2 hours ago, fabiosun said:
Also I do not use actual patch you can find in pavo GitHub but older ones. I think he is doing multi platform experiment with this patches to try to solve Problem for other platform. I think also @Pavo could confirm this as he did in private few hour ago
@iGPUif you have another working Linux you can compile by yourself
I prefer @Pavogive you clear instruction because he has helped me to understand how.
to all
audio is working and the only problem now is audio jack Detection.
by the way now i think pavo had some success we audio in unraid. Maybe it could be useful also in proxmox understand well how Unraid works
First, I should get my system working better.
I tested more tonight and under Windows 10 everything seems fine. I stress tested and temps never got over 75°C (I did not yet run Prime95). It runs without crashing. But under UnRAID or Proxmox, system crashes with same, repeatable errors in 5 min or so. Something about Linux and this CPU.
I'll run other Linux tests tomorrow.
Fabiosun, when you used to use MCE=off, did you place that in GRUB_CMDLINE_LINUX_DEFAULT, or somewhere else?
Thanks.
Edited by iGPU
2 hours ago, cj750 said:
Since my system is closer to yours. Do you feel it stable with your setup. Any new issue pop since you been running it for a few days. Any changes?
Nope. All good so far - pondering whether to switch in the SATA's now so I'll update you shortly. Even ran migration assistant on the USB-C rear in record time! 2TB done inside an hour - now you know how long MA normally takes, it waits around for ages checking things - its not really so much hard drive/net speed - its processing/checking off things. This was real quick.
8K Update: Managed to get the Dell 8K monitor working in 8K Catalina 10.15.5 with ResXtreme. My god it was soooo tiny that I had to scale.
Edited by Driftwood
8 hours ago, fabiosun said:
are not informed well😀
Audio is working well in latest Catalina and it is not flr patch related
Yeah that was a few days ago. I know you and Pavo have been looking into audio issues together. I saw he had it working initially when he streamed live but there were crackling issues, I'm sure you both have sorted it by now. You've both been working on it, I understand. 🙂
@Driftwood Apple has worked for me 🙂
catalina 10.15.5 solved my audio problem and then I have said to Pavo this and also him reached my same situation with his trx40 system (audio perfect but jack detection problematic)
Now I think he is trying with Unraid and see if there could be the same or better.
For now I stay in Proxmox. system is production ready and no so much time to invest to learn Unraid
  • Like 3
Thats interesting. 8K worked for me with the new Cat.
@fabiosun what about USB - all working? NO lag?
Edited by Driftwood
  • whahahah 1
for me Catalina is working well as high sierra if I consider USB job
I pass all controllers less audio controller (xx:00.4)
In Catalina usb is threated differently and USB drivers work as they do in a window VM (as bare metal), in High Sierra driver is old and for now I can use only USB 2.0 device.
for both no lag at all
Pay attention (for lag stuff) if you have some WIFI/BT which need usb power)..I haven't ..but it is problematic if you have
What card are you using? I must of missed it in the past post.
7 minutes ago, A23SS4NDRO said:
What about buying a GT710 for Display output and use the two Radeon VIIs for compute tasks in parallel?
and do you think a 710 gt could remote well that 8k display?
magaraaaa 🙂
PS the problem is also we are using a complex system to boot..and adding a third gfx could be problematic...
Following comments are FYI and have no immediate direct bearing on this build.
I'm researching various Linux distributions and came across this news:
Linus Torvalds has switched to using an MSI TRX40 Creator + 3970X, where the build is described here. Linus describes here using Linux 5.7-rc7.
This all would suggest that the TRX40 platform will have increasingly better Linux support.
I left Windows 10 running over night and zero issues, even after running many different stress tests. That led me to look for issues affecting Linux but not Windows:  Core 6 issues can do this. But after making those changes described here in BIOS (changing 'Typical current idle', from 'Auto' or 'Low current idle'), the same error messages and kernel panel with shutdown happened under Proxmox. So no fix for my CPU.
On 5/29/2020 at 7:40 PM, fabiosun said:
Hi, maybe I am missing something...are you sure of this picture above?
In your pdf on your GitHub there are differences.. 🙂and as it is should not boot (gfx is not there)
with our trx40 is better to pass entire usb controllers and not single device..single device may loose many functionality
good catch i will update this! I had the GTX980 in slot 1 and Radeon VII in slot 3. After this I removed the GTX980 and put the Radeon in slot 1 so indeed this is le dump. 🤦🏼‍♂️
On 5/29/2020 at 7:25 PM, Driftwood said:
I suspected that I might have to do this the other day when talking to Pavo. But after talking, I decided first to get the rear ASMedia USB controller passed through on 44:00 so I was able to use the rear 3.2 gen 2 port - couldn't use it before I passed it which is strange. So are you saying if you remove ALL USB controllers that the rear 3.2 gen 2 USB C connector works without passthrough? Ive actually ordered a Qnap TR4 NAS/Singles USB-C 3.2 gen 1box to stick my spinners in, which is 10Gbs. They also have this https://www.qnap.com/en-uk/product/tl-d800c coming out imminently giving support for USB 3.2 gen 2x2 speeds (20Gbs 8 drive box).
So I might try and go back and un-passthrough the USB controllers/ports in my current config. And use the rear USB C too.
Also I've got plenty of USB-C multi-port adapters from my MBP lappie so all is cool.
Good confirmation, thanks Rox67er.
almost, I DO pass the usb-c through.
On 5/29/2020 at 7:56 PM, Driftwood said:
@Rox67er The two ASRock Creator SATA controllers (8 x SATA3 6.0 Gb/s) which, out of the two FCH address - 48:00 & 49:00 - is the first four?
The reason I ask is I forget if you are booting proxmox from a SATA port or USB?
I currently have Proxmox booting off SATA port 1 on a SSD.
 Im tempted to go USB (as @fabiosun has successfully done)  but would prefer to boot with SATA from inside the box like Im doing. I currently don't passthrough either of the SATA controllers. I don't mind losing half the controllers to proxmox ssd, but which controller is using which IDs? Is 48:00 ports 1 - 4 ? And 49:00 Ports 5 - 8?
I could do with using one of the controllers I guess.
i’m not 100% sure but think port 17 and 16 are on 49:00, 14 and 15 are on 48:00. I use an external ssd for proxmox on one of the usb ports next to the ps2 connector.
In Catalina usb is threated differently and USB drivers work has they do in a window VM (as bare metal), in High Sierra driver is old and for now I can use only USB 2.0 device.
Do you run any kext or other files for usb in opencore?
nice, in the long list of patches I see several iommu / amd patches... 👍🏼
OT (about Unraid)
to test I have built an Unraid test OSX VM, I did to verify if in there I have a better HighSierra support..it is not 🙂
below IOMMU groups seen in Unraid and others datas:
PCI Devices and IOMMU Groups
IOMMU group 0:	[1022:1482] 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 1:	[1022:1483] 00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 2:	[1022:1483] 00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 3:	[1022:1482] 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 4:	[1022:1482] 00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 5:	[1022:1482] 00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 6:	[1022:1482] 00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 7:	[1022:1482] 00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 8:	[1022:1484] 00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 9:	[1022:1482] 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 10:	[1022:1484] 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 11:	[1022:790b] 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
	[1022:790e] 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
IOMMU group 12:	[1022:1490] 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0
	[1022:1491] 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1
	[1022:1492] 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2
	[1022:1493] 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3
	[1022:1494] 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4
	[1022:1495] 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5
	[1022:1496] 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6
	[1022:1497] 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7
IOMMU group 13:	[144d:a804] 01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961
IOMMU group 14:	[1987:5012] 02:00.0 Non-Volatile memory controller: Phison Electronics Corporation E12 NVMe Controller (rev 01)
IOMMU group 15:	[1022:148a] 03:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 16:	[1022:1485] 04:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group 17:	[1022:148c] 04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller
IOMMU group 18:	[1022:1482] 20:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 19:	[1022:1482] 20:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 20:	[1022:1482] 20:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 21:	[1022:1483] 20:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 22:	[1022:1482] 20:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 23:	[1022:1482] 20:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 24:	[1022:1482] 20:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 25:	[1022:1484] 20:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 26:	[1022:1482] 20:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 27:	[1022:1484] 20:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 28:	[10de:1b02] 21:00.0 VGA compatible controller: NVIDIA Corporation GP102 [TITAN Xp] (rev a1)
	[10de:10ef] 21:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1)
IOMMU group 29:	[1022:148a] 22:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 30:	[1022:1485] 23:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group 31:	[1022:1486] 23:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
IOMMU group 32:	[1022:148c] 23:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller
IOMMU group 33:	[1022:1487] 23:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
IOMMU group 34:	[1022:1482] 40:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 35:	[1022:1483] 40:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 36:	[1022:1483] 40:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 37:	[1022:1482] 40:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 38:	[1022:1482] 40:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 39:	[1022:1482] 40:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 40:	[1022:1482] 40:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 41:	[1022:1482] 40:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 42:	[1022:1484] 40:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 43:	[1022:1482] 40:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 44:	[1022:1484] 40:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 45:	[1022:57ad] 41:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
IOMMU group 46:	[1022:57a3] 42:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
IOMMU group 47:	[1022:57a3] 42:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
IOMMU group 48:	[1022:57a3] 42:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
IOMMU group 49:	[1022:57a4] 42:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
	[1022:1485] 46:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	[1022:149c] 46:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
	[1022:149c] 46:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
IOMMU group 50:	[1022:57a4] 42:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
	[1022:7901] 47:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
IOMMU group 51:	[1022:57a4] 42:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
	[1022:7901] 48:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
IOMMU group 52:	[1b21:3242] 43:00.0 USB controller: ASMedia Technology Inc. Device 3242
IOMMU group 53:	[8086:1539] 44:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
IOMMU group 54:	[8086:1539] 45:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
IOMMU group 55:	[1d6a:07b1] 49:00.0 Ethernet controller: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02)
IOMMU group 56:	[1022:148a] 4a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 57:	[1022:1485] 4b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group 58:	[1022:1482] 60:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 59:	[1022:1482] 60:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 60:	[1022:1482] 60:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 61:	[1022:1482] 60:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 62:	[1022:1482] 60:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 63:	[1022:1482] 60:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 64:	[1022:1484] 60:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 65:	[1022:1482] 60:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 66:	[1022:1484] 60:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 67:	[1022:148a] 61:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 68:	[1022:1485] 62:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
CPU Thread Pairings
Pair 1:	cpu 0 / cpu 32
Pair 2:	cpu 1 / cpu 33
Pair 3:	cpu 2 / cpu 34
Pair 4:	cpu 3 / cpu 35
Pair 5:	cpu 4 / cpu 36
Pair 6:	cpu 5 / cpu 37
Pair 7:	cpu 6 / cpu 38
Pair 8:	cpu 7 / cpu 39
Pair 9:	cpu 8 / cpu 40
Pair 10:	cpu 9 / cpu 41
Pair 11:	cpu 10 / cpu 42
Pair 12:	cpu 11 / cpu 43
Pair 13:	cpu 12 / cpu 44
Pair 14:	cpu 13 / cpu 45
Pair 15:	cpu 14 / cpu 46
Pair 16:	cpu 15 / cpu 47
Pair 17:	cpu 16 / cpu 48
Pair 18:	cpu 17 / cpu 49
Pair 19:	cpu 18 / cpu 50
Pair 20:	cpu 19 / cpu 51
Pair 21:	cpu 20 / cpu 52
Pair 22:	cpu 21 / cpu 53
Pair 23:	cpu 22 / cpu 54
Pair 24:	cpu 23 / cpu 55
Pair 25:	cpu 24 / cpu 56
Pair 26:	cpu 25 / cpu 57
Pair 27:	cpu 26 / cpu 58
Pair 28:	cpu 27 / cpu 59
Pair 29:	cpu 28 / cpu 60
Pair 30:	cpu 29 / cpu 61
Pair 31:	cpu 30 / cpu 62
Pair 32:	cpu 31 / cpu 63
USB Devices
Bus 001 Device 001:	ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001:	ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001:	ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001:	ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001:	ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001:	ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 002:	ID 2109:0715 VIA Labs, Inc. VLI Product String
Bus 007 Device 001:	ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002:	ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 007 Device 003:	ID 04d9:1702 Holtek Semiconductor, Inc. Keyboard LKS02
Bus 007 Device 004:	ID 0c76:161f JMTek, LLC. USB PnP Audio Device
Bus 007 Device 005:	ID 0db0:543d Micro Star International USB Audio
Bus 007 Device 006:	ID 1462:7c60 Micro Star International MYSTIC LIGHT
Bus 008 Device 001:	ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 009 Device 001:	ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 002:	ID 13fe:4200 Kingston Technology Company Inc. USB DISK 2.0
Bus 009 Device 003:	ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 010 Device 001:	ID 1d6b:0003 Linux Foundation 3.0 root hub
SCSI Devices
[0:0:0:0]	disk    Samsung  SSD 840 PRO      DXM0  /dev/sda    256GB
[1:0:0:0]	cd/dvd           USB DISK 2.0     PMAP  /dev/sr0        -
[1:0:0:1]	disk             USB DISK 2.0     PMAP  /dev/sdb   1.96GB
[2:0:0:0]	cd/dvd  PIONEER  BD-RW   BDR-207M 1.35  /dev/sr1        -
[3:0:0:0]	disk    ATA      HGST HTS545050A7 ACA0  /dev/sdc    500GB
[4:0:0:0]	disk    ATA      ST6000VX0023-2EF SC60  /dev/sdd   6.00TB
[5:0:0:0]	disk    ATA      ST6000VX0023-2EF SC60  /dev/sde   6.00TB
[6:0:0:0]	disk    ATA      ST10000VX0004-1Z AV01  /dev/sdf   10.0TB
[7:0:0:0]	disk    ATA      ST10000VX0004-1Z AV01  /dev/sdg   10.0TB
[N:0:2:1]	disk    Samsung SSD 960 PRO 1TB__1                 /dev/nvme0n1  1.02TB
[N:1:1:1]	disk    Sabrent__1                                 /dev/nvme1n1  1.02TB
I stay in proxmox 🙂
21 minutes ago, fabiosun said:
OT (about Unraid)
So Unraid isn't going to be specifically any better than Proxmox on these trx40 Mobo chips too?
My system is stable but am probably going to use a USB stick to boot it now.
@All is there a quick way to back up my working  4gb sized ssd proxmox boot to a bootable USB?
If so, please type FULL & EXACT details below.
This will help anyone following this thread
Thanks
No, for me no
Maybe we will see soon some improvement if Linus Torvald has a trx40 PC as we can see from link posted before by IGPU
If your system is stable why do you want to change it?
Then, if you did all correctly you can install in about 5 minute Proxmox on USB (I am saying again to use Asmedia 3.2 type back port)
And then copy on new installation all files you modify in your actual (and working) Proxmox
to summarise:
1)backup your VM config
2)backup kvm.conf, grub, vfio.conf, blacklist.conf and modules
3) backup your modified deb files and hook script if you use them
4) disconnect your proxmox disk and install on a new usb one (I use an external case for a Samsung 840 pro ssd sized 240 Gb)
5) install proxmox
6) copy all your previously backupped files and launch all terminal command you need to reconfigure your new proxmox installation
If you use a passed disk to boot in osx that's all
if you use some vm disk, maybe you have to recreate efi and you have to add a step after my point 3) as 3bis) backup all your vm disk files
more or less these could be a way you can proceed..and in the worst case you have also your previous Proxmox disk you can reconnect back 🙂
I have not studied at all some properties of web interface , I think is also possible to transfer all using internal web interface tools..
I spent most of yesterday trying to get various Linux distros to install (Redhat, Mint, et al). They all crashed during install (to a new SATA SSD). I finally got ArcoLinux to install. I then ran it all night. Completely stable, just like Windows 10 on the problematic CPU (replacement has not yet arrived).
ArcoLinux is based on Arch Linux (which is what I referenced in above post as being the latest, but it is very difficult to install). ArcoLinux has almost the latest Linux kernel, like Arch Linux. During installation ArcoLinux asks if you want to install microcode for Intel or AMD. I chose to install for AMD (? version). I don't know if just because the latest Linux kernel, that supports latest equipment, or if the AMD microcode helps, but in any event, this Linux machine is stable.
What I still don't understand is why my particular CPU was originally working on Proxmox but then gradually became unstable to the point that I couldn't run Proxmox (and I've tried their latest v6.2).
Now, I'm looking into adding KVM and QEMU to ArcoLinux.
I haven't used any of the SATA ports yet. So Im thinking of passing them all through like yours. Probably going to put a few ssds on the SATAs as it seems a shame to waste them.
My 8Tb\10Tb 'spinners' are on an external QNAP TR04 box thru the Asmedia USB port.
The only drive currently on the SATA port 1 is the Proxmox Host.
@fabiosun said: "...disconnect your proxmox disk and install on a new usb one (I use an external case for a Samsung 840 pro ssd sized 240 Gb)"
I guess I could just move the Proxmox host ssd on SATA port 1 and attach it to the rear usb?
Edited by Driftwood
yes i did in this way
i have Proxmox on sata ssd disk and sata was not passable easily
connect the same disk on asmedia usb
all went fine
Really super interested to see how you get on with ArcoLinux. July 2019, I found any interesting article on the best recommended Linux Distro for creating music content  and Graphic Design for Artists. In the article, ArcoLinux was highly praised for super stability. The guy who wrote the article has used Linux, on and off since 1999. For audio production, he is running Reaper DAW on ArcoLinux. My main reason for wanting to go with an AMD 3970/ TRX40 OSX Hackintosh rig was ideally, to hopefully efficiently run Acustica Audio Plugins on a Reaper DAW. Acustica Audio plugins are notoriously heavy on CPU, but Reaper seems to be the DAW of choice to run AA Plugins more efficiently. Really hoping ArcoLinux performs well in your VM.
Here is the link to the original article https://www.ernstrenner.com/best-linux-distro-for-artists/
Edited by paulthesparky
