7 minutes ago, Pavo said:
This is correct.
This is incorrect Min 17.x.x with a Max of 20.x.x means used if set to enabled (yes) from High Sierra to BigSur. Not Catalina
Really? I thought the range is contiguous, so that min 17.00 and max 20.99 would be as fabiosun said (HS, Mojave, Catalina and Big Sur). The only way to isolate a patch is to duplicate.
Example, this will exclude Catalina, and only be active for HS, Mojave and Big Sur (if both enabled):
one patch set to:     : min 17.00, max 18.99
duplicate patch set:  min 20.00, max 20.99.
ah maybe I have understood
I wrote Catalina (it was Big sur)
so maybe all of us are saying the same thing 🙂
for others:
17 mean high sierra
18 means mojave
19 means catalina
20 means big sur
so min 17
max 20.xx
means used if set to yes from high Sierra to Catalina (and this caused all 2/3 message down)
This is correct, I was saying that Min 17.x.x with Max 20.x.x would be applied to High Sierra, Mojave, Catalina and Big Sur. It would not stop with just Catalina. Maybe I misinterpreted what he was saying.
9 hours ago, fabiosun said:
yep but VRM and others quality hardware on it could be the difference
however not for our task
When I have set my system in Italy was available only MSI trx40 Pro 10 g with next delivery day option..It was on 4 December 2019....
My first choice was on Gigabyte designare ex (not available in that period)
Happy for my choice 🙂
@Driftwood: I like the ASRock for its cost and smaller form factor. And the fact is that your use case is probably most similar to mine. Your work on software compatibility is useful and confirms that your mobo would meet my needs.
On the other hand, as @fabiosun points out, for a few hundred more and compromise on size, the Asus yields highest possible performance. But the performance of the MSI Creator and the Gigabyte Aorus Xtreme would also be pretty similar, I believe.
So, does anyone have a view on whether getting the various elements of OC, etc to work would be any more difficult on the Asus than on your boards? @valmeida, I am particularly eager to hear from you... Thanks to all for the hard work you've done on this thread.
3 hours ago, iGPU said:
I finally found the source of the problem. It was my keyboard (here). It was triggering the panic reboots. Once the keyboard was removed, Shutdown began working well (Sleep is also working).
LOL! Its amazing the trouble we go through and all it is is something simple. I guess certain USB hardware is safe and others not. I use a Editors Keys Mac keyboard and is seen by OSX as Mac and works without problems. I guess PC keyboards may be providing the error.
Edited by Driftwood
HEVC Encode Test on AMD Threadripper.
Adobe Media Encoder Metal Works on AMD Hackintosh - Apple's Compressor doesn't seem to be able to use Metal with AMD Hackintosh.
In 5 minutes, Adobe ME Beta had finished transcoding a 10 minute long 12-bit 4444 UHD video file to a HEVC 420 10-bit mp4, in the same time Apple Compressor had barely started - clearly its not making use of Metal and is Software/CPU only.
Handbrake is quicker than Compressor using CPU software encoding doing same file 20% quicker than Compressor.
Compressor would have taken over an hour to complete so I stopped it!
UPDATE: After much reading it appears the following:-
HEVC is hardware-accelerated only in single-pass, 8-bit mode. This is reasonably fast, but not as fast as compressing media into H.264.
10-bit HEVC, which is required for HDR media, is compressed in software – and, that takes forever!
If you are going to do any form of HEVC encoding, use ffmpeg or Handbrake GUI because they implemented tried and test, fast and
efficient encoders developed over many years, AND they fully implement the use of the hardware where it can.
Edited by Driftwood
MSI Customized DSDT File
While working on the USB problem for Thunderbolt, which is now fully working on meina222's GB mobo, I did a comparison of the GB DSDT and the MSI Creator DSDT to see if there are power injection differences. There were, plus some other differences.
The basic differences were: a large section seemingly devoted to Windows (towards the end of the file; shown in Spoiler below) not at all present on GB, 10 fewer GPRW references on the MSI file, and some errors in 8 sections that would not compile (but were okay on GB).
   Scope (_SB)
        Device (WMIC)
            Mutex (MWMI, 0x00)
            Name (_HID, "PNP0C14" /* Windows Management Instrumentation Device */)  // _HID: Hardware ID
            Name (_UID, "WMIC")  // _UID: Unique ID
            Name (WMIO, 0xB9B44A98)
            Name (WQBA, Buffer (0x06CF)
                /* 0000 */  0x46, 0x4F, 0x4D, 0x42, 0x01, 0x00, 0x00, 0x00,  // FOMB....
                /* 0008 */  0xBF, 0x06, 0x00, 0x00, 0x88, 0x2B, 0x00, 0x00,  // .....+..
                /* 0010 */  0x44, 0x53, 0x00, 0x01, 0x1A, 0x7D, 0xDA, 0x54,  // DS...}.T
                /* 0018 */  0x18, 0xD1, 0x94, 0x00, 0x01, 0x06, 0x18, 0x42,  // .......B
                /* 0020 */  0x10, 0x0B, 0x10, 0x0A, 0x0B, 0x21, 0x02, 0x0B,  // .....!..
                /* 0028 */  0x83, 0x50, 0x3C, 0x18, 0x14, 0xA0, 0x45, 0x41,  // .P<...EA
                /* 0030 */  0xC8, 0x05, 0x14, 0x95, 0x02, 0x21, 0xC3, 0x02,  // .....!..
                /* 0038 */  0x14, 0x0B, 0x70, 0x2E, 0x40, 0xBA, 0x00, 0xE5,  // ..p.@...
                /* 0040 */  0x28, 0x72, 0x0C, 0x22, 0x02, 0xF7, 0xEF, 0x0F,  // (r."....
                /* 0048 */  0x31, 0x06, 0x88, 0x14, 0x40, 0x48, 0x22, 0x84,  // 1...@H".
                /* 0050 */  0x44, 0x00, 0x53, 0x21, 0x70, 0x84, 0xA0, 0x5F,  // D.S!p.._
                /* 0058 */  0x01, 0x08, 0x1D, 0x0A, 0x90, 0x29, 0xC0, 0xA0,  // .....)..
                /* 0060 */  0x00, 0xA7, 0x08, 0x22, 0x68, 0x73, 0x02, 0x32,  // ..."hs.2
                /* 0068 */  0x0D, 0x25, 0xA0, 0xC2, 0x31, 0x84, 0xD4, 0xF2,  // .%..1...
                /* 0070 */  0x1C, 0xA4, 0x1D, 0x49, 0x83, 0x88, 0x92, 0xC0,  // ...I....
                /* 0078 */  0x02, 0x47, 0x80, 0x12, 0x33, 0x02, 0x94, 0x4E,  // .G..3..N
                /* 0080 */  0x64, 0xC1, 0xB7, 0x88, 0x2C, 0xA1, 0x28, 0x9A,  // d...,.(.
                /* 0088 */  0x44, 0x94, 0x04, 0xD1, 0xFB, 0x46, 0xD0, 0x90,  // D....F..
                /* 0090 */  0xCA, 0x15, 0xE0, 0x5D, 0x80, 0xED, 0x11, 0x88,  // ...]....
                /* 0098 */  0xC0, 0xF0, 0x3C, 0xA6, 0x09, 0x10, 0x16, 0x63,  // ..<....c
                /* 00A0 */  0x89, 0x0A, 0xE1, 0x00, 0x06, 0xE3, 0x01, 0x44,  // .......D
                /* 00A8 */  0x72, 0x86, 0x89, 0x02, 0xB6, 0xD7, 0x69, 0xC8,  // r.....i.
                /* 00B0 */  0xE4, 0x18, 0xA9, 0x24, 0x38, 0xD4, 0x08, 0x3D,  // ...$8..=
                /* 00B8 */  0xCA, 0xE6, 0x05, 0xE8, 0x1E, 0xAC, 0x06, 0xE2,  // ........
                /* 00C0 */  0x91, 0x85, 0x64, 0xD2, 0x86, 0x82, 0x1A, 0xB6,  // ..d.....
                /* 00C8 */  0x27, 0x75, 0x4A, 0x9E, 0xA1, 0x25, 0x0F, 0x92,  // 'uJ..%..
                /* 00D0 */  0x10, 0x78, 0x14, 0x0C, 0x8D, 0x13, 0x94, 0x05,  // .x......
                /* 00D8 */  0xA1, 0x1D, 0xD1, 0x61, 0x12, 0xC0, 0x93, 0xF0,  // ...a....
                /* 00E0 */  0x0C, 0x8B, 0x1F, 0xB2, 0xA0, 0x4F, 0xE4, 0xAC,  // .....O..
                /* 00E8 */  0x0F, 0x98, 0x1D, 0x07, 0x7C, 0x04, 0xC0, 0xC1,  // ....|...
                /* 00F0 */  0x1A, 0x28, 0x5C, 0xC0, 0xF3, 0x39, 0x86, 0xC8,  // .(\..9..
                /* 00F8 */  0x71, 0x0F, 0x36, 0xC6, 0x51, 0x44, 0x4E, 0x50,  // q.6.QDNP
                /* 0100 */  0xE1, 0x44, 0xE4, 0x73, 0xD2, 0x12, 0x74, 0x04,  // .D.s..t.
                /* 0108 */  0x20, 0x60, 0xD1, 0x0C, 0xD6, 0x33, 0x38, 0x91,  //  `...38.
                /* 0110 */  0x3D, 0x02, 0x94, 0x0C, 0x08, 0x79, 0x14, 0x60,  // =....y.`
                /* 0118 */  0x55, 0xC0, 0xFF, 0x1F, 0xF7, 0x34, 0x4C, 0xD0,  // U....4L.
                /* 0120 */  0xBD, 0x00, 0x65, 0x02, 0x8C, 0x09, 0x70, 0x06,  // ..e...p.
                /* 0128 */  0x2D, 0x6F, 0x02, 0xC4, 0x41, 0x68, 0x1A, 0x6D,  // -o..Ah.m
                /* 0130 */  0x09, 0xB0, 0x76, 0x5B, 0xD0, 0xFC, 0x62, 0x44,  // ..v[..bD
                /* 0138 */  0x39, 0xCF, 0x48, 0x01, 0xC3, 0x44, 0x69, 0x0E,  // 9.H..Di.
                /* 0140 */  0x51, 0x58, 0x11, 0xA3, 0xC4, 0xA9, 0x19, 0x4C,  // QX.....L
                /* 0148 */  0x10, 0x0F, 0x0C, 0xD1, 0x22, 0x85, 0x65, 0x13,  // ....".e.
                /* 0150 */  0x08, 0xD2, 0xFE, 0x20, 0xC8, 0xA0, 0x71, 0xA3,  // ... ..q.
                /* 0158 */  0xF7, 0x5D, 0xE1, 0xC0, 0x8E, 0xE2, 0xE8, 0x8F,  // .]......
                /* 0160 */  0xE8, 0x28, 0xD9, 0x94, 0x0F, 0xEC, 0xC9, 0x20,  // .(.....
                /* 0168 */  0xF4, 0xB1, 0x46, 0x8D, 0x71, 0x16, 0x09, 0x1C,  // ..F.q...
                /* 0170 */  0x7F, 0xA9, 0x3A, 0x50, 0x38, 0x12, 0x3C, 0xEA,  // ..:P8.<.
                /* 0178 */  0xAC, 0xE0, 0x73, 0x81, 0x87, 0x76, 0xD0, 0x9E,  // ..s..v..
                /* 0180 */  0xE3, 0x09, 0x04, 0x79, 0x6C, 0xF0, 0x79, 0xE1,  // ...yl.y.
                /* 0188 */  0x81, 0xC0, 0x63, 0x60, 0xB7, 0x09, 0x1F, 0x01,  // ..c`....
                /* 0190 */  0x7C, 0x42, 0xC0, 0xBB, 0x06, 0xD4, 0xD5, 0xE0,  // |B......
                /* 0198 */  0xC1, 0x80, 0x0D, 0x3A, 0x1C, 0x66, 0xBC, 0x1E,  // ...:.f..
                /* 01A0 */  0x7E, 0xB8, 0x13, 0x38, 0xB9, 0x87, 0x0B, 0x7E,  // ~..8...~
                /* 01A8 */  0xD0, 0xF0, 0xE0, 0x70, 0x77, 0x88, 0x93, 0x39,  // ...pw..9
                /* 01B0 */  0xB2, 0x52, 0x05, 0x98, 0x3D, 0x1C, 0xE8, 0x18,  // .R..=...
                /* 01B8 */  0xE1, 0x93, 0x06, 0x3B, 0x03, 0x60, 0xE4, 0x0F,  // ...;.`..
                /* 01C0 */  0x02, 0x35, 0x32, 0x43, 0xFB, 0x44, 0xF1, 0xC2,  // .52C.D..
                /* 01C8 */  0x61, 0xC8, 0xE7, 0x84, 0xC3, 0x62, 0x62, 0x4F,  // a....bbO
                /* 01D0 */  0x1C, 0x74, 0x3C, 0xE0, 0xBF, 0x08, 0x3C, 0x65,  // .t<...<e
                /* 01D8 */  0x78, 0xFA, 0x9E, 0xAF, 0x4F, 0x21, 0xE0, 0xC1,  // x...O!..
                /* 01E0 */  0x38, 0x83, 0x50, 0x0F, 0x0D, 0xAF, 0x0D, 0x9E,  // 8.P.....
                /* 01E8 */  0xDF, 0x3B, 0x03, 0xFE, 0x14, 0xC2, 0xFF, 0xFF,  // .;......
                /* 01F0 */  0xA7, 0x10, 0xF0, 0xE2, 0x1D, 0x00, 0xE6, 0x38,  // .......8
                /* 01F8 */  0xE0, 0x01, 0x70, 0xF0, 0xA7, 0x88, 0xB3, 0xB3,  // ..p.....
                /* 0200 */  0xD2, 0x39, 0x21, 0x4F, 0x2A, 0x60, 0x10, 0xA6,  // .9!O*`..
                /* 0208 */  0x61, 0xEC, 0x2C, 0x28, 0x85, 0x6C, 0x2C, 0xDE,  // a.,(.l,.
                /* 0210 */  0xC3, 0xA7, 0x42, 0x80, 0x74, 0xB4, 0x38, 0x3E,  // ..B.t.8>
                /* 0218 */  0x4F, 0x11, 0x1E, 0xC1, 0xE0, 0xC7, 0x07, 0x9D,  // O.......
                /* 0220 */  0x3C, 0x3C, 0x00, 0x47, 0x26, 0x51, 0xE8, 0x41,  // <<.G&Q.A
                /* 0228 */  0xD1, 0xD3, 0x0A, 0x39, 0x80, 0x50, 0x10, 0x03,  // ...9.P..
                /* 0230 */  0x3A, 0xC3, 0x39, 0x02, 0xAD, 0xE2, 0x1C, 0x41,  // :.9....A
                /* 0238 */  0xE6, 0x70, 0x14, 0xA7, 0x99, 0xA0, 0xE8, 0x2B,  // .p.....+
                /* 0240 */  0x04, 0x9D, 0xB4, 0x2F, 0x07, 0x7C, 0x59, 0x1A,  // .../.|Y.
                /* 0248 */  0x0B, 0x01, 0xB6, 0x9A, 0xCB, 0x09, 0x0A, 0xCC,  // ........
                /* 0250 */  0xF7, 0x0F, 0x4E, 0x50, 0xD7, 0x01, 0x02, 0x64,  // ..NP...d
                /* 0258 */  0xFA, 0x2E, 0x08, 0xA0, 0x00, 0xF2, 0x89, 0xC0,  // ........
                /* 0260 */  0x57, 0x80, 0x97, 0x02, 0x36, 0x86, 0xB7, 0x00,  // W...6...
                /* 0268 */  0xA3, 0x19, 0x9D, 0x87, 0x1F, 0x2A, 0x2A, 0xEE,  // .....**.
                /* 0270 */  0x50, 0x29, 0x88, 0x87, 0xEA, 0x28, 0x43, 0x45,  // P)...(CE
                /* 0278 */  0xCF, 0xC4, 0xC7, 0x09, 0xCF, 0xA8, 0x75, 0x10,  // ......u.
                /* 0280 */  0xCD, 0xD1, 0x04, 0xAF, 0x04, 0x09, 0xFE, 0xFF,  // ........
                /* 0288 */  0x8F, 0x1F, 0x70, 0x6E, 0x02, 0x21, 0x9F, 0x42,  // ..pn.!.B
                /* 0290 */  0x3C, 0x0D, 0xC3, 0x79, 0xB2, 0x1C, 0xCE, 0x93,  // <..y....
                /* 0298 */  0xE5, 0x63, 0xF1, 0xE9, 0x03, 0x7C, 0xA7, 0x09,  // .c...|..
                /* 02A0 */  0xDC, 0x6C, 0xC1, 0x08, 0x8F, 0x89, 0x35, 0x2A,  // .l....5*
                /* 02A8 */  0x7A, 0x00, 0xF2, 0xF0, 0xF8, 0xE5, 0xC0, 0xF3,  // z.......
                /* 02B0 */  0x79, 0x42, 0x38, 0xCA, 0x47, 0x0F, 0x5F, 0x5B,  // yB8.G._[
                /* 02B8 */  0x3C, 0x9B, 0xB7, 0x04, 0xDF, 0x44, 0x3C, 0x44,  // <....D<D
                /* 02C0 */  0x9F, 0x85, 0x60, 0x4D, 0xE4, 0xA4, 0x7D, 0x5B,  // ..`M..}[
                /* 02C8 */  0x38, 0xD9, 0xA0, 0xF1, 0xC3, 0x7A, 0x98, 0x9E,  // 8....z..
                /* 02D0 */  0xD3, 0xB3, 0x10, 0x58, 0x8E, 0x15, 0xEC, 0x66,  // ...X...f
                /* 02D8 */  0xF1, 0x34, 0x84, 0xB9, 0x1C, 0xF9, 0x5C, 0x81,  // .4....\.
                /* 02E0 */  0x15, 0xBB, 0x1A, 0x1D, 0x32, 0x70, 0x61, 0xDE,  // ....2pa.
                /* 02E8 */  0x05, 0xBA, 0x60, 0xB0, 0x43, 0x06, 0x4C, 0xF1,  // ..`.C.L.
                /* 02F0 */  0x90, 0x3A, 0x64, 0x70, 0xD9, 0x14, 0x12, 0x4E,  // .:dp...N
                /* 02F8 */  0xA3, 0xA3, 0x02, 0x97, 0x7A, 0xD6, 0xA0, 0x20,  // ....z..
                /* 0300 */  0x1E, 0xA4, 0x0F, 0x19, 0xE0, 0xFF, 0xFF, 0x1F,  // ........
                /* 0308 */  0x32, 0x80, 0x45, 0x88, 0x19, 0xA1, 0x6F, 0x3A,  // 2.E...o:
                /* 0310 */  0xD6, 0x7A, 0x57, 0x22, 0x57, 0x88, 0x07, 0x15,  // .zW"W...
                /* 0318 */  0x0F, 0x09, 0xAC, 0x43, 0xF5, 0x31, 0x04, 0xF0,  // ...C.1..
                /* 0320 */  0x3D, 0x12, 0x1F, 0x43, 0x80, 0xEB, 0xFF, 0xFF,  // =..C....
                /* 0328 */  0x18, 0x02, 0x3C, 0x87, 0xE9, 0x63, 0x08, 0x78,  // ..<..c.x
                /* 0330 */  0x2E, 0x1D, 0xEC, 0x18, 0x02, 0x3B, 0xDC, 0x19,  // .....;..
                /* 0338 */  0x91, 0x86, 0x78, 0x17, 0x28, 0xC2, 0x82, 0x28,  // ..x.(..(
                /* 0340 */  0x8C, 0xCF, 0x88, 0x80, 0xA3, 0xF3, 0x18, 0xFE,  // ........
                /* 0348 */  0x8C, 0x08, 0xF3, 0x38, 0xC6, 0x06, 0x7C, 0xC6,  // ...8..|.
                /* 0350 */  0xC1, 0x70, 0x47, 0x44, 0xD8, 0x97, 0xC2, 0xF7,  // .pGD....
                /* 0358 */  0xC2, 0x47, 0xC4, 0x23, 0x7C, 0x77, 0xB3, 0x36,  // .G.#|w.6
                /* 0360 */  0x04, 0x5D, 0x0D, 0x83, 0xC4, 0x89, 0xF0, 0x66,  // .].....f
                /* 0368 */  0xF8, 0x88, 0x68, 0xB8, 0x77, 0xB8, 0x47, 0x44,  // ..h.w.GD
                /* 0370 */  0x63, 0x04, 0x0C, 0x73, 0x34, 0xFF, 0xFF, 0x28,  // c..s4..(
                /* 0378 */  0x4F, 0x87, 0x41, 0x22, 0xFB, 0xA2, 0xF8, 0x7C,  // O.A"...|
                /* 0380 */  0x18, 0xE1, 0x75, 0xD1, 0x38, 0x0F, 0x85, 0x21,  // ..u.8..!
                /* 0388 */  0x1E, 0x11, 0x01, 0x3E, 0x9E, 0x19, 0xD8, 0x95,  // ...>....
                /* 0390 */  0x01, 0x7B, 0x44, 0x04, 0x06, 0xFF, 0xFF, 0x23,  // .{D....#
                /* 0398 */  0x22, 0xF0, 0x11, 0x74, 0x44, 0xA4, 0x21, 0x8F,  // "..tD.!.
                /* 03A0 */  0x88, 0xA8, 0x61, 0x58, 0xC6, 0x11, 0x11, 0x35,  // ..aX...5
                /* 03A8 */  0x45, 0x38, 0x27, 0x44, 0x80, 0x77, 0xFF, 0xFF,  // E8'D.w..
                /* 03B0 */  0xB3, 0x14, 0xF0, 0x0E, 0x75, 0x96, 0x02, 0x6A,  // ....u..j
                /* 03B8 */  0x90, 0x16, 0x79, 0x42, 0x04, 0xE1, 0x59, 0x08,  // ..yB..Y.
                /* 03C0 */  0x96, 0xD0, 0x03, 0x22, 0xEA, 0x08, 0xE0, 0x28,  // ..."...(
                /* 03C8 */  0x07, 0x44, 0xD4, 0x11, 0x03, 0xCE, 0xF9, 0x10,  // .D......
                /* 03D0 */  0xF0, 0xF5, 0xFF, 0x3F, 0x1F, 0x02, 0x3C, 0x3E,  // ...?..<>
                /* 03D8 */  0x84, 0x80, 0xF7, 0xFF, 0x7F, 0x08, 0x01, 0x87,  // ........
                /* 03E0 */  0x84, 0x43, 0x08, 0xA8, 0xCE, 0x87, 0x98, 0x43,  // .C.....C
                /* 03E8 */  0x08, 0xAC, 0xB0, 0x3E, 0x46, 0xC0, 0x62, 0x3C,  // ...>F.b<
                /* 03F0 */  0x0B, 0x14, 0x63, 0x3D, 0x14, 0xC6, 0xC7, 0x43,  // ..c=...C
                /* 03F8 */  0xC0, 0xD1, 0xE1, 0x0C, 0x77, 0x3C, 0x84, 0x7D,  // ....w<.}
                /* 0400 */  0xBC, 0xE4, 0x43, 0x39, 0xB1, 0x88, 0x11, 0x1E,  // ..C9....
                /* 0408 */  0xC6, 0xA2, 0xC5, 0x7C, 0x06, 0xF0, 0xF9, 0x10,  // ...|....
                /* 0410 */  0xF6, 0xDD, 0xF0, 0x71, 0xF0, 0x05, 0x22, 0xC6,  // ...q..".
                /* 0418 */  0xB3, 0xE1, 0xC3, 0xA1, 0xCF, 0x84, 0xEF, 0x85,  // ........
                /* 0420 */  0xE7, 0x11, 0xE5, 0xB9, 0xF0, 0xF9, 0x90, 0x1D,  // ........
                /* 0428 */  0xE0, 0xCE, 0x21, 0x8A, 0x41, 0x22, 0x1D, 0x43,  // ..!.A".C
                /* 0430 */  0xD4, 0x28, 0xCF, 0x8A, 0x61, 0xC3, 0xBC, 0x0D,  // .(..a...
                /* 0438 */  0x86, 0x0B, 0x11, 0x29, 0x42, 0xE4, 0x88, 0x0F,  // ...)B...
                /* 0440 */  0x89, 0x61, 0x9E, 0x0F, 0xC1, 0xF4, 0xFF, 0x3F,  // .a.....?
                /* 0448 */  0x1F, 0xE2, 0x5F, 0x18, 0x3E, 0x1F, 0x02, 0x1C,  // .._.>...
                /* 0450 */  0x39, 0x74, 0xE0, 0xCE, 0x87, 0x60, 0xB8, 0xAA,  // 9t...`..
                /* 0458 */  0xB3, 0x3B, 0x03, 0x8C, 0x03, 0x22, 0x60, 0xE0,  // .;..."`.
                /* 0460 */  0xFF, 0x7F, 0x40, 0xC4, 0x8B, 0x5B, 0xB7, 0x0E,  // ..@..[..
                /* 0468 */  0x2B, 0x56, 0x7C, 0xDC, 0x42, 0x67, 0x79, 0x01,  // +V|.Bgy.
                /* 0470 */  0x08, 0xFA, 0xE8, 0x0E, 0xC7, 0x03, 0x3E, 0x45,  // ......>E
                /* 0478 */  0x18, 0xEA, 0x8F, 0x5B, 0x28, 0xDD, 0x14, 0x52,  // ...[(..R
                /* 0480 */  0x7E, 0xDC, 0x42, 0x69, 0x3D, 0x6E, 0x51, 0x10,  // ~.Bi=nQ.
                /* 0488 */  0x9F, 0x1C, 0x1C, 0xE3, 0x48, 0x04, 0x65, 0x66,  // ....H.ef
                /* 0490 */  0x4F, 0x44, 0xBE, 0x15, 0xF8, 0x64, 0xE3, 0xFB,  // OD...d..
                /* 0498 */  0x16, 0x30, 0x8D, 0x30, 0x26, 0x34, 0x8C, 0xCF,  // .0.0&4..
                /* 04A0 */  0x03, 0x67, 0x74, 0x9A, 0xAF, 0x5B, 0x80, 0xE5,  // .gt..[..
                /* 04A8 */  0xFF, 0xFF, 0x75, 0x0B, 0x30, 0x18, 0xEE, 0xBA,  // ..u.0...
                /* 04B0 */  0x05, 0xD4, 0x4E, 0x00, 0xBE, 0xC0, 0xF8, 0xBA,  // ..N.....
                /* 04B8 */  0x05, 0xAE, 0x9B, 0x07, 0xE6, 0x82, 0x8F, 0x43,  // .......C
                /* 04C0 */  0x7D, 0xF9, 0xC0, 0x5F, 0x44, 0xE0, 0x9C, 0x4E,  // }.._D..N
                /* 04C8 */  0x1E, 0xA6, 0x0C, 0xF8, 0xEA, 0x02, 0xE7, 0x22,  // ......."
                /* 04D0 */  0x02, 0xAC, 0xFE, 0xFF, 0x17, 0x11, 0x80, 0xFF,  // ........
                /* 04D8 */  0xFF, 0xFF, 0x8B, 0x08, 0xF0, 0x1F, 0xA6, 0x2F,  // ......./
                /* 04E0 */  0x22, 0xE0, 0xBB, 0x79, 0xF0, 0x83, 0x08, 0x6C,  // "..y...l
                /* 04E8 */  0x82, 0xC9, 0x4E, 0xF4, 0xA8, 0x01, 0x5B, 0x01,  // ..N...[.
                /* 04F0 */  0x90, 0xC6, 0x7B, 0x48, 0xF1, 0x5E, 0xF9, 0xD8,  // ..{H.^..
                /* 04F8 */  0xB9, 0x2E, 0xC1, 0xE4, 0xC7, 0x79, 0x54, 0x66,  // .....yTf
                /* 0500 */  0x12, 0xA5, 0x3E, 0x29, 0xA0, 0x72, 0x9E, 0x14,  // ..>).r..
                /* 0508 */  0x28, 0x88, 0x01, 0x7D, 0xF5, 0x05, 0x56, 0xD7,  // (..}..V.
                /* 0510 */  0x79, 0x60, 0xFF, 0xFF, 0xBF, 0xCE, 0x03, 0xC6,  // y`......
                /* 0518 */  0xE3, 0x5C, 0xE7, 0x81, 0x9E, 0xBC, 0x3B, 0x06,  // .\....;.
                /* 0520 */  0x68, 0xAE, 0x14, 0xEC, 0x5F, 0xF1, 0x4C, 0x81,  // h..._.L.
                /* 0528 */  0x21, 0x98, 0xEE, 0x72, 0x81, 0xBA, 0xE0, 0x5A,  // !..r...Z
                /* 0530 */  0xC3, 0xE5, 0x02, 0x71, 0xDA, 0x08, 0x7D, 0x5C,  // ...q..}\
                /* 0538 */  0x6F, 0x17, 0xC0, 0xE8, 0xFF, 0x7F, 0xBB, 0x00,  // o.......
                /* 0540 */  0x78, 0x1A, 0xE8, 0x76, 0x01, 0xB4, 0xFE, 0xFF,  // x..v....
                /* 0548 */  0x07, 0x75, 0x7E, 0xA4, 0xC5, 0xDF, 0x2E, 0xE0,  // .u~.....
                /* 0550 */  0x1F, 0x2A, 0xB0, 0x67, 0x62, 0xBD, 0x9E, 0x7D,  // .*.gb..}
                /* 0558 */  0x46, 0xA7, 0x21, 0x8E, 0xE9, 0x80, 0xD6, 0xAB,  // F.!.....
                /* 0560 */  0x89, 0x4F, 0xCF, 0x9E, 0x6F, 0x44, 0x9F, 0xC7,  // .O..oD..
                /* 0568 */  0xC3, 0x3C, 0x3D, 0x1C, 0xF1, 0xDB, 0x83, 0x8F,  // .<=.....
                /* 0570 */  0xE9, 0xF0, 0xCF, 0xE6, 0x6F, 0xE5, 0x71, 0xDF,  // ....o.q.
                /* 0578 */  0xCF, 0x7D, 0x31, 0x7F, 0x38, 0x7F, 0x3D, 0xF7,  // .}1.8.=.
                /* 0580 */  0xE5, 0xDC, 0x87, 0x74, 0xA3, 0x18, 0xC6, 0x50,  // ...t...P
                /* 0588 */  0x86, 0x08, 0x18, 0x34, 0x56, 0x94, 0x23, 0x89,  // ...4V.#.
                /* 0590 */  0x69, 0x94, 0x10, 0x11, 0x5E, 0xD5, 0x8D, 0x15,  // i...^...
                /* 0598 */  0xD2, 0xD6, 0x8E, 0xE9, 0xA0, 0x8E, 0xBF, 0x54,  // .......T
                /* 05A0 */  0x1D, 0xD3, 0xE1, 0xFC, 0xFF, 0x8F, 0xE9, 0x00,  // ........
                /* 05A8 */  0x1F, 0xCE, 0x0C, 0xB8, 0x63, 0x3A, 0xFC, 0x43,  // ....c:.C
                /* 05B0 */  0x03, 0xBF, 0x33, 0xE0, 0x4F, 0xE9, 0x80, 0x8F,  // ..3.O...
                /* 05B8 */  0xC0, 0x77, 0x27, 0x1A, 0x96, 0x42, 0xF7, 0x28,  // .w'..B.(
                /* 05C0 */  0x3E, 0x2C, 0x0B, 0x02, 0xD2, 0xFF, 0x7F, 0x84,  // >,......
                /* 05C8 */  0xF0, 0x44, 0x40, 0x53, 0x08, 0xC7, 0x3F, 0x0E,  // .D@S..?.
                /* 05D0 */  0x01, 0x7D, 0x02, 0x1F, 0x87, 0x80, 0xF7, 0xE1,  // .}......
                /* 05D8 */  0xC3, 0xF7, 0x68, 0xE0, 0x76, 0x9E, 0x01, 0x0E,  // ..h.v...
                /* 05E0 */  0x0A, 0x6D, 0xFA, 0xD4, 0x68, 0xD4, 0xAA, 0x41,  // .m..h..A
                /* 05E8 */  0x99, 0x1A, 0x65, 0x1A, 0xD4, 0xEA, 0x53, 0xA9,  // ..e...S.
                /* 05F0 */  0x31, 0x63, 0xDA, 0xA0, 0x24, 0xE9, 0x80, 0x40,  // 1c..$..@
                /* 05F8 */  0x45, 0x2C, 0x49, 0x63, 0x72, 0x04, 0x10, 0xAA,  // E,Icr...
                /* 0600 */  0xEB, 0xC5, 0x22, 0x23, 0x20, 0x12, 0x09, 0x22,  // .."# .."
                /* 0608 */  0x20, 0xFF, 0xFF, 0x05, 0x7D, 0xD2, 0x04, 0x64,  //  ...}..d
                /* 0610 */  0x79, 0x20, 0x02, 0x72, 0xFE, 0xC7, 0x91, 0x80,  // y .r....
                /* 0618 */  0x2C, 0x66, 0x55, 0x02, 0x72, 0x06, 0x10, 0x01,  // ,fU.r...
                /* 0620 */  0x39, 0x10, 0x10, 0x15, 0x6F, 0x02, 0x88, 0x45,  // 9...o..E
                /* 0628 */  0x01, 0x11, 0x90, 0x83, 0xAB, 0x18, 0x0A, 0x0B,  // ........
                /* 0630 */  0xFA, 0x1E, 0x11, 0x90, 0x65, 0xDA, 0x00, 0x61,  // ....e..a
                /* 0638 */  0xC9, 0x75, 0x80, 0x32, 0x19, 0x3E, 0x80, 0x58,  // .u.2.>.X
                /* 0640 */  0x64, 0x10, 0x01, 0xF9, 0x4D, 0x60, 0x20, 0xA7,  // d...M` .
                /* 0648 */  0xA3, 0x11, 0x90, 0xA3, 0x52, 0x08, 0xC8, 0x0A,  // ....R...
                /* 0650 */  0x95, 0x00, 0x31, 0xB9, 0x20, 0x02, 0xB2, 0x34,  // ..1. ..4
                /* 0658 */  0x27, 0x40, 0x4C, 0x28, 0x88, 0x80, 0x1C, 0xEA,  // '@L(....
                /* 0660 */  0xB9, 0xA4, 0xA1, 0x38, 0x86, 0x16, 0x20, 0x26,  // ...8.. &
                /* 0668 */  0xC2, 0x0B, 0x08, 0x0B, 0xB7, 0x7A, 0x81, 0x3A,  // .....z.:
                /* 0670 */  0x29, 0x88, 0xEE, 0x83, 0xC4, 0x0C, 0x10, 0xD3,  // ).......
                /* 0678 */  0x0A, 0xA2, 0xC1, 0x92, 0xFF, 0x9D, 0x80, 0xAC,  // ........
                /* 0680 */  0x12, 0x44, 0x40, 0x56, 0xF3, 0x92, 0x10, 0x90,  // .D@V....
                /* 0688 */  0xA5, 0x81, 0x08, 0xC8, 0x79, 0x80, 0x68, 0x38,  // ....y.h8
                /* 0690 */  0x20, 0x1A, 0xC4, 0x0E, 0x10, 0x8B, 0x05, 0x22,  //  ......"
                /* 0698 */  0x20, 0xCB, 0xF6, 0x03, 0xC4, 0x32, 0x80, 0x08,  //  ....2..
                /* 06A0 */  0xC8, 0x7A, 0x0F, 0x20, 0x02, 0xB2, 0x7A, 0x10,  // .z. ..z.
                /* 06A8 */  0x01, 0x59, 0x91, 0xA2, 0x03, 0x00, 0x05, 0x11,  // .Y......
                /* 06B0 */  0x90, 0xA5, 0x38, 0x02, 0x62, 0xC2, 0x40, 0x04,  // ..8.b.@.
                /* 06B8 */  0xE4, 0x00, 0x0F, 0x2D, 0x0D, 0xCF, 0x92, 0x35,  // ...-...5
                /* 06C0 */  0x01, 0xB1, 0xC0, 0x20, 0x34, 0x86, 0x28, 0x50,  // ... 4.(P
                /* 06C8 */  0x16, 0x0A, 0x44, 0x40, 0xFE, 0xFF, 0x03         // ..D@...
            OperationRegion (DEB1, SystemIO, 0x80, 0x04)
            Field (DEB1, DWordAcc, NoLock, Preserve)
                DBGD,   32
            OperationRegion (SMI0, SystemIO, LSMB, One)
            Field (SMI0, ByteAcc, NoLock, Preserve)
                APMC,   8
            OperationRegion (WMIM, SystemMemory, WMIO, WMSZ)
            Field (WMIM, AnyAcc, NoLock, Preserve)
                CMD,    8,
                ERR,    32,
                PAR0,   32,
                PAR1,   32,
                PAR2,   32,
                PAR3,   32
                Offset (0x15),
                DBGM,   800,
                RTSM,   800
            Name (_WDG, Buffer (0x64)
                /* 0000 */  0x21, 0x12, 0x90, 0x05, 0x66, 0xD5, 0xD1, 0x11,  // !...f...
                /* 0008 */  0xB2, 0xF0, 0x00, 0xA0, 0xC9, 0x06, 0x29, 0x10,  // ......).
                /* 0010 */  0x42, 0x41, 0x01, 0x00, 0x7C, 0x78, 0x3E, 0x21,  // BA..|x>!
                /* 0018 */  0xD5, 0x50, 0x2D, 0x47, 0x9E, 0x08, 0xDF, 0x4F,  // .P-G...O
                /* 0020 */  0xB2, 0x05, 0x0D, 0x15, 0x47, 0x49, 0x02, 0x02,  // ....GI..
                /* 0028 */  0x66, 0xEA, 0x34, 0xF8, 0x42, 0xA4, 0xBD, 0x48,  // f.4.B..H
                /* 0030 */  0xBE, 0x8C, 0x18, 0x83, 0x75, 0x57, 0xC8, 0x98,  // ....uW..
                /* 0038 */  0x47, 0x42, 0x01, 0x02, 0x27, 0x24, 0x06, 0x68,  // GB..'$.h
                /* 0040 */  0x32, 0xC4, 0xA2, 0x4B, 0xB3, 0xD8, 0xF6, 0x39,  // 2..K...9
                /* 0048 */  0x49, 0xDD, 0x7A, 0x19, 0x53, 0x50, 0x03, 0x02,  // I.z.SP..
                /* 0050 */  0x38, 0x27, 0xAA, 0x81, 0xBA, 0x49, 0x98, 0x44,  // 8'...I.D
                /* 0058 */  0x82, 0x1B, 0xD3, 0x8B, 0x88, 0xD8, 0x14, 0x95,  // ........
                /* 0060 */  0x4C, 0x44, 0x01, 0x02                           // LD..
            Method (TSTD, 1, NotSerialized)
                Local0 = Zero
                Local1 = 0x00030D40
                While ((Local0 < Local1))
                    DBGD = Arg0
                    Local0++
                Return (Zero)
            Mutex (MSMI, 0x07)
            Method (SMI, 5, NotSerialized)
                Acquire (MSMI, 0xFFFF)
                CMD = Arg0
                PAR0 = Arg1
                PAR1 = Arg2
                PAR2 = Arg3
                PAR3 = Arg4
                APMC = AISV /* \AISV */
                While ((ERR == One))
                    Sleep (0x64)
                Local0 = PAR0 /* \_SB_.WMIC.PAR0 */
                Release (MSMI)
                Return (Local0)
            Method (WMII, 2, NotSerialized)
                Return (SMI (0x10, Arg0, Arg1, Zero, Zero))
            Method (WMIP, 2, NotSerialized)
                Return (SMI (0x20, Arg0, Arg1, Zero, Zero))
            Method (WMGI, 3, NotSerialized)
                If ((Acquire (MWMI, 0xFFFF) == Zero))
                    DBGM = Arg2
                    Local0 = WMII (Arg1, Zero)
                    Release (MWMI)
                Return (RTSM) /* \_SB_.WMIC.RTSM */
            Method (WMGB, 3, NotSerialized)
                    DBGM = Arg2
                    Release (MWMI)
            Method (WMSP, 3, NotSerialized)
                    DBGM = Arg2
                    Local0 = WMIP (Arg1, Zero)
                    Release (MWMI)
            Method (WMLD, 3, NotSerialized)
                Local1 = WMII (0xFF, Zero)
                Release (MWMI)
    OperationRegion (SWBA, SystemIO, 0xB2, One)
    Field (SWBA, ByteAcc, NoLock, Preserve)
        BASP,   8
    OperationRegion (BASG, SystemMemory, 0xFDAE04E0, 0x04)
    Field (BASG, AnyAcc, NoLock, Preserve)
            ,   1,
        BADA,   1,
        Offset (0x04)
    Scope (_GPE)
        Method (_E24, 0, NotSerialized)  // _Exx: Edge-Triggered GPE, xx=0x00-0xFF
            Local0 = (BADA & 0x02)
            If ((Local0 == 0x02)){}
            Else
                BASP = OBGA /* \OBGA */
    Scope (_SB.PCI0)
        Name (SLIC, Buffer (0x9E)
            "375016749376Genuine NVIDIA Certified SLI Ready Motherboard for MSI TEMP KEY        71EA-Copyright 2019 NVIDIA Corporation All Rights Reserved-274100472652(R)"
        Device (WMI1)
            Name (_UID, "MXM2")  // _UID: Unique ID
            Name (_WDG, Buffer (0x14)
                /* 0000 */  0x3C, 0x5C, 0xCB, 0xF6, 0xAE, 0x9C, 0xBD, 0x4E,  // <\.....N
                /* 0008 */  0xB5, 0x77, 0x93, 0x1E, 0xA3, 0x2A, 0x2C, 0xC0,  // .w...*,.
                /* 0010 */  0x4D, 0x58, 0x01, 0x02                           // MX..
            Method (WMMX, 3, NotSerialized)
                CreateDWordField (Arg2, Zero, FUNC)
                If ((FUNC == 0x41494C53))
                    Return (SLIC) /* \_SB_.PCI0.SLIC */
                Return (Zero)
After removing the Windows section and applying the other fixes, I came up with a customized DSDT file. It booted easily with no apparent issues. (Note: if you're not booting into Windows via OC, this customized DSDT file won't matter. Boot into Windows from BIOS and this DSDT modified file will have zeros influence.)
I believe this customized DSDT file will work on all MSI (and maybe even most TRX40, but I don't know as I cannot test; note: no GB user should use as it is a derivative). The customized DSDT file is attached below. When derived for my MSI, I did have Above 4G enabled; I don't know if this matters.
Customized DSDT first in OC/ACPI:
While this customized DSDT so far does not enable USB on TB on the MSI (I'm still working on it), it did surprisingly, raise test results as shown below.
The FPS increased from 97 to 142 (previous results here). This is rather significant. Also, the CPU scores increased from 7700 to 8000. All results are bare metal in Big Sur ß6.
One more comment. When going thru the DSDT file, there are many areas where the exact address of the MMIO sections we're using in MmioWhitelist are defined (as shown in Spoiler below for 0xFED00000).
        Method (_CRS, 0, NotSerialized)  // _CRS: Current Resource Settings
            Name (BUF0, ResourceTemplate ()
                IRQNoFlags ()
                    {0}
                IRQNoFlags ()
                    {8}
                Memory32Fixed (ReadOnly,
                    0xFED00000,         // Address Base
                    0x00000400,         // Address Length
            Return (BUF0) /* \HPET._CRS.BUF0 */
2nd Run:
Edited by iGPU
DSDT-MSI-Creator; removed: too esoteric for others.
  • Like 3
This sounds like... amazing. Must try it out.
What are our common MMIO addresses referencing? Do you know?
UPDATE:  Like @fabiosun same, an error at start. Hung there and rebooted.
Edited by Driftwood
Just keep in mind that I didn’t properly extract my DSDT as I should say from Linux. It’s just what I see launching MaciASL in Big Sur. I hope the disassembler is bug-free, I should probably  extract it outside of macOS.
Edited by meina222
You can extract with OC using Debug version: set DisplayDelay to 64, Target to 65 and SysReport to "Yes". This will create a SysReport folder on the EFI partition. Inside this will be a DSDT file.
I should mention that the derived DSDT file will change not only with mobo, but BIOS. So if BIOS is updated, the DSDT file manipulation must be re-done.
3 hours ago, fabiosun said:
@iGPUtested by now your dsdt
in my case it hangs with latest two lines AppleUSBresource@ then after some seconds I have screen character corruption and stop sign
tested with 4g on and off and in different Usb ports
Send me a DSDT file based on instructions in above post. Maybe I can quickly get rid of the same compilation errors and Windows stuff.
Edited by iGPU
This is the DSDT of Gigabyte Designare TRX40 DSDT BIOS f4h (not publicly available but fixes f4c inability to have TB working in Slot 4 in various configurations).
I extracted it by booting via Ubuntu USB and redirecting the output of:
sudo cat /sys/firmware/acpi/tables/DSDT
It might be largely similar or identical to the one before, I just wanted to get it outside of the Hackintosh itself.
@Driftwood - I am not as experienced as @iGPU in DSDT/SSDT understanding. I want to remove some obvious errors (AE_ALREADY_EXISTS are particularly annoying when booting in Linux) and wouldn't mind looking at the diff, but would feel less confident patching it until I do more reading on the matter.
DSIGNARE-TRX40-f4h-DSDT.aml.zip
On 9/6/2020 at 5:45 PM, Driftwood said:
@iGPU Here's the Asrock TRX40 Creator (Above 4G, CSM Disabled BIOS, standard settings) DSDT file to add to your database.
In looking it over, it has more in common with MSI than GB. However, all 3 have 90% in common with each other.
None of the other 2 mobos (GB/ASrock) have the large Windows section at the end as described above for the MSI file. The ASRock does have the same compilation errors. I'll work to remove them and upload, probably tomorrow, for you to try.
EDIT:
I cleaned up the compilations errors and added several GPRW calls that were missing (same as with MSI). Let me know how it boots.
Edited by iGPU
removed DSDT-ASRock-mod file
Just wanted to give everyone an update on the GPU performance fix, it is 100% the last kernel patch, Fix PAT. Disable it and see if you can still boot and if you can, your GPU performance will be like it should be. Currently trying to get the AMD devs to re-work the patch so all AMD systems can benefit from it using the PAT fix without hindering the GPU performance.
I'd already removed this when reducing the patch list down to 13 total patches. The GPU performance on C15 increased from a very low 67 to 97 FPS without Fix PAT.
When I added the modified DSDT file, the GPU further increased to 140 FPS.
Did you try the modified DSDT file?  It should work since we use the same mobo. I derived it with Above 4G enabled, and did not check if this setting affects the DSDT file.
@iGPUthank you for your offer
i appreciate
but for now I do not want interact with dsdt part and I prefer to stay clean and trying all ways I can via bootloader or my bios option
in my case I am very happy of proxmox and bare metal it is only an experiment for my thunderbolt
I will follow your progress👍
  • Recently Browsing   1 member
