[TRX40] 3960X / Gigabyte Aorus Xtreme - Installation Issues
info
30:390 00:003 OCABC: MMIO devirt 0xEA400000 (0x181 pages, 0x8000000000000001) skip 1
now also this is fine
for slowness of booting...
now you have a working EFI to start
If it was my system I will try to see if it is possible to boot without pikera boot args, Whaevergreen kext and so on
AppleAlc is not useful for your internal Realtek audio
and , I think you have to follow some indications of others Gigabyte users
I do not like to fill my ACPI folder with SSDt , I have no wifi or BT so you could have the need to improve this config.plist
pay always attention to your MMIO data, because ie the above one  seems not present in Ploddies config..I do not why and I do not know his bios settings
however welcome in almost working TRX40 community 🙂
Edited by fabiosun
typo
Thank you ! Im still so confused why it takes so long.. sometimes i have to take off the HDMI and put it back and it shows the login screen. I've uploaded a video!
Edited by info
Verbose time is pretty fine
login time no
try to change hdmi or display port you are using
also try to disable whatever green kext
and if you have black screen
without restarting change display port and see if some ports have signal
3 minutes ago, Ploddles said:
This is really strange as 2 others use the same and boot fine. Difference is you have 3960x and we have 3970x.
Maybe Mimo is different with your processor?
You need to do an OC debug to check the values.
Yeah very strange !
How do i do that?
login time no
Sometimes I have to unplug the hdmi and replug it and it works . There is only 1 hdmi port , the other ones are display ports ( i dont have a monitor with dp)
It boots without the pikera and without Whatevergreen . Just "-v"
10 minutes ago, info said:
Yeah very strange !
How do i do that?
I think it is a cable or monitor problem..but from here I can't say more
now you have a pretty basic configured system, you can try to run some benchmark aqs Cinebench 15 and cinebench23 also luxmark3.1 give a great stress test on gpu
then..you can try to add stuff you need (wifi? ethernet kext for your Gigabyte and so on...
So I've spent all night yesterday trying to solve the unpredictable black screen that happens before the login appears but I couldn't figure out. Sometimes , I restart and it loads right away
Also, the USB shows as 3.1 but when I've done some speed tests it writes with 15mbs or something.
What i did is used @Ploddles ACPI and added those to my working config but it doesn't seem like it works as it should. Am i missing anything?
I also tried to copy the MMIO whitelist @fabiosun made for my working config and replace it in @Ploddles OC 6.3 config but I still get the same error I got initially with MACH Reboot
Any ideas?
OC.zip opencore-2020-11-14-101946.txt.zip
@infodo not panic..you not OS I mean 🙂
in my latest config you have proper MMIO list calculated for you by me reading your log
If you change bios parameter MMIO list could change (parameter like CSM/UEFI or 4G if you have)
Have you tested with another cable?
have you tested with a HDMI/DP adaptor if you do not have another Monitor to test?
Monitor I see in your video seems pretty old..
in this latest your debug all MMIO are skipped to 0
not good for future full functionality of your system (Shutdown/Sleep wake and so on)
also previous debug is weird compared from the job we did yesterday
you do not have to mix different MMIO from different motherboard or user bios config
19 hours ago, info said:
So this one works fine and it didnt crash yet! The only issue is that it takes too long to boot. I'll take a video and upload it on youtube so you can see!
from this result you have to start
Yeah the restart and shutdown doesnt work! How can i fix that?
I've tried a few but still get the same issue
How would I go about fixing the USBs? I've used the files from @Ploddles efi but they are still slow
opencore-2020-11-14-115258.txt.zip
Edited by info
which config are you using?
your debug posted is different from what we have done yesterday
check well
first you have to solve your black screen (randomly happen so I thing is not config.plist related)
then you can optimize
your ACPI could differ from mine or from other users also with the same your motherboard
So, SSDT from others have to be tuned with your system
usually you have to start with a clean system and save from it an IOREG
then skilled people could help to produce correct SSDT for your system
check well
I am using the same config but I added the ACPI from Ploddle's. I have uploaded the one i use!
I am so confused on what to do. "Me kernel panic" haha
OC.zip
I would start with a more clean config.plist and you would try to solve your problem with your monitor
then
it is more simple to do the missing optimization (if possible 😛 )
I can't help on bluetooth configuration
but you have to solve a problem and then try to solve others 🙂
so use MMIO list I have produced yesterday for you..and try to solve your monitor problem first.
How?
enabling or disabling whatevergreen kext
clearing Nvram..
only you could test
then search on bios wake on lan parameter if you have..and maybe also with this you could solve "others" problem (ask to gigabyte users here)
then
How?
clearing Nvram..
only you could test
Does the MMIO look ok on this one?
I've tried an external ssd on all USB ports and I get 500mb/s but I when i try a USB3.1 usb stick i get 10mb/s . Isn't that weird?
Wake on LAN is disabled but I cant restart or shutdown. It freezes
opencore-2020-11-14-123314.txt.zip config.plist.zip
see first skip 0 ?
yesterday it was to 1 🙂
check latest result we have yesterday
then, for shutdown and restart you should find proper combinations
I think with 1 there it could works also for you
Where do I change that ? I feel like an annoying kid asking for ice cream ! Hahaha
23 hours ago, fabiosun said:
yes because no pikera booting in there..I have thought you have Nvidia..
48:200 00:054 OCABC: MMIO devirt 0xE2100000 (0x81 pages, 0x8000000000000001) skip 0
48:237 00:036 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 0
48:273 00:036 OCABC: MMIO devirt 0xEA400000 (0x181 pages, 0x8000000000000001) skip 0
48:309 00:036 OCABC: MMIO devirt 0xFA180000 (0x81 pages, 0x8000000000000001) skip 0
48:345 00:036 OCABC: MMIO devirt 0xFA300000 (0x100 pages, 0x8000000000000001) skip 0
48:404 00:058 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 0
48:440 00:036 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 0
48:476 00:036 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 0
48:512 00:035 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 0
48:548 00:036 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 0
48:602 00:053 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 0
48:638 00:036 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 0
48:674 00:036 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 0
48:710 00:036 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
48:747 00:036 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 0
48:805 00:058 OCABC: MMIO devirt 0x1040000000 (0x10400 pages, 0x8000000000000001) skip 0
48:841 00:036 OCABC: MMIO devirt 0x6EE0000000 (0x10400 pages, 0x8000000000000001) skip 0
48:878 00:036 OCABC: MMIO devirt 0x6F10000000 (0x10400 pages, 0x8000000000000001) skip 0
48:914 00:036 OCABC: MMIO devirt 0xCDB0000000 (0x10400 pages, 0x8000000000000001) skip 0
these are your MMIO with bios you are using by now and they are different from @Ploddlesone posted in OP of other thread
My questions are:
1) same BIOS
2)CSM on or off?
check this
and latest you have posted
0xEF1 is not here
so what does it means?
you have changed something in BIOS o in your pci slot position...
and in this way it is not possible to help
sorry ;(
16 minutes ago, fabiosun said:
check this
0xEF1 is not here
sorry ;(
I've changed the graphics card slot to see if it helped. I returned it back to how it was . I haven't touched the bios. Does this look correct now?
I'm not touching anything again , really sorry I am making this more difficult!
opencore-2020-11-14-143028.txt.zip
11:312 00:001 OCABC: MMIO devirt 0xEF100000 (0x181 pages, 0x8000000000000001) skip 0
NO
please..let decide how to start your system (bios setting , and card in slot on it)
then put here a config which boots
then
we will try again 🙂
last chance for you if things will change again (for my help I mean) 🙂
NO
then
we will try again 🙂
This is how I'm going to keep it, im not touching it again I promise!
config.plist.zip
