Tools for automating OpenCore upgrades?
chriswayg
I see you have some nice tools here. Can you recommend any tools that simplify the upgrade procedure of OpenCore?
I usually follow the manual process as described here: https://dortania.github.io/OpenCore-Desktop-Guide/post-install/update.html
I have also used OC-tool, but it has not been fully compatible with the latest release (0.5.9) https://github.com/rusty-bits/OC-tool
What else would you recommend?
