Driftwood Posted September 7, 2020 Share Posted September 7, 2020 (edited) 11 hours ago, iGPU said: EDIT: I cleaned up the compilations errors and added several GPRW calls that were missing (same as with MSI). Let me know how it boots. Thanks @iGPU couldn't see a great deal of difference in BS on benchmark tests. Slight improvement on Apple Compressor rendering! Big Sur BM Tests - NO XMP(Above 4G Enabled, Macpro7,1) Edited September 7, 2020 by Driftwood Link to comment Share on other sites More sharing options...
Driftwood Posted September 7, 2020 Share Posted September 7, 2020 (edited) Catalina Tests with Asrock DSDT.aml Geekbench 3 64-bit test Edited September 7, 2020 by Driftwood Link to comment Share on other sites More sharing options...
Driftwood Posted September 7, 2020 Share Posted September 7, 2020 Im definitely getting mediocre results when looking at other TRX40 / Asrock board owners (rocket88). Im going to have to fine tune things... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 7, 2020 Author Supervisor Share Posted September 7, 2020 Hi @DriftwoodI think you have some task consuming cpu cycle, it seems also your cpu benchmark is not so stable optimal results for 3970x is about 17500 on CB20 maybe you can check with monitor activity It is weird that radeonVII as a benchmark about 100 FPS (only IGPU has a more proper value for this card after patching his DSDT) Maybe a poor support in BS also Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 7, 2020 Author Supervisor Share Posted September 7, 2020 a bit off topic here Would like to advice this pretty app I have using during its beta test period. Useful for number conversion, mounting EFI, installer creation and much more.. Take a look: a mini guide here: 3 Link to comment Share on other sites More sharing options...
Pavo Posted September 7, 2020 Share Posted September 7, 2020 (edited) 10 hours ago, iGPU said: I'd already removed this when reducing the patch list down to 13 total patches. The GPU performance on C15 increased from a very low 67 to 97 FPS without Fix PAT. When I added the modified DSDT file, the GPU further increased to 140 FPS. Did you try the modified DSDT file? It should work since we use the same mobo. I derived it with Above 4G enabled, and did not check if this setting affects the DSDT file. I did not because I do not used custom DSDTs, if you can provide the exact modifications you did I can replicate them with a SSDT. I also created a ACPI delete entry to remove the ACPI error that we were getting see below in the pic. This removes the ShakTooth table that is trying to overwrite the WMI1 device that already exist in the DSDT and causes the ACPI error. Edited September 7, 2020 by Pavo 1 1 Link to comment Share on other sites More sharing options...
Ploddles Posted September 7, 2020 Share Posted September 7, 2020 I finally had a chance to test the MMIOWhitelisting, disabling the last 3/4 entries but enabling all the others. There was no difference between disabling the last 3 or 4 and the system booted fine. Shutdown and restart still work as previous. Sleep still does not work. I also calculate my Slide value, which worked out as 80, but again, this doesn't seem to affect anything. I cannot boot at all with Above 4G enabled and the debug version of OC does not show any MMIO values in the report. Attached is my DSDT file to add to the collection - Gigabyte AORUS Xtreme. DSDT.aml.zip Link to comment Share on other sites More sharing options...
Moderators iGPU Posted September 7, 2020 Moderators Share Posted September 7, 2020 (edited) 54 minutes ago, Ploddles said: I finally had a chance to test the MMIOWhitelisting, disabling the last 3/4 entries but enabling all the others. There was no difference between disabling the last 3 or 4 and the system booted fine. Shutdown and restart still work as previous. Sleep still does not work. I also calculate my Slide value, which worked out as 80, but again, this doesn't seem to affect anything. I cannot boot at all with Above 4G enabled and the debug version of OC does not show any MMIO values in the report. Attached is my DSDT file to add to the collection - Gigabyte AORUS Xtreme. DSDT.aml.zip 14.25 kB · 0 downloads I don't see anything to 'fix' on your DSDT file. Both of the GB DSDT file compile without errors and have the proper GPRW injections. I not certain that you need to use a Slide value. I don't believe any one is using; I know I am not. It is not necessary to use Above 4G; if not working ignore it. You do need to have a proper MMIO section, which is specific for your mobo. Show us the MmioWhitelist values and we can help you select the correct ones. Edited September 7, 2020 by iGPU Link to comment Share on other sites More sharing options...
Ploddles Posted September 7, 2020 Share Posted September 7, 2020 Thanks for taking a look. I have removed the Slide value now I have tested it and found it didn't change anything. I followed your method on page 7 to obtain and calculate the Whitelist, it is only the last 3 or 4 values that are different from everybody else's and following the recommendations earlier I have enabled them all except the last 4. Next thing to try is to remove all the USB devices, except the keyboard and mouse, to see if they affect Sleep. When I put it to sleep, the keyboard, mouse and monitors turn off and then the MB clicks and the BIOS output LEDs start to count up. The mouse, keyboard and monitor do not turn back on and the BIOS codes stop at 30. On a normal start/restart it counts up to AA. There is nothing in the manual about what '30' indicates and a google search wasn't fruitful. Link to comment Share on other sites More sharing options...
Driftwood Posted September 7, 2020 Share Posted September 7, 2020 (edited) @iGPU After trying the DSDT, and looking at comparable builds I am at a losss to explain your 149 fps? There must be something else you are doing or can you get down to the nitty gritty of the DSDT to find out the cause of this graphics performance in CB15? I have to O/c to 4Ghz just to get over 100fps! I really need to understand how. You are not o/c GPU's etc..?. I know u have a decent water block setup but 50% greater than most of us is really quite stunning. Edited September 7, 2020 by Driftwood Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 7, 2020 Author Supervisor Share Posted September 7, 2020 9 minutes ago, Ploddles said: Thanks for taking a look. I have removed the Slide value now I have tested it and found it didn't change anything. I followed your method on page 7 to obtain and calculate the Whitelist, it is only the last 3 or 4 values that are different from everybody else's and following the recommendations earlier I have enabled them all except the last 4. Next thing to try is to remove all the USB devices, except the keyboard and mouse, to see if they affect Sleep. When I put it to sleep, the keyboard, mouse and monitors turn off and then the MB clicks and the BIOS output LEDs start to count up. The mouse, keyboard and monitor do not turn back on and the BIOS codes stop at 30. On a normal start/restart it counts up to AA. There is nothing in the manual about what '30' indicates and a google search wasn't fruitful. code to 30 after a rewake from sleep could be fine With Asus I have had always code 30 also in windows Bad news is with gigabyte I never had a working sleep/wake cycle in my experience with x299 board 1 Link to comment Share on other sites More sharing options...
Moderators iGPU Posted September 7, 2020 Moderators Share Posted September 7, 2020 31 minutes ago, Driftwood said: @iGPU After trying the DSDT, and looking at comparable builds I am at a losss to explain your 149 fps? There must be something else you are doing or can you get down to the nitty gritty of the DSDT to find out the cause of this graphics performance in CB15? I have to O/c to 4Ghz just to get over 100fps! I really need to understand how. You are not o/c GPU's etc..?. I know u have a decent water block setup but 50% greater than most of us is really quite stunning. I've always added DevProper which some here don't like so I don't promote. But I've used before and after the custom DSDT file. I'll attach below as a plist file. To use, open in editor and copy/paste into your DevProp OC section. It is for dual Radeon VII in slots 1 & 3, which is what I recall you're using. These do inject some speed properties. I think they'll be okay with air-cooled. If it throttles or crashes during a stress test, let me know and I'll provide a less-energetic version. There are two sections for each GPU: one is for the display, the other for audio. The audio portion is simply descriptive. If anyone wishes to use for 1 Radeon VII, only use the slot-1. As far as OC, I have not. XMP is off. And none of these should much influence GPU performance. Until we trimmed the Kernel Patch list and I added the custom DSDT, my FPS were in the 60s. Now MarkLux has always been good and your values are the same as mine. So I have the feeling that your set up is just fine. (In my opinion, the tests are somewhat strange in and of themselves.) DevProp-Dual-RadeonVII.plist.zip 1 Link to comment Share on other sites More sharing options...
Ploddles Posted September 7, 2020 Share Posted September 7, 2020 Just out of interest, here is my score for a single lowly RX580. Before disabling the PAT patch it was 100.73, so that is quite a big performance boost. 2 Link to comment Share on other sites More sharing options...
Moderators iGPU Posted September 7, 2020 Moderators Share Posted September 7, 2020 (edited) On 9/7/2020 at 11:57 AM, Ploddles said: Thanks for taking a look. I have removed the Slide value now I have tested it and found it didn't change anything. I followed your method on page 7 to obtain and calculate the Whitelist, it is only the last 3 or 4 values that are different from everybody else's and following the recommendations earlier I have enabled them all except the last 4. Next thing to try is to remove all the USB devices, except the keyboard and mouse, to see if they affect Sleep. When I put it to sleep, the keyboard, mouse and monitors turn off and then the MB clicks and the BIOS output LEDs start to count up. The mouse, keyboard and monitor do not turn back on and the BIOS codes stop at 30. On a normal start/restart it counts up to AA. There is nothing in the manual about what '30' indicates and a google search wasn't fruitful. CREATING MMIOWHITELIST What I originally posted is unnecessarily cumbersome. There is no longer any need to test and re-boot after each modification. Instead, of re-doing the earlier post, I'll write an updated methodology here on how to make an MmioWhitelist (and link the original post to this one). Here are the instructions in a nutshell. First gather your debug text file, which is normally saved on the booted EFI partition. (If you're not certain how to create the debug text file, see the earlier MmioWhitelist post here.) Once you've gotten this debug text file, locate the area of interest within this file, by searching for "MMIO" as shown in the Spoiler below (an excerpt is taken from a file with a name such as "opencore-2020-08-31-150945.txt"). Excerpt from "opencore-2020-08-31-150945.txt": Spoiler Copy and paste this section, placing in a new text file for processing and future reference: Spoiler 09:203 00:002 OCABC: MMIO devirt 0xCB100000 (0x81 pages, 0x8000000000000001) skip 1 09:206 00:002 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 1 09:211 00:005 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 1 09:214 00:002 OCABC: MMIO devirt 0xE3300000 (0x100 pages, 0x8000000000000001) skip 1 09:217 00:002 OCABC: MMIO devirt 0xEF100000 (0x181 pages, 0x8000000000000001) skip 1 09:222 00:005 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1 09:225 00:002 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1 09:228 00:002 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1 09:233 00:005 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1 09:236 00:003 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1 09:239 00:002 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1 09:245 00:005 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1 09:247 00:002 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1 09:250 00:002 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0 09:256 00:005 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1 09:259 00:002 OCABC: MMIO devirt 0x4040000000 (0x10400 pages, 0x8000000000000001) skip 1 09:262 00:002 OCABC: MMIO devirt 0x6F70000000 (0x10400 pages, 0x8000000000000001) skip 0 09:267 00:005 OCABC: MMIO devirt 0x9EA0000000 (0x10400 pages, 0x8000000000000001) skip 0 09:270 00:002 OCABC: MMIO devirt 0xCDD0000000 (0x10400 pages, 0x8000000000000001) skip 0 From this, copy the hex values, creating the following list, which may be in the same, new text file. (I've color-coded for purposes of description; you do not need to do this step). Spoiler 0xCB100000 0xD71800000xE31800000xE3300000 0xEF100000 0xFEA000000xFEC00000 0xFEC10000 0xFED000000xFED40000 0xFED800000xFEDC2000 0xFEDD40000xFEE00000 0xFF000000 0x4040000000 0x6F70000000 0x9EA0000000 0xCDD0000000 These are for my MSI Creator mobo with Above 4G enabled. The red values will be used; the green will not be used (don't even bother entering them into the MmioWhitelist section). That is, the bottom 4 entries do not seem to be necessary for MmioWhitelist. ***** Clarification (5/11/21): Vit9696, the main person behind OpenCore, recommended not using the last 4 entries. However, the most up-to-date method of creating the MMIOWhitelist suggests disabling all entries in the above Spoiler that say "skip 0" and enabling all entries that say "skip 1". This is not discussed below (it is shown in the final code example), but is probably the best method of choosing whether or not to enable or disable a given entry. The color codes have been accordingly updated. ***** Next, run calculations for each red hex value, creating another set of data, shown in white (the decimal conversion of the adjacent hex values). The bottom 11 hex values are in common with all of our mobos. If you have Above 4G enabled, they'll be on the bottom; if not, there will be only 2 values above 0xEF10000 and 2 other values below 0xEF10000, namely 0xFA180000 and 0xFA300000 (shown in orange in the 4G Disabled section). So there is a bit of a pattern... the differences between our mobos seem to lay in the top 4 values if Above 4G is enabled, or, the top 2 values, if Above 4G is disabled, (shown in yellow below for the MSI Creator mobo): Spoiler 4G Enabled: 0xCB100000 34068234240xD7180000. 36086743040xE3180000 38100008960xE3300000 3811573760 0xEF100000 40108032000xFEA00000 42718986240xFEC00000 42739957760xFEC10000 42740613120xFED00000 42750443520xFED40000 42753064960xFED80000 42755686400xFEDC2000 42758389760xFEDD4000 42759127040xFEE00000 42760929280xFF000000 4278190080 0x4040000000 275951648768 4G DISabled: 0xB2100000 2987393024 0xB3180000 3004694528 0xEF100000 4010803200 0xFA180000 4195876864 0xFA300000 41974497280xFEA00000 42718986240xFEC00000 42739957760xFEC10000 42740613120xFED00000 42750443520xFED40000 42753064960xFED80000 42755686400xFEDC2000 42758389760xFEDD4000 42759127040xFEE00000 42760929280xFF000000 4278190080 0x4040000000 275951648768 These values will, in turn, be entered into the MmioWhitelist section in OC (again, these are my values; yours will be somewhat different) for each fo the 15 values. Note that all of these values will be enabled (set to "Yes"). Also note that these values are what were labelled above as "skip 1" ("skip 0" means that entry was set to "No" in MmioWhitelist). Since we've removed the bottom 4 entries, which would otherwise have been disabled (set to "No"), all values in our new MmioWhitelist will be enabled (again, set to "Yes"). Spoiler And the code will look like this (Above 4G enabled): Spoiler <key>MmioWhitelist</key> <array> <dict> <key>Address</key> <integer>3406823424</integer> <key>Comment</key> <string>MMIO devirt 0xCB100000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>3608674304</integer> <key>Comment</key> <string>MMIO devirt 0xD7180000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>3810000896</integer> <key>Comment</key> <string>MMIO devirt 0xE3180000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>3811573760</integer> <key>Comment</key> <string>MMIO devirt 0xE3300000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4010803200</integer> <key>Comment</key> <string>MMIO devirt 0xEF100000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4271898624</integer> <key>Comment</key> <string>MMIO devirt 0xFEA00000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4273995776</integer> <key>Comment</key> <string>MMIO devirt 0xFEC00000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4274061312</integer> <key>Comment</key> <string>MMIO devirt 0xFEC10000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4275044352</integer> <key>Comment</key> <string>MMIO devirt 0xFED00000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4275306496</integer> <key>Comment</key> <string>MMIO devirt 0xFED40000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4275568640</integer> <key>Comment</key> <string>MMIO devirt 0xFED80000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4275838976</integer> <key>Comment</key> <string>MMIO devirt 0xFEDC2000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4275912704</integer> <key>Comment</key> <string>MMIO devirt 0xFEDD4000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4276092928</integer> <key>Comment</key> <string>MMIO devirt 0xFEE00000</string> <key>Disabled</key> <true/> </dict> <dict> <key>Address</key> <integer>4278190080</integer> <key>Comment</key> <string>MMIO devirt 0xFF000000</string> <key>Enabled</key> <true/> </dict> <dict> <key>Address</key> <integer>275951648768</integer> <key>Comment</key> <string>MMIO devirt 0x4040000000</string> <key>Enabled</key> <true/> </dict> </array> Edited May 11, 2021 by iGPU "Clarification (5/11/21)" entry. 1 Link to comment Share on other sites More sharing options...
Driftwood Posted September 7, 2020 Share Posted September 7, 2020 (edited) @iGPU Gave it a whirl in Catalina: No real performance increase (slight decrease). Im getting 98fps avg on BS without DevProp, but will try it over on BS shortly. Here's OC debug text DevProp rip which I assume success means the DevProps were loaded ok. Edited September 7, 2020 by Driftwood Link to comment Share on other sites More sharing options...
Moderators iGPU Posted September 7, 2020 Moderators Share Posted September 7, 2020 23 minutes ago, Driftwood said: @iGPU Gave it a whirl in Catalina: No real performance increase (slight decrease). Im getting 98fps avg on BS without DevProp, but will try it over on BS shortly. Here's OC debug text DevProp rip which I assume success means the DevProps were loaded ok. Ploddles post above shows overall C15 scores about like mine and even with a single RX580 (but the RX580 won't compare as well if tested in LuxMark or using in DaVinci). 1 Link to comment Share on other sites More sharing options...
Ploddles Posted September 7, 2020 Share Posted September 7, 2020 Just a slight difference 🙂 1 1 Link to comment Share on other sites More sharing options...
Driftwood Posted September 7, 2020 Share Posted September 7, 2020 47 minutes ago, iGPU said: Ploddles post above shows overall C15 scores about like mine and even with a single RX580 (but the RX580 won't compare as well if tested in LuxMark or using in DaVinci). No its all good. Methinks I don't need any Device Properties I guess. Thanks so much for letting me try. Of course on Air, I don't wanna damage these babies! But I think you gave me a rather safe power table. I get the drift, we're all good in Metal and that's what matters. 1 Link to comment Share on other sites More sharing options...
meina222 Posted September 8, 2020 Share Posted September 8, 2020 11 hours ago, Pavo said: I did not because I do not used custom DSDTs, if you can provide the exact modifications you did I can replicate them with a SSDT. I also created a ACPI delete entry to remove the ACPI error that we were getting see below in the pic. This removes the ShakTooth table that is trying to overwrite the WMI1 device that already exist in the DSDT and causes the ACPI error. @Pavo, I also get this ACPI error. Does the above apply to all boards or just MSI Creator? Thanks. Link to comment Share on other sites More sharing options...
Moderators iGPU Posted September 8, 2020 Moderators Share Posted September 8, 2020 2 hours ago, meina222 said: @Pavo, I also get this ACPI error. Does the above apply to all boards or just MSI Creator? Thanks. It should work on all of our mobos. Code is below to copy/paste (I added to comments to show how it is derived; data are basically ascii to hex conversions). <key>Delete</key> <array> <dict> <key>All</key> <false/> <key>Comment</key> <string>Delete SHAKTOOH (hex=oemtab); hex SSDT=tablesig; 4271=0010AF (from "log show --last boot | grep ACPI")</string> <key>Enabled</key> <true/> <key>OemTableId</key> <data> U0hBS1RPT0g= </data> <key>TableLength</key> <integer>4271</integer> <key>TableSignature</key> <data> U1NEVA== </data> </dict> </array> Link to comment Share on other sites More sharing options...
ckrueger99 Posted September 8, 2020 Share Posted September 8, 2020 (edited) On 9/6/2020 at 2:49 PM, Driftwood said: HEVC Encode Test on AMD Threadripper. Adobe Media Encoder Metal Works on AMD Hackintosh - Apple's Compressor doesn't seem to be able to use Metal with AMD Hackintosh. In 5 minutes, Adobe ME Beta had finished transcoding a 10 minute long 12-bit 4444 UHD video file to a HEVC 420 10-bit mp4, in the same time Apple Compressor had barely started - clearly its not making use of Metal and is Software/CPU only. Handbrake is quicker than Compressor using CPU software encoding doing same file 20% quicker than Compressor. Compressor would have taken over an hour to complete so I stopped it! UPDATE: After much reading it appears the following:- HEVC is hardware-accelerated only in single-pass, 8-bit mode. This is reasonably fast, but not as fast as compressing media into H.264. 10-bit HEVC, which is required for HDR media, is compressed in software – and, that takes forever! If you are going to do any form of HEVC encoding, use ffmpeg or Handbrake GUI because they implemented tried and test, fast and efficient encoders developed over many years, AND they fully implement the use of the hardware where it can. @DriftwoodConsidering a professional media editor, whose primary work flow is in FCPX and, to a lessor extent, Adobe After Effects but not Premier, would the lack of HEVC hardware acceleration kill the decision to go with a TR hackintosh? Or would the same condition apply to an Intel Xeon 3175X machine? (Nearly as fast but much more expensive and using more power, but maybe without the HEVC compression problems?) Or does Apple Compressor depend on the T2, so we'd have the same problem with any brand of CPU , even a real Mac that doesn't have a T2? Edited September 8, 2020 by ckrueger99 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 8, 2020 Author Supervisor Share Posted September 8, 2020 1) Without patch 2) proxmox 3)with patch Link to comment Share on other sites More sharing options...
dtek Posted September 8, 2020 Share Posted September 8, 2020 (edited) Hey guys, I got my first computer build up and running and would love to join you guys with some testings. I got the installation screen up with EFI-v061-8e2755f-BareMetal-USB-installer-Public but stuck at [PCI configuration begin]. Any idea what the problem is? Edited September 8, 2020 by dtek Link to comment Share on other sites More sharing options...
Ploddles Posted September 8, 2020 Share Posted September 8, 2020 10 minutes ago, dtek said: Hey guys, I got my first computer build up and running and would love to join you guys with some testings. I got the installation screen up with EFI-v061-8e2755f-BareMetal-USB-installer-Public but stuck at [PCI configuration begin]. Any idea what the problem is? Try disabling Above 4G Encoding in the BIOS. Link to comment Share on other sites More sharing options...
Pavo Posted September 8, 2020 Share Posted September 8, 2020 (edited) 55 minutes ago, fabiosun said: 1) Without patch 2) proxmox 3)with patch Thought you said on discord yesterday that removing the Fix PAT effected Bare Metal in HS heavily? Edited September 8, 2020 by Pavo Link to comment Share on other sites More sharing options...
Posted by fabiosun,
Recommended by fabiosun
2 reactions
Go to this post
