schwarzkopf Posted March 25, 2022 Author Share Posted March 25, 2022 o provato un altra modifica si ferma ora a Link to comment Share on other sites More sharing options...
schwarzkopf Posted March 25, 2022 Author Share Posted March 25, 2022 addesso fonziona o fatto un efi da 0 con opencore 0.7.9 1 Link to comment Share on other sites More sharing options...
schwarzkopf Posted March 25, 2022 Author Share Posted March 25, 2022 fatto Link to comment Share on other sites More sharing options...
schwarzkopf Posted June 8, 2023 Author Share Posted June 8, 2023 (edited) ciao a tutti mi serve und efi per installare mac os 14 sonoma con quello mio parte man non trova ssd Edited June 8, 2023 by schwarzkopf Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted June 8, 2023 Supervisor Share Posted June 8, 2023 2 hours ago, schwarzkopf said: ciao a tutti mi serve und efi per installare mac os 14 sonoma con quello mio parte man non trova ssd prova ad usare questo boot arg pci=0x8000000 Link to comment Share on other sites More sharing options...
schwarzkopf Posted June 8, 2023 Author Share Posted June 8, 2023 non va o messo pci=0x8000000 boot arg ma non fonziona Link to comment Share on other sites More sharing options...
schwarzkopf Posted June 9, 2023 Author Share Posted June 9, 2023 (edited) o fatto un efi update il installa non parte ci poi dare una ociata pervafore DOWNLOAD EFI Edited June 9, 2023 by schwarzkopf Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 27, 2023 Author Share Posted December 27, 2023 (edited) ciao a tutti ce serve per installare macos 14.2.1 sonoma ? la mia efi non va il installa non parte da una ora sta lavorando il installa ma non parte cosa posso fare ? Edited December 27, 2023 by schwarzkopf Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 27, 2023 Author Share Posted December 27, 2023 (edited) o configurato un efi novo per macos14.2.1 sonoma il installer parte ora ma non trova la ssd e hdd cosa po essere qui la mia carpeta EFI forse qulcuno po gurdare e modficare EFI.zip Edited December 27, 2023 by schwarzkopf Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted December 27, 2023 Support Team Share Posted December 27, 2023 🫣 Non hai SSDT e nessun kext ...devi mettere anche nelle cartelle,non solo nel plist 1 Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 27, 2023 Author Share Posted December 27, 2023 o messo kext ora ma ugale non trova la ssd e hdd EFI.zip Link to comment Share on other sites More sharing options...
Perdu Posted December 28, 2023 Share Posted December 28, 2023 18 ore fa, antuneddu ha scritto: 🫣 Non hai SSDT e nessun kext ...devi mettere anche nelle cartelle,non solo nel plist leggi bene e attentamente cosa dice antuneddu in ACPI non hai niente hai solo dichiarato un sacco di roba nel plist se lo segui risolvi puoi starne certo Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 28, 2023 Author Share Posted December 28, 2023 (edited) fatto installato o presso un altro efi ma wifi e bluetooth non va cosa posso fare con oclp opencore lagcy patcher non va pc dopo installatione non parte bcm943602cs e la mia carta wifi e bluetooth qui mio efi novo EFI.zip Edited December 28, 2023 by schwarzkopf Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 28, 2023 Supervisor Share Posted December 28, 2023 9 minutes ago, schwarzkopf said: bcm943602cs e la mia carta wifi e bluetooth leggi qui non blocchi il kext come primo errore controlla bene questo link e risolvi Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 28, 2023 Author Share Posted December 28, 2023 o fatto cosi ma qando installo OCLP Opencore lagcy Patcher il pc non parte piu ci sta un altro modo per fare fonzionare wifi e bluetooht senza Opencroelagcypatcher Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 28, 2023 Supervisor Share Posted December 28, 2023 No non hai fatto cosi controlla la Sezione kernel block da te è vuota va bloccato il kext nuovo Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 28, 2023 Author Share Posted December 28, 2023 grazie o mess ora adesso parte il sistema ma wifi non funziana poi guadare tu se e tutto coretto EFI.zip Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 28, 2023 Supervisor Share Posted December 28, 2023 Controlla se sip risulta disabilitato e al boot menu reset nvram prima Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 28, 2023 Author Share Posted December 28, 2023 dove trovo sip o fatto nevram rese ma non va Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 29, 2023 Supervisor Share Posted December 29, 2023 15 hours ago, schwarzkopf said: grazie o mess ora adesso parte il sistema ma wifi non funziana poi guadare tu se e tutto coretto EFI.zip 9.27 MB · 2 downloads questa EFI ha cose di olarila che qui non supportiamo tra l'altro hai molteplici kext di rete attivi che nn ti servono se metti una EFI pulita che ti funziona e' possibile aiutarti altrimenti NO te lo stanno dicendo anche su Hackintosh - forum de forse e' meglio seguire i loro consigli che sono madrelingua per te Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 29, 2023 Author Share Posted December 29, 2023 Boungirono sto usando questa EFI ora poi gurdare tu se tutto aposto EFI.zip 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 29, 2023 Supervisor Share Posted December 29, 2023 24 minutes ago, schwarzkopf said: Boungirono sto usando questa EFI ora poi gurdare tu se tutto aposto EFI.zip 11 MB · 1 download la efi sarà anche questa ma come vedi non corrisponde a quello che dici il file .aml a destra non e' presente nella cartella ACPI e se lo fosse sarebbe un problema per questo forum che non supporta olarila Link to comment Share on other sites More sharing options...
schwarzkopf Posted December 29, 2023 Author Share Posted December 29, 2023 scusa o fatto un altro efi senza olia EFI.zip Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 29, 2023 Supervisor Share Posted December 29, 2023 1 minute ago, schwarzkopf said: scusa o fatto un altro efi senza olia EFI.zip 11 MB · 0 downloads questa EFI e' meglio sbagli l'ordine dei kext che deve essere come questo: poi se ti funziona il WIFI e non il blutooth, devi mappare bene le tue USB poi usa questo kext e togli questo bootarg AMFIPass.kext.zip amfi=0x80 (questo da togliere) il kext che hai tu e' vecchio usa questo allegato che e' l'ultimo Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 29, 2023 Supervisor Share Posted December 29, 2023 controlla bene anche tutti questi kext in blu: ordine a parte per i tre kext che ti ho detto molti non servono probabilmente (quelli doppi di rete ad esempio) Link to comment Share on other sites More sharing options...
