Asus TRX40 E Gaming - Baremetal [Help]
jasin755
in your EFi you have this
useful for?
wait OSX is on. a raid set?
if so I do not know if it is seen fine in bare metal...maybe in Proxmox linux driver help?
sorry I am a bit confused ..I see previous hang and system seems to start and stop when you should login inside it if I am not wrong
24 minutes ago, fabiosun said:
let see with this one 🙂
This EFI freeze on Apple logo:
I have tried to add -v arg and this is output:
Quote
Yes. I hear that fans on GPU change speed (same think happened in Proxmox when login screen appears). But instead login screen I got black screen on baremetal.
Edited by jasin755
useful for?
I don't know. I have downloaded some OpenCore (maybe from Github or from this forum) and it has started work with Proxmox.
Edited by jasin755
@fabiosun I tried Asus EFI again mentioned above. But I turn off verbose mod and it started working. But mouse and keyboard doesn't work (I don't know if it is completely freezed or only USBs doesn't work).
Edit: It is completely freezed. Time doesn't change.
Edited by jasin755
ok, I have some homework for you
52:972 00:064 OCABC: MMIO devirt 0xE2180000 (0x81 pages, 0x8000000000000001) skip 0
53:036 00:063 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 0
53:108 00:072 OCABC: MMIO devirt 0xE3300000 (0x100 pages, 0x8000000000000001) skip 0
53:172 00:063 OCABC: MMIO devirt 0xE8300000 (0x181 pages, 0x8000000000000001) skip 0
53:235 00:063 OCABC: MMIO devirt 0xFA500000 (0x81 pages, 0x8000000000000001) skip 0
53:299 00:064 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 0
53:363 00:063 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 0
53:581 00:218 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 0
53:646 00:064 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 0
53:710 00:064 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 0
53:774 00:064 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 0
53:838 00:063 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 0
53:902 00:063 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 0
53:966 00:064 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
54:029 00:063 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 0
54:093 00:063 OCABC: MMIO devirt 0x10000000000 (0x10400 pages, 0x8000000000000001) skip 0
54:165 00:071 OCABC: MMIO devirt 0x12CA0000000 (0x10400 pages, 0x8000000000000001) skip 0
54:228 00:063 OCABC: MMIO devirt 0x12CD0000000 (0x10400 pages, 0x8000000000000001) skip 0
54:293 00:064 OCABC: MMIO devirt 0x15970000000 (0x10400 pages, 0x8000000000000001) skip 0
convert these MMIO from ex to decimal then we insert it in your config
before try previous EFI
In General MMIO is an optimisation , system must start also with all this to 0
thanks
thanks
Heh 🙂
What hex  do you want to transfer? 0xE2180000, 0x81 or 0x8000000000000001 from first line?
Edited by jasin755
  • fabiosun featured and unfeatured this topic
