bubbleg5 Posted June 3, 2020 Share Posted June 3, 2020 Ho un altro fastidio su uno dei miei primi hack, non ci ho mai fatto caso e non ricordo neanche se ve ne ho mai parlato qui... Praticamente non riesco ad parire HwMonitor crasha subito. Vi allego la mia Clover e il log di crash magari riuscite a capirci qualcosa... spero... Process: HWMonitor [874] Path: /Applications/HWMonitor.app/Contents/MacOS/HWMonitor Identifier: org.hwsensors.HWMonitor Version: 6.26-357-gceb835ea.1800 (1800) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: HWMonitor [874] User ID: 502 Date/Time: 2020-06-03 15:03:57.905 +0200 OS Version: Mac OS X 10.14.6 (18G4032) Report Version: 12 Anonymous UUID: 71210177-6874-35B9-6352-538E103BF3FE Time Awake Since Boot: 680 seconds System Integrity Protection: disabled Crashed Thread: 0 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: DYLD, [0x1] Library missing Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: @executable_path/../Frameworks/Growl.framework/Versions/A/Growl Referenced from: /Applications/HWMonitor.app/Contents/MacOS/HWMonitor Reason: no suitable image found. Did find: /Applications/HWMonitor.app/Contents/MacOS/../Frameworks/Growl.framework/Versions/A/Growl: stat() failed with errno=13 /Applications/HWMonitor.app/Contents/MacOS/../Frameworks/Growl.framework/Versions/A/Growl: stat() failed with errno=13 Binary Images: 0x10b913000 - 0x10b97fff7 +org.hwsensors.HWMonitor (6.26-357-gceb835ea.1800 - 1800) <A1B59C1E-AC66-35F1-B474-3FA605D18159> /Applications/HWMonitor.app/Contents/MacOS/HWMonitor 0x119416000 - 0x11948070f dyld (655.1.1) <C192CA31-D059-3770-9882-D864FEFA0C96> /usr/lib/dyld 0x7fff30b78000 - 0x7fff30b78fff com.apple.Cocoa (6.11 - 23) <5BE4CE24-6041-3708-A83B-D74BC8CB8A9B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff30f76000 - 0x7fff312fbfef com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff33d29000 - 0x7fff33db8fff com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff3c926000 - 0x7fff3cc26ff7 com.apple.security (7.0 - 58286.270.6) <0FA49A7B-26C3-3DEF-B369-046E6D0CDF12> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff3cce5000 - 0x7fff3cce9fff com.apple.xpc.ServiceManagement (1.0 - 1) <7F9EC269-38C8-334B-976A-3951021B28B7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff3fb0a000 - 0x7fff4005aff7 com.apple.WebKit (14607 - 14607.3.9) <7949E652-FCCA-3161-87C1-AB3C3FD0718A> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit  CLOVER.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 3, 2020 Support Team Share Posted June 3, 2020 è ora di aggiornarsi: https://www.macos86.it/topic/1690-hwmonitorsmc2-hardware-monitoring-app/  1 Link to comment Share on other sites More sharing options...
bubbleg5 Posted June 3, 2020 Author Share Posted June 3, 2020 Ecco si vede che non mi aggiorno spesso. lo faccio subito anche sull'altro. Ma sbaglio o questo non fa un test SMART? o lo fa ma non è menzionato? Link to comment Share on other sites More sharing options...
bubbleg5 Posted June 4, 2020 Author Share Posted June 4, 2020 Sta di fatto che segunedo la guida e rimuovnedo FakeSMC e sensor di rehabman o FakeSMC ed installando VirtualSMC + SMCProcessor + SMCSuperIO non si avvia più, per fortuna che avevo il backup di una mia clover e ho dovuto rimettere i FakeSMC e rimuovere i virtualSMC. Simbolo di divieto all'avvio... Link to comment Share on other sites More sharing options...
bubbleg5 Posted June 4, 2020 Author Share Posted June 4, 2020 On 6/3/2020 at 3:52 PM, iCanaro said: è ora di aggiornarsi: https://www.macos86.it/topic/1690-hwmonitorsmc2-hardware-monitoring-app/  Cosa molto strana anche se ho sovrascritto la cartella Clover con quella che avevo nel backup, capita un avvio si e uno no che mi dia il sengo di Divieto all'avvio, la cosa è strana perchè è sempre andato bene... Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 4, 2020 Support Team Share Posted June 4, 2020 4 minuti fa, bubbleg5 ha scritto: Cosa molto strana anche se ho sovrascritto la cartella Clover con quella che avevo nel backup non sovrascrivere eliminare vecchia svuotare cestino copiare nuova  che non ti si avvi più l'hack per la sostituzione di FakeSMC con VirtualSMC, lo trovo quasi inverosimile va bene che hai una accoppiata sgrat sgrat... Z370 gigio e H370 ma per me tu hai anche altri problemi se vuoi postare EFI nel thread del tuo hack, così ci si può ragionare meglio, ci guardo Link to comment Share on other sites More sharing options...
bubbleg5 Posted June 5, 2020 Author Share Posted June 5, 2020 21 hours ago, iCanaro said: non sovrascrivere eliminare vecchia svuotare cestino copiare nuova  che non ti si avvi più l'hack per la sostituzione di FakeSMC con VirtualSMC, lo trovo quasi inverosimile va bene che hai una accoppiata sgrat sgrat... Z370 gigio e H370 ma per me tu hai anche altri problemi se vuoi postare EFI nel thread del tuo hack, così ci si può ragionare meglio, ci guardo Dato che ho una vecchia versione di Clover, provo ad aggiornarla all'attuale, ho ancora il vecchio schema... ho tipo la 5018 e ora c'è la 5119... vediamo cosa succede. anche se sta cosa del divieto è random, tipo oggi non mi ha dato problemi... ieri un sacco e ho dovuto fare il boot da chiaveta.... Link to comment Share on other sites More sharing options...
