Moderators netgear Posted April 13, 2020 Moderators Share Posted April 13, 2020 Che bellezza R-Drive Image 6.3.6300 Spoiler New Features: + Support for the APFS file system has been added including the APFS Fusion Drive. + Automatic update of the device list for disk imaging/copying operations has been added. + Automatic update of the device list for boot / OEM media creation operations has been added. + When R-Drive Image runs out of available free space while creating an image, a new place can be specified, and the image will be split accordingly. + Task progress for running tasks is shown in the scheduled task list. + A tooltip shows detailed information on selected task in the scheduled task list. Improvements: * The Locked disk dialog box shows the list of processes and files that lock the disk. * Linux kernel 5.4.11 is used in the startup version. Bugfixes: - R-Drive Image may have crashed when the last part of a multi-file image was selected and the Restore files or folders option was specified on the Restore Mode Selection panel. Fixed. - Only the Mark All and Unmark All command were active on the right pane of the Select Files panel when folders and files were to be restored. The Mark and Unmark command were not active. Fixed. - Strange object of 0B may have appeared on the target disk diagram when the raw method was used to restore the entire disk. Those objects disappeared after the Refresh command. Fixed. - It may have been impossible to restore data from an image of a smaller disk to a larger disk. The Target partition/volume size is too big error message would appear. Fixed. - The password may have been lost when the task was edited. Fixed. - The -s=I: script command didn't make the partition active, although the script returned the successful result. Fixed. - The entire disk could not be restored using the Realign partitions method. R-Drive Image returned the Specified volume size is too small error message when clicking the Next button on the Processing (Confirm operations) panel. Fixed. - The minimum required partition size may have been calculated incorrectly. The Specified volume size is too small error message would appear if the new partition size was too close the the minimum possible. Fixed. - If the paths to some image parts of a multi-part image were not specified, R-Drive Image showed that the user ignored some write errors, but the final message would be that Image restored successfully. Fixed. - Files and folders may have been impossible to restore. When the files and folders were selected on the Select Files to Restore panel the Unable to prepare the operation error message was appeared upon clicking the Next button. Fixed. - Only zeros were shown for the minimum and maximum partition sizes on the Restore / Copy Parameters panel. Fixed. - When the Cancel button was clicked R-Drive Image continued performing its current operation until the Yes button was clicked on the Are you sure you want to stop current operation? dialog box. Fixed. - R-Drive Image didn't immediately show many disk alterations performed outside the running program. They appeared only after clicking the Refresh button or program restart. Fixed. - An encrypted bitlocker partition could not be successfully copied or restored. It couldn't open it from File Explorer, although R-Drive Image showed it as a successfully restored bitlocker partition. Fixed. - Many internal and cosmetic bugs have been fixed. Dopo la Testo 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 13, 2020 Supervisor Share Posted April 13, 2020 chissà se supporta I drive con 4096 Bytes invece di 512... Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 13, 2020 Author Moderators Share Posted April 13, 2020 Come Drive, i settori dici... - APFS ora è supportato, sono curioso di provarlo, magari preferisco il raw 😄. - Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 13, 2020 Author Moderators Share Posted April 13, 2020 APFS per ora non funziona come mi aspettavo, forse c'è un bug, funziona copia su XXX, ma nn fa l'immagine... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 13, 2020 Supervisor Share Posted April 13, 2020 Si i settori la versione precedente non andava Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 13, 2020 Author Moderators Share Posted April 13, 2020 Ma che problema hai avuto, qual'è il contesto... Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 14, 2020 Author Moderators Share Posted April 14, 2020 Ho scritto alla casa del Programma, vediamo se mi spiegano il discorso APFS. Cmq lo sfrutto in un altro modo, installo in VM, carico il vmdk con OFSMount e copio Disco o Partizione, non RAW quindi ma scrivendo soli i DATI veri. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 14, 2020 Supervisor Share Posted April 14, 2020 On 4/13/2020 at 3:09 PM, netgear said: Ma che problema hai avuto, qual'è il contesto... che ho una immagine di tutto questo che ho fatto per la VM da circa 400 Gb se provo a metterla sul disco con i settori a 4096 mi dice disco nn compatibile.. se lo converto a 512 posso farlo Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 14, 2020 Author Moderators Share Posted April 14, 2020 Un Disco Enterprice senza emulazione a 512... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 14, 2020 Supervisor Share Posted April 14, 2020 e' il sabrent nvme. non ho provato con altri Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 14, 2020 Author Moderators Share Posted April 14, 2020 Perchè l'allineamento Advance Format è automatico, dicono solo questo in merito: R-Drive Image will copy the partitions on the disk with a 512KB alignment. This is very usefulfor SSD and advanced-formatted disks. If there are empty (non-used) spaces between partitions, those spaces will be removed taking into account the alignment. Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 14, 2020 Author Moderators Share Posted April 14, 2020 Speriamo :) Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 22, 2020 Author Moderators Share Posted April 22, 2020 Dopo vari scambi di info hanno Sistemato, questi ragazzi sono davvero in gamba :) Versione 6302 - L'ho testata Backup e Ripristini vari APFS. - - - - Bugfixes: - When the startup version created huge (>10 GB) images over the network (cifs) image data may have been corrupted. Fixed. Improvements: - R-Drive Image shows now several APFS volumes in an APFS container proportionally to their size. Bugfixes: - R-Drive Image may have created APFS volume images incorrectly. Fixed. - R-Drive Image may have restored APFS volume images incorrectly. Fixed. - R-Drive Image working under Windows may have created APFS useful-data-only images as sector-by-sector images. Fixed. Il Tester da hack ha permesso di sviscerare prima e meglio le varie problematiche, visto l'uso più castrato dell'originale :) 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted April 22, 2020 Author Moderators Share Posted April 22, 2020 Adesso le Immagini del Sistema Installato, HFS+ e APFS, incluso Utente, si equivalgono: - Link to comment Share on other sites More sharing options...
Moderators netgear Posted May 24, 2020 Author Moderators Share Posted May 24, 2020 Uscita la Versione R-Drive Image 6.3.6303 :) 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted May 28, 2020 Author Moderators Share Posted May 28, 2020 Ho fatto delle richieste a R-Drive migliorative, ora mi mandano a quel Paese 😄... Però prima gli ho fatto mille complimenti 😁 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted June 10, 2020 Author Moderators Share Posted June 10, 2020 Ho segnalato ripetutamente un problema dal Disco di Boot, ora che se ne sono accorti anche altri spero che risolvano in fretta con la 6304. In sostanza dal disco di boot APFS non lo gestisce, non è una cosa grave ma per chi usa startup disk... Probabilmente all rTT sto già passando come rompi p@lle 😄... 1 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted June 10, 2020 Author Moderators Share Posted June 10, 2020 La nuova Sergei che contiene l'ultima versione 6303: - https://sergeistrelec.ru/winpe-10-8-sergei-strelec-english/190-winpe-10-8-sergei-strelec-x86-x64-native-x86-20200609-english-version.html Da questa WinPE in vece nessun problema... 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted June 10, 2020 Author Moderators Share Posted June 10, 2020 Confermo: - Link to comment Share on other sites More sharing options...
Extreme™ Posted June 24, 2020 Share Posted June 24, 2020 Siamo alla v6305...👍 Link to comment Share on other sites More sharing options...
Moderators netgear Posted July 11, 2020 Author Moderators Share Posted July 11, 2020 Si stanno sviluppando bene, versatilità TOTALE con il Trittico VMDK+OFSMount+R-DRIVE IMAGE: - Link to comment Share on other sites More sharing options...
Moderators netgear Posted July 11, 2020 Author Moderators Share Posted July 11, 2020 Ieri mi ha chiamato un Rivenditore, al quale tre anni or sono gli avevo detto che Acronis non funzionava bene, anzi era un vero disastro. Lui giustamente all'epoca mi aveva detto (l'avrei detto anche io) che probabilmente era un mio problema e che non è possibile che una casa di tale portata faccia un prodotto con tali lacune, giustamente comprensibile, Acronis vs uno qualunque a chi dare ascolto :)... Ma, molti, per non dire tutti, fanno un backup del Sistema installato per poi non usarlo, con buona probabilità mai, ed ecco che il prodotto va bene 🙂 Nel mio caso invece nessun Sistema viene usato direttamente ma solo dopo ripristino, in sostanza tutto quello che uso è SOLO Ripristinato, in media 10 Ripristini al giorno. Il Tizio per una preparazione in serie ha dovuto lavorare di Ripristini e dopo qualche giorno, iniziati i problemi, mi ha chiamato interessato sul chiarimento della cosa... La conclusione è che questo programma, venduto in tutto il mondo, da anni, molti anni, non sempre, quasi mai, fa quello che deve fare. Può sembrare impossibile, io stesso dopo 5 anni continuo a meravigliarmi, ma è così... Nel mezzo ci sono tutta una serie di variabili, il Sistema Backuppato, il tipo di Disco, il tipo di Problema, la posizione di Boot ecc. La cosa che mi stupisce ancora di più è perché non funziona quando tutti i suoi concorrenti funzionano, non è poi una cosa complessa quella che deve fare, sono arrivato alla conclusione che in questo programma ci sia un ingrediente nascosto che non lo fa andare... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 19, 2020 Author Moderators Share Posted October 19, 2020 Uscita la versione 6307, non c'è scritto nulla in descrizione, per ora, forse non lo sanno nemmeno loro :)... 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 20, 2020 Author Moderators Share Posted October 20, 2020 Ecco cosa non va nella nuova versione 😄 The startup version is now based on Linux kernel 5.8.10 with new xorg video drivers. - R-Drive Image 6.3.6307 Mon Oct 19, 2020 New features: + A new backup set parameter Full image every... for incremental/differential images has been added to the Task's Imaging Mode panel. For example, if this parameter is set to 6 for the differential mode, every 6-th image will be a full image, all other 5 images being differential. Bugfixes: - It was impossible to create a "useful data only" image for APFS Fusion drives. Fixed. - It was impossible to unlock a locked BitLocker image connected as a virtual logical disk. Fixed. - The error "Media is removed" may have appeared on Windows 10 when an image of NTFS partition was restored to a FAT32 GPT partition. Fixed. - R-Drive Image may have crashed when several images were successively restored on the same place without program restart.Fixed. - R-Drive Image didn't warn the user that administrative privileges were required to successfully execute a script. Fixed. - An incorrect image may have sometimes been created when a script was executed. Fixed. - Some backup set parameters may have worked incorrectly. Fixed. - The disk letter may have disappeared for a logical disk when an incomplete multi-file image was attempted to restore to this disk. Fixed. - Some cosmetic bugs have been fixed. Startup version Improvements: * The startup version is now based on Linux kernel 5.8.10 with new xorg video drivers. * DPMS screen blanking/sleep has been disabled to prevent undesirable screen shutoffs. * Autosuspend for USB devices has been disabled to prevent interruption of disk image creation on USB disks. Bugfixes: - File systems on read-only flash memory drives could not be mounted. Fixed. - Sometimes individual files could not be restored. Fixed. - An OEM startup disk may have sometimes failed to load the computer into the R-Drive Image startup version. Fixed. 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 20, 2020 Supervisor Share Posted October 20, 2020 un po' off topic, ma a me ad esempio il kernel 5.8 crea in Proxmox molti problemi di instabilità Ho rimesso il precedente 1 Link to comment Share on other sites More sharing options...
