ASUS X299 TUF MARK 2 install macOS
schwarzkopf
rispetto alla EFI che avevamo preparato lo scorso anno questa attuale ha molte cose in piu'
iniziando da tre kext di rete
tornerei alla vecchia che usavi quando hai detto che Monterey ti era partito
e aggiornerei quella
altro al momento non mi viene in mente
o messo bios setting non va ne windows ne macos
AI Tweaker/
ASUS MultiCore Enhancement: Auto
AVX Instruction Core Ratio Negative Offset: 3
AVX-512 Instruction Core Ratio Negative Offset: 4
Advanced/CPU Configuration/
Hyper Threading [ALL]: Enabled
MSR Lock Control: Disabled
Advanced/CPU Configuration/CPU Power Management Configuration/
Enhanced Intel Speed Step Technology (EIST): Enabled
Autonomous Core C-States: Enabled
Enhanced Halt State (C1E): Enabled
CPU C6 report: Enabled
Package C-State: C6(non retention) state
Intel SpeedShift Technology: Enabled
MFC Mode Override: OS Native
Advanced/System Agent Configuration/
Intel VT for Directed I/O (VT-d): Disabled
Boot
Fast Boot: Disabled
Above 4G Decoding: Off
Boot/Compatibility Support Module/
Launch CSM: Disabled
Boot/Secure Boot/
OS Type: Other OS
1.) /AI Tweaker/
a.) ASUS MultiCore Enhancement: Auto
b.) AVX Instruction Core Ratio Negative Offset: "3"
c.) AVX-512 Instruction Core Ratio Negative Offset: "2"
d.) CPU Core Ratio: Sync All Cores
e.) CPU SVID Support: Enabled
f.) DRAM Frequency: e.g. DDR4-3200MHz
2.) /Advanced/CPU Configuration/
a.) Hyper Threading [ALL]: Enabled
b.) MSR Lock Control:Disabled
3.) /Advanced/CPU Configuration/CPU Power Management Configuration/
a.) Enhanced Intel Speed Step Technology (EIST):Enabled
b.) Autonomous Core C-States: Enabled
c.) Enhanced Halt State (C1E):Enabled
d.) CPU C6 report: Enabled
e.) Package C-State: C6(non retention) state
f.) Intel SpeedShift Technology:Enabled
g.) MFC Mode Override: OS Native
4.) /Advanced/Platform Misc Configuration/
a.) PCI Express Native Power Management: Disabled
b.) PCH DMI ASPM: Disabled
d.) ASPM: Disabled
e.) DMI Link ASPM Control: Disabled
f.) PEG - ASMP: Disabled
5.) /Advanced/System Agent Configuration/
a.) Intel VT for Directed I/O (VT-d): Disabled/Enabled
6.) /Boot/
a.) Fast Boot: Disabled
b.) Above 4G Decoding: Off (must be ON with Prime X299 Deluxe BIOS firmware 1603 and 1704 and WS X299 Sage 10G BIOS firmware 0905 in case of GPU firmware load and XHCI ACPI implementation issues. When employing WS X299 Sage 10G BIOS firmware 0905 and enabling Above 4G Decoding in the respective BIOS settings as required, "First VGA 4G Decode" must be set to "Auto", as both Windows 10 and macOS can become irresponsive with different "First VGA 4G Decode" settings.
c.) Set your specific Boot Option Priorities
7.) /Boot/Boot Configuration
a.) Boot Logo Display: Auto
b.) Boot up NumLock State: Disabled
c.) Setup Mode: Advanced
8.) /Boot/Compatibility Support Module/
a.) Launch CSM: Disabled
9.) /Boot/Secure Boot/
a.) OS Type: Other OS
Prova con  Above 4G Decoding:  ON
  • 3 weeks later...
