Catalina Installation problem on TRX40
jasin755
Hi again 🙂
I bought new NVME SSD and I want to create new VM and install macos directly to this NVME. I found address of my memory controller:
01:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5016 (rev 01)
and added as PCI passthrough:
but I don't know how add this drive into VM config.
If you did so you have it and you can format it in disk Utility
you can also see pressing F2 on proxmox logo after vm start
inside boot option
if you can’t see it something where wrong
Ah no need to select pci express flag in passing
Have you patched deb file?
if so revert to a non patched one
then enter in ovmf bios and put your nvme drive as first device to boot you can put CD-ROM drive as second
in vm config option put cd rom as first
none to second and third one option
in this way you can boot from your nvme drive
obviusly it must have inside a bootable EFI partition
follow the instructions here and in main guide
780849707_ScreenShot2020-04-29at16_04_44.thumb.png.87dc8c84857d9a097add5d908f0dba3b.png
