4 hours ago, AllubzV said:
The MacPro7,1 also utilizes multiple GPU's (basically Radeon VII, the Radeon Pro Duo = 2x 40cu Radeon VII which has 36cu), but it's not CrossFire anymore. AMD's recent Pro cards have a variant of Infinity Fabric (like the SLI / CF connector, but $100-200). macOS doesn't mind multiple GPU's, and it sees them typically as separate units, but allows them to work in tandem if the application supports it.
Im currently running MacPro 1,1 do you think Ill be better served running MacPro7,1 for this threadripper 3970x and radeon VII  pair? About to begin passthrough of everything outside of the GFX cards. Hoping to see performance gains in NVMEs and rest.
By the way, if you have dual GPU use PCIe lane 0 and 2 (first and third slot) Both will guarantee x16 speed.
Edited by Driftwood
@Driftwood I asked before
post if you want
your vm config
your lspci -nnk output
your modules file
your kvm.conf file..and all thing could be useful
motherboards are different and you have a radeon which could be more problematic...but solutions could be similar for others controller..
Stay for now with Imacpro1.1
@AllubzV I think did an example to explain that more GPU are possible also in real Mac (and obviously in our hackintosh)
Ok guys here's my system before I begin the main passthru configs. Only pass thru'd a pair of Radeon VII GPUs so far. There's a bit of tidying up to to do and add the 2nd MP600 to the box. Enjoy!
/etc/pve/qemu-server/101.conf
args: -device isa-applesmc,osk="blah... blah... blah...the OSK.." -smbios type=2 -device usb-kbd,bus=ehci.0,port=2 -cpu Penryn,kvm=on,vendor=GenuineIntel, +kvm_pv_unhalt,+kvm_pv_eoi,+hypervisor,+inv$r, +invtsc,+pcid,+ssse3,+sse4.2,+popcnt,+avx,+avx2,+aes,+fma,+fma4,+bmi1,+bmi2,+xsave,+xsaveopt,check
balloon: 0
bios: ovmf
boot: cdn
bootdisk: sata2
cores: 64
cpu: Penryn
efidisk0: local-lvm:vm-101-disk-1,size=4M
hostpci0: 03:00,pcie=1,x-vga=1
hostpci2: 23:00,pcie=1,x-vga=1
machine: q35
memory: 56000
net0: vmxnet3=36:6A:64:7C:4A:95,bridge=vmbr0,firewall=1
numa: 0
ostype: other
sata0: /dev/disk/by-id/nvme-Force_MP600_201482300001285630A0,backup=0,cache=unsafe,size=1953514584K ,ssd=1
sata1: /dev/disk/by-id/nvme-Force_MP600_20148230000128563329,backup=0,cache=unsafe,size=1953514584K ,ssd=1
scsihw: virtio-scsi-pci
smbios1: uuid=xxxxxxxx-xxxx-xxxx-xxxx-5b42458d751f
sockets: 1
unused0: local-lvm:vm-101-disk-0
usb0: host=1532:0109
usb1: host=05ac:0304
vga: none
vmgenid: c60e620c-xxxx-xxxx-xxxx-80e6833f9bc9
etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Proxmox Virtual Environment"
GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=on video=vesafb:off video=efifb:off"
# Tried above for both GPUs and works, you could try this GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=on video=efifb:off"
# or this GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=on video=vesafb:off"
# or  this was original GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=on"
GRUB_CMDLINE_LINUX=""
# Disable os-prober, it might add menu entries for each guest
GRUB_DISABLE_OS_PROBER=true
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
/etc/modprobe.d/kvm.conf
options kvm ignore_msrs=1 report_ignored_msrs=0
/etc/modprobe.d//blacklist.conf
blacklist nouveau
blacklist nvidia
blacklist nvidiafb
blacklist snd_hda_codec_hdmi
blacklist snd_hda_intel
blacklist snd_hda_core
blacklist radeon
blacklist amdgpu
/etc/modprobe.d//vfio.conf
#The next line handles both identical Radeon VIIs cards (I have two), one for OS, one for extra 'Metal' support in e.g. Davinci Resolve etc...!
options vfio-pci ids=1002:66af,1002:ab20
./iommu.sh
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 1 00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 2 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 3 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 4 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 5 00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 6 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 7 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 8 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 9 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 10 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
IOMMU Group 10 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 11 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0 [1022:1490]
IOMMU Group 11 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1 [1022:1491]
IOMMU Group 11 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2 [1022:1492]
IOMMU Group 11 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3 [1022:1493]
IOMMU Group 11 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4 [1022:1494]
IOMMU Group 11 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5 [1022:1495]
IOMMU Group 11 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6 [1022:1496]
IOMMU Group 11 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7 [1022:1497]
IOMMU Group 12 01:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a0] (rev c1)
IOMMU Group 13 02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a1]
IOMMU Group 14 03:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:66af] (rev c1)
IOMMU Group 15 03:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
IOMMU Group 16 04:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 17 05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 18 05:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller [1022:148c]
IOMMU Group 19 20:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 20 20:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 21 20:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 22 20:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 23 20:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 24 20:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 25 20:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 26 20:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 27 20:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 28 20:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 29 21:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a0] (rev c1)
IOMMU Group 30 22:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a1]
IOMMU Group 31 23:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:66af] (rev c1)
IOMMU Group 32 23:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
IOMMU Group 33 24:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 34 25:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 35 25:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
IOMMU Group 36 25:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller [1022:148c]
IOMMU Group 37 25:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
IOMMU Group 38 40:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 39 40:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 40 40:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 41 40:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 42 40:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 43 40:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 44 40:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 45 40:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 46 40:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 47 40:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 48 40:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 49 41:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57ad]
IOMMU Group 50 42:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 51 42:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 52 42:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 53 42:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 54 42:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 55 42:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 55 48:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 55 48:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 55 48:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 56 42:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 56 49:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 57 4a:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 57 42:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 58 43:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation Device [1987:5016] (rev 01)
IOMMU Group 59 44:00.0 USB controller [0c03]: ASMedia Technology Inc. Device [1b21:3242]
IOMMU Group 60 45:00.0 Ethernet controller [0200]: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] [1d6a:07b1] (rev 02)
IOMMU Group 61 46:00.0 Network controller [0280]: Intel Corporation Device [8086:2723] (rev 1a)
IOMMU Group 62 47:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Device [10ec:8125] (rev 01)
IOMMU Group 63 4b:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation Device [1987:5016] (rev 01)
IOMMU Group 64 4c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 65 4d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 66 60:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 67 60:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 68 60:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 69 60:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 70 60:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 71 60:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 72 60:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 73 60:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 74 60:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 75 61:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 76 62:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485] 
dmesg –kernel
[    0.373052] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.373052] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.373053] pci_bus 0000:00: resource 10 [mem 0xe4000000-0xe63ffffe window]
[    0.373053] pci_bus 0000:00: resource 11 [mem 0x63de0200000-0x7a3931fffff window]
[    0.373054] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.373055] pci_bus 0000:01: resource 1 [mem 0xe6000000-0xe61fffff]
[    0.373055] pci_bus 0000:01: resource 2 [mem 0x7a380000000-0x7a3901fffff 64bit pref]
[    0.373056] pci_bus 0000:02: resource 0 [io  0x3000-0x3fff]
[    0.373056] pci_bus 0000:02: resource 1 [mem 0xe6000000-0xe60fffff]
[    0.373057] pci_bus 0000:02: resource 2 [mem 0x7a380000000-0x7a3901fffff 64bit pref]
[    0.373057] pci_bus 0000:03: resource 0 [io  0x3000-0x3fff]
[    0.373058] pci_bus 0000:03: resource 1 [mem 0xe6000000-0xe60fffff]
[    0.373058] pci_bus 0000:03: resource 2 [mem 0x7a380000000-0x7a3901fffff 64bit pref]
[    0.373059] pci_bus 0000:05: resource 1 [mem 0xe6200000-0xe62fffff]
[    0.373091] pci 0000:22:00.0: PCI bridge to [bus 23]
[    0.373092] pci 0000:22:00.0:   bridge window [io  0x6000-0x6fff]
[    0.373095] pci 0000:22:00.0:   bridge window [mem 0xc2300000-0xc23fffff]
[    0.373098] pci 0000:22:00.0:   bridge window [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373102] pci 0000:21:00.0: PCI bridge to [bus 22-23]
[    0.373104] pci 0000:21:00.0:   bridge window [io  0x6000-0x6fff]
[    0.373107] pci 0000:21:00.0:   bridge window [mem 0xc2300000-0xc23fffff]
[    0.373109] pci 0000:21:00.0:   bridge window [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373114] pci 0000:20:03.1: PCI bridge to [bus 21-23]
[    0.373115] pci 0000:20:03.1:   bridge window [io  0x6000-0x6fff]
[    0.373117] pci 0000:20:03.1:   bridge window [mem 0xc2300000-0xc24fffff]
[    0.373118] pci 0000:20:03.1:   bridge window [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373121] pci 0000:20:07.1: PCI bridge to [bus 24]
[    0.373127] pci 0000:20:08.1: PCI bridge to [bus 25]
[    0.373130] pci 0000:20:08.1:   bridge window [mem 0xc2000000-0xc22fffff]
[    0.373134] pci_bus 0000:20: resource 4 [io  0x4000-0x6fff window]
[    0.373134] pci_bus 0000:20: resource 5 [mem 0xc0000000-0xc25ffffe window]
[    0.373135] pci_bus 0000:20: resource 6 [mem 0x47ea0200000-0x5e4531fffff window]
[    0.373136] pci_bus 0000:21: resource 0 [io  0x6000-0x6fff]
[    0.373136] pci_bus 0000:21: resource 1 [mem 0xc2300000-0xc24fffff]
[    0.373137] pci_bus 0000:21: resource 2 [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373137] pci_bus 0000:22: resource 0 [io  0x6000-0x6fff]
[    0.373138] pci_bus 0000:22: resource 1 [mem 0xc2300000-0xc23fffff]
[    0.373138] pci_bus 0000:22: resource 2 [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373139] pci_bus 0000:23: resource 0 [io  0x6000-0x6fff]
[    0.373139] pci_bus 0000:23: resource 1 [mem 0xc2300000-0xc23fffff]
[    0.373140] pci_bus 0000:23: resource 2 [mem 0x5e440000000-0x5e4501fffff 64bit pref]
[    0.373141] pci_bus 0000:25: resource 1 [mem 0xc2000000-0xc22fffff]
[    0.373162] pci_bus 0000:40: max bus depth: 3 pci_try_num: 4
[    0.373166] pci 0000:42:01.0: PCI bridge to [bus 43]
[    0.373170] pci 0000:42:01.0:   bridge window [mem 0xced00000-0xcedfffff]
[    0.373179] pci 0000:42:02.0: PCI bridge to [bus 44]
[    0.373184] pci 0000:42:02.0:   bridge window [mem 0xcec00000-0xcecfffff]
[    0.373192] pci 0000:42:03.0: PCI bridge to [bus 45]
[    0.373197] pci 0000:42:03.0:   bridge window [mem 0xce000000-0xce4fffff]
[    0.373206] pci 0000:42:04.0: PCI bridge to [bus 46]
[    0.373210] pci 0000:42:04.0:   bridge window [mem 0xceb00000-0xcebfffff]
[    0.373220] pci 0000:47:00.0: BAR 9: assigned [mem 0xcea20000-0xcea8ffff 64bit]
[    0.373227] pci 0000:47:00.0: BAR 11: assigned [mem 0xcea90000-0xceaabfff 64bit]
[    0.373233] pci 0000:42:05.0: PCI bridge to [bus 47]
[    0.373235] pci 0000:42:05.0:   bridge window [io  0xc000-0xcfff]
[    0.373240] pci 0000:42:05.0:   bridge window [mem 0xcea00000-0xceafffff]
[    0.373249] pci 0000:42:08.0: PCI bridge to [bus 48]
[    0.373253] pci 0000:42:08.0:   bridge window [mem 0xce600000-0xce7fffff]
[    0.373262] pci 0000:42:09.0: PCI bridge to [bus 49]
[    0.373267] pci 0000:42:09.0:   bridge window [mem 0xce900000-0xce9fffff]
[    0.373275] pci 0000:42:0a.0: PCI bridge to [bus 4a]
[    0.373280] pci 0000:42:0a.0:   bridge window [mem 0xce800000-0xce8fffff]
[    0.373288] pci 0000:41:00.0: PCI bridge to [bus 42-4a]
[    0.373290] pci 0000:41:00.0:   bridge window [io  0xc000-0xcfff]
[    0.373295] pci 0000:41:00.0:   bridge window [mem 0xce000000-0xcedfffff]
[    0.373303] pci 0000:40:01.1: PCI bridge to [bus 41-4a]
[    0.373304] pci 0000:40:01.1:   bridge window [io  0xc000-0xcfff]
[    0.373307] pci 0000:40:01.1:   bridge window [mem 0xce000000-0xcedfffff]
[    0.373311] pci 0000:40:01.3: PCI bridge to [bus 4b]
[    0.373313] pci 0000:40:01.3:   bridge window [mem 0xcef00000-0xceffffff]
[    0.373317] pci 0000:40:07.1: PCI bridge to [bus 4c]
[    0.373323] pci 0000:40:08.1: PCI bridge to [bus 4d]
[    0.373329] pci_bus 0000:40: resource 4 [io  0x7000-0xcfff window]
[    0.373329] pci_bus 0000:40: resource 5 [mem 0xcc000000-0xcf3ffffe window]
[    0.373330] pci_bus 0000:40: resource 6 [mem 0x2bf60200000-0x425131fffff window]
[    0.373330] pci_bus 0000:41: resource 0 [io  0xc000-0xcfff]
[    0.373331] pci_bus 0000:41: resource 1 [mem 0xce000000-0xcedfffff]
[    0.373331] pci_bus 0000:42: resource 0 [io  0xc000-0xcfff]
[    0.373332] pci_bus 0000:42: resource 1 [mem 0xce000000-0xcedfffff]
[    0.373332] pci_bus 0000:43: resource 1 [mem 0xced00000-0xcedfffff]
[    0.373333] pci_bus 0000:44: resource 1 [mem 0xcec00000-0xcecfffff]
[    0.373333] pci_bus 0000:45: resource 1 [mem 0xce000000-0xce4fffff]
[    0.373334] pci_bus 0000:46: resource 1 [mem 0xceb00000-0xcebfffff]
[    0.373335] pci_bus 0000:47: resource 0 [io  0xc000-0xcfff]
[    0.373335] pci_bus 0000:47: resource 1 [mem 0xcea00000-0xceafffff]
[    0.373336] pci_bus 0000:48: resource 1 [mem 0xce600000-0xce7fffff]
[    0.373336] pci_bus 0000:49: resource 1 [mem 0xce900000-0xce9fffff]
[    0.373337] pci_bus 0000:4a: resource 1 [mem 0xce800000-0xce8fffff]
[    0.373337] pci_bus 0000:4b: resource 1 [mem 0xcef00000-0xceffffff]
[    0.373372] pci 0000:60:07.1: PCI bridge to [bus 61]
[    0.373378] pci 0000:60:08.1: PCI bridge to [bus 62]
[    0.373384] pci_bus 0000:60: resource 4 [io  0xd000-0xffff window]
[    0.373384] pci_bus 0000:60: resource 5 [mem 0xd8000000-0xd9ffffff window]
[    0.373385] pci_bus 0000:60: resource 6 [mem 0x10020200000-0x265d31fffff window]
[    0.373471] NET: Registered protocol family 2
[    0.373823] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.374081] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.374507] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.374569] TCP: Hash tables configured (established 524288 bind 65536)
[    0.374712] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.374829] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.375038] NET: Registered protocol family 1
[    0.375041] NET: Registered protocol family 44
[    0.375068] pci 0000:02:00.0: CLS mismatch (64 != 548), using 64 bytes
[    0.375073] pci 0000:03:00.1: D0 power state depends on 0000:03:00.0
[    0.375240] pci 0000:23:00.1: D0 power state depends on 0000:23:00.0
[    0.375731] Trying to unpack rootfs image as initramfs...
[    0.747431] Freeing initrd memory: 41352K
[    0.747468] pci 0000:60:00.2: AMD-Vi: IOMMU performance counters supported
[    0.747506] pci 0000:40:00.2: AMD-Vi: IOMMU performance counters supported
[    0.747524] pci 0000:20:00.2: AMD-Vi: IOMMU performance counters supported
[    0.747540] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.748572] pci 0000:00:01.0: Adding to iommu group 0
[    0.749005] pci 0000:00:01.1: Adding to iommu group 1
[    0.749567] pci 0000:00:02.0: Adding to iommu group 2
[    0.749960] pci 0000:00:03.0: Adding to iommu group 3
[    0.750513] pci 0000:00:04.0: Adding to iommu group 4
[    0.750920] pci 0000:00:05.0: Adding to iommu group 5
[    0.751486] pci 0000:00:07.0: Adding to iommu group 6
[    0.751898] pci 0000:00:07.1: Adding to iommu group 7
[    0.752463] pci 0000:00:08.0: Adding to iommu group 8
[    0.752867] pci 0000:00:08.1: Adding to iommu group 9
[    0.753444] pci 0000:00:14.0: Adding to iommu group 10
[    0.753465] pci 0000:00:14.3: Adding to iommu group 10
[    0.753832] pci 0000:00:18.0: Adding to iommu group 11
[    0.753853] pci 0000:00:18.1: Adding to iommu group 11
[    0.753872] pci 0000:00:18.2: Adding to iommu group 11
[    0.753892] pci 0000:00:18.3: Adding to iommu group 11
[    0.753913] pci 0000:00:18.4: Adding to iommu group 11
[    0.753933] pci 0000:00:18.5: Adding to iommu group 11
[    0.753952] pci 0000:00:18.6: Adding to iommu group 11
[    0.753972] pci 0000:00:18.7: Adding to iommu group 11
[    0.754465] pci 0000:01:00.0: Adding to iommu group 12
[    0.754810] pci 0000:02:00.0: Adding to iommu group 13
[    0.755424] pci 0000:03:00.0: Adding to iommu group 14
[    0.755608] pci 0000:03:00.0: Using iommu direct mapping
[    0.755833] pci 0000:03:00.1: Adding to iommu group 15
[    0.756146] pci 0000:04:00.0: Adding to iommu group 16
[    0.756646] pci 0000:05:00.0: Adding to iommu group 17
[    0.756974] pci 0000:05:00.3: Adding to iommu group 18
[    0.757460] pci 0000:20:01.0: Adding to iommu group 19
[    0.757782] pci 0000:20:02.0: Adding to iommu group 20
[    0.758236] pci 0000:20:03.0: Adding to iommu group 21
[    0.758723] pci 0000:20:03.1: Adding to iommu group 22
[    0.759049] pci 0000:20:04.0: Adding to iommu group 23
[    0.759532] pci 0000:20:05.0: Adding to iommu group 24
[    0.759865] pci 0000:20:07.0: Adding to iommu group 25
[    0.760346] pci 0000:20:07.1: Adding to iommu group 26
[    0.760677] pci 0000:20:08.0: Adding to iommu group 27
[    0.761160] pci 0000:20:08.1: Adding to iommu group 28
[    0.761488] pci 0000:21:00.0: Adding to iommu group 29
[    0.762011] pci 0000:22:00.0: Adding to iommu group 30
[    0.762465] pci 0000:23:00.0: Adding to iommu group 31
[    0.762649] pci 0000:23:00.0: Using iommu direct mapping
[    0.762880] pci 0000:23:00.1: Adding to iommu group 32
[    0.763308] pci 0000:24:00.0: Adding to iommu group 33
[    0.763805] pci 0000:25:00.0: Adding to iommu group 34
[    0.764141] pci 0000:25:00.1: Adding to iommu group 35
[    0.764633] pci 0000:25:00.3: Adding to iommu group 36
[    0.764971] pci 0000:25:00.4: Adding to iommu group 37
[    0.765466] pci 0000:40:01.0: Adding to iommu group 38
[    0.765790] pci 0000:40:01.1: Adding to iommu group 39
[    0.766274] pci 0000:40:01.3: Adding to iommu group 40
[    0.766603] pci 0000:40:02.0: Adding to iommu group 41
[    0.767085] pci 0000:40:03.0: Adding to iommu group 42
[    0.767525] pci 0000:40:04.0: Adding to iommu group 43
[    0.767848] pci 0000:40:05.0: Adding to iommu group 44
[    0.768333] pci 0000:40:07.0: Adding to iommu group 45
[    0.768670] pci 0000:40:07.1: Adding to iommu group 46
[    0.769159] pci 0000:40:08.0: Adding to iommu group 47
[    0.769498] pci 0000:40:08.1: Adding to iommu group 48
[    0.769987] pci 0000:41:00.0: Adding to iommu group 49
[    0.770415] pci 0000:42:01.0: Adding to iommu group 50
[    0.770980] pci 0000:42:02.0: Adding to iommu group 51
[    0.771405] pci 0000:42:03.0: Adding to iommu group 52
[    0.771963] pci 0000:42:04.0: Adding to iommu group 53
[    0.772513] pci 0000:42:05.0: Adding to iommu group 54
[    0.772870] pci 0000:42:08.0: Adding to iommu group 55
[    0.773384] pci 0000:42:09.0: Adding to iommu group 56
[    0.773746] pci 0000:42:0a.0: Adding to iommu group 57
[    0.774301] pci 0000:43:00.0: Adding to iommu group 58
[    0.774697] pci 0000:44:00.0: Adding to iommu group 59
[    0.775239] pci 0000:45:00.0: Adding to iommu group 60
[    0.775622] pci 0000:46:00.0: Adding to iommu group 61
[    0.776208] pci 0000:47:00.0: Adding to iommu group 62
[    0.776243] pci 0000:48:00.0: Adding to iommu group 55
[    0.776281] pci 0000:48:00.1: Adding to iommu group 55
[    0.776309] pci 0000:48:00.3: Adding to iommu group 55
[    0.776342] pci 0000:49:00.0: Adding to iommu group 56
[    0.776376] pci 0000:4a:00.0: Adding to iommu group 57
[    0.776828] pci 0000:4b:00.0: Adding to iommu group 63
[    0.777157] pci 0000:4c:00.0: Adding to iommu group 64
[    0.777618] pci 0000:4d:00.0: Adding to iommu group 65
[    0.778106] pci 0000:60:01.0: Adding to iommu group 66
[    0.778443] pci 0000:60:02.0: Adding to iommu group 67
[    0.778927] pci 0000:60:03.0: Adding to iommu group 68
[    0.779264] pci 0000:60:04.0: Adding to iommu group 69
[    0.779747] pci 0000:60:05.0: Adding to iommu group 70
[    0.780094] pci 0000:60:07.0: Adding to iommu group 71
[    0.780581] pci 0000:60:07.1: Adding to iommu group 72
[    0.780923] pci 0000:60:08.0: Adding to iommu group 73
[    0.781416] pci 0000:60:08.1: Adding to iommu group 74
[    0.781755] pci 0000:61:00.0: Adding to iommu group 75
[    0.782244] pci 0000:62:00.0: Adding to iommu group 76
[    0.782388] pci 0000:60:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.782389] pci 0000:60:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[    0.782389]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    0.782391] pci 0000:40:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.782392] pci 0000:40:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[    0.782392]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    0.782393] pci 0000:20:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.782394] pci 0000:20:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[    0.782394]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    0.782395] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.782395] pci 0000:00:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[    0.782395]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    0.782396] AMD-Vi: Interrupt remapping enabled
[    0.782396] AMD-Vi: Virtual APIC enabled
[    0.782396] AMD-Vi: X2APIC enabled
[    0.782746] AMD-Vi: Lazy IO/TLB flushing enabled
[    0.783401] amd_uncore: AMD NB counters detected
[    0.783417] amd_uncore: AMD LLC counters detected
[    0.785227] LVT offset 0 assigned for vector 0x400
[    0.786108] perf: AMD IBS detected (0x000003ff)
[    0.786121] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.786132] perf/amd_iommu: Detected AMD IOMMU #1 (2 banks, 4 counters/bank).
[    0.786145] perf/amd_iommu: Detected AMD IOMMU #2 (2 banks, 4 counters/bank).
[    0.786157] perf/amd_iommu: Detected AMD IOMMU #3 (2 banks, 4 counters/bank).
[    0.786197] check: Scanning for low memory corruption every 60 seconds
[    0.788011] Initialise system trusted keyrings
[    0.788022] Key type blacklist registered
[    0.788065] workingset: timestamp_bits=36 max_order=24 bucket_order=0
[    0.788727] zbud: loaded
[    0.789067] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.789202] fuse: init (API version 7.31)
[    0.789217] *** VALIDATE fuse ***
[    0.789218] *** VALIDATE fuse ***
[    0.789301] Platform Keyring initialized
[    0.791301] Key type asymmetric registered
[    0.791302] Asymmetric key parser 'x509' registered
[    0.791307] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.791894] io scheduler mq-deadline registered
[    0.793314] pcieport 0000:00:01.1: PME: Signaling with IRQ 31
[    0.793367] pcieport 0000:00:01.1: AER: enabled with IRQ 31
[    0.793409] pcieport 0000:00:01.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[    0.793578] pcieport 0000:00:07.1: PME: Signaling with IRQ 33
[    0.793623] pcieport 0000:00:07.1: AER: enabled with IRQ 33
[    0.793714] pcieport 0000:00:08.1: PME: Signaling with IRQ 34
[    0.793757] pcieport 0000:00:08.1: AER: enabled with IRQ 34
[    0.794116] pcieport 0000:20:03.1: PME: Signaling with IRQ 38
[    0.794169] pcieport 0000:20:03.1: AER: enabled with IRQ 38
[    0.794210] pcieport 0000:20:03.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[    0.794355] pcieport 0000:20:07.1: PME: Signaling with IRQ 40
[    0.794404] pcieport 0000:20:07.1: AER: enabled with IRQ 40
[    0.794489] pcieport 0000:20:08.1: PME: Signaling with IRQ 41
[    0.794541] pcieport 0000:20:08.1: AER: enabled with IRQ 41
[    0.794880] pcieport 0000:40:01.1: PME: Signaling with IRQ 45
[    0.794951] pcieport 0000:40:01.1: AER: enabled with IRQ 45
[    0.794992] pcieport 0000:40:01.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[    0.795094] pcieport 0000:40:01.3: PME: Signaling with IRQ 46
[    0.795140] pcieport 0000:40:01.3: AER: enabled with IRQ 46
[    0.795180] pcieport 0000:40:01.3: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[    0.795319] pcieport 0000:40:07.1: PME: Signaling with IRQ 48
[    0.795368] pcieport 0000:40:07.1: AER: enabled with IRQ 48
[    0.795491] pcieport 0000:40:08.1: PME: Signaling with IRQ 50
[    0.795539] pcieport 0000:40:08.1: AER: enabled with IRQ 50
[    0.797554] pcieport 0000:60:07.1: PME: Signaling with IRQ 62
[    0.797604] pcieport 0000:60:07.1: AER: enabled with IRQ 62
[    0.797724] pcieport 0000:60:08.1: PME: Signaling with IRQ 64
[    0.797771] pcieport 0000:60:08.1: AER: enabled with IRQ 64
[    0.797819] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.798014] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.798024] ACPI: Power Button [PWRB]
[    0.798042] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.798082] ACPI: Power Button [PWRF]
[    0.798123] Monitor-Mwait will be used to enter C-1 state
[    0.804009] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.804755] Linux agpgart interface v0.103
[    0.813304] loop: module loaded
[    0.813541] nvme nvme0: pci function 0000:43:00.0
[    0.813573] nvme nvme1: pci function 0000:4b:00.0
[    0.813644] libphy: Fixed MDIO Bus: probed
[    0.813644] tun: Universal TUN/TAP device driver, 1.6
[    0.813661] PPP generic driver version 2.4.2
[    0.813688] VFIO - User Level meta-driver version: 0.3
[    0.813771] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.813773] ehci-pci: EHCI PCI platform driver
[    0.813781] ehci-platform: EHCI generic platform driver
[    0.813785] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.813786] ohci-pci: OHCI PCI platform driver
[    0.813796] ohci-platform: OHCI generic platform driver
[    0.813800] uhci_hcd: USB Universal Host Controller Interface driver
[    0.813912] xhci_hcd 0000:05:00.3: xHCI Host Controller
[    0.813916] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 1
[    0.814003] xhci_hcd 0000:05:00.3: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.814332] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.814333] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.814334] usb usb1: Product: xHCI Host Controller
[    0.814334] usb usb1: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.814335] usb usb1: SerialNumber: 0000:05:00.3
[    0.814378] hub 1-0:1.0: USB hub found
[    0.814383] hub 1-0:1.0: 2 ports detected
[    0.814543] xhci_hcd 0000:05:00.3: xHCI Host Controller
[    0.814545] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 2
[    0.814546] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.814556] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.814567] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.814567] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.814568] usb usb2: Product: xHCI Host Controller
[    0.814568] usb usb2: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.814569] usb usb2: SerialNumber: 0000:05:00.3
[    0.814603] hub 2-0:1.0: USB hub found
[    0.814606] hub 2-0:1.0: 2 ports detected
[    0.814693] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    0.814696] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 3
[    0.814781] xhci_hcd 0000:25:00.3: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.815078] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.815079] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.815079] usb usb3: Product: xHCI Host Controller
[    0.815080] usb usb3: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.815080] usb usb3: SerialNumber: 0000:25:00.3
[    0.815117] hub 3-0:1.0: USB hub found
[    0.815121] hub 3-0:1.0: 2 ports detected
[    0.815178] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    0.815180] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 4
[    0.815181] xhci_hcd 0000:25:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.815188] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.815196] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.815196] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.815197] usb usb4: Product: xHCI Host Controller
[    0.815197] usb usb4: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.815198] usb usb4: SerialNumber: 0000:25:00.3
[    0.815230] hub 4-0:1.0: USB hub found
[    0.815234] hub 4-0:1.0: 2 ports detected
[    0.815311] xhci_hcd 0000:44:00.0: xHCI Host Controller
[    0.815313] xhci_hcd 0000:44:00.0: new USB bus registered, assigned bus number 5
[    0.870046] xhci_hcd 0000:44:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
[    0.870404] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.870404] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.870405] usb usb5: Product: xHCI Host Controller
[    0.870405] usb usb5: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.870406] usb usb5: SerialNumber: 0000:44:00.0
[    0.870439] hub 5-0:1.0: USB hub found
[    0.870443] hub 5-0:1.0: 1 port detected
[    0.870505] xhci_hcd 0000:44:00.0: xHCI Host Controller
[    0.870506] xhci_hcd 0000:44:00.0: new USB bus registered, assigned bus number 6
[    0.870507] xhci_hcd 0000:44:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[    0.870537] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.870544] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.870545] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.870545] usb usb6: Product: xHCI Host Controller
[    0.870546] usb usb6: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.870546] usb usb6: SerialNumber: 0000:44:00.0
[    0.870576] hub 6-0:1.0: USB hub found
[    0.870579] hub 6-0:1.0: 1 port detected
[    0.870717] xhci_hcd 0000:48:00.1: xHCI Host Controller
[    0.870718] xhci_hcd 0000:48:00.1: new USB bus registered, assigned bus number 7
[    0.870865] xhci_hcd 0000:48:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.871390] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.871390] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.871391] usb usb7: Product: xHCI Host Controller
[    0.871391] usb usb7: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.871392] usb usb7: SerialNumber: 0000:48:00.1
[    0.871429] hub 7-0:1.0: USB hub found
[    0.871441] hub 7-0:1.0: 6 ports detected
[    0.871589] xhci_hcd 0000:48:00.1: xHCI Host Controller
[    0.871590] xhci_hcd 0000:48:00.1: new USB bus registered, assigned bus number 8
[    0.871591] xhci_hcd 0000:48:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[    0.871599] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.871608] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.871609] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.871609] usb usb8: Product: xHCI Host Controller
[    0.871610] usb usb8: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.871610] usb usb8: SerialNumber: 0000:48:00.1
[    0.871644] hub 8-0:1.0: USB hub found
[    0.871650] hub 8-0:1.0: 4 ports detected
[    0.871767] xhci_hcd 0000:48:00.3: xHCI Host Controller
[    0.871769] xhci_hcd 0000:48:00.3: new USB bus registered, assigned bus number 9
[    0.871919] xhci_hcd 0000:48:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.872286] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.872287] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.872287] usb usb9: Product: xHCI Host Controller
[    0.872288] usb usb9: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.872288] usb usb9: SerialNumber: 0000:48:00.3
[    0.872324] hub 9-0:1.0: USB hub found
[    0.872335] hub 9-0:1.0: 6 ports detected
[    0.872496] xhci_hcd 0000:48:00.3: xHCI Host Controller
[    0.872498] xhci_hcd 0000:48:00.3: new USB bus registered, assigned bus number 10
[    0.872499] xhci_hcd 0000:48:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.872507] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.872517] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.872518] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.872518] usb usb10: Product: xHCI Host Controller
[    0.872519] usb usb10: Manufacturer: Linux 5.4.34-1-pve xhci-hcd
[    0.872519] usb usb10: SerialNumber: 0000:48:00.3
[    0.872553] hub 10-0:1.0: USB hub found
[    0.872560] hub 10-0:1.0: 4 ports detected
[    0.872584] usb: port power management may be unreliable
[    0.872661] i8042: PNP: No PS/2 controller found.
[    0.872685] mousedev: PS/2 mouse device common for all mice
[    0.872740] rtc_cmos 00:03: RTC can wake from S4
[    0.872884] rtc_cmos 00:03: registered as rtc0
[    0.872893] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.872895] i2c /dev entries driver
[    0.872940] device-mapper: uevent: version 1.0.3
[    0.872974] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    0.872982] platform eisa.0: Probing EISA bus 0
[    0.872985] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    0.872986] platform eisa.0: Cannot allocate resource for EISA slot 1
[    0.872986] platform eisa.0: Cannot allocate resource for EISA slot 2
[    0.872987] platform eisa.0: Cannot allocate resource for EISA slot 3
[    0.872987] platform eisa.0: Cannot allocate resource for EISA slot 4
[    0.872988] platform eisa.0: Cannot allocate resource for EISA slot 5
[    0.872988] platform eisa.0: Cannot allocate resource for EISA slot 6
[    0.872989] platform eisa.0: Cannot allocate resource for EISA slot 7
[    0.872989] platform eisa.0: Cannot allocate resource for EISA slot 8
[    0.872990] platform eisa.0: EISA: Detected 0 cards
[    0.874538] ledtrig-cpu: registered to indicate activity on CPUs
[    0.874544] EFI Variables Facility v0.08 2004-May-17
[    0.875823] drop_monitor: Initializing network drop monitor service
[    0.875960] NET: Registered protocol family 10
[    0.881705] Segment Routing with IPv6
[    0.881716] NET: Registered protocol family 17
[    0.881727] Bridge firewalling registered
[    0.881774] Key type dns_resolver registered
[    0.885153] RAS: Correctable Errors collector initialized.
[    0.885171] microcode: CPU0: patch_level=0x08301025
[    0.885175] microcode: CPU1: patch_level=0x08301025
[    0.885180] microcode: CPU2: patch_level=0x08301025
[    0.885185] microcode: CPU3: patch_level=0x08301025
[    0.885199] microcode: CPU4: patch_level=0x08301025
[    0.885214] microcode: CPU5: patch_level=0x08301025
[    0.885228] microcode: CPU6: patch_level=0x08301025
[    0.885242] microcode: CPU7: patch_level=0x08301025
[    0.885258] microcode: CPU8: patch_level=0x08301025
[    0.885274] microcode: CPU9: patch_level=0x08301025
[    0.885280] microcode: CPU10: patch_level=0x08301025
[    0.885296] microcode: CPU11: patch_level=0x08301025
[    0.885313] microcode: CPU12: patch_level=0x08301025
[    0.885328] microcode: CPU13: patch_level=0x08301025
[    0.885344] microcode: CPU14: patch_level=0x08301025
[    0.885361] microcode: CPU15: patch_level=0x08301025
[    0.885368] microcode: CPU16: patch_level=0x08301025
[    0.885374] microcode: CPU17: patch_level=0x08301025
[    0.885390] microcode: CPU18: patch_level=0x08301025
[    0.885405] microcode: CPU19: patch_level=0x08301025
[    0.885420] microcode: CPU20: patch_level=0x08301025
[    0.885435] microcode: CPU21: patch_level=0x08301025
[    0.885451] microcode: CPU22: patch_level=0x08301025
[    0.885458] microcode: CPU23: patch_level=0x08301025
[    0.885473] microcode: CPU24: patch_level=0x08301025
[    0.885488] microcode: CPU25: patch_level=0x08301025
[    0.885503] microcode: CPU26: patch_level=0x08301025
[    0.885517] microcode: CPU27: patch_level=0x08301025
[    0.885532] microcode: CPU28: patch_level=0x08301025
[    0.885548] microcode: CPU29: patch_level=0x08301025
[    0.885564] microcode: CPU30: patch_level=0x08301025
[    0.885579] microcode: CPU31: patch_level=0x08301025
[    0.885584] microcode: CPU32: patch_level=0x08301025
[    0.885588] microcode: CPU33: patch_level=0x08301025
[    0.885590] microcode: CPU34: patch_level=0x08301025
[    0.885595] microcode: CPU35: patch_level=0x08301025
[    0.885600] microcode: CPU36: patch_level=0x08301025
[    0.885605] microcode: CPU37: patch_level=0x08301025
[    0.885611] microcode: CPU38: patch_level=0x08301025
[    0.885625] microcode: CPU39: patch_level=0x08301025
[    0.885639] microcode: CPU40: patch_level=0x08301025
[    0.885653] microcode: CPU41: patch_level=0x08301025
[    0.885668] microcode: CPU42: patch_level=0x08301025
[    0.885677] microcode: CPU43: patch_level=0x08301025
[    0.885691] microcode: CPU44: patch_level=0x08301025
[    0.885705] microcode: CPU45: patch_level=0x08301025
[    0.885719] microcode: CPU46: patch_level=0x08301025
[    0.885734] microcode: CPU47: patch_level=0x08301025
[    0.885748] microcode: CPU48: patch_level=0x08301025
[    0.885754] microcode: CPU49: patch_level=0x08301025
[    0.885768] microcode: CPU50: patch_level=0x08301025
[    0.885783] microcode: CPU51: patch_level=0x08301025
[    0.885797] microcode: CPU52: patch_level=0x08301025
[    0.885812] microcode: CPU53: patch_level=0x08301025
[    0.885827] microcode: CPU54: patch_level=0x08301025
[    0.885834] microcode: CPU55: patch_level=0x08301025
[    0.885848] microcode: CPU56: patch_level=0x08301025
[    0.885862] microcode: CPU57: patch_level=0x08301025
[    0.885876] microcode: CPU58: patch_level=0x08301025
[    0.885891] microcode: CPU59: patch_level=0x08301025
[    0.885906] microcode: CPU60: patch_level=0x08301025
[    0.885921] microcode: CPU61: patch_level=0x08301025
[    0.885927] microcode: CPU62: patch_level=0x08301025
[    0.885943] microcode: CPU63: patch_level=0x08301025
[    0.885959] microcode: Microcode Update Driver: v2.2.
[    0.887013] *** VALIDATE rdt ***
[    0.887017] resctrl: L3 allocation detected
[    0.887017] resctrl: L3DATA allocation detected
[    0.887017] resctrl: L3CODE allocation detected
[    0.887017] resctrl: MB allocation detected
[    0.887018] resctrl: L3 monitoring detected
[    0.887020] IPI shorthand broadcast: enabled
[    0.887025] sched_clock: Marking stable (919002491, -31994400)->(892624769, -5616678)
[    0.887319] registered taskstats version 1
[    0.887326] Loading compiled-in X.509 certificates
[    0.888495] Loaded X.509 cert 'Build time autogenerated kernel key: c449e5885e9d432bd16bf0ec456145bfaa491117'
[    0.888636] zswap: loaded using pool lzo/zbud
[    0.888930] Key type ._fscrypt registered
[    0.888930] Key type .fscrypt registered
[    0.894006] Key type big_key registered
[    0.896285] Key type encrypted registered
[    0.896287] AppArmor: AppArmor sha1 policy hashing enabled
[    0.896391] ima: No TPM chip found, activating TPM-bypass!
[    0.896393] ima: Allocated hash algorithm: sha1
[    0.896398] ima: No architecture policies found
[    0.896402] evm: Initialising EVM extended attributes:
[    0.896403] evm: security.selinux
[    0.896403] evm: security.SMACK64
[    0.896403] evm: security.SMACK64EXEC
[    0.896403] evm: security.SMACK64TRANSMUTE
[    0.896403] evm: security.SMACK64MMAP
[    0.896404] evm: security.apparmor
[    0.896404] evm: security.ima
[    0.896404] evm: security.capability
[    0.896404] evm: HMAC attrs: 0x1
[    0.896922] PM:   Magic number: 4:848:849
[    0.897042] graphics fbcon: hash matches
[    0.897049] processor cpu13: hash matches
[    0.897609] rtc_cmos 00:03: setting system clock to 2020-05-14T19:48:41 UTC (1589485721)
[    0.899042] acpi_cpufreq: overriding BIOS provided _PSD data
[    1.028593] nvme nvme1: missing or invalid SUBNQN field.
[    1.028610] nvme nvme1: Shutdown timeout set to 10 seconds
[    1.028622] nvme nvme0: missing or invalid SUBNQN field.
[    1.028634] nvme nvme0: Shutdown timeout set to 10 seconds
[    1.029823] nvme nvme0: 8/0/0 default/read/poll queues
[    1.029827] nvme nvme1: 8/0/0 default/read/poll queues
[    1.031509]  nvme0n1: p1 p2
[    1.033742] Freeing unused decrypted memory: 2040K
[    1.034175] Freeing unused kernel image memory: 2712K
[    1.044051] Write protecting the kernel read-only data: 22528k
[    1.045140] Freeing unused kernel image memory: 2008K
[    1.045515] Freeing unused kernel image memory: 1068K
[    1.052905] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.052907] Run /init as init process
[    1.148035] usb 3-1: new low-speed USB device number 2 using xhci_hcd
[    1.150205] wmi: module verification failed: signature and/or required key missing - tainting kernel
[    1.160691] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    1.160692] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[    1.164901] atlantic 0000:45:00.0: enabling device (0000 -> 0002)
[    1.166184] r8169 0000:47:00.0: enabling device (0000 -> 0003)
[    1.167281] ahci 0000:49:00.0: version 3.0
[    1.177458] libphy: r8169: probed
[    1.177632] r8169 0000:47:00.0 eth0: RTL8125, a8:a1:59:16:33:85, XID 609, IRQ 130
[    1.177633] r8169 0000:47:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.197718] r8169 0000:47:00.0 enp71s0: renamed from eth0
[    1.204048] usb 7-5: new full-speed USB device number 2 using xhci_hcd
[    1.208050] usb 9-5: new high-speed USB device number 2 using xhci_hcd
[    1.314284] usb 3-1: New USB device found, idVendor=05ac, idProduct=0304, bcdDevice= 1.10
[    1.314285] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.314287] usb 3-1: Product: Apple Optical USB Mouse
[    1.314287] usb 3-1: Manufacturer: Mitsumi Electric
[    1.371606] usb 7-5: New USB device found, idVendor=26ce, idProduct=01a2, bcdDevice= 0.00
[    1.371607] usb 7-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.371608] usb 7-5: Product: LED Controller
[    1.371609] usb 7-5: Manufacturer: ASRock
[    1.371610] usb 7-5: SerialNumber: A02019100900
[    1.456044] usb 3-2: new full-speed USB device number 3 using xhci_hcd
[    1.504050] usb 7-6: new full-speed USB device number 3 using xhci_hcd
[    1.622248] usb 3-2: New USB device found, idVendor=1532, idProduct=0109, bcdDevice= a.04
[    1.622250] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.622250] usb 3-2: Product: Razer Lycosa
[    1.622251] usb 3-2: Manufacturer: Razer
[    1.677058] atlantic 0000:45:00.0 enp69s0: renamed from eth0
[    1.677728] hidraw: raw HID events driver (C) Jiri Kosina
[    1.683579] usb 7-6: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[    1.683580] usb 7-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.699610] usbcore: registered new interface driver usbhid
[    1.699611] usbhid: USB HID core driver
[    1.701023] usbcore: registered new interface driver usbmouse
[    1.716335] usbcore: registered new interface driver usbkbd
[    1.718017] input: ASRock LED Controller as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:48:00.1/usb7/7-5/7-5:1.0/0003:26CE:01A2.0002/input/input2
[    1.776087] hid-generic 0003:26CE:01A2.0002: input,hidraw0: USB HID v1.10 Device [ASRock LED Controller] on usb-0000:48:00.1-5/input0
[    1.776181] input: Razer Razer Lycosa as /devices/pci0000:20/0000:20:08.1/0000:25:00.3/usb3/3-2/3-2:1.0/0003:1532:0109.0003/input/input3
[    1.788014] tsc: Refined TSC clocksource calibration: 3700.009 MHz
[    1.788038] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6aaabc71ca1, max_idle_ns: 881590766374 ns
[    1.788391] clocksource: Switched to clocksource tsc
[    1.836082] hid-generic 0003:1532:0109.0003: input,hidraw1: USB HID v1.10 Keyboard [Razer Razer Lycosa] on usb-0000:25:00.3-2/input0
[    1.836175] input: Razer Razer Lycosa Consumer Control as /devices/pci0000:20/0000:20:08.1/0000:25:00.3/usb3/3-2/3-2:1.1/0003:1532:0109.0004/input/input4
[    1.896076] input: Razer Razer Lycosa System Control as /devices/pci0000:20/0000:20:08.1/0000:25:00.3/usb3/3-2/3-2:1.1/0003:1532:0109.0004/input/input5
[    1.896113] hid-generic 0003:1532:0109.0004: input,hidraw2: USB HID v1.10 Device [Razer Razer Lycosa] on usb-0000:25:00.3-2/input1
[    1.897236] input: Mitsumi Electric Apple Optical USB Mouse as /devices/pci0000:20/0000:20:08.1/0000:25:00.3/usb3/3-1/3-1:1.0/0003:05AC:0304.0001/input/input6
[    1.897340] apple 0003:05AC:0304.0001: input,hidraw3: USB HID v1.10 Mouse [Mitsumi Electric Apple Optical USB Mouse] on usb-0000:25:00.3-1/input0
[    2.174000] ahci 0000:49:00.0: failed stop FIS RX (-16)
[    2.174014] ahci 0000:49:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    2.174015] ahci 0000:49:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    2.174213] scsi host0: ahci
[    2.174292] ata1: SATA max UDMA/133 abar m2048@0xce900000 port 0xce900100 irq 129
[    2.174549] ahci 0000:4a:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x2 impl SATA mode
[    2.174550] ahci 0000:4a:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    2.174753] scsi host1: ahci
[    2.174924] scsi host2: ahci
[    2.174970] ata2: DUMMY
[    2.174972] ata3: SATA max UDMA/133 abar m2048@0xce800000 port 0xce800180 irq 132
[    2.484161] ata1: SATA link down (SStatus 0 SControl 300)
[    2.648491] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.649708] ata3.00: ATA-9: WDC WD40EZRX-00SPEB0, 80.00A80, max UDMA/133
[    2.649709] ata3.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.650470] ata3.00: configured for UDMA/133
[    2.650732] scsi 2:0:0:0: Direct-Access     ATA      WDC WD40EZRX-00S 0A80 PQ: 0 ANSI: 5
[    2.650932] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    2.651048] sd 2:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    2.651050] sd 2:0:0:0: [sda] 4096-byte physical blocks
[    2.651057] sd 2:0:0:0: [sda] Write Protect is off
[    2.651058] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.651069] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.731063]  sda: sda1 sda2 sda3
[    2.731854] sd 2:0:0:0: [sda] Attached SCSI disk
[    3.764092] usb 9-5: New USB device found, idVendor=26ce, idProduct=0a01, bcdDevice= 0.04
[    3.764094] usb 9-5: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[    3.764095] usb 9-5: Product: USB Audio
[    3.764096] usb 9-5: Manufacturer: Generic
[    3.827494] input: Generic USB Audio Consumer Control as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:48:00.3/usb9/9-5/9-5:1.7/0003:26CE:0A01.0005/input/input7
[    3.884600] input: Generic USB Audio as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:48:00.3/usb9/9-5/9-5:1.7/0003:26CE:0A01.0005/input/input8
[    3.884678] hid-generic 0003:26CE:0A01.0005: input,hiddev0,hidraw4: USB HID v1.11 Device [Generic USB Audio] on usb-0000:48:00.3-5/input7
[    5.169515] device-mapper: thin: Data device (dm-3) discard unsupported: Disabling discard passdown.
[    5.384091] raid6: avx2x4   gen() 39357 MB/s
[    5.432069] raid6: avx2x4   xor() 18945 MB/s
[    5.480024] raid6: avx2x2   gen() 37448 MB/s
[    5.528022] raid6: avx2x2   xor() 24729 MB/s
[    5.576028] raid6: avx2x1   gen() 20684 MB/s
[    5.624023] raid6: avx2x1   xor() 18150 MB/s
[    5.672066] raid6: sse2x4   gen() 19359 MB/s
[    5.720025] raid6: sse2x4   xor() 11254 MB/s
[    5.768030] raid6: sse2x2   gen() 18559 MB/s
[    5.816028] raid6: sse2x2   xor() 12603 MB/s
[    5.864030] raid6: sse2x1   gen()  8720 MB/s
[    5.912028] raid6: sse2x1   xor()  9185 MB/s
[    5.912028] raid6: using algorithm avx2x4 gen() 39357 MB/s
[    5.912028] raid6: .... xor() 18945 MB/s, rmw enabled
[    5.912029] raid6: using avx2x2 recovery algorithm
[    5.913791] xor: automatically using best checksumming function   avx
[    5.920093] Btrfs loaded, crc32c=crc32c-intel
[    6.068930] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[    9.089294] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[    9.264658] Loading iSCSI transport class v2.0-870.
[    9.264737] RPC: Registered named UNIX socket transport module.
[    9.264737] RPC: Registered udp transport module.
[    9.264738] RPC: Registered tcp transport module.
[    9.264738] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    9.407394] iscsi: registered transport (tcp)
[    9.623482] iscsi: registered transport (iser)
[    9.878352] spl: loading out-of-tree module taints kernel.
[    9.895156] znvpair: module license 'CDDL' taints kernel.
[    9.895157] Disabling lock debugging due to kernel taint
[   10.140321] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.141527] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.189793] cryptd: max_cpu_qlen set to 1000
[   10.207783] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   10.207784] cfg80211: failed to load regulatory.db
[   10.212675] input: PC Speaker as /devices/platform/pcspkr/input/input9
[   10.243437] AVX2 version of gcm_enc/dec engaged.
[   10.243438] AES CTR mode by8 optimization enabled
[   10.269052] Bluetooth: Core ver 2.22
[   10.269069] NET: Registered protocol family 31
[   10.269070] Bluetooth: HCI device and connection manager initialized
[   10.269072] Bluetooth: HCI socket layer initialized
[   10.269073] Bluetooth: L2CAP socket layer initialized
[   10.269075] Bluetooth: SCO socket layer initialized
[   10.359932] Intel(R) Wireless WiFi driver for Linux
[   10.359933] Copyright(c) 2003- 2015 Intel Corporation
[   10.360025] iwlwifi 0000:46:00.0: enabling device (0000 -> 0002)
[   10.363647] iwlwifi 0000:46:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[   10.363657] iwlwifi 0000:46:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[   10.370032] ccp 0000:25:00.1: enabling device (0000 -> 0002)
[   10.370401] ccp 0000:25:00.1: ccp enabled
[   10.478927] iwlwifi 0000:46:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[   10.478929] iwlwifi 0000:46:00.0: Found debug destination: EXTERNAL_DRAM
[   10.478930] iwlwifi 0000:46:00.0: Found debug configuration: 0
[   10.479136] iwlwifi 0000:46:00.0: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm
[   10.506420] usbcore: registered new interface driver btusb
[   10.508313] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[   10.510306] Bluetooth: hci0: Device revision is 1
[   10.510307] Bluetooth: hci0: Secure boot is enabled
[   10.510307] Bluetooth: hci0: OTP lock is enabled
[   10.510307] Bluetooth: hci0: API lock is enabled
[   10.510307] Bluetooth: hci0: Debug lock is disabled
[   10.510308] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   10.577289] mc: Linux media interface: v0.10
[   10.581272] bluetooth hci0: Direct firmware load for intel/ibt-20-1-3.sfi failed with error -2
[   10.581274] Bluetooth: hci0: Failed to load Intel firmware file (-2)
[   10.744654] iwlwifi 0000:46:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   10.747912] kvm: Nested Virtualization enabled
[   10.747962] kvm: Nested Paging enabled
[   10.747963] SVM: Virtual VMLOAD VMSAVE supported
[   10.747963] SVM: Virtual GIF supported
[   10.756855] iwlwifi 0000:46:00.0: Applying debug destination EXTERNAL_DRAM
[   10.757091] iwlwifi 0000:46:00.0: Allocated 0x00400000 bytes for firmware monitor.
[   10.900947] MCE: In-kernel MCE decoding enabled.
[   10.905492] iwlwifi 0000:46:00.0: base HW address: 50:eb:71:77:e7:fa
[   10.918531] thermal thermal_zone0: failed to read out thermal zone (-61)
[   10.928289] iwlwifi 0000:46:00.0 wlp70s0: renamed from wlan0
[   10.965056] EDAC amd64: Node 0: DRAM ECC disabled.
[   10.965057] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                (Note that use of the override may cause unknown side effects.)
[   11.044740] EDAC amd64: Node 0: DRAM ECC disabled.
[   11.044742] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   11.112857] EDAC amd64: Node 0: DRAM ECC disabled.
[   11.112859] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   11.204831] EDAC amd64: Node 0: DRAM ECC disabled.
[   11.204832] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   11.228030] Adding 8388604k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:8388604k FS
[   11.993810] EDAC amd64: Node 0: DRAM ECC disabled.
[   11.993812] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.516865] ZFS: Loaded module v0.8.3-pve1, ZFS pool version 5000, ZFS filesystem version 5
[   12.541256] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.541258] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.605636] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.605637] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.677024] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.677025] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.737060] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.737061] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.793019] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.793020] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.849015] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.849017] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.916940] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.916941] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   12.977044] EDAC amd64: Node 0: DRAM ECC disabled.
[   12.977046] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.033025] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.033026] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.101118] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.101120] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.161109] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.161110] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.225077] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.225078] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.281233] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.281234] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.296143] usb 9-5: cannot get ctl value: req = 0x83, wValue = 0xc00, wIndex = 0x1300, type = 4
[   13.296149] usb 9-5: 19:0: cannot get min/max values for control 12 (id 19)
[   13.353066] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.353067] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.390477] usbcore: registered new interface driver snd-usb-audio
[   13.405630] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.405631] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.441439] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.441440] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.477157] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.477158] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.529710] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.529711] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.569672] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.569673] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.609441] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.609442] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.645585] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.645586] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.689692] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.689693] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.729661] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.729662] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.777670] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.777671] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.817340] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.817342] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.865685] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.865686] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.909500] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.909501] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.949677] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.949678] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   13.993637] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.993638] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.037636] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.037637] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.073513] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.073514] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.109678] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.109679] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.149666] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.149668] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.185668] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.185669] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.221582] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.221582] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.253651] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.253653] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.293633] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.293634] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.333557] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.333558] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.373558] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.373559] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.413618] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.413618] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.453652] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.453653] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.493593] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.493594] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.533515] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.533516] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.573606] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.573607] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.613619] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.613620] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.653645] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.653646] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.705505] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.705506] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.745501] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.745502] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.785570] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.785571] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.821536] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.821537] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.861551] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.861552] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.897531] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.897532] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.937543] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.937544] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.985502] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.985503] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   15.033499] EDAC amd64: Node 0: DRAM ECC disabled.
[   15.033500] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   15.069480] EDAC amd64: Node 0: DRAM ECC disabled.
[   15.069481] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   15.109488] EDAC amd64: Node 0: DRAM ECC disabled.
[   15.109489] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   15.161481] EDAC amd64: Node 0: DRAM ECC disabled.
[   15.161482] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   15.205475] EDAC amd64: Node 0: DRAM ECC disabled.
[   15.205476] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   16.083469] audit: type=1400 audit(1589485736.679:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1333 comm="apparmor_parser"
[   16.083472] audit: type=1400 audit(1589485736.679:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1333 comm="apparmor_parser"
[   16.083782] audit: type=1400 audit(1589485736.679:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1337 comm="apparmor_parser"
[   16.083784] audit: type=1400 audit(1589485736.679:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1337 comm="apparmor_parser"
[   16.083786] audit: type=1400 audit(1589485736.679:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1337 comm="apparmor_parser"
[   16.117200] audit: type=1400 audit(1589485736.715:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=1335 comm="apparmor_parser"
[   16.186028] audit: type=1400 audit(1589485736.783:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=1334 comm="apparmor_parser"
[   16.198691] audit: type=1400 audit(1589485736.795:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=1336 comm="apparmor_parser"
[   16.198694] audit: type=1400 audit(1589485736.795:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=1336 comm="apparmor_parser"
[   16.198696] audit: type=1400 audit(1589485736.795:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-with-mounting" pid=1336 comm="apparmor_parser"
[   16.369980] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[   16.714373] new mount options do not match the existing superblock, will be ignored
[   16.774147] vmbr0: port 1(enp69s0) entered blocking state
[   16.774149] vmbr0: port 1(enp69s0) entered disabled state
[   16.774252] device enp69s0 entered promiscuous mode
[   17.780417] bpfilter: Loaded bpfilter_umh pid 1521
[   20.775492] atlantic: link change old 0 new 1000
[   20.775536] vmbr0: port 1(enp69s0) entered blocking state
[   20.775536] vmbr0: port 1(enp69s0) entered forwarding state
[   20.775608] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
[   79.923592] vfio-pci 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[   79.940067] vfio-pci 0000:23:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[   79.979996] vfio-pci 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[   79.980120] vfio-pci 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[   80.537457] device tap101i0 entered promiscuous mode
[   80.565667] fwbr101i0: port 1(fwln101i0) entered blocking state
[   80.565668] fwbr101i0: port 1(fwln101i0) entered disabled state
[   80.565765] device fwln101i0 entered promiscuous mode
[   80.565822] fwbr101i0: port 1(fwln101i0) entered blocking state
[   80.565823] fwbr101i0: port 1(fwln101i0) entered forwarding state
[   80.568741] vmbr0: port 2(fwpr101p0) entered blocking state
[   80.568742] vmbr0: port 2(fwpr101p0) entered disabled state
[   80.568822] device fwpr101p0 entered promiscuous mode
[   80.568882] vmbr0: port 2(fwpr101p0) entered blocking state
[   80.568883] vmbr0: port 2(fwpr101p0) entered forwarding state
[   80.571267] fwbr101i0: port 2(tap101i0) entered blocking state
[   80.571268] fwbr101i0: port 2(tap101i0) entered disabled state
[   80.571354] fwbr101i0: port 2(tap101i0) entered blocking state
[   80.571355] fwbr101i0: port 2(tap101i0) entered forwarding state
[   85.881188] vfio-pci 0000:03:00.0: enabling device (0002 -> 0003)
[   85.881526] vfio-pci 0000:03:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[   85.881537] vfio-pci 0000:03:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[   85.903882] vfio-pci 0000:03:00.1: enabling device (0000 -> 0002)
[   85.905633] vfio-pci 0000:23:00.0: enabling device (0002 -> 0003)
[   85.905926] vfio-pci 0000:23:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[   85.905938] vfio-pci 0000:23:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[   85.927875] vfio-pci 0000:23:00.1: enabling device (0000 -> 0002)
[  102.767254] usb 3-2: reset full-speed USB device number 3 using xhci_hcd
[  103.199666] usb 3-1: reset low-speed USB device number 2 using xhci_hcd
find /sys/kernel/iommu_groups/ -type l
/sys/kernel/iommu_groups/55/devices/0000:48:00.0
/sys/kernel/iommu_groups/55/devices/0000:48:00.3
/sys/kernel/iommu_groups/55/devices/0000:48:00.1
/sys/kernel/iommu_groups/55/devices/0000:42:08.0
/sys/kernel/iommu_groups/17/devices/0000:05:00.0
/sys/kernel/iommu_groups/45/devices/0000:40:07.0
/sys/kernel/iommu_groups/73/devices/0000:60:08.0
/sys/kernel/iommu_groups/35/devices/0000:25:00.1
/sys/kernel/iommu_groups/7/devices/0000:00:07.1
/sys/kernel/iommu_groups/63/devices/0000:4b:00.0
/sys/kernel/iommu_groups/25/devices/0000:20:07.0
/sys/kernel/iommu_groups/53/devices/0000:42:04.0
/sys/kernel/iommu_groups/15/devices/0000:03:00.1
/sys/kernel/iommu_groups/43/devices/0000:40:04.0
/sys/kernel/iommu_groups/71/devices/0000:60:07.0
/sys/kernel/iommu_groups/33/devices/0000:24:00.0
/sys/kernel/iommu_groups/5/devices/0000:00:05.0
/sys/kernel/iommu_groups/61/devices/0000:46:00.0
/sys/kernel/iommu_groups/23/devices/0000:20:04.0
/sys/kernel/iommu_groups/51/devices/0000:42:02.0
/sys/kernel/iommu_groups/13/devices/0000:02:00.0
/sys/kernel/iommu_groups/41/devices/0000:40:02.0
/sys/kernel/iommu_groups/31/devices/0000:23:00.0
/sys/kernel/iommu_groups/3/devices/0000:00:03.0
/sys/kernel/iommu_groups/21/devices/0000:20:03.0
/sys/kernel/iommu_groups/11/devices/0000:00:18.3
/sys/kernel/iommu_groups/11/devices/0000:00:18.1
/sys/kernel/iommu_groups/11/devices/0000:00:18.6
/sys/kernel/iommu_groups/11/devices/0000:00:18.4
/sys/kernel/iommu_groups/11/devices/0000:00:18.2
/sys/kernel/iommu_groups/11/devices/0000:00:18.0
/sys/kernel/iommu_groups/11/devices/0000:00:18.7
/sys/kernel/iommu_groups/11/devices/0000:00:18.5
/sys/kernel/iommu_groups/68/devices/0000:60:03.0
/sys/kernel/iommu_groups/1/devices/0000:00:01.1
/sys/kernel/iommu_groups/58/devices/0000:43:00.0
/sys/kernel/iommu_groups/48/devices/0000:40:08.1
/sys/kernel/iommu_groups/76/devices/0000:62:00.0
/sys/kernel/iommu_groups/38/devices/0000:40:01.0
/sys/kernel/iommu_groups/66/devices/0000:60:01.0
/sys/kernel/iommu_groups/28/devices/0000:20:08.1
/sys/kernel/iommu_groups/56/devices/0000:49:00.0
/sys/kernel/iommu_groups/56/devices/0000:42:09.0
/sys/kernel/iommu_groups/18/devices/0000:05:00.3
/sys/kernel/iommu_groups/46/devices/0000:40:07.1
/sys/kernel/iommu_groups/74/devices/0000:60:08.1
/sys/kernel/iommu_groups/36/devices/0000:25:00.3
/sys/kernel/iommu_groups/8/devices/0000:00:08.0
/sys/kernel/iommu_groups/64/devices/0000:4c:00.0
/sys/kernel/iommu_groups/26/devices/0000:20:07.1
/sys/kernel/iommu_groups/54/devices/0000:42:05.0
/sys/kernel/iommu_groups/16/devices/0000:04:00.0
/sys/kernel/iommu_groups/44/devices/0000:40:05.0
/sys/kernel/iommu_groups/72/devices/0000:60:07.1
/sys/kernel/iommu_groups/34/devices/0000:25:00.0
/sys/kernel/iommu_groups/6/devices/0000:00:07.0
/sys/kernel/iommu_groups/62/devices/0000:47:00.0
/sys/kernel/iommu_groups/24/devices/0000:20:05.0
/sys/kernel/iommu_groups/52/devices/0000:42:03.0
/sys/kernel/iommu_groups/14/devices/0000:03:00.0
/sys/kernel/iommu_groups/42/devices/0000:40:03.0
/sys/kernel/iommu_groups/70/devices/0000:60:05.0
/sys/kernel/iommu_groups/32/devices/0000:23:00.1
/sys/kernel/iommu_groups/4/devices/0000:00:04.0
/sys/kernel/iommu_groups/60/devices/0000:45:00.0
/sys/kernel/iommu_groups/22/devices/0000:20:03.1
/sys/kernel/iommu_groups/50/devices/0000:42:01.0
/sys/kernel/iommu_groups/12/devices/0000:01:00.0
/sys/kernel/iommu_groups/40/devices/0000:40:01.3
/sys/kernel/iommu_groups/69/devices/0000:60:04.0
/sys/kernel/iommu_groups/30/devices/0000:22:00.0
/sys/kernel/iommu_groups/2/devices/0000:00:02.0
/sys/kernel/iommu_groups/59/devices/0000:44:00.0
/sys/kernel/iommu_groups/20/devices/0000:20:02.0
/sys/kernel/iommu_groups/49/devices/0000:41:00.0
/sys/kernel/iommu_groups/10/devices/0000:00:14.3
/sys/kernel/iommu_groups/10/devices/0000:00:14.0
/sys/kernel/iommu_groups/39/devices/0000:40:01.1
/sys/kernel/iommu_groups/67/devices/0000:60:02.0
/sys/kernel/iommu_groups/29/devices/0000:21:00.0
/sys/kernel/iommu_groups/0/devices/0000:00:01.0
/sys/kernel/iommu_groups/57/devices/0000:4a:00.0
/sys/kernel/iommu_groups/57/devices/0000:42:0a.0
/sys/kernel/iommu_groups/19/devices/0000:20:01.0
/sys/kernel/iommu_groups/47/devices/0000:40:08.0
/sys/kernel/iommu_groups/75/devices/0000:61:00.0
/sys/kernel/iommu_groups/37/devices/0000:25:00.4
/sys/kernel/iommu_groups/9/devices/0000:00:08.1
/sys/kernel/iommu_groups/65/devices/0000:4d:00.0
/sys/kernel/iommu_groups/27/devices/0000:20:08.0
Anything else you need to know let me know!
Proxmox Screens: Hardware & OptionsHARDWARE Proxmox .jpg
Edited by Driftwood
added 2nd nvme, changed sata 2 to 0 (Mac boot), and added sata 1 - the other nvme, changed boot order in Proxmox bios
Oh and my 'lspci -nnk'
root@pve:~# lspci -nnk
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
        Subsystem: ASRock Incorporation Starship/Matisse Root Complex [1849:1480]
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
        Kernel driver in use: pcieport
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
        Subsystem: ASRock Incorporation FCH SMBus Controller [1849:ffff]
        Kernel driver in use: piix4_smbus
        Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
        Subsystem: ASRock Incorporation FCH LPC Bridge [1849:ffff]
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0 [1022:1490]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1 [1022:1491]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2 [1022:1492]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3 [1022:1493]
        Kernel driver in use: k10temp
        Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4 [1022:1494]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5 [1022:1495]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6 [1022:1496]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7 [1022:1497]
01:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a0] (rev c1)
02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a1]
03:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:66af] (rev c1)
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:081e]
        Kernel driver in use: vfio-pci
        Kernel modules: amdgpu
03:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
        Kernel modules: snd_hda_intel
04:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
05:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller [1022:148c]
        Subsystem: ASRock Incorporation Starship USB 3.0 Host Controller [1849:ffff]
        Kernel driver in use: xhci_hcd
20:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
20:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
20:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
20:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
20:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
20:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
21:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a0] (rev c1)
22:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:14a1]
23:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:66af] (rev c1)
23:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
24:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
25:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
25:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
        Kernel driver in use: ccp
        Kernel modules: ccp
25:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller [1022:148c]
25:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:d102]
40:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
40:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
40:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
40:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
40:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
40:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
40:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
41:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57ad]
42:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
42:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
42:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
42:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
42:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
42:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
42:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
42:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
43:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation Device [1987:5016] (rev 01)
        Subsystem: Phison Electronics Corporation Device [1987:5016]
        Kernel driver in use: nvme
44:00.0 USB controller [0c03]: ASMedia Technology Inc. Device [1b21:3242]
        Subsystem: ASMedia Technology Inc. Device [1b21:3242]
45:00.0 Ethernet controller [0200]: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] [1d6a:07b1] (rev 02)
        Subsystem: ASRock Incorporation AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] [1849:d107]
        Kernel driver in use: atlantic
        Kernel modules: atlantic
46:00.0 Network controller [0280]: Intel Corporation Device [8086:2723] (rev 1a)
        Subsystem: Intel Corporation Device [8086:0084]
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
47:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Device [10ec:8125] (rev 01)
        Subsystem: ASRock Incorporation Device [1849:8125]
        Kernel driver in use: r8169
        Kernel modules: r8169
48:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
48:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:1486]
48:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
        Subsystem: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:148c]
49:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
        Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901]
        Kernel driver in use: ahci
        Kernel modules: ahci
4a:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
4b:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation Device [1987:5016] (rev 01)
4c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
4d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
60:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
60:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
60:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
60:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
60:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
61:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
62:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
root@pve:~#
@Driftwoodin my experience you can pass all of these listed above
using previous FLR posted Kernel patch
It is also possible to have some problem if you use sata or nvme disk (for proxmox installation)..I use ASMedia usb 3.2 type controller for Proxmox so  I do not share with proxmox my sata or nvme controller when VM starts, and I pass entire sata/nvme controllers to boot in "vanilla" OSX/Windows VM
I would like also to suggest to comment amdgpu,radeon and nouveau lines in blacklist.conf to have a more friendly AMD system (you can run command from this instead to use another pc/device to modify things)
if you try..be prepared to solve possible problems 🙂
  1. I understand that you have installed Proxmox on the USB stick?
    1. It's ASMedia usb 3.2 expansion card yes? And what USB stick you use with this? Can you provide also model number for expansion card?
    2. This solution is better than creating a virtual file on nvme disk, which will be used for both Proxmox and macOS?
    3. Will this solution affect macOS performance?
What kind of problems can these be?
I am sorry for such a large number of questions, but I want to know and understand the topic as best as possible, and I would not like to write too much in this thread.
Currently, I am waiting for the delivery from Amazon, I bought an additional Nvme disk, as soon as it comes, I start my adventure.
Edited by lvtz
Hi @lvtz
USB controller is integrated on my motherboard and in the main guide I show where I connect my "proxmox" disk.
in 1) and 2) question you mix some different subject..
to install Proxmox you have to create an USB Pen (CD/DVD or what you desire) to install it
Then you can choose a disk to install Proxmox (proxmox = linux)
I have chosen an external USB disk..why? in this way I have all others controller (sata, NVME, and so on to pass to my VM)
Best solution is to have your guest OS system in a separate drive from Proxmox disk
ie
if you have now a working OSX on your system you can use it with only a proper EFI to boot with it..
if you instead install OSX on a file, you can have it on your Proxmox disk..in my opinion it is better to use Proxmox disk only for few things and leave all other OSX separated from it
so you need:
1) an USB/CD/DVD for iso installation file
2) boot from this one and from here you have to configure Proxmox (5 minute of your time)
3) in there you choose disk fr proxmox installation (in my case an external disk on back USB)
4) then you can create following the instructions your VM
if you have an existing OSX on a separate disk you can try to "pass" that disk..I did for my NVME High Sierra
Be prepared to solve different problems..but when you succeed in this task you will be happy 😉
@fabiosun :
Thank you for your help, and patience.
So it's an important thing to focus on a good class and fast external USB SSD disk ,or average external SSD USB disk or USB stick will be enough too?
If I understand correctly, dedicated disk for the Proxmox and OpenCore is important until running macOS from Nvme, so only the initial boot of Proxmox can be slower?
I wonder if I should invest in a better disk for Proxmox + OC, or is it enough a medium class 😃
proxmox start very fast..and when you have your system well calibrated you can start in automatic way also your VM
so you click on your power button and you reach your OSX desktop 🙂
for proxmox I have a SSD Samsung 840 Pro in a cheaper external enclosure 🙂
in my test I have had also for proxmox a cheaper laptop 2.5 '' mechanical hd...
in my opinion if you do not use 100000000 VM you can use a small disk for proxmox..so you can also backup entirely in a flash..then you can have different disk with different OSX as a real pc/hack/Mac
@lvtz have you a working OSX in this system or it is your first experience?
@fabiosun - For some time I have configured OSX, but in a traditional way (using OpenCore and many patches and kexts). I am quite happy, but I am irritated by some random situations or the fact that everything is not necessarily working properly - after all, AMD is not an officially supported processor. That is why I became interested in this method for preparing OSX.
I haven't tried Proxmox yet, I'm still researching and tracking your threads and posts (I study theory, time for practice soon!). I ordered SB-ROCKET-NVMe4-1TB yesterday because I have one more free space on the motherboard - now I'm waiting until Monday for delivery. So far I have Win10 (on PX-512M9PeG), and macOS Catalina + EFI via OpenCore (on second PX-512M9PeG).
I am wondering whether or not to make the PX-512M9PeG format which is now macOS and then install Proxmox + OC there. But on the other hand this disk is 512 GB and if Proxmox is installed on it, it will be largely unused. I don't know what to do now 😅 I have a dilemma about whether to use a USB external disk or maybe the current Nvme 512 GB.
If you have windows installed you can use it
in my case I use grub bootloader (proxmox) to boot and decide what I want use
you have to find a solution for you
better for you I mean 👍
Finally, I decided to buy an additional 120 GB SATA SSD (CT120BX500SSD1) to install Proxmox + OC on it. (OMG! How many disks will I have in my build... Nvme (3), HDD (2), SSD (1) 😂)
At this moment, I think I know everything (in theory). I will probably write again here when I start the configuration... Well, unless everything goes smoothly without any issues 😄 Anyway, I will let you know.
Thanks again for your help. Have a nice weekend!
  • Cross Finger 1
I would like to share something that could be useful for Full PCi tab lovers in about my Mac / System Report /PCI
from Proxmox shell (this naming for path is for latest 6.2 proxmox VE installation:
nano /usr/share/qemu-server/pve-q35-4.0.cfg
you will see:
  GNU nano 3.2                              /usr/share/qemu-server/pve-q35-4.0.cfg
#[device "ehci"]
#  driver = "ich9-usb-ehci1"
#  multifunction = "on"
#  bus = "pcie.0"
#  addr = "1d.7"
#[device "uhci-1"]
#  driver = "ich9-usb-uhci1"
#  bus = "pcie.0"
#  addr = "1d.0"
#  masterbus = "ehci.0"
#  firstport = "0"
#[device "uhci-2"]
#  driver = "ich9-usb-uhci2"
#  bus = "pcie.0"
#  addr = "1d.1"
#  firstport = "2"
#[device "uhci-3"]
#  driver = "ich9-usb-uhci3"
#  bus = "pcie.0"
#  addr = "1d.2"
#  firstport = "4"
#[device "ehci-2"]
#  driver = "ich9-usb-ehci2"
#  bus = "pcie.0"
#  addr = "1a.7"
#[device "uhci-4"]
#  driver = "ich9-usb-uhci4"
#  bus = "pcie.0"
#  addr = "1a.0"
#  masterbus = "ehci-2.0"
#  firstport = "0"
#[device "uhci-5"]
#  driver = "ich9-usb-uhci5"
#  bus = "pcie.0"
#  addr = "1a.1"
#  firstport = "2"
#[device "uhci-6"]
#  driver = "ich9-usb-uhci6"
#  bus = "pcie.0"
#  addr = "1a.2"
#  firstport = "4"
# FIXME: Remove this audio0 device at the next possible time
#     see: https://pve.proxmox.com/pipermail/pve-devel/2019-July/038417.html
#          https://pve.proxmox.com/pipermail/pve-devel/2019-July/038428.html
#[device "audio0"]
# driver = "ich9-intel-hda"
# bus = "pcie.0"
# addr = "1b.0"
[device "ich9-pcie-port-1"]
  driver = "pcie-root-port"
  x-speed = "16"
  x-width = "32"
  bus = "pcie.0"
  addr = "1c.0"
  port = "1"
  chassis = "1"
[device "ich9-pcie-port-2"]
  x-speed = "16"
  x-width = "32"
  bus = "pcie.0"
  addr = "1c.1"
  port = "2"
  chassis = "2"
[device "ich9-pcie-port-3"]
  x-speed = "16"
  x-width = "32"
  bus = "pcie.0"
  addr = "1c.2"
  port = "3"
  chassis = "3"
[device "ich9-pcie-port-4"]
  x-speed = "16"
  x-width = "32"
  bus = "pcie.0"
  addr = "1c.3"
  port = "4"
  chassis = "4"
# Example PCIe switch with two downstream ports
#[device "pcie-switch-upstream-port-1"]
#  driver = "x3130-upstream"
#  bus = "ich9-pcie-port-4"
#  addr = "00.0"
#[device "pcie-switch-downstream-port-1-1"]
#  driver = "xio3130-downstream"
#  bus = "pcie-switch-upstream-port-1"
#  addr = "00.0"
#  port = "1"
#  chassis = "5"
#[device "pcie-switch-downstream-port-1-2"]
#  addr = "00.1"
#  port = "1"
#  chassis = "6"
[device "pcidmi"]
  driver = "i82801b11-bridge"
  bus = "pcie.0"
  addr = "1e.0"
[device "pci.0"]
  driver = "pci-bridge"
  bus = "pcidmi"
  addr = "1.0"
  chassis_nr = "1"
[device "pci.1"]
  bus = "pcidmi"
  addr = "2.0"
  chassis_nr = "2"
[device "pci.2"]
  bus = "pcidmi"
  addr = "3.0"
  chassis_nr = "3"
[device "pci.3"]
  bus = "pcidmi"
  addr = "4.0"
  chassis_nr = "4"
In there I commented many lines (old USB related) , this to have a better and clean situation in PCI device output in app like dpcimanager or Hackintool
My tries it is always related to acquire a perfect functionality on internal audio I miss 😉
with this emu vm config I achieve this:
so a bunch of EHCI and UHCI device are not loaded anymore in my system..and functionality of it seems to be the same.
From picture above you can see some stuff also passed from the pve-q35-4.0.cfg file, I mean QEMU PCI-Pci bridge.. I am trying if is possible to avoid also some of this loading.You see also other stuff (first 6 lines) it seems not present in this file..
Main task/goal could be to inject here some devices we have in our rig? We will see
Previous situation without commenting those lines:
1171634402_ScreenShot2020-04-14at1_39_41PM.png.ee14281b11c85901674246cb786d44fb.png.e712cb5a76b290ed6797cb908b891ba0.png
here less controllers passed..it is a VM I use to test so I pass few devices!
DO NOT DO IT IF YOU PASS USB MOUSE OR KEYBOARD OR OTHER DEVICE AS A SINGLE USB IN WEB INTERFACE
  • +1 3
On 5/4/2020 at 2:52 AM, Driftwood said:
Anyone tried a Radeon VII?
Yes, works. I have Asrock TRX40 Creator and Radeon VII. Need to work around the GPU reset bug though. (If you stop the VM and start again the Radeon VII will not initialise, need to reboot the host)
I found a working trick with a start hookscript: (this will briefly stand-by the host before starting the VM and it works to reset the GPU)
root@ryzen:/var/lib/vz/snippets# more reset-gpu.pl
#!/usr/bin/perl
# Hook script for PVE guests to reset AMD GPU before VM start
# qm set 100 -hookscript local:snippets/reset-gpu.pl
use strict;
use warnings;
print “HOOK: ” . join(‘ ‘, @ARGV). “\n”;
# First argument is the vmid
my $vmid = shift;
# Second argument is the phase
my $phase = shift;
if ($phase eq ‘pre-start’) {
print “HOOK: $vmid is stopped.\n”;
system(“rtcwake -m mem -s 3”);
} else {
print “HOOK: got unknown phase ‘$phase’\n”;
exit(0);
So you have two Radeon VII in your rig? I guess one in slot 1 and one in slot 3.
Do you have the GPU reset issue if you stop the VM and start it again that the GPU doesn't init anymore until you reboot the host?
#!/usr/bin/perl
use strict;
use warnings;
my $vmid = shift;
my $phase = shift;
} else {
exit(0);
I can only 'restart' fine from macos, but 'shutdown' will cause the aforementioned bug. Where do you run that from shell console
Edited by Driftwood
answer properly
@fabiosun I also could now passthrough the "USB" Audio Device, due to the updated kernel patch that we were looking for before. I'm still having trouble with the actual sound, it's loud screeches / scratches / noise, nothing you'd like to listen to. Did I miss something, or are you at the same point still?
@AllubzVif you read I said before
only problem I have
i think is an OS X driver problem because with same proxmox setting in a window vm it is perfect
patch is useful to pass controller but it is also possible to pass without
i have asked @pavo to insert 148c address for us (trx40 user) but as I said not useful to solve
@iGPU has a working usb Dac audio, but in my case I have no others usb to test..only cheaper ones
and these have the same problem
Yes, I'm using the Audient EVO4 (USB DAC) without any problem.
I am giving up, for now, on TB. Based on what I've tried and the response from the Proxmox forum, it is not possible (at this time, as they said) to pass-through a TB device.
On a related issue, has anyone passed-through a BT/Wifi card (like the Fenvi) that's commonly used on Hackintosh builds? When I try, it seems to pass, but is not active on the Mac side (I've included what I believe are its associated USB devices). I know it's a good card as I pulled it from a working build. I can pass and use the on-board BT with special kext files; but the Wifi portion of the AX200, does not yet work, so not ideal for full Mac functionality. I realize that a BT card swap is possible, but BT with the AX200 is more powerful. On other Hackintoshes, I use the native BT from the mobo and supplement with Wifi from the Fenzi card for a nice combination.
One significant problem that's cropped up for me it a prolonged boot, but only when using a pass-through GPU. I've not been able to sort it out for over one week now. (I initially did not see this, but now occurs no matter the GPU.) The Apple progress bar hangs about 2/3 of the way (after the screen flashes off then back on) and sits there for about 90 sec, then it progresses to login. However, about half the time after login, I have no USB connection. I tried with and without the recent trimming of devices discussed here, but of no help. (I do like having the devices trimmed.) The late boot problem seems like a GPU related matter, but using WEG or not using WEG has no effect, nor does injecting or not injecting DeviceProperties.
Mmmmh maybe you have to revert to a not patched kernel?
my booting time is very fast and all usb controller are on without problem
I have opened a thread on proxmox forum for audio problem
but it is hard to explain and I do not think is a proxmox problem because with same distro config a Windows vm is working perfectly
usb part of your thunderbolt is working?
I'm not using patched kernel; I tried PAVO's but was getting a green screen. I  am using Proxmox 6.2. I will re-check verbose mode. Thanks.
TB USB did pass, but was not functional. Even when passing NHI portion, TB drivers started to be loaded on the macOS side, but again, not functional.
After adding -v to OpenCore boot arg, the verbose portion went fast, then the Apple logo appeared and started the progress bar. The progression stopped at about 25%, with no more words appearing, then suddenly went to login screen after 60 sec or so. So this didn't help to figure out the prolonged boot problem.
Then after running for 10 to 15 min, it locks up. I'll try turning off WEG as lock-ups after 15 min is commonly seen on Intel platforms when running WEG and Radeon VII GPUs.
After testing above, I  was suspicious of AppleALC. Leaving WEG and AppleALC disabled, the progress bar no longer paused, but still took a long time to boot. Maybe an issue of newer AppleALC kext breaking something as I had updated various kexts (I'd made so many changes, it is difficult to isolate one). Newest version used  was v1.4.9.
This was the problem: AppleALC. Using an older version from Oct, 2019 fixed the problem (v1.4.3): boot went rapidly. I don't know when in the updates the problem started. I may test tomorrow different ones, but I'm avoiding v1.4.9 and suspicious of v1.4.8 until tested.
update: 5/19/20:
Re-tested to the above issue with different versions of AppleALC and now the older versions are giving the same delay. I now don't know what is going on. It is curious that sometimes changing WEG, AppleALC or DeviceProperties which inject Radeon VII SoftPowerTable data affect this prolong boot. It must be related to the GPU. Further investigation needed on my part.
update: 5/21/20:
the problem was erratic because the main macOS was corrupted. See this post for clarification.
Edited by iGPU
added verbose & AppleALC info
