14	19.0537
24.0873 ± 4.13223
14	18.2418
14	18.315
14	17.2955
14	19.0031
22.1903 ± 4.5866
14	19.5539
14	17.4016
23.3772 ± 4.44981
14	18.1205
14	15.7979
14	18.622
14	16.7852
14	16.9513
14	16.785
14	18.9194
14	18.0776
14	17.3399
14	19.4923
14	16.7407
21.2409 ± 4.21972
14	19.3773
14	17.5678
14	17.4732
14	16.8278
23.8673 ± 4.34997
14	17.3305
21.8282 ± 4.26526
14	16.7305
14	17.3015
21.4988 ± 4.40067
14	19.2091
14	16.6609
14	16.9346
14	18.8954
14	17.2573
23.0522 ± 4.29456
14	17.2443
14	17.0909
14	16.9999
14	18.6154
14	16.7662
23.356 ± 4.1984
21.1812 ± 4.35349
23.7216 ± 4.28315
14	18.3015
22.8701 ± 4.46369
22.703 ± 4.63743
14	18.3152
14	17.9272
22.8054 ± 4.32699
14	16.7517
23.3501 ± 4.2918
23.1668 ± 4.18073
14	16.6966
24.1405 ± 4.1528
14	16.6378
22.5911 ± 4.29697
14	18.268
14	18.2132
23.893 ± 4.34524
14	18.0368
14	17.8418
24.3503 ± 4.21952
14	16.7811
14	17.6637
14	16.6555
21.8478 ± 4.33365
24.3989 ± 4.20619
23.1249 ± 4.32449
22.9977 ± 4.44109
22.3626 ± 4.59364
21.5814 ± 4.42272
23.0596 ± 4.23774
22.9773 ± 4.03758
15	18.9271
15	18.9183
15	18.8846
15	18.1107
15	18.5763
15	16.5433
15	17.1388
15	16.2782
15	16.5171
22.9942 ± 4.00399
15	19.4881
15	19.3998
15	16.4598
15	16.4287
15	19.163
15	16.3465
15	17.3866
15	16.0493
15	17.3375
15	16.8993
15	16.9692
15	16.9633
15	17.5823
15	17.4988
15	17.5005
15	16.77
15	17.0818
15	17.5661
15	17.0081
15	19.6725
15	16.9709
15	19.654
15	16.1476
15	17.1586
15	17.1512
15	19.6353
15	19.3565
15	19.365
15	17.3515
15	17.6126
15	14.8533
15	14.7228
15	17.4326
15	16.7118
15	17.7021
15	17.6142
15	17.5754
15	17.0973
15	17.0133
15	17.883
15	17.9884
15	17.7461
15	16.4554
15	17.0913
15	17.4248
23.0743 ± 4.17001
15	16.7367
15	17.0176
15	16.6088
21.4414 ± 4.27367
15	17.6045
15	17.5409
15	17.1454
15	18.68
15	18.5843
15	17.637
15	16.7308
15	19.0801
15	17.2599
15	17.0188
15	19.1058
15	17.3401
15	17.6186
15	17.5115
15	17.2554
15	17.1293
15	16.1207
15	19.475
15	17.3778
15	16.6895
21.2378 ± 4.46191
15	16.369
15	16.2984
15	16.9554
20.9534 ± 4.28815
15	17.7929
15	17.161
24.7263 ± 3.88323
15	16.4673
15	17.122
15	19.36
15	17.1375
15	19.365
22.4233 ± 4.30658
15	17.2882
15	16.8813
15	17.2832
15	19.145
15	16.9177
15	16.5894
15	16.6519
15	16.1027
15	16.4453
15	16.8937
15	18.9465
15	18.3883
22.9414 ± 4.09777
21.9807 ± 4.13635
15	18.3367
15	16.6895
15	14.636
22.4293 ± 4.23179
15	18.2891
15	17.2258
15	17.9149
15	16.81
15	16.1579
15	16.4072
15	16.0881
21.9889 ± 4.45385
15	18.0629
15	16.628
15	16.5779
15	16.3269
15	17.3422
15	18.0264
15	17.1988
15	18.5158
15	16.8869
15	17.9359
15	18.1566
15	15.9736
19.5309 ± 4.73166
22.3672 ± 4.39965
23.8725 ± 4.06537
22.7475 ± 4.05637
15	17.9666
21.9997 ± 4.50687
15	18.3538
24.2882 ± 4.16474
15	15.9977
15	15.6463
22.3586 ± 4.29473
22.4676 ± 4.2578
15	15.8241
22.5623 ± 4.28463
15	15.6211
15	17.7105
22.274 ± 4.23445
15	16.2481
15	17.9862
15	16.6921
15	16.6871
15	18.3232
15	18.1359
15	18.403
20.9839 ± 4.23524
15	17.896
15	17.0855
22.315 ± 4.11584
22.1306 ± 4.18736
15	17.0441
15	16.9925
15	16.8038
24.5339 ± 4.07351
23.8651 ± 4.17936
15	16.5988
22.3971 ± 4.3105
15	17.6646
15	16.485
21.5882 ± 4.26764
15	16.7547
21.7037 ± 4.31716
15	15.7395
15	16.6912
15	17.7078
15	16.4819
15	18.0993
15	16.205
15	16.7857
15	16.7377
21.6601 ± 4.38035
15	16.47
21.5098 ± 4.29661
15	16.581
15	18.5309
15	18.2788
15	18.4595
20.8289 ± 4.29071
15	17.7305
22.6389 ± 4.36823
15	17.6062
15	17.6036
15	17.2444
15	18.3959
23.0178 ± 4.21674
23.2049 ± 4.27807
15	17.5469
15	18.8042
15	17.3403
21.6709 ± 4.41312
15	16.5825
15	16.277
15	18.382
15	15.5669
15	17.9243
15	18.7485
15	18.2129
15	17.7952
20.9761 ± 4.39718
15	17.2671
15	17.1993
15	18.1771
15	16.8272
15	16.6373
15	16.6017
22.9636 ± 4.42249
20.7679 ± 4.42403
15	18.0911
15	16.8417
23.222 ± 4.05394
15	18.2055
15	16.5856
21.4856 ± 4.20205
22.7526 ± 4.22851
23.3958 ± 4.14333
15	18.0225
15	18.0189
20.5661 ± 4.43798
15	17.3805
23.1807 ± 4.24866
15	18.1443
15	17.0612
22.0659 ± 4.32191
15	16.2631
22.5915 ± 4.29265
22.0693 ± 4.4576
15	16.8018
15	19.0162
15	17.7266
15	17.6952
15	17.5538
15	16.4919
15	16.3633
15	18.6679
21.877 ± 4.55039
15	16.4393
15	17.9945
15	17.9162
15	16.9153
15	17.529
15	17.8277
15	18.6417
21.9051 ± 4.35304
15	16.2556
23.1221 ± 4.33426
15	17.9064
15	16.3745
15	18.9268
21.2947 ± 4.38316
15	16.9079
15	17.6961
22.9266 ± 4.28366
15	16.1823
22.6929 ± 4.16112
22.6066 ± 4.21113
15	15.949
23.7636 ± 4.23849
21.4534 ± 4.55029
15	17.4231
22.3604 ± 4.39266
15	18.8708
21.7784 ± 4.27843
23.6209 ± 4.20923
21.7943 ± 4.22142
22.4322 ± 4.12498
22.4196 ± 4.28178
23.2708 ± 4.19555
16	18.4644
16	18.4323
16	18.3913
16	18.3822
16	18.3089
16	18.0415
22.5075 ± 4.03514
16	15.9078
16	16.3232
16	18.0729
16	16.5739
16	18.0644
16	18.0314
16	17.9069
16	18.7934
16	18.6084
16	15.892
16	15.8081
16	16.994
16	16.9447
16	15.7383
16	16.4698
16	16.1411
16	17.3216
16	17.7354
16	18.3818
16	15.8454
16	16.9155
16	17.225
16	18.2988
16	17.2555
16	15.8631
16	16.8881
16	18.7997
16	17.062
16	17.1156
16	16.9492
16	17.2629
16	17.1473
16	17.1698
16	16.4088
16	16.382
16	18.2424
16	17.0296
16	16.3281
16	16.2638
16	16.0944
16	16.6295
16	14.627
16	16.9107
16	16.8037
16	16.6129
20.4532 ± 4.49524
16	16.3733
16	16.3061
20.5166 ± 4.32894
16	14.5369
16	18.4513
16	16.8834
16	16.7477
16	16.7404
16	16.2532
16	15.9735
16	15.8735
16	16.9541
16	16.8122
16	17.1333
16	17.0764
16	16.7697
16	16.4026
16	18.855
22.75 ± 4.14345
16	16.2812
16	16.3655
16	17.1335
16	16.7378
24.0374 ± 4.02499
16	16.35
16	16.048
16	16.0268
16	16.8341
16	16.8332
16	16.7471
16	16.3461
16	16.316
16	15.7163
16	14.7212
16	19.242
16	16.8263
20.9952 ± 4.29591
21.5423 ± 4.37322
16	16.5754
16	16.2608
16	16.1189
16	16.6785
16	15.6705
16	16.4846
16	14.2269
16	19.1872
16	15.8052
16	15.5415
16	15.4473
16	19.1738
23.2327 ± 4.23913
22.106 ± 4.12337
16	15.4596
16	15.4153
16	15.3941
22.0044 ± 4.23478
16	15.7493
16	17.1564
16	16.8084
21.8283 ± 4.31132
16	17.594
16	17.5128
16	17.803
16	17.7894
16	17.6513
16	15.8511
16	16.1288
16	15.9445
16	16.6053
16	16.5815
16	16.6904
16	16.5167
22.0082 ± 4.20735
16	17.0207
21.8966 ± 4.20068
16	17.8948
16	17.749
16	17.0137
16	15.6863
16	15.8408
16	17.5944
21.5227 ± 4.21927
16	16.2428
16	16.1799
16	17.8584
18.7992 ± 4.58162
16	16.28
16	18.1986
16	17.7803
23.7 ± 4.05828
16	16.8581
16	16.4004
22.0935 ± 4.27703
21.145 ± 4.48647
16	16.2638
16	16.1013
16	19.0412
16	16.3071
16	17.8456
16	17.0522
16	16.9453
20.9781 ± 4.32607
23.8553 ± 4.1372
16	16.1936
16	17.7357
16	17.4993
16	16.0187
16	17.6912
16	16.9842
16	17.6385
16	17.6349
21.4811 ± 4.2889
21.5864 ± 4.31141
16	16.4396
16	16.7433
16	17.7285
16	17.7084
21.0055 ± 4.27767
20.9928 ± 4.39057
16	15.3839
16	16.1587
16	16.2763
16	16.7014
21.11 ± 4.35882
16	17.7735
16	16.1377
16	17.6065
24.0069 ± 4.08511
16	16.5066
20.3038 ± 4.36443
16	15.8174
16	17.585
20.8839 ± 4.19826
16	16.2302
16	16.932
16	17.5419
16	17.0365
16	16.1385
20.1114 ± 4.46542
20.9293 ± 4.40745
21.3425 ± 4.20558
20.5138 ± 4.4572
16	15.2093
16	16.8663
19.9718 ± 4.41886
16	16.6342
16	15.9697
22.1637 ± 4.0781
16	17.2354
16	16.8648
16	17.5179
16	15.7799
16	16.9751
20.3876 ± 4.26472
16	17.2405
16	16.66
22.253 ± 4.28894
22.2146 ± 4.39213
22.4319 ± 4.29473
21.4807 ± 4.31863
16	17.3824
16	17.2405
16	16.5572
16	16.1218
16	16.0934
21.8271 ± 4.29307
23.0664 ± 4.10785
16	16.9813
16	16.465
16	17.214
16	17.7556
22.6917 ± 4.21586
21.7255 ± 4.28706
22.9246 ± 4.18574
16	18.6211
22.3936 ± 4.28251
16	18.4628
16	18.2147
16	17.6162
20.9841 ± 4.28219
21.3906 ± 4.3343
21.9809 ± 4.30867
22.2264 ± 4.2655
16	17.3172
16	16.9851
16	17.1821
16	16.9952
16	16.0217
16	16.0816
21.6909 ± 4.31499
21.1877 ± 4.39202
16	15.9766
21.0388 ± 4.27616
20.7767 ± 4.27995
16	16.4553
16	17.7025
22.4133 ± 4.36869
21.8895 ± 4.20762
21.3937 ± 4.26151
21.0186 ± 4.30132
21.5966 ± 4.48783
16	16.4073
16	16.3559
21.7299 ± 4.25694
16	16.0886
22.174 ± 4.21161
23.4745 ± 4.10969
21.4167 ± 4.25582
16	17.9683
16	17.446
23.0305 ± 4.14009
17	18.0313
17	17.974
17	17.9499
17	17.929
17	17.8565
17	15.822
17	15.6474
17	15.4971
22.3722 ± 3.97567
17	17.6797
17	17.6172
17	17.6014
17	17.5571
17	16.4612
17	16.3931
17	17.4139
17	17.2394
17	18.1704
17	18.1626
17	18.0963
17	16.2253
17	18.0318
17	15.5356
17	15.6209
19.9989 ± 4.28417
17	18.0465
17	16.6502
19.9221 ± 4.49734
17	16.2634
17	18.727
17	18.4484
17	18.0366
17	16.2708
17	16.0257
17	15.9776
22.2599 ± 4.22824
17	15.8609
17	16.1181
17	17.061
17	16.7936
17	16.6634
17	16.5544
17	14.2248
17	14.2148
17	15.5771
17	15.4401
17	16.6437
17	15.4976
17	16.9032
17	16.1154
17	15.5745
17	16.5277
17	18.4415
17	16.457
17	15.7046
17	16.0559
21.3369 ± 4.26643
17	18.0178
17	16.1067
17	15.684
17	15.9633
17	15.5256
22.9836 ± 4.31388
17	15.0365
17	15.4295
17	15.7866
17	15.7175
17	14.2957
21.7994 ± 4.16304
17	15.827
17	16.8711
17	17.5165
17	17.5056
23.2182 ± 4.13635
17	15.7204
17	15.7396
20.3435 ± 4.39116
17	16.659
17	15.5761
17	16.0855
17	15.8923
17	16.6003
17	16.4461
17	15.7672
17	15.7096
17	15.3148
17	16.5082
17	15.7043
17	14.0244
17	15.5453
17	15.2956
17	16.4103
17	15.5684
17	15.558
17	17.49
17	17.4676
17	15.5433
17	17.1884
17	15.0924
17	16.2243
17	17.4384
17	17.4349
17	17.2886
17	15.6743
17	16.5308
17	16.4986
17	17.0488
17	17.2435
17	15.5644
23.3647 ± 4.10846
17	16.4226
17	16.3258
17	16.1236
21.1548 ± 4.36027
20.3353 ± 4.41261
17	15.0217
17	14.5598
17	15.9671
17	16.1211
20.1626 ± 4.37511
17	15.6859
17	16.6335
17	15.6257
17	17.5258
20.85 ± 4.30201
21.7485 ± 4.0849
17	16.0971
21.5019 ± 4.21897
17	16.5479
17	15.3521
17	16.8702
17	16.2519
17	17.6332
17	16.3945
21.222 ± 4.34188
18.2517 ± 4.50906
17	15.9246
20.4604 ± 4.40188
17	16.863
17	14.9009
17	15.551
20.7563 ± 4.27964
17	17.5142
17	17.374
17	16.8766
20.3568 ± 4.32019
17	17.9148
17	19.0138
17	16.9773
17	16.95
17	16.8489
17	16.4856
17	16.1502
17	16.3754
17	16.7769
17	16.1539
17	15.8863
21.2926 ± 4.42305
17	16.1303
17	16.0609
17	18.8731
17	16.5488
19.4075 ± 4.41496
17	17.5532
17	15.6133
17	15.3604
17	17.2017
20.578 ± 4.40057
17	18.69
17	16.8189
17	16.0083
17	17.6066
17	16.8407
17	16.7659
17	16.7215
17	16.6899
17	15.9807
17	16.1722
17	16.0778
21.9592 ± 4.25532
17	15.9482
20.0643 ± 4.39639
17	15.5128
17	16.8592
17	16.0477
21.4473 ± 4.31868
21.5428 ± 4.41539
17	17.1949
17	16.83
17	17.5045
17	18.6046
19.4236 ± 4.51635
17	15.8482
17	18.5494
17	15.7869
17	17.3129
17	16.5365
17	16.7414
17	16.1308
17	17.2572
21.8462 ± 4.30351
17	16.0376
20.5753 ± 4.19212
17	15.379
21.9367 ± 4.1528
19.961 ± 4.33172
17	15.728
20.6704 ± 4.28276
19.5327 ± 4.45358
17	16.8998
17	16.6967
17	16.1132
17	15.6516
21.384 ± 4.13919
22.3408 ± 4.28715
17	16.499
17	15.7995
17	17.1237
17	15.8434
17	18.7813
17	16.5441
17	15.6448
17	15.8261
17	16.0064
17	16.8746
17	15.9764
21.004 ± 4.28875
17	15.8311
17	15.5157
17	16.0886
17	15.6104
17	16.8394
21.1871 ± 4.35341
17	15.5902
17	15.5974
21.372 ± 4.1905
21.1143 ± 4.37671
21.0776 ± 4.39964
17	16.7208
17	15.6998
17	16.5576
22.5768 ± 4.15934
17	16.6882
17	18.29
20.377 ± 4.3357
23.7166 ± 4.07286
17	16.2254
23.2241 ± 4.18419
21.2902 ± 4.18854
17	17.4544
17	17.2754
23.4008 ± 4.00468
20.602 ± 4.37322
21.4348 ± 4.37354
17	15.8548
17	16.0649
22.1916 ± 4.28916
20.3191 ± 4.33871
20.9887 ± 4.44982
17	15.346
21.8224 ± 4.28344
20.5859 ± 4.22713
20.4584 ± 4.31979
17	17.1896
17	15.0236
21.7311 ± 4.21077
21.3164 ± 4.28547
20.7442 ± 4.27931
17	16.5303
20.2279 ± 4.18319
21.2698 ± 4.22055
21.1442 ± 4.23932
22.8003 ± 4.18452
17	17.4143
17	17.2229
22.4858 ± 4.14261
18	17.8463
18	17.6481
18	15.2916
22.0187 ± 4.03273
18	15.2881
18	15.326
18	17.132
18	17.8956
18	17.8
18	17.0667
19.5757 ± 4.29588
18	15.1713
18	15.1384
18	14.0154
18	17.5329
18	15.327
18	14.9192
19.5338 ± 4.48182
18	15.5053
18	14.0123
18	15.9487
18	15.4922
18	16.0445
18	15.3698
18	15.9713
18	15.3186
18	16.1397
18	15.7464
18	16.4946
18	15.2139
18	15.2087
18	15.1409
21.6703 ± 4.28427
18	17.9805
18	16.7377
18	17.3339
22.4665 ± 4.29035
18	13.8344
18	18.0176
18	17.9345
18	15.9308
18	15.6842
18	17.8659
18	15.3251
18	16.611
18	16.1126
18	16.6537
18	17.8342
18	15.3203
18	15.5394
18	16.0863
18	15.2409
18	15.3412
18	17.8103
18	16.0657
18	15.2108
18	16.4137
17.928 ± 4.48174
18	15.9775
18	15.3467
18	17.6059
18	16.7218
18	16.6623
18	16.3114
18	15.3532
18	15.2728
18	16.0916
18	15.2883
18	16.4409
18	16.3439
18	14.2665
18	15.0957
19.6196 ± 4.3953
18	16.3282
18	15.2304
18	16.1845
18	15.2098
18	14.143
18	16.2176
18	15.9285
18	16.0843
18	15.1207
19.7941 ± 4.45615
18	15.9745
18	16.4315
18	14.394
18	15.6104
18	15.3658
18	16.0177
18	15.1088
20.1652 ± 4.32477
18	16.1285
20.3952 ± 4.36973
18	17.519
18	17.1712
18	15.2658
20.7215 ± 4.36036
20.5161 ± 4.47756
18	17.4986
18	15.9987
22.5832 ± 4.14955
18	15.6904
18	15.5187
18	17.3319
18	14.3573
22.9995 ± 4.21354
18	16.2177
18	15.6608
21.4105 ± 4.25959
18	15.8525
20.454 ± 4.2679
18	15.8
18	14.7492
20.5208 ± 4.35876
21.3803 ± 4.08902
19.5394 ± 4.39397
18	15.3138
18	17.2059
18	15.4844
18	15.0724
18	15.1308
21.6779 ± 4.15702
18	14.7281
18	15.0183
19.79 ± 4.32596
20.9749 ± 4.22504
18	16.0157
18	16.0709
18	15.9555
18	15.3583
20.8281 ± 4.36928
18	15.9987
18	15.6864
18	15.9479
18	15.3437
18	17.1698
18	15.5641
18	15.1286
18	18.1552
18	17.1022
18	15.6285
18	15.9721
18	17.097
18	17.0718
18	17.0695
20.928 ± 4.27497
19.5537 ± 4.37418
18	16.2013
18	17.1424
18	15.7655
18	15.4049
18	15.4961
18	16.1987
18	15.17
20.4942 ± 4.16795
18	16.4414
18	17.1402
18	16.134
18	17.067
18	16.7809
19.4797 ± 4.32804
18	16.4365
18.702 ± 4.50527
18	17.0631
19.9455 ± 4.38835
18	16.333
18	17.0042
18	18.1426
18	16.7758
18	16.6557
18	16.0367
18	16.9643
18	15.9457
18	16.6006
21.4806 ± 4.17891
18	16.474
18	16.2538
18	15.8882
18	16.3631
18	17.2255
18	15.2143
18	16.8741
18	17.7999
20.92 ± 4.20452
18	15.3617
18	16.9483
20.01 ± 4.35966
20.4221 ± 4.42932
18	16.2422
22.0138 ± 4.25441
18	16.7778
22.2373 ± 4.04519
18.9568 ± 4.40019
18.8815 ± 4.50345
18	15.0065
18	14.9875
20.2195 ± 4.47351
20.4948 ± 4.21245
18	14.881
18	17.1676
19.7081 ± 4.38827
20.458 ± 4.43383
21.5803 ± 4.29532
20.3512 ± 4.21105
18	16.2655
18	16.4406
18	16.5185
18	16.5062
18	15.5174
20.3934 ± 4.21705
18	17.0107
18	16.4961
21.3704 ± 4.32753
19.8442 ± 4.38177
18	15.7249
23.0474 ± 4.21772
18	16.4237
18	16.489
18	15.8675
20.9025 ± 4.39711
20.8968 ± 4.26127
18	15.3172
18	16.4029
18	16.3793
20.8922 ± 4.26478
21.2732 ± 4.28048
18	16.3212
18	16.3955
18	14.7715
20.4536 ± 4.52699
20.7478 ± 4.26554
21.7924 ± 4.29428
18	16.721
20.1475 ± 4.35757
19.6985 ± 4.26758
22.8126 ± 4.26704
20.332 ± 4.43898
18	16.4723
18	16.2727
21.1497 ± 4.32258
20.7931 ± 4.34733
18	16.9205
22.0694 ± 4.29427
20.9083 ± 4.26863
21.9968 ± 4.22801
19	17.5443
19	17.5102
19	15.1582
19	15.0932
19	15.0528
22.0864 ± 3.98463
19	16.7784
19	14.1124
19	16.7002
19	15.1016
19	14.9515
19	14.8914
19	16.5957
19.4901 ± 4.28912
19	13.8255
19	13.7946
19	15.7188
19	15.6816
19	15.5013
19	17.3261
19	13.6976
19	17.2262
19	15.9367
19	15.9688
19	15.1859
19	17.5643
19	17.5378
19	15.8546
19	15.8143
19	15.0215
19	15.0643
19	14.8453
19	14.7616
19	17.3304
19	15.0127
19	14.9819
19	16.4594
19	16.3031
19	13.5578
19	15.7725
19	15.5811
19	14.9796
19	16.2132
19	16.2063
19	15.3633
19	17.6748
19	15.8685
19	15.6122
19	15.5624
19	15.548
19	16.185
19	15.2144
19	17.6355
19.016 ± 4.47436
19	14.3115
21.205 ± 4.25683
19	17.6169
19	17.2572
19	14.269
19	15.6864
19	14.644
19	16.1231
19	14.9236
19	14.6912
19	15.5244
19	15.5367
19	13.4036
19	15.0588
19	14.1915
17.6262 ± 4.441
19.57 ± 4.32138
19	14.9774
19	15.51
19	15.5914
19	15.6355
19.7217 ± 4.32072
19	14.1276
19	15.5021
19	17.1991
21.8548 ± 4.3328
19	15.2042
19	15.8734
19	17.0403
19	15.462
19	15.189
19	14.775
19	14.5395
19	14.1134
19	15.7056
20.1616 ± 4.37043
19	15.0865
19	14.0425
19	16.0003
19	16.2616
19	15.5882
19.7968 ± 4.21521
19	15.0361
19	15.1433
19	13.9922
19	14.8484
19	16.9622
19.1674 ± 4.38494
19	13.9922
20.4555 ± 4.24549
22.4321 ± 4.24484
19	15.1195
19	14.065
19	14.7408
19	15.0349
19.1794 ± 4.38106
19	14.5815
19	15.9399
20.9145 ± 4.25345
19	14.9117
19	14.8075
19	17.0245
19	18.2788
20.0392 ± 4.38646
19	15.9242
19	15.8271
20.818 ± 4.33481
19	16.8417
19.3501 ± 4.44403
19	15.9739
19.9779 ± 4.36621
19	16.8297
19	14.8254
19	14.9036
20.4935 ± 4.2833
19	15.8609
19.9412 ± 4.30456
19	15.85
19.2714 ± 4.37212
19	15.8434
19	15.0091
20.2734 ± 4.34696
22.4915 ± 4.15832
19	15.5738
19	14.8847
18.3288 ± 4.46615
19.9411 ± 4.33017
19	16.6988
19	14.8896
19	16.1981
19	15.0138
19	16.1931
19	15.4944
19	15.4645
19	18.2496
20.3979 ± 4.29857
19	15.1776
19	15.2182
19	15.1141
19	15.8001
21.6137 ± 4.3041
19	15.6056
19	16.8194
19	15.2838
19	15.3274
19	15.1679
21.3753 ± 4.09745
18.2443 ± 4.51879
19	15.1006
19	17.1435
19.3886 ± 4.4461
19.7392 ± 4.39304
19	16.6815
19	15.0083
19	16.5877
19	14.7575
19	16.1321
19	16.2168
19	14.8694
19	18.1249
19.1443 ± 4.34489
19	14.7087
19	15.8516
19	15.1154
19.9321 ± 4.42518
20.2551 ± 4.20772
19	14.7354
19	15.1465
19	15.0871
19	16.6341
19.3191 ± 4.41782
19	14.7488
19	16.1747
19	16.0452
19	16.732
23.0455 ± 4.08378
19	14.6117
19	14.8146
22.0025 ± 4.12553
19	16.5346
19	14.8704
19.8025 ± 4.37351
19	16.5206
19.4352 ± 4.38219
20.3587 ± 4.46534
19	16.4539
21.2362 ± 4.29924
20.9718 ± 4.21395
19	15.0921
19	15.5703
19	16.4891
19.8003 ± 4.28731
19	16.5652
19	16.5636
20.3943 ± 4.34299
20.119 ± 4.26472
19.9155 ± 4.45205
19	17.7632
19	16.4522
19	15.0531
19	16.292
19	14.988
20.5452 ± 4.16516
20.2839 ± 4.40203
19	14.8991
19	17.5319
19	16.2741
19.4457 ± 4.37564
20.456 ± 4.13156
19	14.8465
21.003 ± 4.36266
20.8425 ± 4.32338
22.1013 ± 4.36573
22.9242 ± 4.04289
19.1817 ± 4.25198
19	16.2905
19	16.1675
20.8211 ± 4.26972
19	16.0254
19	15.9233
19	16.2167
19	16.1874
19.9425 ± 4.41613
20.7759 ± 4.265
21.3946 ± 4.44467
19	16.1416
19	16.0701
20.8553 ± 4.29503
19	16.676
56 sends to 14
56 receives from 5
55 sends to 12
55 receives from 39
58 sends to 33
58 receives from 23
61 sends to 61
61 receives from 61
57 sends to 4
57 receives from 27
59 sends to 59
59 receives from 59
62 sends to 62
62 receives from 62
60 sends to 60
60 receives from 60
5
21
2
10
42
56
6
7
8
9
39
11
3
32
23
15
18
27
16
19
48
50
1
58
35
25
26
57
51
54
30
20
13
22
34
28
36
37
38
55
40
41
0
43
44
45
29
47
31
49
17
24
52
53
63
12
14
4
33
59
60
61
62
46
0 sends to 5
0 receives from 42
12 sends to 3
12 receives from 55
24 sends to 35
24 receives from 51
1 sends to 21
1 receives from 22
11 sends to 11
11 receives from 11
18 sends to 16
18 receives from 16
2 sends to 2
2 receives from 2
17 sends to 27
17 receives from 50
13 sends to 32
13 receives from 32
19 sends to 19
19 receives from 19
4 sends to 42
4 receives from 57
32 sends to 13
32 receives from 13
21 sends to 50
21 receives from 1
5 sends to 56
5 receives from 0
14 sends to 23
14 receives from 56
23 sends to 58
23 receives from 14
6 sends to 6
6 receives from 6
26 sends to 26
26 receives from 26
7 sends to 7
7 receives from 7
16 sends to 18
16 receives from 18
28 sends to 51
28 receives from 35
8 sends to 8
8 receives from 8
27 sends to 57
27 receives from 17
9 sends to 9
9 receives from 9
31 sends to 20
31 receives from 48
10 sends to 39
10 receives from 3
29 sends to 54
29 receives from 46
22 sends to 1
22 receives from 33
20 sends to 48
20 receives from 31
15 sends to 15
15 receives from 15
34 sends to 34
34 receives from 34
35 sends to 28
35 receives from 24
30 sends to 30
30 receives from 30
37 sends to 37
37 receives from 37
36 sends to 36
36 receives from 36
38 sends to 38
38 receives from 38
39 sends to 55
39 receives from 10
40 sends to 40
40 receives from 40
42 sends to 0
42 receives from 4
44 sends to 44
44 receives from 44
46 sends to 29
46 receives from 63
41 sends to 41
41 receives from 41
45 sends to 45
45 receives from 45
47 sends to 47
47 receives from 47
48 sends to 31
48 receives from 20
51 sends to 24
51 receives from 28
53 sends to 53
53 receives from 53
52 sends to 52
52 receives from 52
54 sends to 63
54 receives from 29
19	16.5579
19.6661 ± 4.35615
50 sends to 17
50 receives from 21
63 sends to 46
63 receives from 54
43 sends to 43
43 receives from 43
25 sends to 25
25 receives from 25
21.016 ± 4.23957
33 sends to 22
33 receives from 58
21.4393 ± 4.22192
49 sends to 49
49 receives from 49
3 sends to 10
3 receives from 12
20	14.8281
20	15.2359
20	14.8146
20	14.7623
20	14.5179
20	13.4015
20	13.3947
20	16.7444
20	14.2711
20	14.1269
20	15.462
20	15.2871
20	13.9888
20	15.5013
20	14.6546
20	15.2136
20	13.3915
20	14.8846
20	15.1809
20	14.8521
20	14.6534
20	14.5703
20	14.4771
20	14.6952
20	13.3314
20	14.5604
20	14.4975
20	13.9767
20	14.5554
20	14.8649
20	14.4128
20	16.6874
20	16.0418
20	15.8888
20	14.5944
18.9178 ± 4.41502
20	15.1678
20	15.5021
20	15.5036
20	15.189
20	15.1158
20	15.3342
20	15.3078
20	15.7271
20	16.5145
20	14.9507
20	14.6844
20	14.6804
20	14.5209
20	17.236
20	14.3313
20	14.8451
20	14.8171
20	15.2871
20	14.38
20	16.6263
20	15.748
17.3237 ± 4.46929
19.0559 ± 4.30302
20	15.7503
20	15.2947
21.6877 ± 4.28367
20	16.9217
19.1077 ± 4.42767
20	14.7235
20	15.861
20	15.6056
20	15.7943
20	17.0111
20	16.6814
20	15.9242
20	15.5919
20	15.6113
20	15.1195
20.6234 ± 4.19803
20	16.7079
20	15.7506
20	14.4599
20	14.4281
20	13.9922
20	15.0796
20	14.5068
20	15.0679
20	15.8609
20	14.3143
20	14.2974
20	14.2312
20	14.2103
20	14.183
20	14.1348
20	15.2354
20	16.1168
20	15.9053
20	14.6351
20	15.2701
20	14.1124
20	14.4496
20	13.9386
20	16.5927
19.0307 ± 4.39421
20	17.3635
20	17.1398
20	16.4522
20	15.4357
20	15.8359
20	15.2427
20	14.9216
20	14.775
21.107 ± 4.15791
20.8709 ± 4.2207
21.2075 ± 4.17213
20	14.983
20	16.0747
20	15.1614
18.7529 ± 4.38756
20	16.3057
20.8125 ± 4.43718
20	14.6117
20	16.5926
20	16.545
20	15.3121
20	15.0138
20	14.6519
20	15.6565
20	16.4539
20	16.3533
20	15.4819
20	15.4625
20	15.1249
20	14.9927
20	14.9114
19.2073 ± 4.30835
19.9995 ± 4.23826
20	14.7408
20	16.1276
20	14.5631
20	14.9018
20	14.4864
20	13.9087
20	15.0531
20	15.0114
20	16.3345
19.6061 ± 4.29755
20	14.9129
20	14.7472
20	16.1839
20	15.0083
20	14.7353
20	14.6216
19.4618 ± 4.34005
18.8829 ± 4.39795
20	18.1239
20	15.4385
20	14.5413
20	15.9114
19.6746 ± 4.35309
20	13.6605
20	15.781
20	16.037
21.9383 ± 4.35616
20	15.8167
21.8796 ± 4.25961
20	17.997
20	14.6334
21.2012 ± 4.27758
20	17.9706
20	15.0176
20.3462 ± 4.33155
20	15.9787
20	15.1272
22.0229 ± 4.3135
20	15.8887
22.1023 ± 4.16603
20	14.6547
21.361 ± 4.38813
18.6624 ± 4.39352
19.2682 ± 4.32701
21.0548 ± 4.34212
23.0496 ± 4.21177
21.5626 ± 4.23012
20.3127 ± 4.2852
20.1544 ± 4.37959
20	14.9747
20.573 ± 4.25793
20	14.8966
19.9459 ± 4.38815
20	15.8033
20	15.0556
19.6125 ± 4.32886
20	15.8308
20	14.9583
22.1918 ± 4.04787
20.1036 ± 4.36849
20	15.6683
20.3151 ± 4.32491
20.82 ± 4.30065
22.438 ± 4.08806
20	14.6826
21.0042 ± 4.05168
22.6278 ± 4.15992
19.8806 ± 4.30615
20.3509 ± 4.31782
20.4876 ± 4.17071
20.3777 ± 4.23335
20.7413 ± 4.22717
20.4049 ± 4.34772
22.1965 ± 4.32114
21.4333 ± 4.08759
20.6477 ± 4.35554
19.7012 ± 4.49684
19.3721 ± 4.36536
19.6755 ± 4.26723
20.1016 ± 4.22482
21	14.4468
21	14.2494
21	14.588
21	13.324
21	13.2641
21	14.7909
21	16.4346
21	15.1529
21	14.7138
21	14.5256
21	15.1366
21	16.207
21	15.1069
21	14.7236
21	14.2616
21	15.0374
21	14.2662
21	15.1419
21	16.0541
18.8639 ± 4.35591
21	15.0235
21	14.7105
21	15.5774
21	14.6817
21	14.6979
18.5671 ± 4.37721
21	15.4645
21	15.1197
21	14.5413
21	14.4644
21	14.3906
21	14.3567
21	14.6874
20.2246 ± 4.36871
21	14.2413
21	15.1406
21	15.7749
18.4826 ± 4.3859
21	14.9791
21	14.5581
21	15.325
21	14.6759
21	14.3149
21	15.6995
21	16.8139
21	15.683
21	15.7084
21	15.593
21	14.9576
21	14.6228
21.119 ± 4.36729
21	14.5671
21	15.4535
21	15.0217
18.8479 ± 4.35131
19.1616 ± 4.3617
20.8509 ± 4.20764
20.6827 ± 4.26409
17.134 ± 4.42114
21	15.2676
21	13.4054
21	14.3241
21	15.8787
21	15.8316
21	15.7916
21	14.9969
21	14.9861
21	14.7326
21	15.7982
21	15.5603
21	14.2282
21	15.053
21	14.4885
21	14.4038
21	15.4278
21	16.3369
18.3629 ± 4.41084
21	16.5424
21	16.3819
21	16.0174
21	17.8875
19.9493 ± 4.68996
21	15.092
21	17.4124
21	14.4871
21	14.851
21	15.5152
21	14.1609
21	14.1075
19.237 ± 4.49004
21	15.3784
21	14.999
21	14.6324
21	15.4127
21.6478 ± 4.28573
18.2938 ± 4.36742
21	13.9595
21	16.2928
21	15.5509
21	14.7664
21	14.9658
21	14.208
18.4866 ± 4.34321
21	16.7323
19.8334 ± 4.43417
21.7057 ± 4.40422
21	14.563
20.2176 ± 4.36318
21	14.5482
21	14.4349
21	14.8902
21	14.5847
21	14.4176
21	15.7381
21	14.6518
21	14.555
21	15.7734
21	14.9284
21	13.8204
21	14.2189
19.3024 ± 4.32635
21	15.738
21	14.9441
21	14.6241
21	13.7479
21	13.7294
21.0473 ± 4.54484
21	16.265
21	14.7064
21	14.7473
21.7108 ± 4.15101
21	16.0385
21	15.2462
21	15.1915
19.8385 ± 4.22013
21	14.6964
21	15.0246
21	15.005
21	16.4734
19.1985 ± 4.36474
21	14.6031
21	14.6015
21	13.8305
21	13.7015
21	14.4324
22.2074 ± 4.45947
21	14.8942
21	14.9269
21	14.5503
21	14.504
21	13.6788
21	13.8825
21	13.7207
21	14.787
21	15.738
21	15.6845
21	14.3243
21.7516 ± 4.16609
20.5054 ± 4.42115
21.013 ± 4.3373
21	16.2166
21	15.6401
19.6471 ± 4.42229
20.7496 ± 4.45193
21	14.4257
19.5224 ± 4.54742
19.0558 ± 4.46462
18.8088 ± 4.31451
21	15.7151
21	15.0025
21	15.6729
21.9115 ± 4.39213
21	14.3677
19.0843 ± 4.3968
18.3874 ± 4.33032
19.3309 ± 4.43244
21	14.588
21	13.4054
22.6229 ± 4.0425
21	14.7317
21	15.9108
21	15.3624
21	14.9429
21	14.7096
21	14.3473
21.9745 ± 4.3483
21	14.6668
19.7972 ± 4.25651
20.2011 ± 4.25909
21	14.7061
20.9177 ± 4.21098
20.1837 ± 4.26741
20.438 ± 4.35063
19.3737 ± 4.34372
21	14.2723
19.0781 ± 4.47746
21.3368 ± 4.20387
19.8562 ± 4.34005
21	15.2279
18.5607 ± 4.48223
20.0425 ± 4.56366
19.894 ± 4.28894
19.3103 ± 4.40456
20.0078 ± 4.49525
20.0174 ± 4.30787
20.3786 ± 4.42401
21.0386 ± 4.3922
22.3923 ± 4.20542
19.276 ± 4.43058
20.6552 ± 4.43622
19.6693 ± 4.44177
21.2097 ± 4.34189
21	13.5241
21	13.3065
21	13.3016
19.1566 ± 4.54413
22	14.145
22	14.1146
22	13.2639
22	13.262
22	13.0952
22	15.8469
22	14.9831
22	14.9121
22	14.7707
22	14.6776
22	14.7142
22	14.1535
22	14.5341
22	14.4562
22	15.1689
22	14.7783
22	15.7081
22	15.5218
22	15.2812
22	15.4718
22	14.385
18.6383 ± 4.33551
22	14.6695
22	14.1825
22	15.455
22	15.2179
22	14.4893
17.0708 ± 4.49185
22	14.3692
22	14.1403
22	14.7684
18.9251 ± 4.38208
22	14.7092
22	14.062
19.63 ± 4.47242
22	14.3451
22	14.2331
22	16.6947
20.5228 ± 4.44884
22	14.3826
22	14.4129
19.9229 ± 4.40048
22	14.1592
22	14.0158
18.2918 ± 4.3492
18.0656 ± 4.40975
22	15.4074
18.8331 ± 4.53544
22	15.2368
22	14.9298
22	14.2471
22	14.0614
22	14.6936
18.5152 ± 4.41756
22	13.687
22	14.0571
22	15.2234
22	14.1041
22	15.1852
22	14.9331
22	14.9208
22	14.9206
22	15.0961
18.1281 ± 4.41682
22	16.3247
20.4219 ± 4.59748
22	15.5299
22	13.8485
22	15.086
22	13.9627
22	13.9343
21.2869 ± 4.40257
22	14.282
19.4011 ± 4.22156
22	14.1475
22	14.8315
20.8762 ± 4.53899
18.9669 ± 4.40983
21.4 ± 4.22526
22	14.0466
22	16.0174
22	13.2479
20.2955 ± 4.39257
22	15.3416
22	15.2591
22	14.9241
22	14.337
18.1142 ± 4.39987
19.9917 ± 4.51862
22	14.2183
22	14.9233
22	14.7193
22	14.826
22	15.6211
22	15.4086
22	14.5503
22	13.9615
22	14.5293
22	14.4723
18.1069 ± 4.38208
22	15.5944
22	13.6403
22	15.9022
22	15.0467
22	15.1967
22	15.6606
22	15.6465
22	16.2114
22	15.5897
22	14.493
22	14.6753
22	14.4889
22	14.1863
22	15.6188
22	15.8838
22	16.1806
22	15.7843
22	14.0872
21.7355 ± 4.49024
18.488 ± 4.49979
22	14.5862
22	15.5222
22	15.7663
22	14.5388
22	17.399
22	15.5504
22	14.6713
22	13.3935
18.349 ± 4.32407
22	14.1539
22	13.7909
22	14.5794
22	14.561
22	15.6915
22	14.4357
22	14.5444
20.2226 ± 4.40947
18.9006 ± 4.64388
22	14.0088
19.4857 ± 4.3052
18.7805 ± 4.38537
22	15.2206
22	15.1952
19.5005 ± 4.31992
22	15.3828
22	15.5239
20.542 ± 4.44623
22	15.1535
22	16.1332
22	14.5146
22	14.6615
22	17.2382
18.0595 ± 4.42293
22	14.3003
22	14.3185
22	15.4469
22	13.3171
18.8813 ± 4.35976
22	14.6405
18.5226 ± 4.48855
22	16.0674
19.7089 ± 4.33218
22	14.8634
22	13.3007
18.4606 ± 4.54845
20.6392 ± 4.26963
22	14.5045
22	14.2326
22	15.9996
21.2345 ± 4.53028
19.6617 ± 4.37199
22	15.3173
19.5369 ± 4.29249
22	14.4094
20.7301 ± 4.44644
19.0759 ± 4.37523
19.6014 ± 4.45841
22	13.1656
22.2043 ± 4.13189
22	14.0366
22	14.0831
19.572 ± 4.44975
22	14.6003
22	14.9353
22	14.2015
22	14.6068
19.5285 ± 4.4055
21.0741 ± 4.29756
22	14.2876
19.4137 ± 4.38193
22	14.522
21.555 ± 4.33833
22	14.4748
18.9952 ± 4.49805
21.158 ± 4.5207
19.6838 ± 4.41388
19.5095 ± 4.54261
19.5804 ± 4.48318
20.9108 ± 4.32025
19.1138 ± 4.4356
20.4443 ± 4.49263
22	12.9366
20.0758 ± 4.47431
19.1161 ± 4.30362
17.8246 ± 4.54379
20.2515 ± 4.56488
22	13.1793
22	13.151
22	13.0168
18.2225 ± 4.63917
23	12.9928
23	13.8924
23	14.5051
23	14.5579
23	14.4014
23	14.4941
23	14.3902
23	14.3679
23	14.7003
23	14.6106
23	14.2898
23	14.3651
23	13.238
23	14.3595
23	14.2389
23	14.5753
23	14.996
23	14.3434
23	14.1885
23	16.2169
23	14.0733
23	15.822
23	16.1513
23	14.1095
23	15.626
23	13.1756
23	14.6341
23	14.5011
23	14.2326
23	13.9331
23	14.0123
16.9153 ± 4.49919
23	14.555
17.7722 ± 4.34435
23	14.2974
23	14.2424
19.2194 ± 4.45742
23	14.1485
23	14.0922
23	14.0272
23	13.609
23	14.8507
23	14.0682
23	16.0141
23	14.073
23	14.9526
23	14.2165
23	13.9447
23	14.1342
23	14.7592
19.0893 ± 4.55036
23	14.7987
23	13.5226
23	13.3808
17.9881 ± 4.67288
23	14.7981
18.6024 ± 4.39852
23	14.4692
23	15.0225
23	14.0521
18.4991 ± 4.51625
23	13.4485
23	13.4356
19.6554 ± 4.63422
23	13.3598
23	14.7863
18.2833 ± 4.33939
23	14.778
23	14.8219
23	14.4043
23	14.7452
23	13.4415
20.1008 ± 4.48452
23	13.3872
18.2064 ± 4.38489
18.4636 ± 4.45826
23	15.3421
21.0417 ± 4.26332
23	13.8506
23	13.7878
23	15.0025
23	13.3031
18.279 ± 4.31979
20.6366 ± 4.42691
23	13.9379
23	13.878
23	14.3061
17.8218 ± 4.3844
23	15.3009
23	14.8963
23	15.7953
23	13.7243
17.821 ± 4.35932
19.5993 ± 4.48103
23	15.2861
23	13.8387
19.8529 ± 4.58933
17.9294 ± 4.43176
23	13.826
23	15.1592
23	14.2509
23	14.2022
23	14.2758
23	13.1026
18.1526 ± 4.65496
23	14.0744
19.4894 ± 4.29078
23	14.733
20.8491 ± 4.55313
23	15.987
23	13.947
23	13.7418
23	13.7101
23	15.8489
23	15.3563
23	15.2107
23	15.1756
23	14.1606
18.3031 ± 4.48843
23	15.3034
23	14.1844
19.525 ± 4.55887
23	14.4764
23	14.0368
23	17.1722
23	13.9731
23	14.5676
23	14.5102
23	13.9239
23	14.4822
23	14.0627
17.7414 ± 4.4951
23	14.4304
23	14.4511
19.0674 ± 4.29737
23	14.1963
18.7101 ± 4.37366
23	14.0766
23	14.3009
23	14.111
19.7936 ± 4.42743
23	14.0438
23	14.8423
17.9763 ± 4.39534
23	15.1348
23	12.9282
23	12.9023
23	12.8919
23	13.2228
23	13.1596
23	14.2875
18.032 ± 4.41845
23	12.6969
18.7447 ± 4.4092
23	14.1107
23	14.1086
23	14.5481
23	15.8377
23	15.0297
23	13.9999
23	14.4602
23	14.3353
23	14.4493
20.9694 ± 4.15507
23	14.844
23	14.029
23	14.7941
23	14.4249
23	14.0154
19.3812 ± 4.2211
23	14.452
19.223 ± 4.2654
23	15.7093
23	13.9576
19.2396 ± 4.49699
23	13.76
23	13.8445
18.2164 ± 4.46129
23	13.7212
23	17.0346
23	16.0551
23	13.848
23	14.3191
23	15.9059
23	14.7381
23	14.2289
19.0135 ± 4.47284
18.4297 ± 4.52616
19.0217 ± 4.54406
23	14.4349
20.3382 ± 4.21491
20.8093 ± 4.38066
23	15.8589
23	13.974
23	15.8342
23	14.3534
23	13.8429
20.1604 ± 4.69624
21.7204 ± 4.19632
20.3934 ± 4.5151
19.1233 ± 4.37927
18.5478 ± 4.51576
20.2101 ± 4.44406
20.3503 ± 4.57084
18.9734 ± 4.52333
19.0221 ± 4.43585
18.7098 ± 4.47253
19.2796 ± 4.57638
23	14.3494
17.2053 ± 4.6104
18.8682 ± 4.46092
19.7895 ± 4.50491
17.7061 ± 4.57903
23	14.2678
23	14.4551
19.1053 ± 4.39722
19.488 ± 4.57787
20.538 ± 4.35727
18.6809 ± 4.33242
19.1777 ± 4.39084
23	12.8138
23	12.8087
17.4324 ± 4.63816
24	12.9907
24	12.9839
24	14.3586
24	12.8167
24	13.8924
24	13.8858
24	14.497
24	14.4754
24	13.9008
24	13.1334
24	12.9142
24	13.8755
24	14.2327
24	14.1184
16.73 ± 4.50106
24	15.4871
24	14.1317
24	15.8231
24	13.5421
24	13.8089
24	15.6273
19.1874 ± 4.38625
24	13.4428
24	15.384
24	13.771
24	14.3873
24	13.9057
24	14.8342
24	13.5209
24	14.0755
24	14.5077
17.5864 ± 4.38022
24	14.6801
24	14.3349
24	14.7392
24	14.7254
18.5934 ± 4.48244
24	14.1782
24	14.5945
24	12.5442
19.0334 ± 4.60455
18.0194 ± 4.38734
17.4062 ± 4.61029
24	14.1112
24	14.0095
24	13.9832
24	14.6005
24	14.028
24	14.7054
24	14.0951
18.2881 ± 4.35102
24	13.9378
24	13.2897
24	13.9778
24	13.2784
24	13.4761
24	14.2077
24	13.9949
19.8174 ± 4.35036
24	13.9351
17.4921 ± 4.46647
18.7314 ± 4.3128
24	13.1784
18.2319 ± 4.28328
24	14.0523
24	13.8253
24	13.1674
24	13.4028
17.6286 ± 4.54061
21.2232 ± 4.14124
24	15.1344
24	13.9611
24	15.0034
19.6359 ± 4.42397
24	15.6879
24	13.0625
24	13.9605
24	13.4172
24	13.6087
24	14.5823
24	14.0783
24	14.3105
19.9079 ± 4.46638
24	15.6103
24	14.0046
24	14.1237
24	15.0023
18.9741 ± 4.53479
24	14.0955
19.1642 ± 4.39624
24	13.1084
24	15.0035
24	13.9691
24	15.5473
24	13.7413
18.6575 ± 4.39568
24	13.5636
24	13.9259
24	15.7926
24	15.7818
24	13.4059
18.0148 ± 4.39892
19.9908 ± 4.51026
18.1678 ± 4.49335
24	13.692
24	15.7177
19.0008 ± 4.58098
17.6537 ± 4.40774
24	13.5882
24	13.6649
24	14.2348
24	14.1357
24	16.9881
24	14.5287
18.7997 ± 4.5772
17.5996 ± 4.42877
24	15.1856
24	15.1093
24	15.5712
24	12.5526
24	15.4773
24	14.4655
24	14.6904
24	16.9711
24	14.1707
24	13.9025
24	14.4161
24	13.9749
24	13.8188
24	14.1272
19.4224 ± 4.44249
24	13.656
24	13.932
17.7081 ± 4.50544
24	14.4236
18.7617 ± 4.34695
24	14.0067
20.2096 ± 4.45331
19.1866 ± 4.68956
24	14.3632
24	14.3026
17.7826 ± 4.52199
24	13.68
24	13.8046
17.656 ± 4.40572
18.6245 ± 4.36753
24	13.7231
24	14.3887
24	14.1921
24	13.6005
24	13.1345
19.8673 ± 4.27941
24	13.904
24	14.2705
24	14.1188
24	14.2234
24	13.4189
20.7984 ± 4.12228
24	14.2468
24	13.1231
24	14.2647
17.958 ± 4.52837
19.2681 ± 4.32313
24	13.7584
24	14.3085
18.6425 ± 4.42997
24	14.9526
24	15.7092
24	13.4154
24	14.843
24	14.1515
18.3984 ± 4.57501
18.2004 ± 4.47536
24	13.7982
24	15.4646
24	14.0503
24	14.2372
24	13.7621
24	13.6063
19.7583 ± 4.47961
16.6846 ± 4.53919
24	14.1899
17.7104 ± 4.41516
18.6433 ± 4.49897
21.2479 ± 4.22236
18.7589 ± 4.33755
19.2466 ± 4.22944
24	14.1355
18.3461 ± 4.5056
18.5124 ± 4.5607
19.7589 ± 4.59177
18.4749 ± 4.32845
24	13.6901
24	14.1377
18.4517 ± 4.55046
19.0643 ± 4.54681
18.651 ± 4.39772
20.0487 ± 4.36246
17.2295 ± 4.54269
18.5602 ± 4.38204
18.6549 ± 4.54078
19.5961 ± 4.48268
18.8716 ± 4.50378
18.6843 ± 4.34123
24	12.7405
16.8553 ± 4.54284
25	12.8078
25	12.8046
25	13.7711
25	13.7407
25	14.3293
25	13.7675
16.4799 ± 4.46362
25	13.37
25	15.36
25	15.2273
25	14.5811
25	14.5214
17.3922 ± 4.37727
25	14.815
25	13.2787
25	13.2751
25	14.442
25	13.2716
25	14.3628
25	14.3319
25	13.8742
25	14.0774
25	14.0756
25	14.0518
25	14.0645
17.7611 ± 4.41881
18.5955 ± 4.53452
25	13.0492
25	13.9585
19.0194 ± 4.39915
25	13.7069
25	13.0083
25	13.8064
25	15.5118
25	13.7494
25	13.6874
25	13.8098
25	15.1197
17.3306 ± 4.55645
25	12.9482
25	13.8564
17.1482 ± 4.38955
19.4915 ± 4.33448
25	13.8881
25	13.5468
19.002 ± 4.47326
25	14.275
25	13.7948
25	14.0996
25	13.09
25	12.9478
25	13.5394
18.2152 ± 4.47467
25	13.8062
25	14.7448
25	15.3265
25	14.1762
25	14.6727
25	13.5712
25	15.0788
25	13.8698
18.0124 ± 4.39106
25	13.8317
25	14.317
19.5089 ± 4.37346
25	12.8631
18.5753 ± 4.37623
25	13.878
25	13.6233
25	13.4822
25	13.4658
25	12.942
18.4453 ± 4.33394
17.1814 ± 4.49596
25	14.5445
25	13.4423
25	14.6542
25	14.0938
25	14.6144
25	13.33
25	14.7299
17.7835 ± 4.5117
25	13.7999
25	13.5227
25	15.0477
20.7317 ± 4.34446
17.7371 ± 4.41542
25	13.0214
17.193 ± 4.53477
18.4021 ± 4.4185
25	12.5361
25	13.2658
25	13.2557
25	13.394
18.5815 ± 4.62797
25	13.3389
25	13.0069
25	13.515
25	13.3415
25	12.3919
25	13.3048
25	13.2859
18.2466 ± 4.41791
25	13.1304
25	14.5754
25	13.4878
25	13.6111
25	15.5515
25	13.7879
25	14.0821
25	14.1345
25	13.5361
19.4796 ± 4.22449
25	13.2727
17.3483 ± 4.40518
25	14.4214
25	14.1756
25	13.1402
25	13.5478
17.5441 ± 4.50597
18.3043 ± 4.4941
25	14.5171
25	14.4008
25	13.6724
25	13.5949
19.2667 ± 4.49
25	14.0808
25	13.9571
18.7931 ± 4.40428
17.1656 ± 4.62501
19.7023 ± 4.44365
25	12.9867
25	14.1272
18.3926 ± 4.57695
25	16.9245
25	16.8634
25	14.0562
25	14.0772
25	13.9889
25	16.7657
25	14.6718
25	13.098
17.4036 ± 4.44025
25	13.7157
25	13.5377
25	14.1594
25	16.7602
18.2077 ± 4.47001
25	13.2553
25	14.5085
20.7356 ± 4.20557
25	14.6449
17.7571 ± 4.49985
16.3027 ± 4.51353
25	16.7231
25	13.8028
25	13.9897
25	14.0992
25	13.9003
25	13.7848
25	14.0498
18.753 ± 4.37437
17.9215 ± 4.31235
25	15.3391
25	14.0075
25	13.3934
17.4958 ± 4.52127
25	14.1251
25	13.5769
25	15.2208
17.8228 ± 4.51834
25	13.8305
25	13.5564
18.871 ± 4.37675
25	13.6652
25	13.474
17.9555 ± 4.45537
25	13.9761
25	13.4609
25	14.4921
17.9203 ± 4.47616
17.7871 ± 4.49712
25	12.86
18.8453 ± 4.29264
25	14.3729
18.2551 ± 4.38114
25	16.6824
25	15.0976
18.3035 ± 4.44439
18.4267 ± 4.5048
25	13.3362
25	15.0763
20.9404 ± 4.28148
19.1131 ± 4.47994
18.2329 ± 4.38878
19.156 ± 4.53427
19.2934 ± 4.5438
18.4786 ± 4.52032
16.9354 ± 4.54239
25	13.8357
18.1005 ± 4.42592
19.5912 ± 4.38718
18.4101 ± 4.48586
18.2625 ± 4.46557
18.5393 ± 4.43421
25	12.5761
16.5496 ± 4.4978
26	12.6529
26	13.7486
26	13.5867
16.349 ± 4.41637
26	13.2459
26	13.6471
26	13.4538
26	13.2389
26	14.3037
26	14.3072
26	13.9179
26	13.3995
26	13.962
26	14.2825
26	14.254
26	13.1943
26	14.727
26	13.6754
26	13.9048
26	13.6748
26	13.144
17.2817 ± 4.3779
26	13.4122
17.5363 ± 4.40731
26	13.8675
26	14.2379
26	13.5653
26	14.1634
26	14.1542
26	13.7864
26	12.8811
26	14.1817
17.0685 ± 4.47615
26	13.6214
26	13.755
26	12.9236
26	13.2787
18.4225 ± 4.42105
26	13.73
18.3481 ± 4.51637
26	13.559
26	13.5918
26	13.2761
26	14.0698
18.6059 ± 4.43333
26	14.0612
26	13.7407
26	13.6848
26	12.7674
26	14
26	14.6397
26	13.6645
17.6845 ± 4.48029
19.4809 ± 4.29551
26	13.5959
26	14.836
26	13.4908
26	14.4844
26	14.5739
26	14.4323
17.8067 ± 4.48527
26	14.7962
26	13.1811
26	13.8914
26	13.5541
26	14.3289
26	13.2305
26	13.509
26	13.1023
16.9893 ± 4.47214
18.9608 ± 4.39139
26	13.3558
26	13.2527
26	14.3765
26	13.3141
26	13.9177
26	14.3322
26	13.1285
26	14.8857
18.4434 ± 4.47791
26	12.3289
26	14.1653
26	12.127
26	14.2945
17.4272 ± 4.43966
26	12.7488
26	14.1522
26	13.7596
16.8334 ± 4.53617
26	13.9103
26	12.9634
26	13.0898
17.4655 ± 4.38246
26	13.4492
26	13.3177
26	13.5977
17.8751 ± 4.50733
17.962 ± 4.41719
26	14.9677
26	12.9136
26	13.5784
26	14.9511
18.9514 ± 4.30378
19.9657 ± 4.40088
26	14.743
18.0867 ± 4.53086
18.9663 ± 4.31223
26	13.426
26	12.885
26	13.9581
16.9855 ± 4.42732
26	14.8969
18.1185 ± 4.3661
19.1686 ± 4.26149
26	14.8969
26	13.0565
26	13.4316
26	13.026
26	14.1861
26	13.1277
26	12.8926
26	14.0629
26	12.8349
17.3477 ± 4.51722
16.8105 ± 4.51567
26	13.5311
26	13.5239
17.2034 ± 4.39772
26	14.317
18.7953 ± 4.43356
26	13.9109
26	13.5405
26	13.856
26	14.7931
26	14.1037
26	14.0923
26	13.4264
17.9357 ± 4.47493
17.1307 ± 4.49052
26	14.1314
19.2546 ± 4.39547
16.9068 ± 4.62991
18.0128 ± 4.35636
26	13.353
16.071 ± 4.50144
26	13.9553
26	16.6188
26	16.5501
17.2951 ± 4.50006
26	13.2835
18.9316 ± 4.33798
17.7442 ± 4.42086
26	13.7987
17.8008 ± 4.51186
26	13.8168
26	13.3329
26	14.0294
26	13.4152
26	15.4293
26	13.696
26	14.0558
26	13.9533
26	13.2557
26	13.8536
18.5486 ± 4.45262
26	12.6659
17.8566 ± 4.43059
26	14.2979
26	14.1252
18.0294 ± 4.47646
26	13.9796
17.372 ± 4.48644
26	13.292
26	14.8115
17.909 ± 4.4827
18.4333 ± 4.45695
26	13.9292
26	13.8126
26	13.1223
18.0691 ± 4.49045
26	13.6258
17.4312 ± 4.44493
18.4352 ± 4.40065
17.8972 ± 4.4627
26	15.3175
26	13.7652
16.6421 ± 4.52618
20.6688 ± 4.25889
17.6186 ± 4.52145
19.2118 ± 4.40518
18.7109 ± 4.55079
26	13.6085
20.3536 ± 4.2829
17.8162 ± 4.51322
17.8092 ± 4.43639
18.6327 ± 4.44847
17.6373 ± 4.46617
18.7448 ± 4.57294
18.1184 ± 4.46354
26	12.4618
16.3219 ± 4.526
27	13.5507
27	13.024
27	13.508
27	13.9584
27	13.7221
27	13.6138
27	13.9384
27	13.6433
27	13.6301
27	13.4144
27	13.7209
27	13.8685
27	14.694
27	14.5504
27	14.4984
27	12.6389
27	13.6894
27	13.41
27	13.4212
27	13.8469
27	13.7678
27	13.3806
27	13.7398
27	13.6129
17.1778 ± 4.39458
17.1381 ± 4.39741
27	13.3136
27	13.5494
27	13.7042
27	13.6607
27	12.5368
27	13.2761
17.8808 ± 4.42826
18.0701 ± 4.46904
27	13.3643
27	14.5478
27	13.5445
17.3042 ± 4.45575
27	14.461
17.4188 ± 4.44164
27	12.4289
27	14.3438
27	13.2572
27	13.9908
27	12.742
19.2303 ± 4.33433
27	14.2465
27	14.2665
18.221 ± 4.47653
16.2487 ± 4.52757
27	13.7428
27	14.7487
27	14.6041
27	13.2076
27	13.8685
27	13.6072
27	13.4763
27	13.4261
27	12.9461
27	12.9012
27	13.597
18.333 ± 4.43629
17.2314 ± 4.47648
27	13.7994
17.9536 ± 4.53739
16.8112 ± 4.45489
27	13.1394
27	13.3767
17.522 ± 4.48817
27	13.6391
27	13.0955
27	14.6754
27	12.8938
27	14.5656
27	12.7434
27	13.5615
27	14.2303
27	14.3063
27	14.2761
27	12.8963
18.5611 ± 4.33238
27	14.259
17.0716 ± 4.40127
27	13.7387
27	13.505
27	13.7757
27	13.0545
27	13.9423
27	12.6939
27	13.9063
27	13.2844
27	13.6627
27	13.2026
27	14.5246
27	13.7103
27	13.2468
17.8223 ± 4.44151
27	13.8468
27	12.8087
27	12.7982
27	13.8439
27	14.6462
27	12.8846
17.2733 ± 4.45734
18.8182 ± 4.33099
27	13.8032
27	13.4121
27	13.1085
27	13.2507
19.3653 ± 4.4701
18.9776 ± 4.29734
17.0198 ± 4.53289
27	14.1242
16.9714 ± 4.42538
18.0255 ± 4.38843
27	13.9669
27	12.6068
27	13.5195
17.7166 ± 4.51098
17.7115 ± 4.37451
18.1467 ± 4.5202
27	13.4552
27	13.4183
27	13.3698
27	13.2127
27	13.3295
17.1166 ± 4.55158
27	13.9484
27	12.1241
16.6426 ± 4.51459
27	13.4016
17.6318 ± 4.24021
27	12.7031
27	13.0798
16.9287 ± 4.46754
27	13.2472
18.4914 ± 4.4676
27	13.1217
27	13.061
18.9429 ± 4.36333
17.361 ± 4.46164
27	14.6089
27	12.4821
16.7549 ± 4.3884
27	14.0449
27	13.5758
27	13.6978
18.7186 ± 4.3976
27	13.7755
17.9778 ± 4.44401
27	13.8755
27	13.9469
16.9296 ± 4.43872
17.7232 ± 4.50499
18.1012 ± 4.47094
27	16.4139
27	13.7657
17.82 ± 4.51413
27	13.7462
27	13.9311
27	14.8103
17.2963 ± 4.46896
17.9902 ± 4.45741
27	14.7991
17.563 ± 4.4866
27	13.1018
27	13.0076
27	13.6811
27	13.644
27	13.6273
27	13.8218
27	14.7205
27	13.4562
27	13.545
27	13.0666
15.8239 ± 4.50648
27	15.1952
27	12.9886
17.3188 ± 4.48967
27	16.1623
17.6322 ± 4.54219
17.3256 ± 4.4157
18.1061 ± 4.39773
27	12.9542
17.16 ± 4.48498
17.4896 ± 4.50805
17.6097 ± 4.45318
16.3843 ± 4.53103
18.2761 ± 4.55134
18.2358 ± 4.53375
27	15.8183
20.3442 ± 4.24637
27	14.6451
18.8107 ± 4.34682
18.2834 ± 4.30497
18.3988 ± 4.40534
17.3762 ± 4.40601
19.91 ± 4.35047
27	12.4618
27	12.4609
27	12.3626
16.7271 ± 4.49716
28	12.5579
16.2183 ± 4.50068
28	13.0133
28	14.2324
28	12.9141
28	12.6062
28	12.8636
28	13.513
28	13.482
28	13.1561
28	13.3352
28	13.6343
28	12.4924
28	13.1398
28	13.1546
28	13.5781
28	14.3759
28	13.3129
28	13.2178
28	14.2001
28	13.1946
28	12.2429
28	13.2627
28	13.9581
28	12.8925
28	12.8219
28	12.8648
28	14.2138
16.9162 ± 4.45045
18.8778 ± 4.44428
17.7264 ± 4.48526
28	14.5854
17.1922 ± 4.43052
28	12.7989
28	14.5743
17.4555 ± 4.47179
28	13.1361
28	13.3475
28	12.8014
28	12.8752
16.0464 ± 4.51352
17.2547 ± 4.49504
28	13.6631
28	14.2289
17.5102 ± 4.53344
28	12.8281
28	13.0752
17.2447 ± 4.49677
28	13.9014
28	13.8956
28	14.2179
28	13.7417
28	13.2592
17.0413 ± 4.46634
28	14.1741
28	13.048
18.3556 ± 4.37496
17.8408 ± 4.5205
28	13.3794
28	13.0684
17.6436 ± 4.4974
28	13.6584
28	13.8843
28	13.6292
28	13.2534
28	12.7601
28	13.0575
28	13.0477
16.6657 ± 4.36383
28	13.2807
28	13.463
28	13.8745
28	13.0098
28	14.2126
28	13.414
18.8082 ± 4.28564
28	12.6557
28	12.9972
28	13.7191
28	12.6422
28	13.7804
28	12.9378
28	14.4692
28	13.0175
28	14.6034
16.6525 ± 4.4181
28	14.0477
28	12.5329
28	13.0588
28	13.8592
28	13.0365
18.8112 ± 4.44877
28	13.5731
28	13.2781
28	11.8592
28	13.7649
17.851 ± 4.57875
28	13.0471
28	13.7548
17.2603 ± 4.2935
28	13.5221
28	13.6109
18.5884 ± 4.38349
28	13.009
28	12.8947
28	12.6982
28	13.6552
16.5417 ± 4.50856
28	13.2508
28	12.9567
28	12.6243
28	14.5873
18.5365 ± 4.44244
18.2095 ± 4.41096
18.1992 ± 4.485
17.5532 ± 4.46626
28	12.8528
17.7731 ± 4.52436
28	12.4472
28	13.0375
28	13.6318
28	12.8139
16.6306 ± 4.53393
28	13.0164
28	13.6483
17.3926 ± 4.39215
28	14.5913
17.0182 ± 4.46477
17.5843 ± 4.49418
17.2798 ± 4.5198
28	13.5631
17.5997 ± 4.34072
28	13.9831
28	13.0124
17.5177 ± 4.39393
28	13.0825
28	13.1383
28	13.3471
28	12.9414
28	13.0364
28	14.5883
17.4762 ± 4.43039
16.5745 ± 4.34666
28	14.5186
28	12.5785
16.8912 ± 4.48029
19.1218 ± 4.41236
28	12.6068
17.012 ± 4.44224
28	13.579
28	15.7456
15.6591 ± 4.49548
28	15.6995
17.8114 ± 4.46471
28	13.5221
28	12.4277
28	13.5753
16.9822 ± 4.45351
28	13.7492
28	13.9043
28	13.3999
28	15.6821
16.6319 ± 4.49476
17.7913 ± 4.45768
28	13.2878
17.1517 ± 4.56257
16.8791 ± 4.50029
28	14.4769
17.6055 ± 4.42098
28	13.8945
17.4814 ± 4.45612
18.7841 ± 4.3432
28	15.6496
28	14.8913
28	13.8478
17.3631 ± 4.52983
18.0147 ± 4.57187
28	13.7856
28	13.5123
28	15.4575
28	13.8335
28	13.6476
17.2428 ± 4.4117
19.8716 ± 4.3074
17.8829 ± 4.51575
28	13.4645
17.8063 ± 4.42722
18.0513 ± 4.4902
28	14.8656
17.3683 ± 4.42216
18.1458 ± 4.38065
19.5069 ± 4.40919
28	12.3617
28	12.3289
16.3568 ± 4.49782
29	13.3304
29	12.5458
29	13.3264
29	13.6269
16.9436 ± 4.40046
29	12.8528
29	12.3024
16.1117 ± 4.45867
29	12.7893
29	12.7784
29	13.232
29	12.7857
29	12.1914
29	13.5452
29	13.2258
29	13.9468
29	13.1913
29	12.6942
29	13.0373
29	12.7066
29	12.7753
29	13.8843
29	13.8021
17.6198 ± 4.49867
29	12.7043
29	12.6536
16.572 ± 4.42307
29	12.6983
29	14.1557
29	12.6468
29	13.1932
16.9378 ± 4.54826
29	14.1414
29	13.153
29	12.6431
17.2402 ± 4.3704
29	13.7859
16.9342 ± 4.45532
29	13.6997
18.4479 ± 4.47545
29	13.0118
15.9143 ± 4.51248
29	12.6963
29	12.4253
29	12.6326
29	12.4062
29	13.2207
29	13.0707
17.409 ± 4.513
17.1595 ± 4.45183
16.9264 ± 4.45187
16.8468 ± 4.5024
29	12.4224
29	14.4905
29	12.4153
17.899 ± 4.35212
29	13.0137
29	13.5588
29	12.7963
16.8044 ± 4.4557
29	13.0076
29	12.7927
29	12.7033
18.8792 ± 4.28474
29	13.7253
29	14.019
29	12.2756
29	13.734
16.4396 ± 4.40786
29	12.9599
29	12.7702
17.072 ± 4.57053
29	12.8688
29	13.7473
29	12.6348
29	12.7537
17.0854 ± 4.39135
29	13.2381
29	12.9489
29	12.7616
29	13.217
29	13.6637
29	12.7381
29	13.3941
29	12.4803
29	12.7151
17.5255 ± 4.63566
18.3921 ± 4.44996
29	12.945
29	13.4114
29	12.676
29	13.6217
29	14.4286
29	14.3913
17.3845 ± 4.62326
16.4543 ± 4.43554
16.7149 ± 4.54902
29	12.8299
29	13.4561
29	13.0658
29	13.1982
16.7415 ± 4.52742
29	13.4492
29	13.0138
16.7397 ± 4.48141
29	12.5741
29	14.3302
29	13.95
29	14.2334
17.2314 ± 4.40601
17.4015 ± 4.41595
29	12.4652
29	12.4227
29	13.2865
18.3073 ± 4.48823
18.3358 ± 4.32825
29	13.2073
29	13.165
17.9374 ± 4.38029
29	13.672
29	12.6315
17.8174 ± 4.41872
17.2849 ± 4.33339
29	13.6674
16.5135 ± 4.41885
29	12.3538
29	15.3387
29	13.4081
29	15.2499
29	13.4894
16.3977 ± 4.43968
29	13.5782
16.7731 ± 4.44646
17.2474 ± 4.53531
29	14.9758
29	13.4985
29	13.5311
29	13.5921
29	13.2958
16.851 ± 4.53543
29	13.2352
29	13.3314
29	12.978
29	12.3267
16.6228 ± 4.51184
0
20
58
59
47
45
6
7
21
15
39
25
4
13
48
51
16
11
62
50
49
8
40
23
24
17
26
27
57
52
30
31
61
33
34
35
36
37
38
10
22
42
41
28
44
5
46
29
9
19
43
32
12
53
54
55
56
14
2
3
60
18
1
63
2 sends to 58
2 receives from 58
25 sends to 17
25 receives from 11
19 sends to 50
19 receives from 49
32 sends to 61
32 receives from 51
21 sends to 8
21 receives from 8
14 sends to 48
14 receives from 57
23 sends to 23
23 receives from 23
6 sends to 6
6 receives from 6
7 sends to 7
7 receives from 7
16 sends to 16
16 receives from 16
27 sends to 27
27 receives from 27
9 sends to 15
9 receives from 48
15 sends to 51
15 receives from 9
34 sends to 34
34 receives from 34
30 sends to 30
30 receives from 30
37 sends to 37
37 receives from 37
36 sends to 36
36 receives from 36
39 sends to 10
39 receives from 10
40 sends to 22
40 receives from 22
42 sends to 41
42 receives from 41
44 sends to 44
44 receives from 44
41 sends to 42
41 receives from 42
49 sends to 19
49 receives from 20
53 sends to 53
53 receives from 53
52 sends to 12
52 receives from 29
54 sends to 54
54 receives from 54
55 sends to 55
55 receives from 55
61 sends to 18
61 receives from 32
59 sends to 3
59 receives from 3
62 sends to 1
62 receives from 18
0 sends to 0
0 receives from 0
12 sends to 4
12 receives from 52
1 sends to 20
1 receives from 62
11 sends to 25
11 receives from 17
58 sends to 2
58 receives from 2
57 sends to 14
57 receives from 28
43 sends to 28
43 receives from 50
22 sends to 40
22 receives from 40
29	12.4325
17.3476 ± 4.4875
63 sends to 63
63 receives from 63
33 sends to 33
33 receives from 33
17.4848 ± 4.37817
4 sends to 47
4 receives from 12
17.1445 ± 4.41495
17.577 ± 4.40559
17.0722 ± 4.521
29	13.2672
17.6154 ± 4.63335
17.0975 ± 4.42508
18.5675 ± 4.39773
17.5331 ± 4.46294
18.509 ± 4.44181
17.295 ± 4.48436
16.3085 ± 4.51407
35 sends to 35
35 receives from 35
20 sends to 49
20 receives from 1
17.4571 ± 4.44858
17.5864 ± 4.51153
19.4429 ± 4.31947
29	14.6682
18 sends to 62
18 receives from 61
45 sends to 5
45 receives from 5
17.5745 ± 4.5161
51 sends to 32
51 receives from 15
31 sends to 31
31 receives from 31
8 sends to 21
8 receives from 21
10 sends to 39
10 receives from 39
29 sends to 52
29 receives from 47
17.1929 ± 4.46191
13 sends to 13
13 receives from 13
28 sends to 57
28 receives from 43
24 sends to 24
24 receives from 24
46 sends to 46
46 receives from 46
3 sends to 59
3 receives from 59
29	12.2297
17.7832 ± 4.4446
60 sends to 60
60 receives from 60
5 sends to 45
5 receives from 45
38 sends to 38
38 receives from 38
47 sends to 29
47 receives from 4
48 sends to 9
48 receives from 14
56 sends to 56
56 receives from 56
19.1618 ± 4.39308
17 sends to 11
17 receives from 25
16.1584 ± 4.57407
26 sends to 26
26 receives from 26
50 sends to 43
50 receives from 19
30	13.3031
30	12.6892
30	12.9531
30	12.1558
30	12.7043
30	13.1723
30	12.8011
30	12.7898
30	12.6942
30	12.6151
30	12.9677
30	12.5558
30	12.5458
30	13.1398
30	12.9809
30	12.9424
30	12.3142
30	12.5939
30	12.8071
30	12.802
30	12.4803
30	12.7839
30	12.2824
30	12.2756
30	12.9096
30	13.1598
30	13.1453
30	12.8299
30	12.7331
30	13.5687
30	12.6019
30	11.8592
30	12.6178
30	13.2068
30	13.1477
30	12.912
30	12.6431
30	12.8954
17.2483 ± 4.55901
30	12.0842
16.8652 ± 4.42195
30	13.5115
30	12.4041
30	12.3973
17.0451 ± 4.36403
17.0477 ± 4.33999
16.665 ± 4.54478
30	12.3199
30	13.201
30	13.1035
30	12.978
30	12.9803
16.8035 ± 4.43256
30	13.2289
30	13.1541
30	13.0076
30	12.8666
30	12.3232
30	12.5679
16.5756 ± 4.53007
18.3412 ± 4.37466
30	13.5469
30	12.95
30	13.3843
16.3019 ± 4.48235
30	13.2949
30	12.9237
30	12.4732
30	12.3267
30	13.5218
30	13.1472
30	13.0138
30	14.1661
30	13.4081
30	13.1814
30	13.2673
30	12.2493
18.498 ± 4.47703
30	12.1914
30	12.0842
30	12.6147
16.8747 ± 4.40991
17.5606 ± 4.36041
30	13.2781
17.446 ± 4.30587
30	13.2019
30	12.9885
17.2317 ± 4.41307
30	13.8274
30	13.6263
30	13.5645
30	13.1982
17.0523 ± 4.49979
30	13.1786
30	12.7033
30	12.9072
16.6439 ± 4.60523
30	13.5718
30	13.4758
30	12.945
17.1376 ± 4.24851
17.9235 ± 4.51404
17.7711 ± 4.36434
30	12.8738
30	11.7422
16.8917 ± 4.64773
16.4632 ± 4.51743
18.0923 ± 4.24854
30	13.4097
30	13.2631
15.8779 ± 4.47522
30	12.9916
17.2433 ± 4.33732
30	12.8628
17.311 ± 4.36605
17.9035 ± 4.26225
30	13.007
16.8368 ± 4.37251
16.8201 ± 4.55267
30	13.1879
17.2589 ± 4.47713
30	12.5988
18.2429 ± 4.32464
18.1337 ± 4.387
30	12.2223
17.5949 ± 4.46928
16.7369 ± 4.39532
18.3015 ± 4.20711
30	12.6197
30	12.5587
15.9048 ± 4.55007
30	12.2288
30	12.5868
17.3078 ± 4.35313
16.87 ± 4.40999
18.211 ± 4.38355
18.484 ± 4.38536
16.8343 ± 4.19172
18.541 ± 4.37366
17.0201 ± 4.53185
18.4917 ± 4.26588
17.7904 ± 4.32928
30	14.5476
16.9886 ± 4.43672
18.5498 ± 4.50108
17.6092 ± 4.25706
18.7915 ± 4.41288
17.1025 ± 4.57655
30	11.9072
18.2757 ± 4.42424
31	12.8186
31	12.6133
31	12.6021
31	12.3812
31	12.862
31	12.916
31	12.6779
31	12.2715
31	12.4549
31	12.2772
31	12.2225
31	12.867
31	12.6341
31	13.5123
31	12.0769
31	12.5992
31	12.5865
31	12.6151
17.0189 ± 4.54878
31	12.1294
31	12.4933
16.6767 ± 4.48947
31	12.6935
31	12.7693
31	12.5559
31	12.2507
31	13.1459
17.3206 ± 4.42404
31	13.1044
31	13.137
31	12.8507
31	12.0623
17.9333 ± 4.48171
31	13.0939
31	13.3437
16.8059 ± 4.36084
16.7104 ± 4.47887
31	13.4233
17.4152 ± 4.37291
31	12.0769
31	13.2065
31	12.1066
31	12.8328
31	13.329
31	12.6247
31	13.1653
31	12.6006
31	12.5504
16.631 ± 4.4402
16.3929 ± 4.60463
31	12.9905
31	13.0891
31	13.087
16.7905 ± 4.48571
16.8224 ± 4.53198
31	12.3937
16.816 ± 4.38981
31	12.4389
31	13.5145
31	12.9249
31	13.0801
31	13.7389
16.1346 ± 4.51176
17.1261 ± 4.3742
31	12.4312
31	13.2014
31	13.4233
15.7242 ± 4.51362
18.2802 ± 4.40206
31	12.4188
31	13.077
16.376 ± 4.4718
31	12.0385
16.2104 ± 4.51906
31	13.3366
31	13.1325
16.5143 ± 4.57196
17.4316 ± 4.51364
31	12.2444
31	13.1416
17.5932 ± 4.42022
31	13.1673
31	12.8407
17.0366 ± 4.33918
16.6919 ± 4.39048
17.0953 ± 4.48416
31	12.9585
31	13.0652
31	12.1323
18.0136 ± 4.50937
31	12.8328
17.1729 ± 4.4192
17.9432 ± 4.42668
31	12.9044
31	13.4796
31	12.9633
31	12.935
17.3172 ± 4.47102
17.7397 ± 4.37158
31	12.9633
15.721 ± 4.55336
31	12.5541
31	13.3656
17.7362 ± 4.30647
31	12.8022
17.9502 ± 4.49191
31	12.8725
31	12.8938
31	12.7988
18.7676 ± 4.32551
31	12.5774
17.6194 ± 4.51501
16.5597 ± 4.40746
16.2649 ± 4.58667
16.318 ± 4.5113
31	14.4919
16.7123 ± 4.42737
31	12.7753
31	12.7653
31	12.7485
31	12.8719
31	12.8648
17.4541 ± 4.31463
31	12.7473
31	12.835
18.9222 ± 4.27981
16.8115 ± 4.44872
16.7274 ± 4.50106
17.8582 ± 4.57445
17.5306 ± 4.37707
31	13.199
18.163 ± 4.47613
18.0754 ± 4.45853
18.2641 ± 4.46176
18.2069 ± 4.34828
31	12.4662
16.7604 ± 4.54553
16.5702 ± 4.53206
17.9681 ± 4.48034
32	12.7304
32	12.6519
32	12.5288
32	13.0453
32	12.8525
32	12.8439
32	12.8331
32	12.2437
32	12.5467
32	12.543
32	12.7016
32	12.5203
32	12.6385
32	12.8413
16.827 ± 4.59136
32	12.4444
32	12.6751
32	12.478
32	12.0161
32	12.1898
32	12.4204
32	12.2765
32	12.6701
32	12.6497
16.4023 ± 4.46431
32	12.2683
32	12.5133
32	12.5204
32	12.0083
32	12.5937
32	12.7259
32	12.7014
32	12.5252
32	12.4796
32	13.3668
32	12.9313
32	12.5374
32	12.4016
15.6614 ± 4.55795
32	12.3393
17.3731 ± 4.23163
32	12.3853
16.6229 ± 4.45182
32	12.1452
32	12.0087
32	13.2748
32	12.1284
16.7944 ± 4.43577
16.5167 ± 4.45306
16.0882 ± 4.4562
32	12.4754
17.068 ± 4.48999
32	13.0867
32	12.6777
16.6469 ± 4.38188
32	13.0612
32	13.1283
32	12.4222
32	13.109
32	13.1071
32	12.082
32	11.7933
16.9074 ± 4.52449
16.4991 ± 4.3724
18.0283 ± 4.48442
32	12.3585
16.3394 ± 4.56827
16.2804 ± 4.49445
32	12.6172
32	12.3278
17.3792 ± 4.55355
32	13.3028
17.0513 ± 4.57202
32	12.7473
32	12.6567
32	13.414
16.3237 ± 4.55723
15.8684 ± 4.45842
32	12.1274
32	12.0314
32	13.0968
17.5864 ± 4.61949
32	12.7452
32	11.7066
17.0619 ± 4.46598
17.2637 ± 4.45122
17.125 ± 4.44916
32	12.0126
32	13.1283
32	13.0338
17.3076 ± 4.54817
32	12.9344
32	12.5473
32	12.8196
15.6277 ± 4.54659
32	12.682
32	13.061
32	12.7941
16.5766 ± 4.54787
32	12.5846
32	12.9807
32	13.2866
17.4043 ± 4.57356
32	12.8633
32	12.5849
32	13.2787
32	12.841
32	12.0843
17.0149 ± 4.51927
17.5151 ± 4.49742
32	12.6569
32	12.7403
17.0138 ± 4.48863
32	13.2467
32	12.0244
16.2764 ± 4.48181
32	12.2288
17.3045 ± 4.55538
32	12.8507
17.0991 ± 4.43486
16.5159 ± 4.50198
32	11.819
32	12.7996
32	12.5401
32	12.4475
16.7965 ± 4.39008
32	14.4419
16.3051 ± 4.56733
32	11.6879
17.6656 ± 4.52446
17.1864 ± 4.55663
32	12.3853
15.9527 ± 4.53667
32	13.3466
18.1957 ± 4.47392
17.8027 ± 4.44396
32	12.3332
32	11.5625
17.5813 ± 4.42063
15.9527 ± 4.58457
32	12.4237
32	12.7276
16.5093 ± 4.39649
32	12.2903
32	13.2896
17.1632 ± 4.46365
17.6888 ± 4.60503
16.4651 ± 4.50724
17.1924 ± 4.62232
16.3963 ± 4.49758
17.7831 ± 4.54317
16.7518 ± 4.54387
17.7668 ± 4.55315
18.8622 ± 4.3325
16.4981 ± 4.54053
17.2615 ± 4.65112
33	12.5028
33	12.3618
33	12.6945
33	12.4769
33	12.2572
33	12.4696
33	12.0087
33	13.0122
33	12.4904
33	12.2214
33	12.9793
33	12.1431
33	12.9379
33	12.388
33	11.9104
33	12.3541
33	12.7073
33	12.1362
33	12.446
16.247 ± 4.51206
33	12.0647
33	12.2236
16.3719 ± 4.47944
33	12.3606
16.3641 ± 4.42471
33	12.5799
33	12.9147
33	12.4685
16.029 ± 4.45831
33	11.771
33	13.2738
33	12.9455
15.5297 ± 4.50644
33	11.9453
33	12.5972
33	12.3947
16.3417 ± 4.37106
17.4949 ± 4.22437
33	12.169
16.7134 ± 4.57997
33	12.3408
15.7142 ± 4.44182
33	13.0998
33	11.9364
16.4984 ± 4.52774
33	12.9699
33	12.8168
33	12.378
33	12.8796
33	12.7916
16.3572 ± 4.40815
33	12.7379
33	12.7366
33	12.7162
33	11.5366
33	12.5828
33	13.0357
33	12.6939
33	12.3807
16.7123 ± 4.58323
33	12.1982
16.8837 ± 4.52188
33	12.7022
16.76 ± 4.56332
15.9974 ± 4.55581
33	12.8768
33	12.3026
33	12.6251
33	13.0966
33	12.2374
33	12.9761
33	12.2282
16.4537 ± 4.47889
33	12.5243
16.1767 ± 4.45128
33	12.5215
33	13.0338
17.6049 ± 4.48032
33	12.5061
16.86 ± 4.48056
33	11.4939
16.8427 ± 4.48437
33	12.7379
33	11.6736
15.9556 ± 4.57484
33	13.0089
33	12.7719
33	12.4235
16.9481 ± 4.46752
33	12.3998
33	12.3758
33	12.2
16.7353 ± 4.58948
15.8839 ± 4.46817
16.1436 ± 4.58883
33	12.5603
16.846 ± 4.58644
33	12.9908
33	12.7216
16.2487 ± 4.47222
16.7705 ± 4.54139
33	12.4854
17.2539 ± 4.57989
17.3294 ± 4.4423
16.7179 ± 4.43565
33	12.0278
33	12.5274
33	12.6975
33	14.2298
17.153 ± 4.56992
33	12.0845
33	12.523
33	12.9977
33	13.2639
33	13.1726
17.6216 ± 4.58852
15.5564 ± 4.58278
33	12.1523
16.3659 ± 4.48117
17.7181 ± 4.72489
16.7722 ± 4.54738
33	12.4001
33	12.058
33	12.395
33	12.3789
33	11.9072
33	12.3462
33	12.1592
17.3962 ± 4.47752
33	12.6882
17.0118 ± 4.64012
16.3733 ± 4.46158
16.7571 ± 4.57497
16.7022 ± 4.59503
33	13.1627
16.3968 ± 4.55643
16.8446 ± 4.54075
33	12.006
33	12.1573
17.521 ± 4.56082
17.1936 ± 4.58184
15.7195 ± 4.52651
18.5599 ± 4.33689
16.3515 ± 4.5525
17.3407 ± 4.5199
16.6466 ± 4.64036
16.3934 ± 4.5176
34	12.2621
34	12.0859
34	12.7244
16.0834 ± 4.45524
34	12.0545
34	12.361
34	12.6945
34	12.0675
34	12.0406
34	12.2046
34	12.2046
34	12.3023
16.4168 ± 4.61085
34	12.2416
34	12.6973
34	11.9942
34	11.7297
34	12.929
34	12.5235
34	12.1427
34	11.8925
34	11.808
34	12.7067
34	11.6615
34	12.506
34	11.6407
34	12.9074
34	12.692
15.7431 ± 4.53068
15.9438 ± 4.51533
34	12.2243
15.7863 ± 4.57441
34	11.9751
34	12.439
34	12.7138
16.2923 ± 4.44413
34	12.5738
16.0204 ± 4.3887
34	12.163
16.19 ± 4.50201
16.5649 ± 4.355
34	12.4626
16.3903 ± 4.45882
15.9132 ± 4.52941
15.6766 ± 4.54923
16.2712 ± 4.53471
34	12.3279
16.1706 ± 4.51516
34	11.7636
34	12.8203
34	12.7381
34	13.0538
34	13.003
34	12.5338
34	12.9688
16.5844 ± 4.51198
34	12.9578
34	12.6875
34	12.9423
34	12.7163
16.1162 ± 4.48931
16.2952 ± 4.56142
34	12.3339
34	12.9287
17.5483 ± 4.25412
16.6924 ± 4.52726
34	12.071
15.6689 ± 4.61425
34	12.2899
16.2409 ± 4.66288
16.5401 ± 4.56207
34	12.0106
34	12.8573
34	12.5105
34	12.9098
34	11.4611
34	12.5886
34	11.4484
34	12.2883
15.8693 ± 4.65735
34	13.011
34	11.9134
34	12.5738
34	12.3228
34	12.172
34	12.9504
16.1132 ± 4.43082
17.3476 ± 4.54537
34	11.7628
34	12.8391
16.4134 ± 4.6487
34	13.1032
17.6127 ± 4.35304
34	14.193
16.6788 ± 4.48819
16.8737 ± 4.52134
16.8996 ± 4.4985
34	11.8646
16.5061 ± 4.45809
34	11.8307
34	11.7536
34	11.9969
34	12.3823
16.7511 ± 4.46658
34	14.1863
34	12.006
34	12.0561
16.8973 ± 4.59228
34	12.5404
17.3082 ± 4.6093
34	12.0321
34	12.377
34	12.3524
34	12.6073
16.3595 ± 4.59247
16.4598 ± 4.63126
34	12.9075
34	12.9807
34	14.0677
34	12.5971
16.0973 ± 4.54793
17.1936 ± 4.72987
16.3724 ± 4.57968
34	12.3624
17.0998 ± 4.48968
34	11.7122
15.313 ± 4.57609
16.2609 ± 4.51099
34	12.3239
15.6353 ± 4.49979
34	12.354
17.0513 ± 4.54213
17.0656 ± 4.50729
34	11.9687
16.153 ± 4.52169
16.1626 ± 4.57432
16.4714 ± 4.56328
16.24 ± 4.68321
34	12.1899
15.5739 ± 4.53927
18.2465 ± 4.42579
16.9899 ± 4.64601
16.4994 ± 4.53031
16.2346 ± 4.57822
34	11.6752
16.9883 ± 4.46996
16.116 ± 4.70338
16.1589 ± 4.49131
16.2858 ± 4.58292
16.7902 ± 4.63632
35	12.2508
35	12.2249
35	12.6746
15.944 ± 4.42676
35	12.3664
35	11.8302
35	12.0177
35	12.0644
35	11.9682
35	12.7046
35	12.6977
35	12.6386
35	11.6373
35	11.6184
35	12.0025
35	11.9956
35	11.7685
35	12.4718
15.6364 ± 4.53835
35	12.8172
35	12.4298
16.3309 ± 4.51105
15.6475 ± 4.5615
35	11.6432
35	12.2916
35	12.3396
35	13.0947
35	13.0677
35	13.0482
35	12.402
35	11.9719
35	13.0395
35	12.3999
17.0529 ± 4.32024
35	12.4387
35	12.5345
35	12.3716
15.6289 ± 4.56378
35	12.3122
35	12.8677
35	12.345
35	12.6431
35	12.5445
15.8743 ± 4.54625
35	12.2887
35	12.8651
15.4551 ± 4.64372
16.0077 ± 4.53921
16.3016 ± 4.41785
16.5437 ± 4.54657
35	11.7514
35	11.693
16.3201 ± 4.44404
35	11.6337
16.6967 ± 4.47227
35	12.6503
17.2447 ± 4.41059
16.0805 ± 4.50244
35	12.6363
35	12.1286
35	12.5903
35	12.4562
16.0517 ± 4.55399
17.3619 ± 4.42545
16.0354 ± 4.46847
35	11.9134
35	12.2815
35	11.9591
35	12.2602
35	11.4343
35	11.9522
35	11.9643
16.1874 ± 4.61163
35	12.3847
35	12.2528
16.2978 ± 4.49247
35	12.0366
35	12.8771
35	12.4979
35	12.791
35	11.67
16.6823 ± 4.53699
35	12.7866
16.5177 ± 4.53403
15.4326 ± 4.55511
15.6902 ± 4.56846
35	12.3622
35	12.803
35	11.9643
35	11.9086
16.3325 ± 4.45363
16.7591 ± 4.69889
35	12.591
35	12.5515
35	12.2319
15.8233 ± 4.54798
35	12.9701
16.8347 ± 4.52598
35	12.7807
35	12.355
16.0406 ± 4.60225
16.0086 ± 4.49188
35	11.6938
16.2275 ± 4.62207
35	12.9601
35	12.2039
16.2056 ± 4.51101
16.626 ± 4.44476
35	12.8964
15.8718 ± 4.43525
16.2392 ± 4.57169
35	12.3944
16.5495 ± 4.55568
35	12.2763
15.8632 ± 4.58389
35	14.0308
16.2496 ± 4.56999
16.7868 ± 4.53267
15.8716 ± 4.55753
16.6975 ± 4.48109
16.0926 ± 4.53761
16.8136 ± 4.54903
35	13.9585
16.5294 ± 4.63026
17.9691 ± 4.42757
36	12.1778
36	12.1231
15.8278 ± 4.44307
36	11.8228
36	11.8513
15.9122 ± 4.38243
36	12.1824
36	12.164
36	12.6737
36	12.009
36	12.4316
36	11.5668
36	13.0041
36	12.4059
36	12.9846
15.5379 ± 4.51267
36	11.5807
36	12.9754
15.4408 ± 4.49613
36	12.2182
36	12.029
36	12.6317
36	12.8477
36	12.11
36	11.7422
15.6839 ± 4.51051
36	12.13
15.9715 ± 4.51135
16.3176 ± 4.52524
36	12.6905
36	12.933
36	12.3206
36	12.068
15.3287 ± 4.59041
16.1921 ± 4.48868
15.5342 ± 4.49275
36	12.729
36	12.3087
16.5807 ± 4.51438
36	12.3064
36	12.6295
15.9097 ± 4.56149
36	12.3081
17.0935 ± 4.44574
36	12.3518
15.8139 ± 4.419
36	12.3778
16.5474 ± 4.55511
36	11.948
36	12.3121
36	12.9697
16.8587 ± 4.48793
36	12.3496
36	11.6466
15.3985 ± 4.56754
36	12.4697
36	12.4757
16.1518 ± 4.47675
36	12.3855
15.9794 ± 4.57781
36	12.2356
36	11.9295
36	11.9572
15.8474 ± 4.53102
36	12.4881
16.5252 ± 4.50416
16.4006 ± 4.50719
15.6367 ± 4.48424
36	12.2061
16.4732 ± 4.53554
36	12.0453
36	11.7425
36	12.0361
16.5448 ± 4.41743
36	11.4121
36	11.8759
36	12.5976
36	12.3519
36	12.4629
16.4861 ± 4.6416
36	12.4323
36	11.9937
15.369 ± 4.61525
36	12.7085
36	12.4372
15.8008 ± 4.46357
15.8743 ± 4.56236
16.4883 ± 4.56653
15.9968 ± 4.50152
36	12.1381
36	11.8777
16.0688 ± 4.57441
36	12.1165
15.6686 ± 4.48088
36	11.8313
16.5329 ± 4.46946
16.3119 ± 4.56032
16.3146 ± 4.51584
16.0097 ± 4.48518
15.6379 ± 4.54317
36	12.8857
16.0486 ± 4.51631
36	12.365
16.5775 ± 4.4535
15.9249 ± 4.62221
16.1722 ± 4.48646
15.6097 ± 4.53725
15.8788 ± 4.57728
16.406 ± 4.46631
16.6744 ± 4.55172
36	12.2721
36	12.203
16.2478 ± 4.59108
37	12.1405
37	12.0388
37	11.985
37	11.9772
16.1567 ± 4.37877
37	12.1587
15.9092 ± 4.39223
37	12.648
37	11.5733
37	12.1076
37	12.6397
37	12.013
15.4541 ± 4.48685
37	12.5994
37	12.2796
37	12.1449
37	12.0077
37	12.0045
37	12.7919
37	12.6274
37	12.6205
37	12.4463
37	12.8772
37	12.6931
16.0473 ± 4.57261
37	11.7289
37	12.6551
37	12.078
15.8091 ± 4.5529
37	12.6291
37	12.5843
37	12.2031
37	12.0768
37	12.3052
37	12.0402
15.7772 ± 4.5547
16.2779 ± 4.53532
37	12.11
37	12.2261
37	12.276
15.9216 ± 4.47029
15.2734 ± 4.56967
37	12.3392
37	12.5964
16.3556 ± 4.55087
37	12.0659
17.3339 ± 4.31259
15.5008 ± 4.50079
16.4068 ± 4.47457
15.3074 ± 4.57295
37	11.6252
37	12.3736
16.8592 ± 4.6485
16.6455 ± 4.48822
15.8119 ± 4.3328
37	12.3381
16.1596 ± 4.49843
37	12.1168
16.4638 ± 4.48778
16.2691 ± 4.48295
37	11.7986
15.7633 ± 4.48611
15.3042 ± 4.5993
37	12.1621
37	12.3294
16.2347 ± 4.60152
16.0844 ± 4.54862
37	12.0884
37	12.0287
37	12.3859
37	13.9037
16.2468 ± 4.59315
37	11.9117
15.7029 ± 4.53314
37	11.6627
16.4811 ± 4.61491
15.1231 ± 4.46711
37	12.3311
15.9347 ± 4.49955
37	12.3792
15.8649 ± 4.49876
37	11.8701
15.7081 ± 4.46264
15.4455 ± 4.49208
37	12.8674
37	12.3521
37	12.821
37	13.7137
37	12.4658
15.6653 ± 4.56281
15.9861 ± 4.50746
17.5934 ± 4.38835
37	12.2854
37	12.7914
15.5505 ± 4.58066
16.1017 ± 4.51576
16.1544 ± 4.53223
16.1712 ± 4.52884
16.5241 ± 4.50757
38	12.0853
38	12.0218
38	11.9686
38	11.9445
38	12.0321
38	12.04
15.7456 ± 4.42119
38	12.3292
38	12.1201
15.8243 ± 4.53798
38	12.5494
38	12.3502
38	12.5047
38	12.1042
38	12.785
38	12.6863
15.7494 ± 4.52972
38	12.832
15.4099 ± 4.44676
38	12.3071
38	11.9438
38	12.2675
38	12.2268
16.1485 ± 4.55571
16.6795 ± 4.44487
38	12.2173
38	12.2354
38	12.0712
16.3699 ± 4.55479
38	12.5204
38	11.6115
16.1502 ± 4.44636
16.4866 ± 4.50151
38	11.8834
15.6105 ± 4.49188
16.321 ± 4.47209
38	12.6747
38	12.0749
38	12.0333
16.3953 ± 4.52902
38	11.7956
38	12.495
38	13.6045
15.6048 ± 4.59652
15.9934 ± 4.56513
38	11.6795
15.8681 ± 4.32723
16.1593 ± 4.59709
38	12.2631
38	12.3487
38	12.9338
38	11.6788
38	12.707
38	12.6964
16.349 ± 4.49038
15.6267 ± 4.45161
38	12.1135
15.1825 ± 4.50438
38	12.3148
38	12.5632
38	12.2677
38	12.4115
15.4463 ± 4.52654
15.966 ± 4.54263
38	11.9075
38	11.9986
16.0317 ± 4.63861
38	12.0246
15.6548 ± 4.59059
17.4763 ± 4.49358
16.5234 ± 4.48818
16.1625 ± 4.54072
15.8553 ± 4.44731
15.9407 ± 4.47141
15.8662 ± 4.42696
15.9783 ± 4.46238
15.7073 ± 4.57873
16.4076 ± 4.48173
15.8916 ± 4.57602
15.598 ± 4.58754
39	11.9805
39	11.9742
39	11.949
15.6794 ± 4.55549
39	11.8256
39	12.1199
39	12.0873
39	11.892
39	12.3481
39	12.3413
39	12.8136
39	12.7573
16.0764 ± 4.41995
39	12.6277
39	11.7231
39	11.6396
39	11.6705
39	11.9237
39	12.5343
39	12.1581
15.3433 ± 4.54499
39	12.192
39	12.1846
39	12.0964
16.342 ± 4.55241
15.9554 ± 4.58459
39	12.4426
39	11.9946
16.4408 ± 4.56997
15.4877 ± 4.53767
39	11.6652
39	12.0489
15.5135 ± 4.55248
15.1801 ± 4.53296
16.3632 ± 4.51561
39	12.4853
16.2829 ± 4.5431
39	12.215
16.4152 ± 4.51039
39	11.6602
16.0473 ± 4.58705
17.025 ± 4.48256
39	12.3184
39	11.7856
39	11.6212
39	11.5607
39	12.289
15.5427 ± 4.51539
39	11.9049
15.344 ± 4.43771
39	12.2907
39	12.1398
39	11.9809
16.1895 ± 4.45423
39	12.1869
39	11.7959
39	12.8643
15.5381 ± 4.4388
39	11.7724
39	12.5526
16.2319 ± 4.54649
15.4834 ± 4.45758
15.7025 ± 4.49082
39	12.2086
39	12.483
16.0027 ± 4.53074
15.3817 ± 4.48644
15.258 ± 4.47651
15.7682 ± 4.47141
39	13.4875
16.4042 ± 4.4203
15.3388 ± 4.52137
17.253 ± 4.43643
15.6966 ± 4.4958
15.8472 ± 4.49913
16.1733 ± 4.4618
60
1
32
16
59
54
6
7
46
17
10
4
61
53
5
15
3
39
18
19
48
21
22
31
24
30
26
43
28
63
62
11
0
33
34
35
41
37
13
9
40
36
42
52
2
55
25
47
20
49
50
51
27
58
45
14
56
57
8
44
23
12
38
29
0 sends to 60
0 receives from 32
12 sends to 61
12 receives from 61
24 sends to 24
24 receives from 24
11 sends to 4
11 receives from 31
18 sends to 18
18 receives from 18
2 sends to 32
2 receives from 44
17 sends to 39
17 receives from 9
3 sends to 16
3 receives from 16
13 sends to 53
13 receives from 38
4 sends to 59
4 receives from 11
32 sends to 0
32 receives from 2
21 sends to 21
21 receives from 21
5 sends to 54
5 receives from 14
23 sends to 31
23 receives from 60
6 sends to 6
6 receives from 6
7 sends to 7
7 receives from 7
16 sends to 3
16 receives from 3
28 sends to 28
28 receives from 28
8 sends to 46
8 receives from 58
27 sends to 43
27 receives from 52
9 sends to 17
9 receives from 39
31 sends to 11
31 receives from 23
10 sends to 10
10 receives from 10
29 sends to 63
29 receives from 63
22 sends to 22
22 receives from 22
33 sends to 33
33 receives from 33
20 sends to 48
20 receives from 48
15 sends to 15
15 receives from 15
34 sends to 34
34 receives from 34
35 sends to 35
35 receives from 35
30 sends to 62
30 receives from 25
37 sends to 37
37 receives from 37
40 sends to 40
40 receives from 40
42 sends to 42
42 receives from 42
43 sends to 52
43 receives from 27
46 sends to 25
46 receives from 8
45 sends to 55
45 receives from 54
49 sends to 49
49 receives from 49
56 sends to 56
56 receives from 56
55 sends to 14
55 receives from 45
61 sends to 12
61 receives from 12
57 sends to 57
57 receives from 57
59 sends to 44
59 receives from 4
62 sends to 38
62 receives from 30
63 sends to 29
63 receives from 29
36 sends to 41
36 receives from 41
41 sends to 36
41 receives from 36
58 sends to 8
58 receives from 53
47 sends to 47
47 receives from 47
53 sends to 58
53 receives from 13
39 sends to 9
39 receives from 17
44 sends to 2
44 receives from 59
39	12.1633
26 sends to 26
26 receives from 26
15.7891 ± 4.4363
25 sends to 30
25 receives from 46
50 sends to 50
50 receives from 50
60 sends to 23
60 receives from 0
48 sends to 20
48 receives from 20
52 sends to 27
52 receives from 43
54 sends to 45
54 receives from 5
19 sends to 19
19 receives from 19
14 sends to 5
14 receives from 55
51 sends to 51
51 receives from 51
38 sends to 13
38 receives from 62
1 sends to 1
1 receives from 1
40	11.4121
40	11.763
40	12.0433
40	12.0513
40	11.9237
40	12.2954
40	12.1993
40	11.9203
40	11.3711
40	11.9278
40	11.7672
40	12.4496
40	12.1563
40	12.0287
40	11.9946
15.2103 ± 4.50598
40	11.6627
40	11.8377
40	11.8256
40	11.896
40	11.7681
40	11.6652
15.6389 ± 4.45459
40	12.1265
40	11.949
16.2412 ± 4.43906
16.933 ± 4.43862
15.7945 ± 4.5159
40	12.3039
40	12.1589
40	12.1364
40	12.0087
15.8864 ± 4.49056
40	12.1829
40	12.1787
40	12.0321
40	12.2035
40	12.0246
16.0887 ± 4.52876
40	11.5591
40	12.0749
40	12.0433
40	11.9891
40	12.0154
40	11.6938
40	12.1155
40	12.0333
40	11.8948
40	12.0157
40	11.737
40	11.6115
40	11.6225
40	13.2815
40	12.6627
40	11.6814
14.9032 ± 4.54241
40	11.9814
40	12.1869
15.9521 ± 4.36247
40	11.5733
40	11.9701
40	12.0768
15.6281 ± 4.49374
40	12.0116
40	12.1135
40	12.0455
40	11.6432
15.2931 ± 4.48988
40	12.1235
40	11.9445
40	11.9319
16.3061 ± 4.61904
15.7337 ± 4.51002
40	12.0363
16.6312 ± 4.37072
16.1557 ± 4.42603
40	11.9994
14.9973 ± 4.47831
40	12.3519
40	12.2752
15.9894 ± 4.49296
40	11.8719
16.7488 ± 4.37432
16.3341 ± 4.50362
16.2232 ± 4.47261
16.1691 ± 4.29956
17.1158 ± 4.34722
17.0752 ± 4.4043
15.1059 ± 4.55073
17.1735 ± 4.35008
15.4364 ± 4.50976
16.8707 ± 4.28505
16.8749 ± 4.31879
16.045 ± 4.44422
15.2704 ± 4.53128
16.3704 ± 4.50456
16.4224 ± 4.34879
16.6327 ± 4.36087
16.1755 ± 4.28036
16.9953 ± 4.39805
15.652 ± 4.46407
16.5405 ± 4.32921
16.7233 ± 4.30822
15.9712 ± 4.43254
17.1503 ± 4.48115
17.0727 ± 4.46222
16.6964 ± 4.4855
41	11.5454
41	11.9891
41	11.9796
41	12.1333
14.9529 ± 4.50701
41	11.7446
41	12.2933
41	12.2864
41	11.5896
41	12.0204
15.2249 ± 4.56011
41	12.3699
41	11.957
15.7593 ± 4.5972
16.1011 ± 4.55866
41	11.9199
41	12.2333
41	11.6525
41	12.2833
15.496 ± 4.51167
14.9995 ± 4.51723
16.6361 ± 4.53897
41	11.951
41	11.8766
17.1957 ± 4.50787
41	11.9363
16.209 ± 4.62588
41	11.902
15.8646 ± 4.45526
41	11.5566
41	11.8895
41	11.6422
16.39 ± 4.45391
41	11.8961
41	13.2768
41	13.1583
41	12.0336
41	11.7679
41	11.7939
41	11.9768
41	11.74
41	11.827
15.8668 ± 4.58267
41	11.8736
41	11.846
15.6346 ± 4.56219
15.5749 ± 4.51619
17.1993 ± 4.37514
41	11.6081
41	11.9235
16.6489 ± 4.44211
16.6037 ± 4.43023
41	11.922
15.9606 ± 4.51266
16.3009 ± 4.4922
15.5378 ± 4.45945
16.4613 ± 4.4527
41	12.2211
15.9348 ± 4.5306
16.6288 ± 4.44642
16.6304 ± 4.48804
41	12.0408
16.7156 ± 4.4295
15.874 ± 4.53725
15.7785 ± 4.4515
42	11.9254
42	12.1485
42	12.0632
42	11.7979
42	11.8739
42	12.2052
42	11.535
16.1585 ± 4.48617
42	11.9072
15.8033 ± 4.56166
42	11.7598
16.0068 ± 4.60278
42	11.6064
42	11.8107
15.9073 ± 4.47578
42	12.0145
42	12.0113
42	13.0413
15.4604 ± 4.49144
42	12.9618
15.857 ± 4.48532
16.0727 ± 4.55235
16.7386 ± 4.60583
16.2949 ± 4.41516
42	11.8768
42	11.5852
42	12.0832
15.1946 ± 4.51853
42	11.8289
16.2095 ± 4.56689
42	11.8535
42	11.6533
42	12.6379
42	12.3643
42	12.0151
42	11.9619
42	11.8065
42	11.9635
42	11.8018
42	11.7818
42	11.8721
16.1502 ± 4.49825
42	11.7273
17.2288 ± 4.36471
42	11.6158
42	11.8197
42	11.5745
15.2312 ± 4.57739
42	11.834
16.2818 ± 4.54847
16.9011 ± 4.54942
42	11.7705
16.0346 ± 4.53846
15.5603 ± 4.57577
42	11.7583
16.3656 ± 4.52629
15.7345 ± 4.57251
15.8033 ± 4.55565
16.5317 ± 4.55407
16.4361 ± 4.5478
15.5919 ± 4.47041
42	11.7222
15.9196 ± 4.51676
15.7152 ± 4.45629
15.6462 ± 4.54265
16.0435 ± 4.49041
43	12.0248
43	12.0689
16.0659 ± 4.43
43	11.8099
43	11.9553
43	11.7911
43	11.5477
43	11.5381
43	11.5237
43	11.8081
14.9447 ± 4.53175
43	11.9669
43	11.7598
43	11.8983
15.1248 ± 4.48683
43	11.57
43	11.931
15.9015 ± 4.50642
15.8713 ± 4.5588
43	11.8006
15.6049 ± 4.51968
43	12.1931
43	11.8599
43	11.8537
43	11.9275
15.1527 ± 4.50587
16.0836 ± 4.47608
43	11.9086
15.4239 ± 4.4185
15.7271 ± 4.50496
43	11.901
16.1296 ± 4.48134
16.8512 ± 4.61254
15.9034 ± 4.5932
43	11.7111
43	11.8036
43	11.7277
43	11.7173
43	11.5829
43	11.9789
43	11.8281
43	11.8162
43	12.8447
43	11.7021
43	11.6467
16.6021 ± 4.56854
15.7456 ± 4.50387
15.963 ± 4.57035
15.4156 ± 4.50324
15.4111 ± 4.41559
43	11.6197
43	11.6713
16.113 ± 4.65318
15.4547 ± 4.6674
43	11.9649
17.2807 ± 4.40806
43	11.7968
15.8143 ± 4.60106
16.5049 ± 4.45098
15.3679 ± 4.45115
16.1247 ± 4.5399
15.4591 ± 4.54487
43	11.708
43	11.6956
15.7517 ± 4.5902
15.8181 ± 4.57477
44	12.1333
44	11.5377
44	11.7923
44	11.3735
15.6119 ± 4.56106
44	11.8535
44	11.6525
15.8398 ± 4.4612
15.791 ± 4.5496
44	11.8982
44	11.8932
44	11.3024
15.5036 ± 4.44804
15.7313 ± 4.49481
44	11.9103
44	11.6964
44	11.9032
14.7813 ± 4.56529
44	11.6984
44	11.6761
44	11.9445
15.605 ± 4.62078
44	11.7449
44	11.5279
15.3532 ± 4.42549
44	11.7502
15.8965 ± 4.60232
15.9351 ± 4.557
44	11.7447
15.7066 ± 4.52843
44	11.8073
44	12.3569
44	11.9312
44	12.0723
44	11.6372
44	11.8872
15.7248 ± 4.578
44	12.0052
44	11.7971
44	11.5425
15.5194 ± 4.55143
14.9949 ± 4.47292
15.9925 ± 4.58364
15.7931 ± 4.63851
44	11.3366
15.8168 ± 4.60817
44	11.8868
16.3264 ± 4.31948
44	11.7614
15.4478 ± 4.55743
15.2806 ± 4.41235
44	12.8343
15.6506 ± 4.44228
15.6991 ± 4.59926
44	11.6586
15.4612 ± 4.52146
15.5105 ± 4.52262
44	11.7596
17.0003 ± 4.45097
15.6563 ± 4.59558
15.9848 ± 4.51125
45	11.785
45	11.7604
15.6967 ± 4.4274
45	11.6628
45	11.7971
45	11.8976
15.2972 ± 4.55243
45	11.7111
15.1346 ± 4.53851
45	11.6274
45	11.6245
15.6697 ± 4.57327
15.5647 ± 4.50053
45	12.0706
45	11.6138
45	11.5087
45	11.8745
45	11.8655
45	11.515
45	11.8483
45	11.5651
45	11.6233
45	11.7539
45	11.4671
45	11.5939
15.0139 ± 4.49865
15.2996 ± 4.53359
15.8645 ± 4.51549
16.5675 ± 4.33048
45	11.8332
14.9608 ± 4.52303
15.4018 ± 4.59379
15.4553 ± 4.55535
15.1689 ± 4.52914
45	11.7745
15.3519 ± 4.59573
15.6417 ± 4.5882
15.3764 ± 4.5575
15.5928 ± 4.60259
45	11.7253
45	11.8235
16.434 ± 4.46334
45	12.8212
15.5171 ± 4.51062
15.5481 ± 4.58159
15.9719 ± 4.61244
17.1844 ± 4.40961
46	11.4121
14.9389 ± 4.57407
46	11.64
46	11.594
46	11.5939
46	11.8682
46	12.051
15.1748 ± 4.50067
46	11.743
46	11.6011
46	12.0368
46	11.9334
15.435 ± 4.53901
46	11.7465
46	11.7598
15.3834 ± 4.64737
46	11.8219
16.7428 ± 4.351
15.8592 ± 4.45103
46	11.6041
46	11.6904
46	11.7154
15.956 ± 4.51778
46	11.7275
15.2813 ± 4.48085
15.6785 ± 4.54063
15.258 ± 4.56892
15.1538 ± 4.54036
46	11.8647
46	11.7136
46	11.6209
46	11.5905
15.2866 ± 4.54382
15.4361 ± 4.53826
15.2668 ± 4.58802
46	11.7408
46	11.8593
15.4542 ± 4.54295
46	11.3335
15.3858 ± 4.53504
15.2889 ± 4.51308
46	11.6166
46	11.7523
15.5505 ± 4.46675
15.4423 ± 4.57138
15.0092 ± 4.54884
16.3244 ± 4.42024
15.307 ± 4.62248
47	12.0948
15.5134 ± 4.4856
47	11.7797
47	11.7654
47	11.5832
47	11.5791
47	11.7679
15.4531 ± 4.49933
47	11.6041
47	12.0168
47	11.5829
15.2539 ± 4.54551
14.9763 ± 4.51364
47	11.8585
47	11.8289
47	11.8059
47	11.708
47	11.7725
15.1337 ± 4.54731
15.8089 ± 4.44622
15.6014 ± 4.57562
47	11.7496
47	12.6029
47	11.6823
47	11.8122
47	11.8846
15.0559 ± 4.50333
15.3049 ± 4.49795
47	11.951
47	11.6836
15.2807 ± 4.50202
15.3713 ± 4.5766
47	11.9284
15.4454 ± 4.59315
47	11.5715
16.8909 ± 4.49871
15.7141 ± 4.63268
15.4633 ± 4.48986
15.3678 ± 4.45183
47	11.4894
15.3103 ± 4.54222
48	11.3994
16.0704 ± 4.38164
48	11.568
48	11.5594
48	11.5061
48	11.7591
48	11.8049
48	11.9934
48	11.5405
15.9975 ± 4.33513
48	11.7523
48	11.7129
48	11.6361
48	11.4411
48	11.4671
48	11.5067
14.8854 ± 4.50354
48	11.6478
15.312 ± 4.51047
48	11.6353
15.7478 ± 4.45191
15.314 ± 4.47939
48	12.5899
15.3293 ± 4.56498
15.1314 ± 4.56722
15.3037 ± 4.61751
14.8471 ± 4.51917
15.2341 ± 4.5472
15.2485 ± 4.51702
16.6199 ± 4.51814
48	11.5987
48	11.6981
15.2351 ± 4.57096
48	11.8498
48	11.4538
15.148 ± 4.54083
15.1358 ± 4.53158
15.6058 ± 4.6468
49	12.0151
49	11.6579
49	11.5289
49	11.6073
15.4631 ± 4.46985
15.0841 ± 4.47897
49	11.4278
49	11.4178
15.0706 ± 4.51701
49	11.7647
49	11.8298
49	11.7327
49	11.7264
15.4184 ± 4.57883
49	11.6524
49	11.7577
49	11.4996
15.2073 ± 4.57261
16.082 ± 4.41044
49	11.9422
49	11.5782
49	11.6279
49	11.5829
49	11.6904
15.0581 ± 4.53295
15.309 ± 4.55567
49	12.5676
49	11.6987
15.1443 ± 4.48109
49	12.4938
15.1316 ± 4.5167
15.3058 ± 4.57568
49	11.5782
49	11.4959
49	11.7588
15.4517 ± 4.52885
15.1804 ± 4.55017
14.9869 ± 4.50347
15.3878 ± 4.45904
16.4421 ± 4.53163
15.1573 ± 4.57816
14.9448 ± 4.47343
49	11.6743
49	11.5268
15.5813 ± 4.56042
15.6502 ± 4.57133
22
40
2
3
28
5
0
16
8
9
18
14
12
13
42
33
46
39
21
19
20
10
44
23
61
25
36
27
4
62
30
31
32
56
57
35
7
37
38
58
63
41
55
43
24
45
26
53
48
47
15
6
52
49
54
50
11
34
17
59
60
51
29
1
60 sends to 60
60 receives from 60
41 sends to 41
41 receives from 41
49 sends to 47
49 receives from 53
51 sends to 6
51 receives from 61
54 sends to 54
54 receives from 54
57 sends to 34
57 receives from 34
0 sends to 22
0 receives from 6
12 sends to 12
12 receives from 12
24 sends to 61
24 receives from 44
1 sends to 40
1 receives from 63
11 sends to 14
11 receives from 56
18 sends to 21
18 receives from 10
2 sends to 2
2 receives from 2
25 sends to 25
25 receives from 25
17 sends to 39
17 receives from 58
19 sends to 19
19 receives from 19
32 sends to 32
32 receives from 32
21 sends to 10
21 receives from 18
6 sends to 0
6 receives from 51
26 sends to 36
26 receives from 46
7 sends to 16
7 receives from 36
28 sends to 4
28 receives from 4
8 sends to 8
8 receives from 8
27 sends to 27
27 receives from 27
9 sends to 9
9 receives from 9
31 sends to 31
31 receives from 31
10 sends to 18
10 receives from 21
29 sends to 62
29 receives from 62
22 sends to 44
22 receives from 0
15 sends to 33
15 receives from 50
30 sends to 30
30 receives from 30
33 sends to 56
33 receives from 15
34 sends to 57
34 receives from 57
35 sends to 35
35 receives from 35
36 sends to 7
36 receives from 26
38 sends to 38
38 receives from 38
39 sends to 58
39 receives from 17
40 sends to 63
40 receives from 1
42 sends to 55
42 receives from 14
43 sends to 43
43 receives from 43
46 sends to 26
46 receives from 16
47 sends to 53
47 receives from 49
48 sends to 48
48 receives from 48
50 sends to 15
50 receives from 55
56 sends to 11
56 receives from 33
55 sends to 50
55 receives from 42
58 sends to 17
58 receives from 39
61 sends to 51
61 receives from 24
59 sends to 59
59 receives from 59
63 sends to 1
63 receives from 40
53 sends to 49
53 receives from 47
15.5592 ± 4.57877
62 sends to 29
62 receives from 29
20 sends to 20
20 receives from 20
37 sends to 37
44 sends to 24
44 receives from 22
3 sends to 3
3 receives from 3
4 sends to 28
4 receives from 28
23 sends to 23
23 receives from 23
16 sends to 46
16 receives from 7
5 sends to 5
5 receives from 5
37 receives from 37
13 sends to 13
13 receives from 13
52 sends to 52
52 receives from 52
45 sends to 45
45 receives from 45
14 sends to 42
14 receives from 11
50	11.57
50	11.4956
50	11.4671
50	11.473
50	11.6515
50	11.5381
50	11.7021
50	11.8418
50	11.5289
50	11.568
50	11.4178
50	11.6361
50	11.6478
50	11.3882
50	11.4411
50	11.3722
50	11.4704
15.6395 ± 4.41952
50	11.6726
50	11.5377
50	11.5591
50	11.5243
50	11.3735
50	11.5558
50	11.6893
50	11.5477
50	11.4327
14.9419 ± 4.56653
50	11.4398
50	11.3366
15.4723 ± 4.42722
50	11.4206
50	11.7414
50	11.7094
50	11.5939
50	12.3999
50	11.9045
15.3647 ± 4.49789
50	11.8647
50	11.5829
50	11.6073
50	11.279
50	11.5222
50	11.3994
50	11.9662
50	11.9422
50	11.4603
50	11.8002
50	11.7577
50	11.8953
50	12.2199
50	11.3551
50	11.8242
16.5281 ± 4.35017
16.288 ± 4.27805
50	11.5946
15.0997 ± 4.51371
16.1354 ± 4.3507
16.1735 ± 4.35111
16.3325 ± 4.29325
15.1164 ± 4.54135
16.0102 ± 4.3286
15.4493 ± 4.4416
16.0109 ± 4.35719
14.9171 ± 4.49809
16.0823 ± 4.36706
15.9908 ± 4.33203
16.4618 ± 4.26828
15.294 ± 4.52773
15.4907 ± 4.52232
14.7719 ± 4.56326
50	11.6164
50	11.4115
15.6795 ± 4.46586
15.1699 ± 4.59001
15.46 ± 4.47395
15.6522 ± 4.49788
15.3893 ± 4.48066
50	11.8763
15.5047 ± 4.575
16.7997 ± 4.3714
16.3843 ± 4.33123
15.4216 ± 4.51278
51	11.4874
51	11.4053
51	11.7114
51	11.3408
51	11.4727
51	11.385
15.4775 ± 4.4748
51	11.4473
51	11.3934
51	11.3024
51	11.5295
15.2538 ± 4.47073
15.3445 ± 4.51752
51	11.8216
15.3472 ± 4.48386
51	11.8036
14.8747 ± 4.50126
14.8615 ± 4.48027
51	11.624
51	11.8114
51	11.4484
15.6742 ± 4.32762
16.0867 ± 4.44253
15.2982 ± 4.54405
51	11.3335
51	11.3478
51	11.8082
15.5664 ± 4.49425
16.1797 ± 4.38741
51	11.3938
51	11.3812
51	11.338
51	11.3146
16.2815 ± 4.32739
51	11.5556
51	11.634
51	11.6272
51	11.3456
15.2517 ± 4.48318
51	11.4894
51	11.5446
51	11.6414
15.0519 ± 4.48942
16.1419 ± 4.3956
15.2929 ± 4.58173
51	11.5377
15.2628 ± 4.56797
51	11.4628
15.4955 ± 4.44353
16.3402 ± 4.36234
16.7492 ± 4.36923
16.0779 ± 4.49351
15.3791 ± 4.62622
15.4045 ± 4.53145
15.1365 ± 4.58444
51	11.3408
15.99 ± 4.36163
52	11.4121
52	11.8015
52	11.279
14.7523 ± 4.46986
52	11.4727
52	11.3767
15.1866 ± 4.54004
14.8705 ± 4.54939
52	11.7947
14.9024 ± 4.49502
52	11.5646
15.9531 ± 4.31554
52	11.7674
16.0843 ± 4.46023
52	11.3335
52	11.3224
52	11.5767
15.2185 ± 4.50375
52	11.4022
52	11.681
52	11.798
16.1423 ± 4.47398
52	11.6601
16.5442 ± 4.48328
15.397 ± 4.49791
15.7464 ± 4.57588
16.3412 ± 4.50712
53	11.5043
53	11.4127
15.6375 ± 4.59535
53	11.3366
15.087 ± 4.56597
53	11.7847
53	11.344
14.8155 ± 4.47088
53	11.6402
53	11.5829
15.5601 ± 4.51464
53	11.3867
15.9999 ± 4.37208
53	11.279
53	11.3306
14.9224 ± 4.50156
53	11.4927
15.7922 ± 4.47295
15.4726 ± 4.38873
15.6228 ± 4.51798
53	11.3994
53	11.579
15.1432 ± 4.64921
15.0862 ± 4.58157
53	11.3662
53	11.535
53	11.5677
15.6129 ± 4.53432
53	11.5043
53	11.4873
15.5448 ± 4.5578
15.8622 ± 4.6102
15.8713 ± 4.52766
54	11.4916
14.9226 ± 4.53237
54	11.6365
15.434 ± 4.47171
54	11.3636
54	11.5619
54	11.4618
15.6131 ± 4.55775
54	11.369
54	11.4916
15.344 ± 4.59167
15.3014 ± 4.59904
14.9451 ± 4.59113
15.5074 ± 4.59074
54	11.6263
15.7685 ± 4.6364
55	11.5113
55	11.6375
55	11.6405
55	11.4202
55	11.3335
15.545 ± 4.43972
15.5476 ± 4.48769
55	11.3478
15.4457 ± 4.57798
15.1003 ± 4.58467
55	11.3664
15.1523 ± 4.56528
55	11.6478
15.1058 ± 4.61127
55	11.3335
15.3975 ± 4.55336
14.8833 ± 4.60676
55	11.5646
15.4409 ± 4.52719
56	11.3335
14.6668 ± 4.49522
56	11.5708
56	11.4121
56	11.3968
15.0583 ± 4.53898
56	11.374
56	11.4361
15.3637 ± 4.49617
56	11.3662
15.0698 ± 4.54005
14.9899 ± 4.52309
15.0251 ± 4.59888
56	11.3335
14.9626 ± 4.58981
14.8994 ± 4.56097
56	11.3306
15.0525 ± 4.58082
57	11.5925
14.9992 ± 4.53031
57	11.5666
57	11.279
57	11.4916
15.0155 ± 4.55262
14.6692 ± 4.5213
15.1335 ± 4.62065
57	11.312
57	11.5829
14.7755 ± 4.55891
57	12.0717
57	11.5619
15.14 ± 4.53274
15.2314 ± 4.5672
15.6482 ± 4.46572
58	11.279
58	11.5862
15.0327 ± 4.53386
14.723 ± 4.51035
58	11.3433
58	11.3636
58	11.3968
14.9451 ± 4.58478
14.7832 ± 4.54005
58	11.6405
14.8613 ± 4.58948
16.0529 ± 4.51555
59	11.5921
15.0474 ± 4.58542
59	11.3306
59	11.3994
59	11.3306
14.75 ± 4.52496
14.8399 ± 4.4927
14.861 ± 4.52036
0
60
2
22
37
58
21
7
19
11
10
13
51
36
3
40
5
24
52
8
20
27
9
35
14
25
12
6
28
29
30
31
1
33
38
23
62
4
34
53
45
41
42
61
44
15
46
26
48
49
50
47
17
39
54
55
56
57
43
59
32
18
16
63
0 sends to 0
0 receives from 0
20 sends to 20
20 receives from 20
15 sends to 40
15 receives from 45
30 sends to 30
30 receives from 30
48 sends to 48
48 receives from 48
58 sends to 43
58 receives from 5
12 sends to 51
12 receives from 26
24 sends to 14
24 receives from 17
11 sends to 13
11 receives from 9
18 sends to 52
18 receives from 61
2 sends to 2
2 receives from 2
25 sends to 25
25 receives from 25
17 sends to 24
17 receives from 52
3 sends to 22
3 receives from 14
13 sends to 36
13 receives from 11
19 sends to 8
19 receives from 8
32 sends to 1
32 receives from 60
14 sends to 3
14 receives from 24
23 sends to 35
23 receives from 35
6 sends to 21
6 receives from 27
7 sends to 7
7 receives from 7
28 sends to 28
28 receives from 28
8 sends to 19
8 receives from 19
27 sends to 6
27 receives from 21
31 sends to 31
31 receives from 31
10 sends to 10
10 receives from 10
22 sends to 9
22 receives from 3
45 sends to 15
45 receives from 40
47 sends to 26
47 receives from 51
51 sends to 47
51 receives from 12
53 sends to 39
53 receives from 39
52 sends to 17
52 receives from 18
50 sends to 50
50 receives from 50
54 sends to 54
54 receives from 54
55 sends to 55
55 receives from 55
61 sends to 18
61 receives from 43
57 sends to 57
57 receives from 57
62 sends to 16
62 receives from 36
63 sends to 63
63 receives from 63
60 sends to 32
60 receives from 1
34 sends to 38
34 receives from 38
36 sends to 62
36 receives from 13
38 sends to 34
38 receives from 34
40 sends to 45
40 receives from 15
41 sends to 41
41 receives from 41
43 sends to 61
43 receives from 58
29 sends to 29
29 receives from 29
46 sends to 46
46 receives from 46
59 sends to 59
59 receives from 59
37 sends to 4
37 receives from 4
33 sends to 33
33 receives from 33
16 sends to 5
16 receives from 62
5 sends to 58
5 receives from 16
35 sends to 23
35 receives from 23
21 sends to 27
21 receives from 6
49 sends to 49
49 receives from 49
56 sends to 56
56 receives from 56
44 sends to 44
44 receives from 44
42 sends to 42
42 receives from 42
9 sends to 11
9 receives from 22
1 sends to 60
1 receives from 32
26 sends to 12
26 receives from 47
39 sends to 53
39 receives from 53
4 sends to 37
4 receives from 37
60	11.4462
60	11.3306
60	11.3994
60	11.4733
60	11.3478
15.3409 ± 4.40857
60	11.279
60	11.3366
60	11.5087
60	11.4727
60	11.4653
15.966 ± 4.39697
60	11.3968
60	11.8085
60	11.4873
60	11.3408
60	11.5446
60	11.4895
60	11.4734
60	11.385
60	11.4127
60	11.279
60	11.3224
60	11.279
60	11.279
16.0985 ± 4.40088
60	11.7914
60	11.747
60	11.4836
60	11.3335
15.9889 ± 4.35912
60	11.5939
60	11.4671
60	11.3946
60	11.279
60	11.4653
60	11.6373
60	11.4127
14.9465 ± 4.58796
15.0463 ± 4.57222
15.333 ± 4.49466
16.0531 ± 4.31208
15.622 ± 4.62052
14.8854 ± 4.56081
14.9111 ± 4.5773
15.0935 ± 4.5462
15.0074 ± 4.57543
60	11.279
16.0351 ± 4.35123
15.2674 ± 4.48775
15.9603 ± 4.35582
15.3035 ± 4.60452
15.6078 ± 4.47358
15.2324 ± 4.5481
15.3638 ± 4.49868
16.2538 ± 4.32841
15.876 ± 4.32244
16.0148 ± 4.46021
61	11.3306
61	11.279
15.8729 ± 4.44606
61	11.5877
61	11.4993
15.2464 ± 4.60948
61	11.3146
61	11.3335
16.1631 ± 4.33714
15.262 ± 4.48385
16.26 ± 4.48238
62	11.279
15.2058 ± 4.51133
62	11.279
16.1738 ± 4.41758
63	11.3605
15.4033 ± 4.50161
63	11.3335
15.2375 ± 4.56575
63	11.3994
14.8617 ± 4.58669
64	12.0247
15.5438 ± 4.42056
64	11.279
14.6436 ± 4.49486
65	11.5169
15.3414 ± 4.63222
66	11.279
15.0177 ± 4.56261
67	11.279
14.8544 ± 4.58811
67	11.579
14.9951 ± 4.5412
68	11.4127
68	11.2917
68	11.3146
14.8113 ± 4.41549
68	11.4653
15.0657 ± 4.57459
68	11.456
14.793 ± 4.502
15.0285 ± 4.54981
69	11.279
14.6792 ± 4.52959
69	11.2917
14.7269 ± 4.51606
69	11.279
14.6564 ± 4.53423
13
35
2
3
19
61
6
21
12
9
11
10
34
62
14
40
16
17
18
43
20
25
22
55
58
7
26
27
23
8
30
5
52
15
63
1
36
37
38
39
49
41
56
59
47
45
46
44
48
33
50
51
24
53
54
28
42
57
4
32
60
31
0
29
49 sends to 33
49 receives from 40
48 sends to 48
48 receives from 48
51 sends to 51
51 receives from 51
53 sends to 53
53 receives from 53
52 sends to 24
52 receives from 32
50 sends to 50
50 receives from 50
54 sends to 54
54 receives from 54
55 sends to 28
55 receives from 23
58 sends to 4
58 receives from 24
61 sends to 31
61 receives from 5
57 sends to 57
57 receives from 57
59 sends to 32
59 receives from 43
62 sends to 0
62 receives from 13
63 sends to 29
63 receives from 34
60 sends to 60
60 receives from 60
16 sends to 16
16 receives from 16
8 sends to 12
8 receives from 29
27 sends to 27
27 receives from 27
10 sends to 11
10 receives from 11
29 sends to 8
29 receives from 63
22 sends to 22
22 receives from 22
20 sends to 20
20 receives from 20
34 sends to 63
34 receives from 12
35 sends to 1
35 receives from 1
30 sends to 30
30 receives from 30
37 sends to 37
37 receives from 37
36 sends to 36
36 receives from 36
39 sends to 39
39 receives from 39
40 sends to 49
40 receives from 15
42 sends to 56
42 receives from 56
44 sends to 47
44 receives from 47
43 sends to 59
43 receives from 19
41 sends to 41
41 receives from 41
47 sends to 44
47 receives from 44
0 sends to 13
0 receives from 62
12 sends to 34
12 receives from 8
24 sends to 58
24 receives from 52
11 sends to 10
11 receives from 10
18 sends to 18
18 receives from 18
2 sends to 2
2 receives from 2
25 sends to 7
25 receives from 21
17 sends to 17
17 receives from 17
3 sends to 3
3 receives from 3
13 sends to 62
13 receives from 0
19 sends to 43
19 receives from 4
32 sends to 52
32 receives from 59
21 sends to 25
21 receives from 7
14 sends to 14
14 receives from 14
23 sends to 55
23 receives from 28
7 sends to 21
7 receives from 25
28 sends to 23
28 receives from 55
33 sends to 15
33 receives from 49
15 sends to 40
15 receives from 33
45 sends to 45
45 receives from 45
46 sends to 46
46 receives from 46
56 sends to 42
56 receives from 42
31 sends to 5
31 receives from 61
1 sends to 35
1 receives from 35
38 sends to 38
38 receives from 38
4 sends to 19
4 receives from 58
26 sends to 26
26 receives from 26
6 sends to 6
6 receives from 6
9 sends to 9
9 receives from 9
5 sends to 61
5 receives from 31
70	11.279
70	11.4127
70	11.4127
70	11.3433
70	11.3306
70	11.7521
70	11.725
70	11.4671
70	11.3306
70	11.3146
15.0272 ± 4.4306
70	11.385
70	11.3456
70	11.4428
70	11.3946
70	11.279
70	11.4611
70	11.3335
70	11.3335
70	11.4022
70	11.3146
70	11.279
70	11.456
70	11.279
70	11.3306
14.8583 ± 4.49753
70	11.279
14.8744 ± 4.55703
70	11.4814
70	11.3306
70	11.3306
70	11.3478
70	11.279
15.8379 ± 4.24566
15.3988 ± 4.48344
15.9445 ± 4.3268
70	11.374
15.2437 ± 4.5323
15.3975 ± 4.49982
14.9052 ± 4.49841
70	11.279
14.9474 ± 4.57039
70	11.3335
15.3958 ± 4.5353
14.9842 ± 4.43602
15.871 ± 4.30303
14.8854 ± 4.51657
14.9951 ± 4.57493
15.4825 ± 4.50078
14.9125 ± 4.52564
15.834 ± 4.33515
15.2057 ± 4.48637
15.8462 ± 4.27967
14.7446 ± 4.52571
15.2335 ± 4.47417
71	11.279
71	11.279
71	11.3224
71	11.279
15.2254 ± 4.52765
71	11.4127
15.3071 ± 4.51418
15.9772 ± 4.29097
71	11.358
71	11.3224
71	11.279
15.3583 ± 4.46545
15.1804 ± 4.62169
15.2808 ± 4.52365
15.1167 ± 4.59006
73	11.279
15.6812 ± 4.61698
74	11.3306
14.8566 ± 4.54846
74	11.579
15.0084 ± 4.53577
74	11.312
14.702 ± 4.48413
74	11.279
14.8788 ± 4.57371
75	11.279
14.7342 ± 4.55809
75	11.279
14.8285 ± 4.56123
76	11.5509
76	11.5666
14.9718 ± 4.51439
15.0167 ± 4.54058
76	11.3335
14.6727 ± 4.49969
76	11.279
15.0018 ± 4.60219
77	11.279
77	11.279
14.6389 ± 4.49205
14.6994 ± 4.49207
78	11.4656
15.0365 ± 4.53945
0
47
54
3
32
34
13
7
40
9
10
37
12
60
50
28
16
36
41
19
59
26
22
23
24
25
38
27
15
29
30
31
4
33
53
35
17
8
5
39
49
55
42
43
14
45
46
1
48
6
61
51
52
21
44
20
56
57
58
11
18
2
62
63
0 sends to 0
0 receives from 0
12 sends to 12
12 receives from 12
24 sends to 24
24 receives from 24
1 sends to 47
1 receives from 47
11 sends to 37
11 receives from 59
18 sends to 41
18 receives from 60
2 sends to 54
2 receives from 61
25 sends to 25
25 receives from 25
17 sends to 36
17 receives from 36
3 sends to 3
3 receives from 3
13 sends to 60
13 receives from 6
19 sends to 19
19 receives from 19
4 sends to 32
4 receives from 32
32 sends to 4
32 receives from 4
21 sends to 26
21 receives from 53
5 sends to 34
5 receives from 38
14 sends to 50
14 receives from 44
23 sends to 23
23 receives from 23
6 sends to 13
6 receives from 49
26 sends to 38
26 receives from 21
7 sends to 7
7 receives from 7
16 sends to 16
16 receives from 16
28 sends to 15
28 receives from 15
8 sends to 40
8 receives from 37
27 sends to 27
27 receives from 27
9 sends to 9
9 receives from 9
31 sends to 31
31 receives from 31
10 sends to 10
10 receives from 10
29 sends to 29
29 receives from 29
22 sends to 22
22 receives from 22
20 sends to 59
20 receives from 55
15 sends to 28
15 receives from 28
30 sends to 30
30 receives from 30
49 sends to 6
49 receives from 40
56 sends to 56
56 receives from 56
58 sends to 58
58 receives from 58
61 sends to 2
61 receives from 50
40 sends to 49
40 receives from 8
44 sends to 14
44 receives from 54
55 sends to 20
55 receives from 41
57 sends to 57
57 receives from 57
59 sends to 11
59 receives from 20
62 sends to 62
62 receives from 62
63 sends to 63
63 receives from 63
60 sends to 18
60 receives from 13
33 sends to 33
33 receives from 33
34 sends to 53
34 receives from 5
36 sends to 17
36 receives from 17
38 sends to 5
38 receives from 26
39 sends to 39
39 receives from 39
42 sends to 42
42 receives from 42
43 sends to 43
43 receives from 43
46 sends to 46
46 receives from 46
41 sends to 55
41 receives from 18
47 sends to 1
47 receives from 1
48 sends to 48
48 receives from 48
53 sends to 21
53 receives from 34
52 sends to 52
52 receives from 52
50 sends to 61
50 receives from 14
54 sends to 44
54 receives from 2
37 sends to 8
37 receives from 11
45 sends to 45
45 receives from 45
51 sends to 51
51 receives from 51
35 sends to 35
35 receives from 35
80	11.279
80	11.279
80	11.279
80	11.4379
80	11.3946
80	11.3335
14.9086 ± 4.58835
80	11.279
15.7872 ± 4.35732
14.8245 ± 4.55552
80	11.4127
80	11.279
80	11.3224
80	11.279
80	11.6007
80	11.279
80	11.3306
80	11.279
15.2807 ± 4.49849
80	11.3335
80	11.423
80	11.279
80	11.3224
14.9144 ± 4.54036
14.6376 ± 4.50553
15.2973 ± 4.45107
15.8696 ± 4.29359
15.2966 ± 4.50906
15.0644 ± 4.48332
14.9141 ± 4.56969
15.9612 ± 4.32691
16.0039 ± 4.29061
14.9569 ± 4.57099
15.9784 ± 4.31124
81	11.279
81	11.369
15.8487 ± 4.38626
81	11.3664
14.9091 ± 4.49589
82	11.3335
14.8702 ± 4.55396
86	11.5509
14.9442 ± 4.53091
86	11.279
14.869 ± 4.53665
89	11.3335
14.7654 ± 4.53734
9
1
37
3
20
5
7
14
8
59
10
57
31
41
6
15
51
34
50
19
13
36
22
53
42
25
26
11
32
29
18
12
43
27
17
35
21
2
38
54
40
4
24
47
44
45
16
28
39
49
60
58
52
0
33
55
56
48
62
23
30
61
46
63
39 sends to 54
39 receives from 48
46 sends to 16
46 receives from 62
56 sends to 56
56 receives from 56
0 sends to 9
0 receives from 53
12 sends to 31
12 receives from 31
24 sends to 42
24 receives from 42
11 sends to 57
11 receives from 27
18 sends to 50
18 receives from 30
25 sends to 25
25 receives from 25
17 sends to 34
17 receives from 34
3 sends to 3
3 receives from 3
19 sends to 19
19 receives from 19
32 sends to 43
32 receives from 28
21 sends to 36
21 receives from 36
23 sends to 53
23 receives from 59
7 sends to 14
7 receives from 6
16 sends to 51
16 receives from 46
28 sends to 32
28 receives from 47
8 sends to 8
8 receives from 8
27 sends to 11
27 receives from 33
9 sends to 59
9 receives from 0
31 sends to 12
31 receives from 12
10 sends to 10
10 receives from 10
29 sends to 29
29 receives from 29
22 sends to 22
22 receives from 22
30 sends to 18
30 receives from 60
41 sends to 4
41 receives from 13
45 sends to 45
45 receives from 45
47 sends to 28
47 receives from 43
48 sends to 39
48 receives from 57
51 sends to 58
51 receives from 16
53 sends to 0
53 receives from 23
52 sends to 52
52 receives from 52
50 sends to 60
50 receives from 18
55 sends to 55
55 receives from 55
58 sends to 62
58 receives from 51
61 sends to 61
61 receives from 61
57 sends to 48
57 receives from 11
59 sends to 23
59 receives from 9
62 sends to 46
62 receives from 58
63 sends to 63
63 receives from 63
60 sends to 30
60 receives from 50
1 sends to 1
1 receives from 1
33 sends to 27
33 receives from 54
15 sends to 15
15 receives from 15
35 sends to 35
35 receives from 35
37 sends to 2
37 receives from 2
42 sends to 24
42 receives from 24
44 sends to 44
44 receives from 44
43 sends to 47
43 receives from 32
14 sends to 6
14 receives from 7
6 sends to 7
6 receives from 14
26 sends to 26
26 receives from 26
20 sends to 13
20 receives from 4
34 sends to 17
34 receives from 17
36 sends to 21
36 receives from 21
38 sends to 38
38 receives from 38
49 sends to 49
49 receives from 49
54 sends to 33
54 receives from 39
2 sends to 37
2 receives from 37
13 sends to 41
13 receives from 20
4 sends to 20
4 receives from 41
5 sends to 5
5 receives from 5
40 sends to 40
40 receives from 40
90	11.3335
90	11.279
15.2656 ± 4.52471
90	11.3946
90	11.3335
90	11.279
90	11.279
90	11.279
90	11.3306
90	11.4993
14.7433 ± 4.55464
90	11.4127
90	11.279
90	11.279
90	11.279
90	11.279
14.8067 ± 4.58239
15.1912 ± 4.49192
15.07 ± 4.49971
14.7169 ± 4.53172
90	11.3335
15.0279 ± 4.58056
15.8838 ± 4.5413
15.882 ± 4.31036
14.8678 ± 4.59069
14.734 ± 4.52026
15.065 ± 4.47938
14.8256 ± 4.58734
15.8131 ± 4.31756
91	11.279
91	11.279
16.0515 ± 4.37793
14.7701 ± 4.56909
0
5
51
10
4
17
6
46
8
39
3
43
12
13
14
15
50
30
18
19
20
23
22
37
24
25
26
57
29
28
7
2
45
33
44
27
36
52
56
54
1
41
59
11
34
32
35
48
40
49
16
61
21
53
9
55
47
31
58
42
60
38
62
63
0 sends to 0
0 receives from 0
12 sends to 12
12 receives from 12
24 sends to 24
24 receives from 24
11 sends to 43
11 receives from 43
2 sends to 51
2 receives from 31
17 sends to 30
17 receives from 5
13 sends to 13
13 receives from 13
19 sends to 19
19 receives from 19
32 sends to 45
32 receives from 45
14 sends to 14
14 receives from 14
7 sends to 46
7 receives from 30
16 sends to 50
16 receives from 50
28 sends to 29
28 receives from 29
8 sends to 8
8 receives from 8
9 sends to 39
9 receives from 54
31 sends to 2
31 receives from 57
10 sends to 3
10 receives from 3
29 sends to 28
29 receives from 28
20 sends to 20
20 receives from 20
30 sends to 7
30 receives from 17
39 sends to 54
39 receives from 9
40 sends to 1
40 receives from 48
44 sends to 34
44 receives from 34
46 sends to 35
46 receives from 7
41 sends to 41
41 receives from 41
49 sends to 49
49 receives from 49
53 sends to 53
53 receives from 53
54 sends to 9
54 receives from 39
56 sends to 47
56 receives from 38
55 sends to 55
55 receives from 55
58 sends to 58
58 receives from 58
62 sends to 62
62 receives from 62
63 sends to 63
63 receives from 63
60 sends to 60
60 receives from 60
36 sends to 36
36 receives from 36
43 sends to 11
43 receives from 11
51 sends to 61
51 receives from 2
61 sends to 38
61 receives from 51
52 sends to 21
52 receives from 37
50 sends to 16
50 receives from 16
6 sends to 6
6 receives from 6
26 sends to 26
26 receives from 26
33 sends to 33
33 receives from 33
34 sends to 44
34 receives from 44
25 sends to 25
25 receives from 25
21 sends to 23
21 receives from 52
27 sends to 57
27 receives from 35
3 sends to 10
3 receives from 10
57 sends to 31
57 receives from 27
18 sends to 18
18 receives from 18
22 sends to 22
22 receives from 22
35 sends to 27
35 receives from 46
37 sends to 52
37 receives from 23
45 sends to 32
45 receives from 32
15 sends to 15
15 receives from 15
4 sends to 4
4 receives from 4
23 sends to 37
23 receives from 21
48 sends to 40
48 receives from 47
47 sends to 48
47 receives from 56
42 sends to 59
42 receives from 59
5 sends to 17
5 receives from 1
38 sends to 56
38 receives from 61
59 sends to 42
59 receives from 42
1 sends to 5
1 receives from 40
100	11.279
100	11.279
100	11.279
100	11.279
100	11.279
15.1397 ± 4.49604
15.0686 ± 4.47351
15.0196 ± 4.45038
100	11.279
100	11.279
100	11.279
14.8514 ± 4.58546
14.8129 ± 4.56244
14.8853 ± 4.53977
15.037 ± 4.46617
15.0814 ± 4.51556
61
1
2
3
4
5
56
7
40
27
10
11
25
57
14
17
16
58
44
49
22
21
9
23
29
12
38
20
28
24
60
37
18
32
34
35
8
36
19
39
13
41
30
43
33
45
46
47
48
26
53
51
63
42
54
55
6
50
15
59
31
0
62
52
0 sends to 61
0 receives from 61
12 sends to 25
12 receives from 25
2 sends to 2
2 receives from 2
25 sends to 12
25 receives from 12
17 sends to 58
17 receives from 15
13 sends to 57
13 receives from 40
32 sends to 18
32 receives from 33
14 sends to 14
14 receives from 14
23 sends to 23
23 receives from 23
6 sends to 56
6 receives from 56
7 sends to 7
7 receives from 7
16 sends to 16
16 receives from 16
28 sends to 28
28 receives from 28
8 sends to 40
8 receives from 36
27 sends to 20
27 receives from 9
9 sends to 27
9 receives from 22
31 sends to 37
31 receives from 60
10 sends to 10
10 receives from 10
29 sends to 24
29 receives from 24
33 sends to 32
33 receives from 44
15 sends to 17
15 receives from 58
34 sends to 34
34 receives from 34
35 sends to 35
35 receives from 35
30 sends to 60
30 receives from 42
37 sends to 36
37 receives from 31
36 sends to 8
36 receives from 37
39 sends to 39
39 receives from 39
40 sends to 13
40 receives from 8
42 sends to 30
42 receives from 53
44 sends to 33
44 receives from 18
46 sends to 46
46 receives from 46
41 sends to 41
45 sends to 45
45 receives from 45
49 sends to 26
49 receives from 19
53 sends to 42
53 receives from 50
50 sends to 53
50 receives from 57
55 sends to 55
55 receives from 55
57 sends to 50
57 receives from 13
62 sends to 62
62 receives from 62
63 sends to 52
63 receives from 52
60 sends to 31
60 receives from 30
24 sends to 29
24 receives from 29
51 sends to 51
51 receives from 51
41 receives from 41
21 sends to 21
21 receives from 21
59 sends to 59
59 receives from 59
54 sends to 54
54 receives from 54
43 sends to 43
43 receives from 43
26 sends to 38
26 receives from 49
3 sends to 3
3 receives from 3
20 sends to 22
20 receives from 27
58 sends to 15
58 receives from 17
11 sends to 11
11 receives from 11
47 sends to 47
47 receives from 47
56 sends to 6
56 receives from 6
22 sends to 9
22 receives from 20
48 sends to 48
48 receives from 48
61 sends to 0
61 receives from 0
19 sends to 49
19 receives from 38
38 sends to 19
38 receives from 26
1 sends to 1
1 receives from 1
4 sends to 4
4 receives from 4
18 sends to 44
18 receives from 32
5 sends to 5
5 receives from 5
52 sends to 63
52 receives from 63
110	11.279
15.1047 ± 4.47733
110	11.279
15.1409 ± 4.50572
12
16
37
42
4
20
49
7
8
26
52
11
55
13
53
15
54
33
18
38
5
21
22
23
10
14
19
27
28
62
44
58
47
17
34
35
36
2
1
9
6
41
48
43
3
40
46
32
61
45
50
51
24
25
29
0
56
57
31
59
60
39
30
63
13 sends to 13
13 receives from 13
14 sends to 53
14 receives from 25
7 sends to 7
7 receives from 7
28 sends to 28
28 receives from 28
9 sends to 26
9 receives from 39
34 sends to 34
34 receives from 34
35 sends to 35
35 receives from 35
39 sends to 9
39 receives from 61
40 sends to 6
40 receives from 45
43 sends to 43
43 receives from 43
41 sends to 41
41 receives from 41
48 sends to 61
48 receives from 42
51 sends to 51
51 receives from 51
50 sends to 50
50 receives from 50
54 sends to 29
54 receives from 16
59 sends to 59
59 receives from 59
0 sends to 12
0 receives from 55
3 sends to 42
3 receives from 44
32 sends to 47
32 receives from 47
12 sends to 55
12 receives from 0
17 sends to 33
17 receives from 33
57 sends to 57
57 receives from 57
27 sends to 27
27 receives from 27
24 sends to 10
24 receives from 52
2 sends to 37
2 receives from 37
45 sends to 40
45 receives from 49
30 sends to 44
30 receives from 62
31 sends to 58
31 receives from 58
25 sends to 14
25 receives from 53
58 sends to 31
58 receives from 31
37 sends to 2
37 receives from 2
6 sends to 49
42 sends to 48
42 receives from 3
6 receives from 40
16 sends to 54
16 receives from 1
61 sends to 39
61 receives from 48
1 sends to 16
1 receives from 38
11 sends to 11
11 receives from 11
33 sends to 17
33 receives from 17
60 sends to 60
60 receives from 60
62 sends to 30
62 receives from 29
55 sends to 0
55 receives from 12
5 sends to 20
5 receives from 20
44 sends to 3
44 receives from 30
21 sends to 21
21 receives from 21
22 sends to 22
22 receives from 22
29 sends to 62
29 receives from 54
8 sends to 8
8 receives from 8
52 sends to 24
52 receives from 10
38 sends to 1
38 receives from 19
19 sends to 38
19 receives from 26
15 sends to 15
15 receives from 15
18 sends to 18
18 receives from 18
56 sends to 56
56 receives from 56
4 sends to 4
4 receives from 4
20 sends to 5
20 receives from 5
10 sends to 52
10 receives from 24
46 sends to 46
46 receives from 46
47 sends to 32
47 receives from 32
53 sends to 25
53 receives from 14
23 sends to 23
23 receives from 23
26 sends to 19
26 receives from 9
36 sends to 36
36 receives from 36
49 sends to 45
49 receives from 6
63 sends to 63
63 receives from 63
120	11.279
14.7409 ± 4.57351
12
31
63
3
53
19
52
58
38
25
10
4
48
13
55
15
17
16
35
0
20
39
22
23
24
46
26
45
28
29
30
37
56
33
14
6
36
1
8
21
40
54
42
43
2
27
9
11
5
49
50
59
18
34
41
7
32
57
47
51
60
61
62
44
22 sends to 22
22 receives from 22
20 sends to 20
20 receives from 20
15 sends to 15
15 receives from 15
30 sends to 30
30 receives from 30
37 sends to 1
37 receives from 31
12 sends to 48
12 receives from 0
1 sends to 31
1 receives from 37
17 sends to 16
17 receives from 16
13 sends to 13
13 receives from 13
19 sends to 0
19 receives from 5
4 sends to 53
4 receives from 11
21 sends to 39
21 receives from 39
14 sends to 55
14 receives from 34
23 sends to 23
23 receives from 23
6 sends to 52
6 receives from 35
26 sends to 26
26 receives from 26
16 sends to 17
16 receives from 17
28 sends to 28
28 receives from 28
8 sends to 38
8 receives from 38
10 sends to 10
10 receives from 10
29 sends to 29
29 receives from 29
11 sends to 4
11 receives from 47
18 sends to 35
18 receives from 52
2 sends to 63
2 receives from 44
32 sends to 56
32 receives from 56
7 sends to 58
7 receives from 55
27 sends to 45
27 receives from 45
9 sends to 25
9 receives from 46
33 sends to 33
33 receives from 33
34 sends to 14
34 receives from 53
38 sends to 8
38 receives from 8
39 sends to 21
39 receives from 21
44 sends to 2
44 receives from 63
43 sends to 43
43 receives from 43
41 sends to 54
41 receives from 54
45 sends to 27
45 receives from 27
47 sends to 11
47 receives from 58
48 sends to 5
48 receives from 12
51 sends to 59
51 receives from 59
53 sends to 34
53 receives from 4
50 sends to 50
50 receives from 50
54 sends to 41
54 receives from 41
56 sends to 32
56 receives from 32
55 sends to 7
55 receives from 14
58 sends to 47
58 receives from 7
57 sends to 57
57 receives from 57
59 sends to 51
59 receives from 51
62 sends to 62
62 receives from 62
60 sends to 60
60 receives from 60
0 sends to 12
0 receives from 19
36 sends to 36
36 receives from 36
40 sends to 40
40 receives from 40
52 sends to 18
52 receives from 6
61 sends to 61
61 receives from 61
3 sends to 3
3 receives from 3
49 sends to 49
49 receives from 49
25 sends to 46
25 receives from 9
35 sends to 6
35 receives from 18
31 sends to 37
31 receives from 1
24 sends to 24
24 receives from 24
46 sends to 9
46 receives from 25
5 sends to 19
5 receives from 48
42 sends to 42
42 receives from 42
63 sends to 44
63 receives from 2
5
36
2
3
49
55
22
25
8
4
52
11
12
13
9
15
40
41
18
46
54
21
6
23
10
16
63
60
28
37
30
31
20
35
34
39
29
53
57
47
7
17
42
43
44
45
19
50
48
14
26
1
24
51
32
0
58
38
62
59
27
61
56
33
0 sends to 5
0 receives from 55
49 sends to 14
49 receives from 4
53 sends to 51
53 receives from 37
56 sends to 58
56 receives from 62
59 sends to 59
59 receives from 59
12 sends to 12
12 receives from 12
24 sends to 10
24 receives from 52
11 sends to 11
11 receives from 11
18 sends to 18
18 receives from 18
2 sends to 2
2 receives from 2
17 sends to 41
17 receives from 41
3 sends to 3
3 receives from 3
13 sends to 13
13 receives from 13
19 sends to 46
19 receives from 46
32 sends to 20
32 receives from 54
21 sends to 21
21 receives from 21
14 sends to 9
14 receives from 49
6 sends to 22
6 receives from 22
26 sends to 63
26 receives from 50
7 sends to 25
7 receives from 40
16 sends to 40
16 receives from 25
28 sends to 28
28 receives from 28
8 sends to 8
8 receives from 8
27 sends to 60
27 receives from 60
9 sends to 4
9 receives from 14
31 sends to 31
31 receives from 31
10 sends to 52
10 receives from 24
22 sends to 6
22 receives from 6
20 sends to 54
20 receives from 32
15 sends to 15
15 receives from 15
30 sends to 30
30 receives from 30
38 sends to 57
38 receives from 57
34 sends to 34
34 receives from 34
36 sends to 29
36 receives from 1
39 sends to 47
39 receives from 35
42 sends to 42
42 receives from 42
44 sends to 44
44 receives from 44
43 sends to 43
43 receives from 43
46 sends to 19
46 receives from 19
41 sends to 17
41 receives from 17
45 sends to 45
45 receives from 45
48 sends to 48
48 receives from 48
51 sends to 1
51 receives from 53
52 sends to 24
52 receives from 10
50 sends to 26
50 receives from 47
55 sends to 0
55 receives from 5
58 sends to 62
58 receives from 56
57 sends to 38
57 receives from 38
62 sends to 56
62 receives from 58
60 sends to 27
60 receives from 27
33 sends to 35
33 receives from 63
37 sends to 53
37 receives from 29
47 sends to 50
47 receives from 39
61 sends to 61
61 receives from 61
40 sends to 7
40 receives from 16
23 sends to 23
23 receives from 23
63 sends to 33
63 receives from 26
54 sends to 32
54 receives from 20
25 sends to 16
25 receives from 7
5 sends to 55
5 receives from 0
1 sends to 36
1 receives from 51
4 sends to 49
4 receives from 9
29 sends to 37
29 receives from 36
35 sends to 39
35 receives from 33
0
1
2
18
4
5
17
14
35
9
10
47
6
31
52
23
16
15
3
19
20
27
22
49
48
25
26
21
40
28
30
44
58
33
62
53
39
37
63
34
29
41
42
7
13
45
46
11
24
55
50
51
32
36
54
60
56
57
8
59
12
61
43
38
9 sends to 9
9 receives from 9
10 sends to 10
10 receives from 10
29 sends to 28
29 receives from 40
22 sends to 22
22 receives from 22
15 sends to 23
15 receives from 17
30 sends to 30
30 receives from 30
42 sends to 42
42 receives from 42
33 sends to 33
33 receives from 33
34 sends to 62
34 receives from 39
36 sends to 39
36 receives from 53
48 sends to 24
48 receives from 24
51 sends to 51
51 receives from 51
53 sends to 36
53 receives from 35
54 sends to 54
54 receives from 54
55 sends to 60
55 receives from 49
59 sends to 59
59 receives from 59
63 sends to 38
63 receives from 38
60 sends to 12
60 receives from 55
0 sends to 0
0 receives from 0
12 sends to 6
12 receives from 60
24 sends to 48
24 receives from 48
11 sends to 47
11 receives from 47
18 sends to 3
18 receives from 3
25 sends to 25
25 receives from 25
17 sends to 15
17 receives from 6
3 sends to 18
3 receives from 18
13 sends to 31
13 receives from 44
19 sends to 19
19 receives from 19
32 sends to 58
32 receives from 52
21 sends to 27
21 receives from 27
14 sends to 52
14 receives from 7
23 sends to 49
23 receives from 15
26 sends to 26
26 receives from 26
7 sends to 14
7 receives from 43
16 sends to 16
16 receives from 16
28 sends to 40
28 receives from 29
8 sends to 35
8 receives from 58
27 sends to 21
27 receives from 21
31 sends to 44
31 receives from 13
44 sends to 13
44 receives from 31
43 sends to 7
43 receives from 62
46 sends to 46
46 receives from 46
41 sends to 41
41 receives from 41
45 sends to 45
45 receives from 45
49 sends to 55
49 receives from 23
52 sends to 32
52 receives from 14
58 sends to 8
58 receives from 32
57 sends to 57
57 receives from 57
62 sends to 43
62 receives from 34
37 sends to 37
37 receives from 37
39 sends to 34
39 receives from 36
50 sends to 50
50 receives from 50
56 sends to 56
56 receives from 56
38 sends to 63
38 receives from 63
47 sends to 11
47 receives from 11
4 sends to 4
4 receives from 4
6 sends to 17
6 receives from 12
20 sends to 20
20 receives from 20
35 sends to 53
35 receives from 8
40 sends to 29
40 receives from 28
61 sends to 61
61 receives from 61
1 sends to 1
1 receives from 1
2 sends to 2
2 receives from 2
5 sends to 5
5 receives from 5
42
26
19
2
24
5
33
7
8
44
10
43
12
13
62
40
56
54
18
3
59
21
22
34
27
17
1
4
29
41
30
15
25
6
23
35
36
37
38
39
46
53
0
11
9
45
28
47
57
32
50
51
31
61
49
55
14
48
58
63
20
52
16
60
54 sends to 49
54 receives from 17
56 sends to 14
56 receives from 16
59 sends to 63
59 receives from 20
12 sends to 12
12 receives from 12
24 sends to 27
24 receives from 4
1 sends to 26
1 receives from 26
18 sends to 18
18 receives from 18
2 sends to 19
2 receives from 3
25 sends to 17
25 receives from 32
3 sends to 2
3 receives from 19
13 sends to 13
13 receives from 13
19 sends to 3
19 receives from 2
21 sends to 21
21 receives from 21
23 sends to 34
23 receives from 34
6 sends to 33
6 receives from 33
26 sends to 1
26 receives from 1
7 sends to 7
7 receives from 7
8 sends to 8
8 receives from 8
27 sends to 4
27 receives from 24
10 sends to 10
10 receives from 10
29 sends to 41
29 receives from 28
22 sends to 22
22 receives from 22
15 sends to 40
15 receives from 31
34 sends to 23
34 receives from 23
35 sends to 35
35 receives from 35
30 sends to 30
30 receives from 30
40 sends to 46
40 receives from 15
42 sends to 0
42 receives from 0
43 sends to 11
43 receives from 11
61 sends to 52
61 receives from 53
57 sends to 48
57 receives from 48
63 sends to 60
63 receives from 59
60 sends to 20
60 receives from 63
32 sends to 25
32 receives from 49
14 sends to 62
14 receives from 56
16 sends to 56
16 receives from 62
28 sends to 29
28 receives from 46
9 sends to 44
9 receives from 44
37 sends to 37
37 receives from 37
36 sends to 36
36 receives from 36
39 sends to 39
39 receives from 39
44 sends to 9
44 receives from 9
46 sends to 28
46 receives from 40
41 sends to 53
41 receives from 29
45 sends to 45
45 receives from 45
47 sends to 47
47 receives from 47
49 sends to 32
49 receives from 54
51 sends to 51
51 receives from 51
52 sends to 31
52 receives from 61
50 sends to 50
50 receives from 50
0 sends to 42
0 receives from 42
55 sends to 55
55 receives from 55
11 sends to 43
4 sends to 24
4 receives from 27
31 sends to 15
31 receives from 52
48 sends to 57
48 receives from 57
11 receives from 43
53 sends to 61
53 receives from 41
58 sends to 58
58 receives from 58
5 sends to 5
5 receives from 5
38 sends to 38
38 receives from 38
33 sends to 6
33 receives from 6
20 sends to 59
20 receives from 60
62 sends to 16
62 receives from 14
17 sends to 54
17 receives from 25
13
1
26
45
4
3
6
40
39
51
10
11
9
28
31
15
14
17
34
41
33
21
22
12
24
25
5
54
0
29
8
44
53
56
18
49
36
37
38
19
16
2
42
43
7
20
46
47
48
35
50
23
63
32
27
55
30
57
58
59
60
61
62
52
0 sends to 13
0 receives from 28
12 sends to 9
12 receives from 23
24 sends to 24
24 receives from 24
18 sends to 34
18 receives from 34
2 sends to 26
2 receives from 41
3 sends to 45
3 receives from 5
13 sends to 28
13 receives from 0
32 sends to 53
32 receives from 53
21 sends to 21
21 receives from 21
14 sends to 31
14 receives from 16
23 sends to 12
23 receives from 51
6 sends to 6
6 receives from 6
26 sends to 5
26 receives from 2
7 sends to 40
7 receives from 44
16 sends to 14
16 receives from 40
28 sends to 0
28 receives from 13
27 sends to 54
27 receives from 54
9 sends to 51
9 receives from 12
31 sends to 44
31 receives from 14
29 sends to 29
29 receives from 29
15 sends to 15
15 receives from 15
30 sends to 8
30 receives from 56
37 sends to 37
37 receives from 37
42 sends to 42
42 receives from 42
44 sends to 7
44 receives from 31
46 sends to 46
46 receives from 46
47 sends to 47
47 receives from 47
49 sends to 35
49 receives from 35
48 sends to 48
48 receives from 48
54 sends to 27
54 receives from 27
55 sends to 55
55 receives from 55
57 sends to 57
57 receives from 57
34 sends to 18
34 receives from 18
36 sends to 36
36 receives from 36
39 sends to 19
39 receives from 8
40 sends to 16
40 receives from 7
43 sends to 43
43 receives from 43
41 sends to 2
41 receives from 19
45 sends to 20
45 receives from 3
50 sends to 50
50 receives from 50
56 sends to 30
56 receives from 33
58 sends to 58
58 receives from 58
60 sends to 60
60 receives from 60
22 sends to 22
22 receives from 22
53 sends to 32
53 receives from 32
61 sends to 61
61 receives from 61
51 sends to 23
51 receives from 9
10 sends to 10
10 receives from 10
52 sends to 63
52 receives from 63
63 sends to 52
63 receives from 52
38 sends to 38
38 receives from 38
11 sends to 11
11 receives from 11
19 sends to 41
19 receives from 39
62 sends to 62
62 receives from 62
20 sends to 33
20 receives from 45
8 sends to 39
8 receives from 30
5 sends to 3
5 receives from 26
59 sends to 59
59 receives from 59
25 sends to 25
25 receives from 25
35 sends to 49
35 receives from 49
1 sends to 1
1 receives from 1
33 sends to 56
33 receives from 20
17 sends to 17
17 receives from 17
4 sends to 4
4 receives from 4
0
1
2
16
4
6
5
38
8
9
10
20
44
58
40
50
14
37
31
48
45
21
55
23
52
25
26
43
51
29
30
18
12
33
34
35
36
28
32
57
3
56
54
15
7
22
46
47
19
49
11
27
24
53
42
39
41
17
13
62
60
61
59
63
9 sends to 9
9 receives from 9
10 sends to 10
10 receives from 10
33 sends to 33
33 receives from 33
20 sends to 45
20 receives from 11
34 sends to 34
34 receives from 34
30 sends to 30
30 receives from 30
37 sends to 28
37 receives from 17
40 sends to 3
40 receives from 14
44 sends to 7
44 receives from 12
43 sends to 15
43 receives from 27
46 sends to 46
46 receives from 46
48 sends to 19
48 receives from 19
53 sends to 53
53 receives from 53
52 sends to 24
52 receives from 24
50 sends to 11
50 receives from 15
54 sends to 42
54 receives from 42
56 sends to 41
56 receives from 41
58 sends to 13
58 receives from 13
57 sends to 17
57 receives from 39
59 sends to 62
59 receives from 62
62 sends to 59
62 receives from 59
60 sends to 60
60 receives from 60
0 sends to 0
0 receives from 0
12 sends to 44
12 receives from 32
24 sends to 52
24 receives from 52
11 sends to 20
11 receives from 50
18 sends to 31
18 receives from 31
13 sends to 58
13 receives from 58
21 sends to 21
21 receives from 21
7 sends to 38
7 receives from 44
16 sends to 14
16 receives from 3
28 sends to 51
28 receives from 37
27 sends to 43
27 receives from 51
22 sends to 55
22 receives from 45
15 sends to 50
15 receives from 43
39 sends to 57
39 receives from 55
42 sends to 54
42 receives from 54
51 sends to 27
51 receives from 28
63 sends to 63
63 receives from 63
29 sends to 29
29 receives from 29
45 sends to 22
45 receives from 20
38 sends to 32
38 receives from 7
3 sends to 16
3 receives from 40
25 sends to 25
25 receives from 25
19 sends to 48
19 receives from 48
55 sends to 39
55 receives from 22
8 sends to 8
8 receives from 8
1 sends to 1
1 receives from 1
32 sends to 12
32 receives from 38
61 sends to 61
61 receives from 61
23 sends to 23
23 receives from 23
41 sends to 56
41 receives from 56
17 sends to 37
17 receives from 57
36 sends to 36
36 receives from 36
49 sends to 49
49 receives from 49
31 sends to 18
31 receives from 18
6 sends to 5
6 receives from 5
35 sends to 35
35 receives from 35
14 sends to 40
14 receives from 16
26 sends to 26
26 receives from 26
47 sends to 47
47 receives from 47
5 sends to 6
5 receives from 6
4 sends to 4
4 receives from 4
2 sends to 2
2 receives from 2
43
45
2
3
28
23
16
7
48
9
57
11
22
13
52
15
6
17
10
19
18
21
32
46
4
26
25
27
54
51
36
31
47
63
34
35
30
40
62
39
37
41
42
24
44
55
20
5
8
49
0
29
59
53
50
12
56
1
58
14
60
38
61
33
45 sends to 55
45 receives from 1
58 sends to 58
58 receives from 58
57 sends to 1
57 receives from 10
59 sends to 14
59 receives from 52
63 sends to 33
63 receives from 33
60 sends to 60
60 receives from 60
39 sends to 39
39 receives from 39
40 sends to 37
40 receives from 37
42 sends to 42
42 receives from 42
44 sends to 44
44 receives from 44
43 sends to 24
43 receives from 0
46 sends to 20
46 receives from 23
51 sends to 29
51 receives from 29
53 sends to 53
53 receives from 53
52 sends to 59
52 receives from 14
50 sends to 0
50 receives from 54
54 sends to 50
54 receives from 28
56 sends to 56
56 receives from 56
55 sends to 12
55 receives from 45
0 sends to 43
0 receives from 50
11 sends to 11
11 receives from 11
2 sends to 2
2 receives from 2
17 sends to 17
17 receives from 17
3 sends to 3
3 receives from 3
13 sends to 13
13 receives from 13
19 sends to 19
19 receives from 19
32 sends to 47
32 receives from 22
14 sends to 52
14 receives from 59
7 sends to 7
7 receives from 7
28 sends to 54
28 receives from 4
8 sends to 48
8 receives from 48
27 sends to 27
27 receives from 27
9 sends to 9
9 receives from 9
10 sends to 57
10 receives from 18
29 sends to 51
29 receives from 51
20 sends to 18
20 receives from 46
15 sends to 15
15 receives from 15
34 sends to 34
34 receives from 34
35 sends to 35
35 receives from 35
30 sends to 36
30 receives from 36
36 sends to 30
36 receives from 30
33 sends to 63
33 receives from 63
37 sends to 40
37 receives from 40
62 sends to 61
4 sends to 28
4 receives from 24
62 receives from 38
48 sends to 8
48 receives from 8
12 sends to 22
12 receives from 55
31 sends to 31
31 receives from 31
61 sends to 38
61 receives from 62
41 sends to 41
41 receives from 41
21 sends to 21
21 receives from 21
26 sends to 25
26 receives from 25
24 sends to 4
24 receives from 43
16 sends to 6
16 receives from 6
22 sends to 32
22 receives from 12
6 sends to 16
6 receives from 16
49 sends to 49
49 receives from 49
38 sends to 62
38 receives from 61
5 sends to 23
5 receives from 47
1 sends to 45
1 receives from 57
47 sends to 5
47 receives from 32
25 sends to 26
25 receives from 26
18 sends to 10
18 receives from 20
23 sends to 46
23 receives from 5
14.6897 ± 4.54948
{0, 38, 30, 23, 25, 18, 26, 8, 16, 45, 41, 44, 24, 31, 3, 13, 35, 6, 49, 5, 12, 9, 29, 42, 7, 43, 39, 17, 48, 33, 19, 40, 36, 21, 37, 2, 20, 27, 46, 14, 15, 28, 10, 47, 22, 1, 4, 32, 11, 34};
Noooooo
14.6811 ± 4.54318
Execution time: 129.536 s
Noooooo
14.7005 ± 4.58067
Noooooo
Execution time: 129.63 s
14.6472 ± 4.52587
14.6568 ± 4.55945
14.6824 ± 4.50041
14.7033 ± 4.5293
Noooooo
Noooooo
Execution time: 129.526 s
Noooooo
14.6439 ± 4.53458
Noooooo
14.6458 ± 4.50058
14.7509 ± 4.59585
14.6584 ± 4.54859
Noooooo
Execution time: 129.61 s
Execution time: 129.591 s
14.6538 ± 4.58557
Noooooo
14.6842 ± 4.54822
Noooooo
Noooooo
Execution time: 129.645 s
Execution time: 129.631 s
14.6696 ± 4.50512
14.7491 ± 4.56167
14.72 ± 4.57454
14.6913 ± 4.53706
Noooooo
Noooooo
Execution time: 129.686 s
14.6986 ± 4.56862
Noooooo
14.7143 ± 4.55767
Noooooo
14.6812 ± 4.55076
Noooooo
Noooooo
14.8046 ± 4.61822
14.6736 ± 4.55714
14.7318 ± 4.55558
Execution time: 129.589 s
Execution time: 129.503 s
Execution time: 129.639 s
Noooooo
Noooooo
Noooooo
Execution time: 129.476 s
14.6917 ± 4.5401
14.6821 ± 4.51094
Noooooo
Noooooo
Noooooo
Execution time: 129.522 s
Execution time: 129.621 s
14.6991 ± 4.5195
14.7708 ± 4.58122
Execution time: 129.62 s
Execution time: 129.554 s
Execution time: 129.549 s
Execution time: 129.575 s
Noooooo
Noooooo
14.6923 ± 4.56958
14.7303 ± 4.5797
Execution time: 129.599 s
14.7272 ± 4.55024
Execution time: 129.687 s
Noooooo
Noooooo
14.6669 ± 4.51335
14.6723 ± 4.55158
14.7401 ± 4.54681
14.6792 ± 4.56115
Execution time: 129.59 s
Noooooo
Noooooo
Execution time: 129.583 s
14.6358 ± 4.54386
14.688 ± 4.5499
Noooooo
14.7585 ± 4.58348
14.7205 ± 4.56452
Noooooo
Noooooo
Noooooo
Execution time: 129.57 s
Execution time: 129.466 s
14.7497 ± 4.59685
Noooooo
Noooooo
Noooooo
Execution time: 129.577 s
Noooooo
Execution time: 129.611 s
Noooooo
14.695 ± 4.53701
14.6728 ± 4.48693
14.7202 ± 4.54783
14.6929 ± 4.57906
14.7238 ± 4.57657
14.6555 ± 4.50514
Execution time: 129.605 s
14.6221 ± 4.48284
Execution time: 129.542 s
Noooooo
Noooooo
Execution time: 129.553 s
14.754 ± 4.59646
Execution time: 129.537 s
14.6632 ± 4.53302
14.7493 ± 4.58042
14.7078 ± 4.56831
Noooooo
Noooooo
Noooooo
Noooooo
Noooooo
Execution time: 129.477 s
Noooooo
14.6297 ± 4.52601
14.6734 ± 4.56739
Execution time: 129.509 s
Execution time: 129.519 s
Noooooo
Noooooo
14.6758 ± 4.57403
Execution time: 129.643 s
Noooooo
14.6773 ± 4.55755
Noooooo
14.6771 ± 4.44938
14.7773 ± 4.62504
14.7179 ± 4.61941
Noooooo
14.7424 ± 4.51499
Noooooo
Execution time: 129.585 s
14.6424 ± 4.54296
14.7771 ± 4.6115
Execution time: 129.622 s
Noooooo
14.7035 ± 4.57281
14.6727 ± 4.50928
Noooooo
Noooooo
Execution time: 129.651 s
Noooooo
Execution time: 129.608 s
Execution time: 129.55 s
Noooooo
Execution time: 129.601 s
Noooooo
Noooooo
14.6671 ± 4.55881
Execution time: 129.626 s
Noooooo
Noooooo
Execution time: 129.625 s
Execution time: 129.508 s
Noooooo
Execution time: 129.637 s
Noooooo
Execution time: 129.561 s
Execution time: 129.713 s
Execution time: 129.627 s
Execution time: 129.528 s
Execution time: 129.558 s
14.719 ± 4.57104
Execution time: 129.564 s
Execution time: 129.679 s
Noooooo
Execution time: 129.632 s
Execution time: 129.56 s
Execution time: 129.646 s
Execution time: 129.598 s
fabio@fabios-iMac-Pro ~ %
C'e' qualcosa che non capisco
 ho usato questo tools per utilizzare o bloccare threads, cores
  • Supervisor.
I core dell'HT non sono core fisici, quindi molto probabilmente il programma rallenta.
Dalla struttura del programma, all'aumentare dei core il tempo di esecuzione dovrebbe rimanere uguale (perché aumenta anche la complessità computazionale di pari passo).
In realtà non è così. Tra i vari motivi che mi sono venuti in mente:
  • Non tutti i core vanno alla stessa velocità (nel senso che ci sono anche altri processi in esecuzione) e il programma deve aspettare i core più lenti.
  • I thread non sono indipendenti tra loro ma si "passano informazioni", quindi c'è da aspettarsi della latenza, soprattutto nel passare da 1 thread a più thread, ma questa differenza si nota anche per un numero maggiore di thread.
  • Probabilmente per questione di Power Limit della CPU, in single core raggiunge frequenze più elevate (almeno così credo che sia su Intel).
Sarebbe interessare vedere cosa succede su architetture con core diversificati, come M1, in cui i 4 core ad alta efficienza dovrebbero rallentare il programma e, paradossalmente, potrebbe essere vantaggioso eseguirlo solo sui 4 core ad alte prestazioni.
In teoria, all'aumentare dei thread eseguiti, il programma dovrebbe ridurre la complessità computazionale di ogni singolo thread. Non è così perché è pensato per essere eseguito in due casi: 1 core o 4 core e riducevo la complessità direttamente in fase di compilazione.
Questo significa però che su 64 thread è più probabile che il programma trova il risultato corretto, mentre su 12 thread si ferma a un risultato sub-optimale.
Vedendo i risultati qui sopra, i 14.7006 ± 4.55493 sono migliori dei risultati ottenuti su Intel con meno core. Per ottenere gli stessi risultati su meno core bisognerebbe allungare i tempi di esecuzione (e di tanto, perché più ti avvicini alla soluzione e più diventa difficile).
14 minutes ago, fabiosun said:
I primi errori si risolvono
io non capisco i risultati
16c +16t
124
32 cores senza HT
93s
32c+32t
129
Adesso spero sia chiaro perché si dice spesso che le CPU 4C/4T sono decisamente meglio delle CPU 2C/4T.😅
Bei test, in ogni caso. Istruttivi.
  • Supervisor.
E perché mai?😂
Quella CPU è un mostro. In single thread ci massacri tutti quanti. E hai 32 core fisici...
Dovrei impacchettarla, quando uscirà il nuovo Mac Pro, mi sa. Quello sì...😂
10 minutes ago, foskvs said:
E perché mai?😂
un mumendo..un mumendo....
allora i dati si leggono al contrario?
Mi sembrava di avere il core...piu' piccolo di tutti voi 🙂
  • whahahah 1
  • Supervisor.
Il tempo di esecuzione, ovviamente, più è basso, meglio è.
I numeri che vedi sopra, invece sono distanze e il programma deve calcolare la più breve. Quindi più è bassa, meglio è.
Ribadisco... se gli iMac avranno l'M1X, il Mac pro avrà l'M1XX. Lì si farà interessante. O ti ridicolizza o Apple si ridicolizza da sola e scopriamo che Ryzen è ampiamente davanti nel settore Pro/Enthusiast.
Sono d'accordo con ogni singola lettera che hai scritto.
Ora Apple vende M1 come rivoluzione e come "bomba" rispetto ad intel, ma in realtà stiamo testando i processori di fascia bassissima della sua gamma
