Glad it worked out.
On the reset topic - you can also replace "reboot" with "shutdown -f now" in the earlier version of my hookscript. Thus, when you shutdown your  VM, this will shut your host - clearly a misuse of the VM concept as you want your host to be up, but the reset bug (depending on your usage of the GPU) might force this to be the best option. I use the VM as a desktop proxy and not as a multi-VM server right now so such setting works for me.
Another thing in my hook is "tasksets" - depending on how many CPU's you pass to the VM, you can change this (mine is 0-63 in the hook as I have 128 logical cores and I pass 64 of them). You have 64 logical cores (SMT on 32 cores) and if you pass 32 of them to the VM, you can tweak this part to say 0-31. This will "pin" your VM tasks to these cores, which may bring some performance benefits (unlikely to be noticed in most benchmarks).
Finally if you ever pass ethernet, you may need different networking configs for your host - I recommend using VM ethernet due to this as it is fast enough.
Edited by meina222
@dtek
I used the Dortania guide.
https://dortania.github.io/OpenCore-Post-Install/universal/iservices.html
Basically you need to do this:
1. Find out the PCI id of your ethernet card in Proxmox and pass it through to the VM. Make sure your Porxmox host can get its connectivity from another place (2nd ethernet, wireless)
As an example, the highlighted id below is one my two ethernets (the 2nd I leave to Proxmox for host connectivity).
args: -device isa-applesmc,osk="ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc" -smbios type=2 -device usb-kbd,bus=ehci.0,port=2 -cpu host,+invtsc,vendor=GenuineIntel
balloon: 0
bios: ovmf
boot: cdn
bootdisk: virtio0
cores: 64
cpu: Penryn
efidisk0: aorus:vm-101-disk-1,size=1M
hookscript: local:snippets/vmhook.sh
hostpci0: 43:00,pcie=1,x-vga=1,romfile=vbios.bin
hostpci1: 86:00,pcie=1
hostpci2: 85:00,pcie=1
hostpci3: 88:00,pcie=1
hostpci4: 02:00,pcie=1
hugepages: 1024
ide2: local:iso/OpenCoreBeta.iso,size=150M
machine: q35
memory: 196608
numa: 1
ostype: other
scsihw: virtio-scsi-pci
smbios1: uuid=4b5493a6-6a73-48b7-8ce5-2be70a66a383
sockets: 1
vga: none
virtio0: aorus:vm-101-disk-0,cache=unsafe,discard=on,size=250G
vmgenid: 18d68c27-3a62-4059-9280-7f86a572af59
vmgenid: 0c7cc702-74ba-4d8e-ba4b-d52d5fe53847
2. Get the ROM/MAC address of the ethernet device you passed-thru and specify it in your OpenCore config.plist as described in the Dortania guide
3. Make sure your enX (e.g. en0) device matching the card is "primary" in MacOS as described in the guide
4. Make sure NVRAM works in MacOS as described in the guide
When done, you can activate iMessage. Worked for me.
Edited by meina222
  On 11/6/2020 at 9:02 PM, meina222 said:
@dtek
balloon: 0
bios: ovmf
boot: cdn
bootdisk: virtio0
cores: 64
cpu: Penryn
hugepages: 1024
machine: q35
memory: 196608
numa: 1
ostype: other
sockets: 1
vga: none
2. Get the ROM/MAC address of the ethernet and specify it in your OpenCore config.plist as described in the Dortania guide
Expand
I have 2 ethernet ports.  How do I find out which one is being used by Proxmox host?
  On 11/6/2020 at 9:51 PM, meina222 said:
Could you post the outputs of the following in Proxmox
1)   ls -l /sys/class/net
2)   less /etc/network/interfaces
Expand
root@dtk:~#  ls -l /sys/class/net
total 0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 eno1 -> ../../devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:04.0/0000:44:00.0/net/eno1
lrwxrwxrwx 1 root root 0 Nov  6 17:17 enp69s0 -> ../../devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:05.0/0000:45:00.0/net/enp69s0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwbr100i0 -> ../../devices/virtual/net/fwbr100i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwbr101i0 -> ../../devices/virtual/net/fwbr101i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwln100i0 -> ../../devices/virtual/net/fwln100i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwln101i0 -> ../../devices/virtual/net/fwln101i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwpr100p0 -> ../../devices/virtual/net/fwpr100p0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 fwpr101p0 -> ../../devices/virtual/net/fwpr101p0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 lo -> ../../devices/virtual/net/lo
lrwxrwxrwx 1 root root 0 Nov  6 17:17 tap100i0 -> ../../devices/virtual/net/tap100i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 tap101i0 -> ../../devices/virtual/net/tap101i0
lrwxrwxrwx 1 root root 0 Nov  6 17:17 vmbr0 -> ../../devices/virtual/net/vmbr0
auto lo
iface lo inet loopback
iface enp69s0 inet manual
auto vmbr0
iface vmbr0 inet static
        address 192.168.1.14
        netmask 255.255.255.0
        gateway 192.168.1.1
        bridge_ports enp69s0
        bridge_stp off
        bridge_fd 0
iface eno1 inet manual
Based on below you need to add to VM config (assuming hostpci1 is free in your VM config if not use next free one say hostpci2):
hostpci1: 44:00,pcie=1
To verify make sure that 44:00 shows up in your ID's when you do
lspci | grep -i eth
you should see 2 ethernets and one of them will be 44:00 and the other 45:00. Try passing 44:00.
Is that your 10G card or 1G card? You may need a kext / patch in macOS if it is Aquantia. @fabiosun, has the same motherboard so he can share what kext / patch is needed, I don't have this device. The other one may be supported by default.
Explanation:
The yellow ethernet from your 1st output (PCI id 45:00) corresponds to enp69s0 which is used as the bridge/gateway for your Proxmox host. You need to pass the free card 44:00. If you want to swap you need to change the Proxmox host network config below.
total 0
auto lo
auto vmbr0
        gateway 192.168.1.1
        bridge_stp off
        bridge_fd 0
To test which one is which, unplug the cables 1 at a time (assuming both are connected) and see which one loses your Proxmox host network/internet connection and which one is ignored. The one that is not affecting Proxmox will be the 44:00 one you pass-thru.
This 44:00 card you give the VM will then connect to the virtual network bridge/gateway defined by Proxmox to get internet
auto lo
auto vmbr0
        gateway 192.168.1.1
        bridge_stp off
        bridge_fd 0
Edited by meina222
As last step, before you pass-thru, write-down the MAC address of the card you pass thru. Check the output of:
ip link
and find the entry for eno1
The mac address will look like  for example (made up the HEX string separated by :)
link/ether a4:2e:79:bb:21:ff
You need to write down a4:2e:79:bb:21:ff (you will see your own MAC address of course this is dummy) as this will go in your OpenCore config.plist in binary format as described by Dortania. You can use XCode to encode it.
Edited by meina222
@dtek
our motherboard has 2 i211 intel ethernet
they need of small5276 kext in other
aquantia is an external card and it is seen by default
in Bs it needs of a kexttopatch to work
personally never used imessage or facetime on my hackintosh
Hello
I just started on a hackinstosh.
I have been reading this thread for 2 days and improving my efi.
I'm not done. I'm on page 42 of this thread.
Thank you for your dissemination of your knowledge.
I confirm Fabiosun's trick this one:
637971134_Capturedcran2020-11-1118_50_24.png.200fe8365db1de420f0bb71ae58b7785.png637971134_Capturedcran2020-11-1118_50_24.png.200fe8365db1de420f0bb71ae58b7785.png
unleash the performance of the cpu / gpu couple here is proof.
Image 1 before
Image 2 after.
I will get back to you as soon as I have plenty of time.
Sincerely thanks to Fabiosun, Ploddles, meina222, iGPU, Pavo and the others.
GPU reset now works on 5700XT (tested with mine) and possibly Vega 64/56 (unable to test) by using a non-kernel module install generously offered by https://github.com/gnif/vendor-reset/
@dtek,  and others using Proxmox - worth trying! I can now reboot my single GPU VM in MacOS to upgrade it and regain it back via pass-thru. It works pretty reliably in Windows 10 VMs too. You can checkout the repo and install the module to try it.
  On 11/25/2020 at 7:10 AM, fabiosun said:
@meina222I have tested a little my new Vega 64 GPU in Proxmox..
I have had not reset bug problem with it without using the non-kernel module..
However good to know it
Thank you
Expand
That's interesting. I have been plagued by my Navi 10 not resetting since day 1 - to the point where in order to update MacOS I had to disable GPU passthru and use VMWARE compatible remote display to reboot the VM. This module seems to do the magic. I can now reboot or shutdown my VM and bring up another VM and GPU is picked up by new VM - before I'd get a blank screen (with the exception of WIndows 10 which would launch with driver disabled).
Edited by meina222
  On 11/25/2020 at 3:14 PM, Driftwood said:
Hopefully this will work on Radeon VIIs under Proxmox.
Expand
 It is listed in supported devices, but don't have one to test. I did encounter a potential bug still, but need to test more - one a reset, my DisplayPort sound stopped working. Still much better than the complete hang before.
Supported Devices
Vendor Family Common Name(s)
AMD Polaris 10
AMD Polaris 11
AMD Polaris 12
AMD Vega 10 Vega 56/64
AMD Vega 20 Radeon VII
AMD Navi 10 5600XT, 5700, 5700XT
AMD Navi 12 Pro 5600M
AMD Navi 14 Pro 5300, RX 5300, 5500XT
Edited by meina222
however it is a big improvment
I am ashamed and a little embarrassed to tell you that I no longer have my EFI proxmox working 🙂
I have to research it, but when I got the Vega 64 I tried to do several restarts but I don't think I had the problem, I also seem to have written it As soon as I can try again
I don't know if the DP sound not working is a systematic or one-off issue. Noticed it when I shutdown Big Sur VM and started Windows 10 VM. I'll research more and report.
I continue to maintain Proxmox and find myself using my VMs more often than not. I have 4 VMs on it including a Win 10 VM I use to sometimes do light gaming.
I really hope to finally get a 6800XT/6900XT and make this VM the main gaming rig and try newest titles such as MS flight sim at max settings.
Just got my Valve Index VR headset recently - the new 6000 cards have a USB-C port direct that seems handy for that. Too bad the 6000 launch seems as bad as Nvidia's 3000.
I can confirm that the reset is not perfect, however still a huge leap. The reset works perfectly for video but not DP/HDMI audio so still WIP. Given how long this has taken and how complicated (and vendor specific) the issue seems to be, I am sure these imperfections will be fixed soon.
In particular this comment thread confirms Navi 10 is still work in progress and sound has some issues, but Vega and Polaris might fare better:
https://github.com/gnif/vendor-reset/issues/3
Expand
OMG I can't wait to try this.  GPU passthrough  was removed from my VM ever since I had to reinstall everything from scratch.  It refused to boot after multiple forceful resets 😣
